LCD display bacground light -, goes down when you turn the lighst on?
zorpetus |
27 Apr 2006, 19:23
Membru Group: Members Posts: 120 Joined: 17 April 06 |
None
None
- None
martin245 |
27 Apr 2006, 19:28
EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) |
[quote=zorpetus,27 Apr 2006, 19:23]
I guess that is normal that background light on the LCD display (orange) is Check the battery terminals are tight !!!!!! On my NEW Logan the terminals were not tight this can cause all sorts of problems It is normal that the light on the board computer dimms Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
zorpetus |
27 Apr 2006, 21:08
[quote=martin245,27 Apr 2006, 19:28]
[quote=zorpetus,27 Apr 2006, 19:23] I guess that is normal that background light on the LCD display (orange) is Check the battery terminals are tight !!!!!! On my NEW Logan the terminals were not tight this can cause all sorts of problems It is normal that the light on the board computer dimms Stu [/quote] Battery terminals checked - everything seems to be tight and OK. Needless to say that all contacts are clean, as car is brand new. As for the LCD display background light dimming - OK, if that is normal - only my impression was that dimming is quite "drastic". |
None
None
- None
27 Apr 2006, 23:00
Is normal, there is no problem
zorpetus |
27 Apr 2006, 23:26
None
None
- None
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 12th May 2024 - 14:15 |
