[VAND] piese LOGAN, SuperNova, SOLENZA, 1300, 1310, piese la CELE MAI MICI PRETURI
julache |
25 Feb 2009, 14:02
Membru Group: Members Posts: 118 Joined: 16 February 09 |
Clio Symbol
2005 Fidji
orwo |
1 Mar 2009, 11:39
taxidriver Group: Members Posts: 58 Joined: 3 July 06 From: timisoara |
ar trebui sa faci separat listele logan,solenta,nova,desi unele se potrivesc la altele sa nu iasa confuzii
2006,1.4 YELLOW CAB
- TM-50-RWO [/B]taxi for ever
julache |
1 Mar 2009, 14:06
Clio Symbol
2005 Fidji
julache |
4 Mar 2009, 15:35
up
4 Mar 2009, 15:59: Solenza bascula echipata - 95 RON bieleta directie - 39.5 RON bieleta inferioara - 59 RON bobina inductie - 190 RON bucsa electromotor - 18 RON burduf planetara + rulment - 47.5 RON clapeta usa interior - 25 RON contact marsarier - 38 RON curea distributie - 34 RON disc ambreiaj - 90 RON echilibror hayon - 25 RON far - 100 RON filtru aer - 18 RON filtru ulei - 13 RON fisa bujii - 35 RON flansa amortizor - 70 RON garnitura chiuloasa - 37 RON geam far - 25 RON joja ulei - 15 RON pivot - 25 RON placa presiune - 95 RON platou perii electromotor - 46 RON pompa apa - 79.5 RON set ambreiaj - 175 RON set distributie solenza - 55 RON set supape admisie - 63 RON set supape evacuare - 63 RON simering distributie Solenza - 11 RON simering palier - 21 RON simering supapa - set - 12 RON sonda apa - 28 RON sonda ulei - 26 RON starter electromotor - 65 RON tampon cv - 35 RON tampon motor hidroelastic - 86 RON termostat - 16 RON vas expansiune - 38 RON This post has been edited by julache: 4 Mar 2009, 15:59 |
Clio Symbol
2005 Fidji
julache |
5 Mar 2009, 22:36
SuperNova
bascula echipata - 95 RON bieleta directie - 39.5 RON bloc lumini - 49.5 RON bobina inductie - 190 RON bucsa electromotor - 18 RON clapeta usa interior - 25 RON contact marsarier - 38 RON cruce volan - 26 RON curea distributie - 34 RON disc ambreiaj - 105 RON echilibror hayon - 25 RON far - 100 RON filtru aer - 18 RON fisa bujii - 35 RON garnitura chiuloasa - 37 RON geam far - 17 RON joja ulei - 15 RON pivot - 25 RON platou perii electromotor - 46 RON pompa apa - 79.5 RON rola intinzator - 35 RON set distributie - 55 RON sonda apa - 28 RON sonda ulei - 26 RON tampon cv - 35 RON tampon motor hidroelastic - 86 RON termostat - 16 RON vas expansiune - 38 RON |
Clio Symbol
2005 Fidji
orwo |
6 Mar 2009, 20:19
am luat covorase logan si burduf planetara ,ff prompt si calitate ok,recomand
2006,1.4 YELLOW CAB
ronin33dan |
6 Mar 2009, 20:21
Membru Afumat Group: Members Posts: 514 Joined: 11 September 08 From: Braila |
Scuze de stres dar revin! Cumva suportii de polita spate ptr o supernova , se poate??!!
Multumesc! |
Supernova
- BR-29-***
didosdoru |
7 Mar 2009, 09:32
Membru autentic Group: Members Posts: 414 Joined: 2 July 05 |
Pentru Pick-UP 1.9 D se poate niste preturi?
