"Corabia" mea...., de la Nissan la Logan
alecsnissanlaurel |
11 Oct 2009, 20:52
#121
Membru incepator Group: Members Posts: 12 Joined: 4 October 09 |
Nissan Laurel
Nissan Laurel
1981
11 Oct 2009, 20:53
#122
@Fan3, transmisia de care vorbesti e facuta sa se 'pupe' cu motorul ala care are cuplul bun la 1200 rpm, nu invers, asadar nu era de ales.
alecsnissanlaurel |
11 Oct 2009, 20:53
#123
voiam sa spun povestea:) scuzati greselile
Nissan Laurel
Nissan Laurel
1981
11 Oct 2009, 20:59
#124
cel mai bun ulei e ala care ti-l recomanda cartea, si ca pret, cel mai scump pe care ti-l permiti.
Fan3 |
11 Oct 2009, 21:05
#125
Membru autentic Group: Members Posts: 619 Joined: 1 January 05 |
poate posteaza cineva...legat de brandurile astea de uleuri care...cui apartin...
eu am aflat de curant ca elf-u e al total-ului.... |
11 Oct 2009, 21:06
#126
Elf-ul de la noi de pe piata se face la Brasov in fosta fabrica Lubrifin. Aral si Castrol apartin BP.
kossak |
11 Oct 2009, 21:36
#127
Membru autentic Group: Members Posts: 745 Joined: 27 May 08 From: Cluj-Napoca |
Eu am schimbat de 3 ori uleiul de cand am masina si de fiecare data am folosit alt brand.
La primul schimb am pus Catrol Magnatec Diesel 10w40 A doua oara am bagat Elf Turbo Diesel 10w40 - inainte sa-l schimb pe asta trebuiau 3-4 secunde sa mi se stinga becul de presiune de ulei de pe bord Ultima oara am bagat Mobil 1 10w40, acuma becul se stinga dupa aproximativ o secunda de la pornire. In rest eu nu am observat nicio diferenta ( de genul motorul e mai silentios etc) Uite niste date luate de pe un forum dedicat acestui motor: "The official recommendation is API CD rated oil. That was a specification developed in about 1955. Any name-brand oil is going to meet that, though if you buy house-brand oils, be sure and check the API rating first -- there are still some very poor oils being sold under no-name brands. Oils not specifically rated for "diesel" use will likely still be fine; again, check the API rating for a Cx rating where the "x" is greater than "D". The current diesel API spec is CI-4! The official viscosity recommendation is 5W30 if the ambient temp is always below 60°F; 10W30 for temps above 0°F, and SAE 30 optional above freezing. The LD28 is not picky about viscosity, but unless you have a real oil-burner, thinner oil is better than thicker. It requires less hp to pump (a not insignificant amount) and will lubricate better at cold start and during warmup." QUOTE Ce bine arata asta. Pacat ca-i taxa asta de tot rahatu'. Cred ca o recarosare ar fi solutia pt asta. Totusi, mi se pare ciudat rulajul....200k e putin pt varsta ei, dar daca te uiti si la altele de pe mobile, toate cam pe acolo se invart. Un alt exemplar frumos ar fi asta This post has been edited by kossak: 11 Oct 2009, 21:40 |
Honda
Civic
1.8 Sport, ex Dacia Logan 1.4 Laureate "Whenever you find yourself on the side of the majority, it is time to pause and reflect"
11 Oct 2009, 21:38
#128
ce frumos au pus-o in showroom langa modelele actuale
kossak |
11 Oct 2009, 21:47
#129
Totusi si pretul e pe masura
Da' asta deja are alt motor, de generatie mai noua, distributia e pe curea etc. Uite o diferenta intre asta si cel vechi: asta vechi: |
Honda
Civic
n@styx |
16 Oct 2009, 12:32
#130
Membru incepator Group: Members Posts: 11 Joined: 26 October 06 |
Am vrut sa-ti trimit un mesaj privat dar nu merge .... te anunt ca s-a modificat pretu' pt. nissan ... a venit criza peste mine 700 euro
1984
kossak |
19 Oct 2009, 17:22
#131
Am primit azi cureaua aceea de distributie
curea.jpg ( Size: 143.02k ) Number of downloads: 858 Am dat pe ea 35 de RON ( made in EC ) Urmeaza sa-mi gasesc un weekend liber sa ma pun s-o schimb. In afara de asta, trebuie sa schimb cat mai repede pivotii, deja troncane ca naiba in gropi ( am constatat asta weekendul trecut, cand am fost acasa la tara) Pivotii noi ii am deja, au venit ca bonus cu masina cand am cumparat-o. Aveti vreo idee cam cat costa la un service asa o "operatiune" ? Asa estimativ.. |
Honda
Civic
Fan3 |
20 Oct 2009, 19:54
#132
2 ore de manopera...zic eu
bogdan_dsn |
30 Oct 2009, 21:12
#133
Membru autentic Group: Members Posts: 730 Joined: 14 September 07 From: Cluj-Napoca |
Te-am vazut astazi prin oras cu limuzina. Stateai la libraria universitatii la stop. Arata foarte bine masina.
