Sunet neplacut la frinare
Bocu |
26 Dec 2009, 14:27
Membru incepator Group: Members Posts: 2 Joined: 26 December 09 |
2006, 1.4 MPI
- MS05XXX
Relu_GTT |
26 Dec 2009, 15:07
Membru autentic Group: Members Posts: 1.502 Joined: 11 May 08 From: BRASOV |
de la saboti cum freaca pe tamburi se aude
This post has been edited by Relu_GT: 26 Dec 2009, 15:08 |
SuperNova
2002 Confort
- BV 27 GTT BMW e46 FL 2.0i
axabrt |
26 Dec 2009, 16:07
Membru autentic Group: Members Posts: 3.064 Joined: 15 February 05 From: Ploiesti |
dupa ce se incalzesc franele nu mai face
Focus mk3.5
Ecob00st .dracnev si boboru’ este viitoru’.
BZN |
26 Dec 2009, 17:10
Itan convins Group: Members Posts: 3.590 Joined: 29 January 08 From: Rucar / Bucuresti |
Pe suprafata discurilor se formeaza rugina, din aceasta cauza apare un harait la primele actionari ale pedalei de frana. N-are nimic, "asa face toate".
This post has been edited by BZN: 26 Dec 2009, 17:13 |
Tico 0,796 6v, 1998
/Logan 1,598 16v, 2009
- AGXXMAV / AGXXVAB
Lord Hades |
26 Dec 2009, 17:51
Memento Mori Group: Members Posts: 1.640 Joined: 28 July 07 From: Brasov |
daca vine din fata (si asta e cel mai probabil) e de la impuritatile prinse intre placute si discuri. In general nu ar trebui sa fie o problema majora, dar daca te streseaza galagia poti desface etrierele, cureti placutele si discurile si gata
OOOO
A3
2010 / Vorsprung Durch Technik
- BV03:-) "Death smiles at us all. All a man can do is smile back."
Bocu |
29 Dec 2009, 14:43
Multumesc pentru sfaturi.
2006, 1.4 MPI
- MS05XXX
29 Dec 2009, 15:18
fan Dacia Group: Members Posts: 19.913 Joined: 12 November 05 From: Bucuresti |
QUOTE(Lord Hades @ 26 Dec 2009, 18:51) daca vine din fata (si asta e cel mai probabil) e de la impuritatile prinse intre placute si discuri. In general nu ar trebui sa fie o problema majora, dar daca te streseaza galagia poti desface etrierele, cureti placutele si discurile si gata Se pot si unge anumite piese. |
robbie_ro |
29 Dec 2009, 16:32
----------------------- Group: Members Posts: 459 Joined: 25 June 07 |
Ar trebui sa specifici care piese, sa nu cumva sa se apuce sa lubrifieze placutele sau discurile (cunosc cazuri). De asemenea sa nu fie unse in exces, ca sa nu curga lubrifiant pe discuri sau placute mai apoi.
2007, Laureate Plus
Lord Hades |
29 Dec 2009, 18:04
QUOTE(robbie_ro @ 29 Dec 2009, 17:32) Ar trebui sa specifici care piese, sa nu cumva sa se apuce sa lubrifieze placutele sau discurile (cunosc cazuri). De asemenea sa nu fie unse in exces, ca sa nu curga lubrifiant pe discuri sau placute mai apoi. asta ar fi chiar simpatica, sa dea cu vaselina pe discuri si pe urma sa se intrebe de ce nu mai franeaza |
OOOO
A3
shadow_x3x |
29 Dec 2009, 22:36
Membru Group: Members Posts: 149 Joined: 28 December 09 From: Galati |
Cel mai probabil este de la pietricele, nisip sau alte impuritati...dar la fel si rugina poate fi o cauza...
Honda
Civic 5D
robbie_ro |
31 Dec 2009, 08:50
Razi tu, Harap Alb (Lord Hades), dar la serviciu si noi am cazut pe jos de ras cand un coleg nu mai putea frana de nici o culoare dupa ce a uns discurile de frana cu vaselina (nu-i placea ca scartaiau franele), asta in loc sa-si schimbe placutele.