Dacia/Opel
Pick-Up/Logan MCV/Astra G
2003/2009/2000
- GL O6 HKV / 53 DGD
julache |
7 Mar 2009, 13:24
QUOTE(ronin33dan @ 6 Mar 2009, 20:21) Salut, am intrebat si nu avem din pacate. QUOTE(didosdoru @ 7 Mar 2009, 09:32) Papuc bendix - 48 RON bucsa electromotor - 28 RON buson ulei - 18 RON capac sp.electromotor - 33 RON curea distributie - 37 RON disc frana - 70 RON electromotor 1.9 - 365 RON electroventilator 1.9 - 240 RON filtru motorina - 9 RON filtru ulei - 10 RON fulie alternator 1.9 - 51 RON fulie motor 1.9 - 174.5 RON garnitura chiuloasa 1.9 - 44 RON ghid supape - 115.5 RON joja ulei - 15 RON palier aluminiu - 59.5 RON palier reductor - 51.5 RON placa presiune 1.9 - 109.5 RON platou perii - 47.5 RON pompa apa - 79.5 RON radiator - 189.5 RON rotor electromotor - 124.5 RON set ambreiaj - 195.5 RON set supape admisie 1.9 - 69.5 RON set supape evacuare 1.9 - 69.5 RON simering distributie - 10 RON simering palier - 19.5 RON simering supape-set - 13 RON starter electromotor - 65 RON stator electromotor - 77.5 RON tampon motor 1.9 - 65 RON vas expansiune - 38 RON 7 Mar 2009, 15:13: up This post has been edited by julache: 7 Mar 2009, 15:13 |
Clio Symbol
2005 Fidji
mugur71 |
17 Mar 2009, 09:01
Membru incepator Group: Members Posts: 1 Joined: 11 September 08 |
aparatorile noroi sint exact ca alea de origine DACIA?
poti pune o poza? |
uscatu83 |
17 Mar 2009, 13:17
Membru autentic Group: Members Posts: 390 Joined: 20 November 07 From: Turnu Magurele - Bucuresti |
Injectoare super nova ai? Si daca da la ce pret? Si ma mai intereseaza un Spray Zinc daca aduceti asa ceva. Multumesc.
Super Nova cu Ac.
2001 Detinator de Super Nova cu Ac si rugina.
julache |
17 Mar 2009, 15:10
QUOTE(mugur71 @ 17 Mar 2009, 09:01) nu pot pune poza pentru ca nu le avem mometan pe stoc, vor veni cu urmatorul transport. QUOTE(uscatu83 @ 17 Mar 2009, 13:17) Injectoare super nova ai? Si daca da la ce pret? Si ma mai intereseaza un Spray Zinc daca aduceti asa ceva. Multumesc. nu am, imi pare rau. |
Clio Symbol
2005 Fidji
K-tlyn |
18 Mar 2009, 09:47
FAN DACIA 1300 Group: Members Posts: 281 Joined: 27 July 07 From: IASI |
Salut, te deranjez si eu cu o intrebare: as avea nevoie de doua ornamente pentru oglinzile de Dacia Solenza. Au forma de triunghi si sunt montate la interior pentru a sustine acel joystick de unde se regleaza oglinda. Am atasat o poza ca sa-ti dai seama despre ce este vorba. M-ar interesa ornamentele pentru stanga si dreapta.
Merci! Attached image(s) |
twingo cinetic 1.2 16V
- IS-08-JOT
alindrgn |
18 Mar 2009, 13:57
mamut lânos Group: Members Posts: 1.347 Joined: 27 April 08 From: brasov |
oglinzi manuale de mcv?
Logan / Duster --
2008 abs plus / 2017 black touch Dacia Logan Abs Plus 1.4 2008 / Dacia Duster Black Touch 1.6 16v 2017 -- BV 83 RMJ / BV 84 RMJ --
CrysMM |
18 Mar 2009, 14:55
Membru autentic Group: Members Posts: 473 Joined: 11 March 09 From: Braila - Ulmu |
cruce volan - 26 RON pentru supernova. este cumva cea de la axul volan inferior?
