RESET service light, RESET service light
martin555 |
13 Aug 2013, 18:40
Membru incepator Group: Members Posts: 2 Joined: 13 August 13 |
mcv
- 45465kl546k
torquemada |
14 Aug 2013, 09:05
Reinitializare alerta dupa schimbul de ulei
Dupa ce ati pus contactul, in 10 secunde apasati si tineti apasata acceleratia, apoi apasati de 3 ori pe pedala de frana. Martorul luminos oil-change trebuie sa se stinga. Reboot alert after oil change After ignition, within 10 seconds press and hold the throttle pedal, then press the brake pedal 3 times. Oil-change warning light should turn off. |
2012 / 0.9 TCe Laureate
roland |
14 Aug 2013, 09:07
Membru autentic Group: Members Posts: 2.704 Joined: 18 November 04 |
Just to be very clear in English, do not start the engine, just put the key in the position where all the lights on the dashboard comes on.
martin555 |
14 Aug 2013, 12:52
thank you, I reset-ed it.
-why so dificult? press pedals? why not press the small RESET button between the rpm and km/h gauge?? -question: I tried to press and hold the small reset button when ignition, and the RPM and km/h clocks went up-and down, up and down.. hopefully I have not make an error? what happened? |
mcv
- 45465kl546k
sorin1983 |
14 Aug 2013, 13:01
Membru autentic Group: Members Posts: 5.588 Joined: 3 July 06 From: Bucuresti-Rahova |
it's test mode, no problem, no error. if you press again and again on the reset i think you can see different menus showing... like how many litres of gasoline you have.
Megane1-
marian_ariciuc |
2 Sep 2014, 09:01
User Group: Members Posts: 322 Joined: 6 May 10 From: de obicei, acasa |
confirm!
metoda a functionat din prima incercare, respectand instrucitunile lui Torquemada! respect! |
1.6 16V E5 Vand modul inteligent de geam pentru logan 1 si 2 si alte...
cd06 |
11 Oct 2014, 08:36
Membru incepator Group: Members Posts: 25 Joined: 11 October 14 |
Trebuie sa nu stii sa citesti ) normal ca merge!
none
none
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 6th May 2024 - 21:47 |