Kia
Ceed SW 1.4 TGDI
2020
kossak |
30 Oct 2009, 21:33
#134
Mersi Bogdan
Maine o asteapta din nou o spalare, mi se tot aduna frunze pe ea peste noapte si e jegoasa rau 31 Oct 2009, 18:37: - Mini update - Am ajuns azi la 240.000 km. Am observat la un moment dat multe cifre la fel, repede m-am agitat sa fac poze 239.jpg ( Size: 39.67k ) Number of downloads: 817 240.jpg ( Size: 34.74k ) Number of downloads: 851 In rest nimic nou deocamdata, lasand la o parte micile chestii care ma deranjeaza, masina merge bine. This post has been edited by kossak: 31 Oct 2009, 18:37 |
Honda
Civic
kossak |
6 Nov 2009, 21:10
#135
Hai sa mai scriu ceva pe aici.
Am tot observat de-o vreme incoace un suierat cand franez. M-am tot gandit la chestii de genul "placute din material ecologic", "a intrat mizerie, umezeala" etc. la un moment dat m-am gandit ca poate e ceva de la vacuum... Dupa ce am studiat mai atent, am observat ca suieratul se aude o scurta vreme si dupa ce las frana, la un interval regulat. Am verificat jantele - cea din stanga e mai fierbinte decat cea din dreapta. Tre' sa demontez roata sa-mi bag nasul pe acolo. Probabil aman pe weekendul viitor pana merg acasa, si schimb si pivotii. Si ceva offtopic. Ca tot a aparut iar treaba asta cu Dacia Kiss FM, am fost sa fac si eu un test drive ( mi-am dorit asta de ceva vreme). Am prins un Sandel Laureat 1.6 cu kitul ala smecher. Desi nu prea poti sa-ti faci o imagine despre masina in urma unui test drive, tutusi vreau sa scriu aici una alta. Mi-a placut foarte mult spatiul interior, e loc nu gluma. Pozitia la volan mi s-a parut OK, cu scaunul dat la maxim in spate (am 1.82). Am studiat volanul reglabil pe inaltime, se plangea la un moment dat cineva ca are "cursa" prea scurta, mie mi s-a parut OK. Oglinzile la fel, sunt foarte utile, vezi tot in spate De tinuta pe drum nu prea am ce sa zic avand in vedere durata testului. Directia merge putin mai usor decat la corabia mea. Si ca toate masinile astea noi, suspensiile sunt tari, scaunele la fel. In schimb am studiat atent plasticele, le-am pipait bine si adevarul e ca intr-adevar nu sunt prea grozave, dar nu as zice sa sunt chiar slabe. In concluzie pot sa zic ca a fost o experienta placuta, nu am fost dezamagit. Totusi, nu inteleg o treaba: ce naiba e asa greu sa faci un plastic de calitate? Chiar e ceva foarte complicat si costisitor avand in vedere tehnologia de azi? Nu inteleg trend-ul asta, cu kilogramele de plastic dintr-o masina... In fine, sper sa mearga la fel de bine corabia ca pana acum. |
Honda
Civic
Bwwlan |
7 Nov 2009, 21:01
#136
Membru autentic Group: Members Posts: 1.599 Joined: 16 September 09 From: .de, ex Cluj |
Salut-salut.