2007, Laureate Plus
vi_escu |
31 Dec 2009, 13:43
Membru somnambul Group: Members Posts: 1.996 Joined: 13 November 04 From: republica procurorilor |
Tot nu am inteles, deranjaza sunetul in sine sau doar faptul ca este neplacut? Am primit cadou o goarna d'aia care canta macarena cand dai cu spatele, o donez cu placere (daca o mai gasesc prin garaj). O legi pe lampile de frana si ai rezolvat problema!
ABS plus 1,6MPi
. 2007 Decat mult si fara rost mai bine putin si prost!
Lord Hades |
31 Dec 2009, 15:35
valeu vi_escule! ce faci tata vrei sa ne nenorocesti? o sa isi puna toti manelistii goarna, dar nu cu macarena ci cu gutza si o sa stea la semafor cu piciorul pe frana ascultand manele ...
OOOO
A3
CrudeS |
14 Jan 2010, 10:50
Membru incepator Group: Members Posts: 10 Joined: 31 August 09 |
Am patit-o si eu cu harsaitul la franare. Imi intrase nisip cu zapada la saboti. Am fost in service dat tamburi jos, curatati (pe garantie) montat la loc si dai bice. Daca face la rotile fata am observat ca dupa o pauza mai lunga 2 zile si mie imi face la fel primele 2-3 franari pana se curata discurile de rugina.
2006/1,6 8v
- B 49 UVD
rratzoiusexos |
23 Jan 2010, 13:09
Membru autentic Group: Members Posts: 714 Joined: 4 June 08 |
mai sunt unii saboti,care nu sunt de origine,gen asam,la solenza,care au insertie metalica in ei.cand sunt reci se aude un harait la franare de la materialul din care sunt facuti.cei de origine nu fac asa,dar sunt si mai scumpi cam de 4 ori.
1307/Solenza/Duster
- B-xx-xxx
25 Jan 2010, 10:42
pt a preintampina scartaitul exista o pasta cu care se ung discu si sau placutele.
PASTA FRANE ( anti-scartait ) Caracteristici: o pasta ceramica care previne scartaitul produs de placute la franare se aplica direct pe placutele de franare Atentie ! eficienta este scazuta la franare, imediat dupa aplicare |
csocso |
18 Feb 2010, 19:27
Membru autentic Group: Members Posts: 264 Joined: 5 December 04 |
Am observat ca dupa cateva zile de nefolosit masina, pe discurile d efrana se depune un strat de rugina.La pornire apoi franele pana nu se duce acest strat nu prind asa cum trebuie, m-am uitat si la alte masini si nu am vazut asa ceva....oare o fi calitatea proasta a discului?
PRESTIGE
SorinXp |
18 Feb 2010, 20:18
Membru Group: Members Posts: 196 Joined: 30 June 05 |
Ruginesc toate discurile pe partea unde se freaca cu placuta. Dupa 2-3 semafoare sunt ok.Un disc e facut din fonta, otel si alte nebunii de aliaje. Poate alea cu ceramica si cine stie ce tampenii (sunt foarte scumpe...) nu ruginesc. La mine daca ploua torential in 1-2 zile deja se vede pe disc rugina, dar din punctul meu de vedere cand nu or mai rugini in conditiile astea o sa mi fac probleme... Pana una alta franele sunt super ok
Prestige 1.6 16v Dec2008
- B97GCT
VyRuZ |
18 Feb 2010, 20:19
Chauffeur du Renault Group: Members Posts: 1.099 Joined: 3 December 09 From: București |
Nu. Materialul din care este făcut discurile este de așa natură. Dacă le-ar fi făcut din ceva inoxidabil... nu ar fi avut aceleași proprietăți.
