Logan MCV fara scanteie
G3orgevty |
30 May 2022, 12:27
Membru incepator Group: Members Posts: 3 Joined: 27 May 22 |
Logan mcv
- VS46MDL
GIC |
31 May 2022, 08:46
Doar membru Group: Members Posts: 919 Joined: 13 January 04 From: Oradea |
N-ai spus daca ai 12V (dupa contact) pe pinul C de la bobina de inductie.
Idem pe injectoare Attached File(s) bobina_LGN_1.pdf ( 38.89k ) Number of downloads: 7 |
G3orgevty |
31 May 2022, 09:33
nu am
pinul c imi apare sa aiba continuitate cu masa tot timpul si nu am reusit sa imi dau seama pe ce pin din ecu ar veni..daca vine in ecu la injector nu mam gandit sa verific deloc inca..pe cand inca pornea in 3 aveam bujia 4 mereu neagra in capat This post has been edited by G3orgevty: 31 May 2022, 09:37 |
Logan mcv
- VS46MDL
GIC |
2 Jun 2022, 07:34
Pe pinul C ar trebui sa ai + dupa contact, acelasi + care alimenteaza si pompa de benzina.
Ia schema in mana si verifica relee, sigurante si fire. Cel mai probabil minusul de pe C e ca tranzistorii din ECU tin bobina la masa prin pinii A/B This post has been edited by GIC: 2 Jun 2022, 07:37 Attached File(s) injectie___aprindere.pdf ( 953.69k ) Number of downloads: 10 |
G3orgevty |
5 Jun 2022, 22:38
am resut sa o rezolv
problema era mufa in sine am schimbato a mers perfect dar uneori ramanea fara putere si dupa ce am cositorit cablul nu a mai facut nici o problema This post has been edited by G3orgevty: 5 Jun 2022, 22:38 |
Logan mcv
- VS46MDL
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th April 2024 - 00:55 |