1310 + SuperNova + Ford Focus combi 1,6b
1999 / 2001 / 2010
julache |
20 Mar 2009, 18:17
QUOTE(K-tlyn @ 18 Mar 2009, 09:47) Salut, te deranjez si eu cu o intrebare: as avea nevoie de doua ornamente pentru oglinzile de Dacia Solenza. Au forma de triunghi si sunt montate la interior pentru a sustine acel joystick de unde se regleaza oglinda. Am atasat o poza ca sa-ti dai seama despre ce este vorba. M-ar interesa ornamentele pentru stanga si dreapta. Merci! Din pacate nu avem. QUOTE(alindrgn @ 18 Mar 2009, 13:57) Din pacate nu avem. QUOTE(CrysMM @ 18 Mar 2009, 14:55) Da aceea este, dar momentan nu o avem pe stoc. Piesele care sunt disponibile si pe care le avem sunt cele postate. Multumesc. Mai multe detalii julache@yahoo.com sau 0726.130.815 <span class='edit'>20 Mar 2009, 21:37:</span> Cateva dintre preturi s-au modificat. Piese LOGAN ansamblu roata față LOGAN - 1100 RON aparator noroi LOGAN spate set - 25 RON bara față LOGAN - 188 RON bascula echipata - 110 RON bieleta antiroliu LOGAN - 20 RON bieleta direcție LOGAN - 29 RON bieleta inferioara LOGAN - 76 RON bobină inducție LOGAN - 190 RON bucșa bascula LOGAN - 13 RON burduf planetară LOGAN - 26 RON buson ulei logan - 18 RON cablu ambreiaj LOGAN - 50 RON cablu frână de mână LOGAN - 58 RON cablu frînă ABS LOGAN - 65 RON cilindru frână LOGAN - 70 RON clapetă ușă exterior LOGAN - 37 RON contact marșarier - 49 RON curea distribuție LOGAN diesel - 35 RON cuzineti biela 1.5 DCI - 155 RON cuzineti palier 1.5 DCI - 175 RON disc ambreiaj 1.6 LOGAN - 125 RON disc frână LOGAN - 72 RON electromotor 1.5 dci - 490 RON far LOGAN - 125 RON filtru aer LOGAN 1.4, 1.6 - 17 RON filtru aer LOGAN 1.5 dci - 25 RON filtru motorina LOGAN - 60 RON fișă bujii LOGAN - 35 RON fulie alternator cu ambreiaj LOGAN - 125 RON garnitura chiuloasă 1.5dci - 85 RON geam oglindă LOGAN - 25 RON ghid supape 1.5 dci - 118 RON husă capotă LOGAN - 50 RON jojă ulei LOGAN - 15 RON kit distribuție LOGAN diesel - 110 RON kit saboți LOGAN - 20 RON lampa stop LOGAN TN07 - 110 RON lampa stop LOGAN TV04 - 110 RON pipă bieleta LOGAN - 60 RON piuliță planetară LOGAN - 17 RON pivot LOGAN - 35 RON platou frână echipat LOGAN - 205 RON pompă apă LOGAN 1.4 - 95 RON pompa apa LOGAN 1.6 - 95 RON pompă apă 1.5 dci LOGAN - 100 RON proiector LOGAN - 75 RON rolă alternator LOGAN cu AC - 70 RON rolă alternator simplă LOGAN - 65 RON rolă întinzător LOGAN - 40 RON rulment amortizor LOGAN - 48 RON saboți LOGAN - 60 RON scrumieră LOGAN - 15 RON set covoraș tăviță - 55 RON set distribuție LOGAN 1.4 - 55 RON set lanț antiderapant 13" - 55 RON set lanț antiderapant 15" - 70 RON set supape admisie 1.5 dci - 70 RON set supape evacuare 1.5 dci - 70 RON sonda ulei LOGAN - 45 RON tampon amortizor LOGAN - 38 RON tampon amortizor+rulment LOGAN - 60 RON tampon CV LOGAN 1.4, 1.6, 1.5 - 70 RON tampon motor hidroelastic LOGAN - 165 RON vas expansiune LOGAN - 43 RON vibrochen 1.5 DCI - 1150 RON Solenza bascula echipata - 95 RON bieleta directie - 39.5 RON bieleta inferioara - 59 RON bobina inductie - 190 RON bucsa electromotor - 18 RON burduf planetara + rulment - 47.5 RON clapeta usa interior - 25 RON contact marsarier - 38 RON curea distributie - 34 RON disc ambreiaj - 90 RON echilibror hayon - 25 RON far - 100 RON filtru aer - 17 RON filtru ulei - 10 RON fisa bujii - 35 RON flansa amortizor - 75 RON garnitura chiuloasa - 37 RON geam far - 25 RON joja ulei - 15 RON pivot - 25 RON placa presiune - 95 RON platou perii electromotor - 46 RON pompa apa - 95 RON set ambreiaj - 175 RON set distributie solenza - 55 RON set supape admisie - 63 RON set supape evacuare - 63 RON simering distributie Solenza - 11 RON simering palier - 25.5 RON simering supapa - set - 13 RON sonda apa - 28 RON sonda ulei - 26 RON starter electromotor - 65 RON tampon cv - 35 RON tampon motor hidroelastic - 86 RON termostat - 16 RON vas expansiune - 43 RON vibrochen - 1050 RON SuperNova: bascula echipata - 95 RON bieleta directie - 39.5 RON bloc lumini - 49.5 RON bobina inductie - 190 RON bucsa electromotor - 18 RON clapeta usa interior - 25 RON contact marsarier - 38 RON cruce volan - 26 RON curea distributie - 34 RON disc ambreiaj - 110 RON echilibror hayon - 25 RON far - 100 RON filtru aer - 17 RON fisa bujii - 35 RON garnitura chiuloasa - 37 RON geam far - 17 RON joja ulei - 15 RON pivot - 25 RON platou perii electromotor - 46 RON pompa apa - 95 RON rola intinzator - 35 RON set distributie - 55 RON sonda apa - 28 RON sonda ulei - 26 RON tampon cv - 35 RON tampon motor hidroelastic - 86 RON termostat - 16 RON vas expansiune - 43 RON vibrochen - 1050 RON Astea sunt majoritatea pieselor, sunt si altele, dar o sa le postez mai tarziu. Pentru detalii si comenzi: 0726.130.815 This post has been edited by julache: 20 Mar 2009, 21:38 |
Clio Symbol
2005 Fidji
CrysMM |
22 Mar 2009, 06:11
Ma intereseaza crucea pentru volan si geam far S+ D pentru DSN. Cum mi le poti trimite?
1999 / 2001 / 2010
mickey_sol |
22 Mar 2009, 07:37
Membru incepator Group: Members Posts: 71 Joined: 30 December 08 |
garantezi pentru fiabilitatea acestor piese? nu vreau doar sa ma bag in seama as dori sa cumpar mai mai multe pt logan si solenza dar ce garantie dai si ce producatori sunt? adica iau kit distributie si daca mi se rupe cureaua si se duce motorul ce fac?
t rog sa nu eviti postul si daca se poate un raspuns. multumesc |
2003/clima
- cl 03 laz
julache |
22 Mar 2009, 13:43
QUOTE(CrysMM @ 22 Mar 2009, 06:11) Salut, din pacate nu avem crucea de volan pe stoc pt SN, avem doar pt Nova si nu sunt la fel. Iar pentru geam far S+D (17 RON fiecare) pt SN le pot trimite prin posta cu plata ramburs. Pt mai multe detalii 0726.130.815 sau julache@yahoo.com QUOTE(mickey_sol @ 22 Mar 2009, 07:37) garantezi pentru fiabilitatea acestor piese? nu vreau doar sa ma bag in seama as dori sa cumpar mai mai multe pt logan si solenza dar ce garantie dai si ce producatori sunt? adica iau kit distributie si daca mi se rupe cureaua si se duce motorul ce fac? t rog sa nu eviti postul si daca se poate un raspuns. multumesc Piesele sunt NOI si sunt importate din Turcia, nu stiu sa iti spun producatorii. Cat despre garantie, daca le montezi intr-un service autorizat si se strica atunci se inlocuiesc. Pentru ca piesele se pot strica si din cauza manoperei. Pt mai multe detalii: 0726.130.815 sau julache@yahoo.com |
Clio Symbol
2005 Fidji
julache |
5 Apr 2009, 12:47
up
Pt detalii/comenzi: 0726.130.815 |
Clio Symbol
2005 Fidji
julache |
6 Apr 2009, 23:55
Comenzi/Detalii : 0726.130.815 sau 0748.135.077
e-mail: julache@yahoo.com This post has been edited by julache: 6 Apr 2009, 23:58 |
Clio Symbol
2005 Fidji
julache |
17 Apr 2009, 18:56
Pt comenzi/detalii: julache@yahoo.com sau 0726.130.815 sau 0748.135.077
Clio Symbol
2005 Fidji
Bogdan11 |
18 Apr 2009, 12:29
#53
Membru incepator Group: Members Posts: 34 Joined: 4 November 08 |
Sunt interesat de o pompita pentru ambreiaj (sub volan) pentru o SuperNova ...Multumesc.