O intrebare: ar fi o idee sa-i pui niste jante de aliaj? Ca eu m-am uitat pe ebay.de si pe mobile.de si n-am gasit jante originale Nissan din perioada aia, ca sa-mi fac o idee cam cum ar trebui sa arate. Nu ceva bling-bling, ceva simplut, decent, care sa inlocuiasca capacele alea... Apropo, cate prezoane are /roata? 4, nu? Multi km. fara probleme |
VW
Golf Sportsvan
2017 1.4 TSI 150CP DSG Comfortline "Să gândești e dificil, de aceea majoritatea oamenilor doar judecă."
C.G.Jung |
Serje |
7 Nov 2009, 21:08
#137
Membru autentic Group: Members Posts: 2.129 Joined: 11 December 04 From: Cluj-Napoca |
Este aici o poza : Link
MTD
Optima
53 SPB HW
kossak |
7 Nov 2009, 21:21
#138
Salut.
M-am tot gandit si eu sa ii pun niste jante de aluminiu dar inca nu am avut finantele pentru asa ceva. A fost la un moment dat pe mobile un Laurel ca si al meu cu jante de aluminiu (din fabrica). Erau genul ala cu multe spite, parca a avut BMW asa ceva mai demult. Ce am acuma pe masina sunt de 14", cu 4 prezoane. Cele de aliaj de fabrica era pe 15". Dar inainte de asta as vrea sa refac cumva fata masinii, nu-mi place improvitatia de acuma. Am gasit far nou la 300 de RON, nou, chiar si masca la comanda. Ar mai ramane sa gasesc o bara si treaba ar fi rezolvata. Momentan inca am retineri in a baga bani in asa ceva, treaba cu cutia automata nu-mi da pace, mi-ar place sa pot povesti cu cineva priceput in domeniu ca sa ii explic exact simptomele. Si inca nu am gasit pe nimeni. Este un tip din Cluj care se ocupa cu asa ceva, dar dupa ce am reusit intr-un final sa vorbesc cu el si sa-i zic ce ma doare, m-a refuzat instant auzind varsta masinii. |
Honda
Civic
kossak |
1 Dec 2009, 22:40
#139
Hmm...se pare ca lucrurile au inceput sa schimbe putin mai repede decat m-am asteptat eu.
De ieri a inceput sa fac figuri cutia de viteze. La rece schimba foarte greu intr-a 2-a si cand schimba scutura bine de tot masina. Asta e o noutate. Dupa ce se incalzeste isi mai da drumul. Presupuneri? 1. scapa vacuum pe undeva; am verificat asa in mare conductele si nu am observat nicio crapatura 2. modulatorul de vacuum de pe cutia de viteze. n-am idee 3. leaking seals/ stuck valves. n-am cum sa depistez. Nasola treaba...foarte nasoala.... Service de automate? Probabil m-ar taxa incat as dubla valoarea masinii... Momentan habar n-am ce sa fac... |
Honda
Civic
bogdan_dsn |
1 Dec 2009, 22:46
#140
Parca e un service ce se ocupa de cutii pe strada spre care mergi la dezmembrari in lomb. Nu le stiu exact numele. Ai incercat acolo?
Kia
Ceed SW 1.4 TGDI
2020
kossak |
1 Dec 2009, 22:53
#141
Hmmm...nu am fost acolo. Cam pe unde vine asta? ( sorry, nu stiu pe unde e lomb) Ms
Honda
Civic
Serje |
2 Dec 2009, 00:18
#142
Cauta strada Lombului pe harta.
MTD
Optima
53 SPB HW
2 Dec 2009, 09:10
#143
Din cauza ca nu repara nimeni la noi, multi cetateni cu Daewoo-uri automate, tot asa ca a ta, obosite dupa 2-3-400.000 km, au schimbat-o cu una manuala luata din dezmebrari, care desi are tot atatia sau mai multi km n-are moarte, prinderea e la fel, doar modificari minore, nu poti face aceasi miscare? Daca nu se repara la o masina de 10 ani m-as mira sa gasesti pe cineva sa-ti repare la a ta.
