Care e cel mai serios service DACIA din Bucuresti?, reparatie directie
vip3rutz |
3 Jan 2008, 13:38
Membru cu LOGAN Group: Members Posts: 4 Joined: 3 January 08 From: Bucuresti |
Logan 1.6 MPI Ambition full option
- B-87-DDD "The object of war is not to die for your country.. But to make the other bastard die for his"..
Chipu |
3 Jan 2008, 14:26
Membru autentic Group: Members Posts: 262 Joined: 11 April 06 |
De mai bine de un an eu merg numai la Nesty, e la iesire din Berceni.
E cat se poate de ok. Dar foarte departe, si eu traversez tot orasul, dar altul mai bun si mai aproape nu stiu. |
SuperNova
FullOption Mondeo Ghia 1.8 Duratec HE@125 stock
Sudsemnatu |
3 Jan 2008, 14:58
Membru Huligan Group: Members Posts: 1.703 Joined: 28 November 06 From: Bucuresti |
du-te frate oriunde unde are geometrie .ca se rezolva repede.
am un prieten care a patit la fel si s-a rezolvat in 5 minute la un service autorizat dar nu era neaparat nevoie acolo. sau tu vrei sa faci pe casco? aaaa si nu te gandi ca e lonjeronul ...sa iti explice baietii care stiu mecanica dar mai mult ca sigur ca nu e lonjerul afectat .loganul din cate am inteles e facut pe alt sistem |
Skoda Fabia 2005
Ex: Dacia Nova/Logan/Supernova
2000/2007/2002 Midland Alan 52/PNI ML 160
Speed doesn't kill people, its the sudden stop that does |
Kojak |
3 Jan 2008, 15:18
Membru autentic Group: Members Posts: 1.786 Joined: 18 January 07 From: Bucuresti |
adip |
4 Jan 2008, 00:20
Banned Group: Members Posts: 2.177 Joined: 12 July 06 From: Melbourne, Victoria |
QUOTE(Chipu @ 3 Jan 2008, 14:26) De mai bine de un an eu merg numai la Nesty, e la iesire din Berceni. Eu cred ca glumesti |
* What you live with you learn.
What you learn you practice. What you practice you become. What you become has consequences . |
dydycom |
8 Jan 2008, 15:16
daca exista vointa, orice se poate Group: Members Posts: 628 Joined: 24 March 05 From: Bucharest |
pt initiatorul topicului:
Da o fuga pana la o geometrie si ai sa afli ca ai tija amortizorului stramba. Si de acolo iti cumperi ce iti zic oamenii si abia dupa mergi la service sa le inlocuiesti. POate fi si unu de cartier sau chiar cei cu geometria mai fac astfel de reparatii |
laguna
2.0 dci cva
2008 privilege Imi vand Laguna 3, Detalii la bursa!
http://https://www.reno.ro/index.php?act=ST&f=5&t=313709 |
CriSTI68 |
8 Jan 2008, 18:10
Membru Valvos Group: Members Posts: 5.001 Joined: 8 January 07 From: Bucuresti |
FILter |
21 Jan 2008, 14:50
Membru autentic Group: Members Posts: 211 Joined: 27 April 07 From: Bucuresti |
Am mai multi cunoscuti care au fost la Cobalcescu cel de pe valea Oltului si au fost multumiti. Marea problema la ei e pretul, insa ai sanse foarte mari sa-ti faca treaba de calitate. Merita sa le faci o vizita si sa vezi daca nu cumva poti aduce piesele tu, si ei doar sa le monteze.
-X-
2000 toamna
Brainie |
22 Jan 2008, 10:28
Membru autentic Group: Members Posts: 464 Joined: 2 May 07 From: Bucuresti |
Din păcate convingerea mea este că seriozitatea și priceperea oamenilor din service-uri sunt chestii aleatoare, care variază de la maxim la minim după formule necunoscute de nimeni.
Autocobălcescu Valea Oltului: -un coleg a reparat mașina de 2 ori la ei, odată numai tinichigerie, a doua oară tinichigerie și ceva mecanică pe la partea de rulare (după un accident): foarte mulțumit de calitatea lucrărilor, nu și de viteza lucrării și de comunicarea cu recepția și alții de acolo -eu m-am dus pentru că mi se aprindea martorul ABS din bord; de 3 ori au considerat problema rezolvată (tester, probă pe drum), și de 3 ori becul s-a reaprins înainte să ies din curtea lor; plus că dacă nu-i bați la cap te uită (duc mașina dimineața, conform programării, pe la 13:00 sun - deși promiseseră că mă anunță ei - și din tonul recepționerului deduc că nici nu se apucaseră de ea) Adras Militari -m-am dus să-mi monteze RadioCDMP3 și boxe; nu au fost în stare să lege firele la aparat; au tăiat și legat împreună plusul permanent cu plusul de la accesorii; după câteva zile când am venit cu reclamația au modificat ceva, dar tot prost; și nu trebuiau decât să înfigă conectorii, nu trebuia nimic tăiat; manualul aparatului (cu o schemă de legături foarte clară) a fost la ei permanent, dar nu l-a deschis nimeni; nu aveau cabluri și papuci să-mi lege și boxele spate, m-au trimis să mi le cumpăr singur. Concluzia: DOBITOCI cu D foarte mare -cu ocazia montării RadioCD-ului au observat că e martorul ABS aprins; s-au umflat în pene că-l rezolvă ei, și atât au insistat că am acceptat; într-adevăr, am stat vreo 2 ore după ei (max 45 min de lucru efectiv, cu șef de service, cu DACOTEC și încă vreo 2 executanți), dar l-au rezolvat. Concluzia: și-au dat interesul și au rezolvat Și exemplele pot continua, cu plusuri și minusuri. De-asta zic că depinde foarte mult cum iese la zaruri în momentul când ai nevoie. |
Ex Dacia 1310 Li ;
Ex Logan ABS+ 1.6 MPI
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 28th April 2024 - 17:11 |