Paste fericit ! |
Laguna 3
2008, Dynamique 2.0 dci 150 cp
Valy90 |
18 Apr 2009, 16:46
#54
Membru autentic Group: Members Posts: 440 Joined: 3 January 09 From: Giurgiu |
Amortizoare spate solenza aduci? si un pret daca se poate.
Paste fericit! |
Dacia/Opel
Solenza/Astra H
2004/ 1.4 mpi / 2005-1.7 cdti
- GR-xx-WAL
gabikry |
20 Apr 2009, 14:59
#55
Membru incepator Group: Members Posts: 50 Joined: 8 March 08 From: Bucuresti Berceni |
QUOTE(julache @ 22 Mar 2009, 13:43) Piesele sunt NOI si sunt importate din Turcia, nu stiu sa iti spun producatorii. Cat despre garantie, daca le montezi intr-un service autorizat si se strica atunci se inlocuiesc. Pentru ca piesele se pot strica si din cauza manoperei. Pt mai multe detalii: 0726.130.815 sau julache@yahoo.com Man ce inseamna service autorizat,ma gandesc ca ai tu un service agreat de tine,banuiesc ca daca vrei tva inseamna ca oferi si factura eventual si garantie,intreb ca sa stie cei interesati de exemplu de un kit distributie,pretul este atractiv dar la ruperea curelei de distributie te costa de de numai stii sa vorbesti reparatia |
Renault Megane 2.1
1,5dci
- B63KFM
julache |
21 Apr 2009, 11:42
#56
QUOTE(gabikry @ 20 Apr 2009, 14:59) Man ce inseamna service autorizat,ma gandesc ca ai tu un service agreat de tine,banuiesc ca daca vrei tva inseamna ca oferi si factura eventual si garantie,intreb ca sa stie cei interesati de exemplu de un kit distributie,pretul este atractiv dar la ruperea curelei de distributie te costa de de numai stii sa vorbesti reparatia Nu am un service agreat, era vorba doar de faptul ca trebuie sa iti schimbi piesele la un SERVICE, nu la cine stie ce mecanic necunoscut, care sa monteze prost piesele si sa se strice din cauza lui. Noi oferim garantie si schimbam piesele doar daca ti se strica masina din cauza pieselor, daca au vreun defect ele sau ceva de genul asta.. pentru ca e posibil, chiar la distributie cum spuneai tu, ca un mecanic sa faca o greseala minuscula de montare care sa duca la cine stie ce stricaciuni; Daca se intampla la un service treaba asta (service-urile ofera garantie pentru montajul facut la ei), le poti cere lor socoteala, fiind greseala lor, iar daca te duci si iti arata ca a fost din cauza pieselor, atunci nu e nicio problema, ne recunoastem vina. Totusi, pana acum nu am avut probleme cu nicio piesa, nimeni nu s-a plans. This post has been edited by julache: 21 Apr 2009, 11:45 |
Clio Symbol
2005 Fidji
bogdan.lx24 |
21 Apr 2009, 13:15
#57
Membru incepator Group: Members Posts: 4 Joined: 21 April 09 |
Salut! Ma intereseaza daca gasesc cumva la tine macara electrica dreapta fata pt solenza! Daca da imi poti spune un pret?? Multumesc
2003 clima
- ph 09 flf
julache |
26 Apr 2009, 02:15
#58
Clio Symbol
2005 Fidji
daniM |
4 May 2009, 19:14
#59
Membru autentic Group: Members Posts: 580 Joined: 11 July 07 From: Gugulania |
cap de planetara Solenza este?ce pret?
- Skoda Octavia
calinu' |
4 May 2009, 21:45
#60
Membru Group: Members Posts: 176 Joined: 11 December 08 |
placute frana ferrodo solenza ai?
Megane 2
2005 17" sunroof:X
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 25th May 2024 - 19:33 |