Catalinmodena |
2 Dec 2009, 12:08
#144
Membru autentic Group: Members Posts: 2.547 Joined: 7 April 08 From: Aproape de Craiova |
Da,confirm ce zice argon.Insa eu stiu pe cineva cu un Bora care a facut la fel!
megane sedan
manager 1.4 16v 2007
kossak |
2 Dec 2009, 13:06
#145
Am citit pe net despre conversie din automata in manuala la un model de Nissan foarte asemanator cu al meu ( e vorba de Nissan Maxima 1982-1986)
Acelasi motor, aceeasi cutie de viteze automata. In principiu nu e o treaba complicata, cu conditia sa se potriveasca cutia de viteze de pe masina de piese de acasa. Ar fi cam asa: - schimbat pedalele ( frana si ambreiaj) - pompa ambreiaj - conducta - cilindru ambreiaj - schimbat volanta (cea de automata are convertorul de cuplu "lipit" de ea) - kit ambreiaj nou - schimbat ax cardanic cu varianta pt cutia manuala Daca as avea piesele, probabil in vreo 2 zile as putea face miscarea asta. |
Honda
Civic
evil_2009 |
2 Dec 2009, 22:17
#146
Membru autentic Group: Members Posts: 217 Joined: 20 June 09 From: BUCURESTI |
va fi foarte costisitoare toata operatiunea apropo esti sigur ca ti se potriveste la fix cutia manuala ?
This post has been edited by evil_2009: 2 Dec 2009, 22:18 |
solenza 1.9 d + logan 1.5 dci
europa / laureat
kossak |
2 Dec 2009, 23:32
#147
Cutia potriveste 100% asta nu e problema. Masina de acasa are exact acelasi motor ca si masina actuala; exeptand design-ul exterior, cele 2 masini sunt foarte asemanatoare.
Financiar nu ar fi super scump, "operatiunea" as face-o acasa cu tata. Problema cea mai mare e ca nu am cum sa ridic masina ca sa ma bag sub ea, e f f joasa. Asta ramane inca de vazut. |
Honda
Civic
evil_2009 |
3 Dec 2009, 21:12
#148
asteptam cutia inlocuita
europa / laureat
kossak |
4 Dec 2009, 16:41
#149
Se pare ca am mai "bagat" viata in cutia vietii.
Am deconectat una dintre conducte de la pompa de vacuum, care merge la un senzor ( un bec pe bord) Am facut o tura asa cu masina. Cum scapa vacuum pe acolo a inceput sa schimbe vitezele mai dur si schimba in jos de fiecare data cand incetineam putin si lasam acceleratia. Dupa ce am reconectat conducta respectiva a inceput sa mearga mai bine cutia, sa schimbe fin. Tare am o presimtire ca ceva e infundat pe acolo, o supapa sau ceva de genul. Poate asa cum a tot schimbat ea in sus si-n jos s-a mai curatat ceva mizerie....Ma gandesc sa bag ceva solutie "magica" in cutie, poate are ceva efect. Asta e ceva foarte popular prin America pentru probleme de tot felul la automate, ma gandesc ca poate merita riscul. |
Honda
Civic
kossak |
17 Dec 2009, 19:09
#150
Zilele astea mi-au reamintit boala acestei masini: propulsia asta in combinatie cu greutatea mica din spate. Am patinat de mi-au iesit ochii din cap, fir-ar sa fie..
Nici nu am reusit sa ies din parcare desi am parcat intr-o portiune fara denivelari... Ma tot chinui de 2 zile sa gasesc undeva niste gume de iarna sa le pun pe spate (pe fata deja am) si inca nu am gasit nimic...Al dracului si marimea asta 195/70R14. Noi ar fi doar foarte scumpe, de la 300 RON/bucata ceea ce nu-mi convine ( iau 4 bucati si dublez valoarea masinii ) Seconduri la fel nu am gasit inca. Mai stau pana sambata, sper sa fie mai cald si sa pot sa ies cu masina la "vanatoare".... Aaah, si trebuie sa mai cumpar si vreo 2 saci de ciment sa-i pun in portbagaj This post has been edited by kossak: 17 Dec 2009, 19:14 |
Honda
Civic
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 27th April 2024 - 17:00 |
