Driver's door handle, Intermittent failure of driver's inside door handle
pollux83 |
21 Sep 2010, 09:36
Membru incepator Group: Members Posts: 5 Joined: 21 September 10 From: SE France |
2010
21 Sep 2010, 09:38
fan Dacia Group: Members Posts: 19.920 Joined: 12 November 05 From: Bucuresti |
I haven't heard of such a concern.
rotproof |
21 Sep 2010, 19:15
Membru incepator Group: Members Posts: 8 Joined: 16 September 10 |
In Ukraine nobody had ever had such problems.
I think you should go to authorized service. Maybe you've broken internal handle. |
Sandero
2008 Ambiance
CriSTI68 |
21 Sep 2010, 21:21
Membru Valvos Group: Members Posts: 5.001 Joined: 8 January 07 From: Bucuresti |
inside handle is operated by a rod which has escaped, it need to be put back by removing the inside handle (connected with only 1 screw) and there you will see that rod wich you will have to put it back in the handle mechanism (one hole with a rubber gasket), mount back the handle and problem solved, that problem also ocured at my car to, but fixed quik
2008 Prestige 1.6 16V 105 Ponei Putere
- EDH Renault Clio 3 - 2008 1.5 dci
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 6th May 2024 - 08:36 |
