Logan MCV 2009 motor horse power ?
mostafabakry |
17 Jan 2009, 20:24
Membru incepator Group: Members Posts: 14 Joined: 16 January 09 |
renault
rddg
Peja |
18 Jan 2009, 01:04
Membru incepator Group: Members Posts: 81 Joined: 26 January 08 From: SERBIA |
1.6MPI 16V 110hp
Logan 1.4MPI Preference + AC
Apr 2008 http://loganimprovements.blogspot.com
Barrie |
18 Jan 2009, 06:17
Membru incepator Group: Members Posts: 42 Joined: 15 April 08 |
Hi There, I have the 80hp diesel MCV. This performs very well indeed,this drives and responds well loaded or towing a one ton caravan, so whichever you choose, you'll be delighted. Go for it. Regards, Barrie. |
Logan MCV Diesel
- Not known yet
mostafabakry |
18 Jan 2009, 11:32
QUOTE(Barrie @ 18 Jan 2009, 06:17) Hi There, I have the 80hp diesel MCV. This performs very well indeed,this drives and responds well loaded or towing a one ton caravan, so whichever you choose, you'll be delighted. Go for it. Regards, Barrie. but i think that the diesel engines are different from the gasolin ones because the moment of the diesel one is more stroger than the gasoline engine although the power is lower than the gasoline I think it is some relations between the speed & moment which affect the engine's performance 18 Jan 2009, 11:34: QUOTE(Peja @ 18 Jan 2009, 01:04) yes but when I visit the web site of renault - dacia logan I read that it is 105 HP not 110 HP could you please put a link for this data thanks for your interest This post has been edited by mostafabakry: 18 Jan 2009, 11:34 |
renault
rddg
Peja |
18 Jan 2009, 12:08
I've made mistake. Maximum is 77kW (105hp) from 1.6 16V.
Suppose you will use it for taxi or somthing. 6 persons + AC is huge load. so recomand this type of motor. Also, 1.6 16V motors are made from Renault, others are under big ? Peja This post has been edited by Peja: 18 Jan 2009, 12:09 |
hobit |
27 Jan 2009, 10:34
Membru incepator Group: Members Posts: 7 Joined: 31 October 08 |
Hi,
I'm owner of MCV with 1.6 8V engine - 64 kW (88 HP). My experience is, that this engine is rather weak for this type of car. We use is especially for family trips with five persons on board and full luggage space and the acceleration is very poor and there is no reserve for overtaking. If the price difference between these two options - 1.6 8V and 1.6 16V is not to high for you, I strongly recommend to buy the 16V version. It is newer construction and despite higher power it also should have considerably lower fuel consumption. Hobit. |
Logan MCV
1.6 MPi
mostafabakry |
8 Mar 2009, 21:55
QUOTE(Peja @ 18 Jan 2009, 12:08) I've made mistake. Maximum is 77kW (105hp) from 1.6 16V. Suppose you will use it for taxi or somthing. 6 persons + AC is huge load. so recomand this type of motor. Also, 1.6 16V motors are made from Renault, others are under big ? Peja Yeh, you are right Finally I get the car with the new engine 16 V , 105 HP I'm very satisfied with my choice thanks for your reply Peja QUOTE(hobit @ 27 Jan 2009, 10:34) Hi, I'm owner of MCV with 1.6 8V engine - 64 kW (88 HP). My experience is, that this engine is rather weak for this type of car. We use is especially for family trips with five persons on board and full luggage space and the acceleration is very poor and there is no reserve for overtaking. If the price difference between these two options - 1.6 8V and 1.6 16V is not to high for you, I strongly recommend to buy the 16V version. It is newer construction and despite higher power it also should have considerably lower fuel consumption. Hobit. Thanks Hobit for you advise which I keep it on my mind Really I bought the 16 V one and it very good I had a trip with it & it was full loaded about 9 persons !!!! and it was great thanks alot BR |
renault
rddg
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th May 2024 - 23:44 |