Deci, totul e OK. No worries. La 2-3 frâne se va duce rugina și gata. |
Megane 2.2 Coupe, 1.5 dCI, 63 KW,
09/2007
- B-***-**F If it ain't broke, don't fix it.
csocso |
19 Feb 2010, 14:44
da, am sesizat si eu ca dupa cateva franari e ok...
mersi |
PRESTIGE
VyRuZ |
21 Feb 2010, 22:53
QUOTE(VyRuZ @ 18 Feb 2010, 20:19) Nu. Materialul din care este făcut discurile este de așa natură. Din care sunt făcute, voiam să zic. |
09/2007
phara |
24 Feb 2010, 21:47
Membru Group: Members Posts: 170 Joined: 17 February 07 |
discurile ruginesc din cauza condensului, umiditatii, umezelii si astfel apare si zgomotul acela la franare. la mine de exemplu cand sunt discurile umede masina franeaza mult mai brusc, adica frana este mai eficienta
2005 Ambiance
costinn |
25 Feb 2010, 00:26
Membru Group: Members Posts: 115 Joined: 19 February 10 |
sunetul neplacut poate sa fie din cauza placutelor mai exact a cantitatii mari de cupru din ele
logan 1.5 dci
dorudorel |
11 May 2010, 10:48
Membru incepator Group: Members Posts: 19 Joined: 4 May 07 |
Intru si eu in vorba.
Si la mine se aude acea haraiala cand franez prima oara, dupa ce masina a stationat 2-3 zile. Dupa cateva franari, rugina de pe suprafetele discurilor si a sabotilor se curata si franarea nu mai este insotita de acel zgomot specific, dar acest sunet mi-a aparut cand imi intra abs-ul in functiune (insotit de trepidatia normal a pedalei de frana). Nu mai stiu daca acest sunet era prezent cand masina era noua si ma cam ingrijoreaza. Dupa cate am citit, la unii colegi de forum se aud trancaneli, zumzet de pompa electrica, la mine cand intra abs-ul am impresia ca nu mai am cauciucuri pe masina si franez direct cu jantele pe asfalt. |
-Dacia
-Logan 1,5dci/85cp
-2007
robbie_ro |
11 May 2010, 13:05
Poate cand era masina noua aveai tu urechile infundate (glumeam). La mine senzatia asta o am de cand am cumparat masina, dar zgomotul e normal. Pana sa ma conving am mai ascultat vreo 3 masini.
2007, Laureate Plus
dorudorel |
12 May 2010, 07:02
robbie_ro-----------
-Dacia
-Logan 1,5dci/85cp
-2007
poe |
12 May 2010, 10:56
Membru autentic Group: Members Posts: 203 Joined: 7 June 06 From: Constanta |
Am un prieten caruia ii scartiaie pe spate "ceva" nu se stie ce cu o frecventa foarte deranjanta, a demontat de 2 ori rotile pe spate in service dacia au curatat pe acolo si tot degeaba dupa scurt timp iar scartaie. In momentul cand calca pedala de frana in mers, scartaitul inceteaza. Eu am considerat ca mai mult ca sigur e vreun span pe la saboti care-si face de cap. Dar chiar asa demontata de 2 ori cei din service nu au dat cu marcar un pic de hartie abraziva pe saboti?
Logan Kiss FM, 1.5 dci 85CP
12 May 2010, 11:43
sigur e pe spate? Sa stea cineva pe bancheta spate cu capul pe geam sa analizeze mai bine zgomotul, ca poate fi si de pe fata, dar pare a se auzi de pe spate
bobo77 |
12 May 2010, 21:01
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Zgomotele astea sunt foarte inselatoare, klaus are dreptate verifica cu atentie.
Laureate 1,6 mpi
2008 ph 2
- CT _ _ _ _ Multa lume,putini oameni...
YRX |
13 May 2010, 06:21
Membru autentic Group: Members Posts: 4.730 Joined: 6 July 06 From: Bucuresti |
QUOTE(ydaniel @ 25 Jan 2010, 11:42) pt a preintampina scartaitul exista o pasta cu care se ung discu si sau placutele. PASTA FRANE ( anti-scartait ) Caracteristici: o pasta ceramica care previne scartaitul produs de placute la franare se aplica direct pe placutele de franare Atentie ! eficienta este scazuta la franare, imediat dupa aplicare Pasta aia ceramica sau pe baza de cupru nu se foloseste pe fata placutei sau a discului. Se da pe spatele placutei, la contacutl cu pistonul si pe ghidajele placutelor in port-etrier. Daca aveti placute cu banda anti-vibratii (pe spate) nu se da cu vaselina pe ele, doar pe ghidaje. |
2005 Ambition 1.6 MPI
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 29th April 2024 - 18:08 |
