tunning for dashboard, dashboard computer as diy for foreigners
dydycom |
25 Jan 2006, 16:44
daca exista vointa, orice se poate Group: Members Posts: 628 Joined: 24 March 05 From: Bucharest |
laguna
2.0 dci cva
2008 privilege Imi vand Laguna 3, Detalii la bursa!
http://https://www.reno.ro/index.php?act=ST&f=5&t=313709 |
icatenej |
26 Jan 2006, 11:58
Membru incepator Group: Members Posts: 51 Joined: 15 July 05 From: Belgrade, Serbia |
Now I have couple of question.
- Is soldering operation require someone with really high electronics skills or it could be done by average person who worked with solder couple of times? - Do I need some special soldering equipment (i.e. solder with vacuum pump suitable for SMD components) - Is dissasembly and assembly proces complicated? - Could you please post picture with wallet button assembly so we can see where is button exactly located. thnx. |
LGN 1.4 Amb. Pack
- BG 694 668
dydycom |
26 Jan 2006, 15:13
OK,
-soldering proces is not very difficul, also i will put in the instruction manual the easy way to do it, you don't neet to be rocket scientist to do it. -all you need is a basic soldering station ...thermoregulated..is the best..and some flux paste & solder wire -you will need 2 torx screwdrivers 10 and 20 .no 20 is for board case plastics and the 10 torx is for electronic dashboard dissasembly&assembly..the procedure is also described in the manual the wallet button is a simple push-button with metalic cover( like the one wich comes with car alarms used for reseting) mounted on de case underneith the drivewheel near the ignition key. It's function is to give you the posibility to acces the menu. this is for ambiance and preferance users only . upper versions have this already. This post has been edited by dydycom: 26 Jan 2006, 15:16 |
laguna
2.0 dci cva
AL |
27 Jan 2006, 15:42
dydycom, I think your attitude is not fair regarding the forum.... you tried to use the forum for making money... please give us your adress in order to send you a bill for advertising services... it is not free!
P.S. in romanian: dydycom, daca te folosesti de forum pentru reclama in acest fel, vei primi o factura pentru asta!... era altceva sa spui doar ca se poate face prin montarea etc. ... dar ce faci tu e reclama pura si nu suntem dispusi sa ti-o gazduim gratis... puteai sa te limitezi la Bursa, fie si in engleza...insa sectiunile tehnice vor ramane tehnice si fara link-uri cu iz de reclama!!! |
Skoda
KAROQ
2019
- B-21-NEW
DiMaggio |
27 Jan 2006, 16:55
Membru autentic Group: Members Posts: 465 Joined: 8 November 05 From: Bucuresti |
itŽs the romanian spirit
Megane RS
2012
Codrin |
27 Jan 2006, 16:58
Membru autentic Group: Members Posts: 1.364 Joined: 7 January 05 From: Bucuresti |
No, it's private property and advertising is not free.
Mazda
dydycom |
28 Jan 2006, 18:43
would you be kind to point me to english bursa! no one said anything about clear backlights thread...this is a way of helping people! all the details here are on the posibility of how to mount(have) this future.i gave most of my knowledge on the forum trying to help...and never issued a bill for the forum, also never will, as long is basic knowhow.All over the internet the support threads are free of charge because of site advertisment..Is it differeny here?
Also all the comercials details i'll try to write it only in bursa or in private. Good day to every one! |
laguna
2.0 dci cva
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 10th May 2024 - 02:43 |
