TEMPORIZATOR STERGĂTOARE, ...asa cum avea până si bătrâna Berlină
hash |
21 Apr 2011, 20:22
#271
calculatorist Group: Members Posts: 1.388 Joined: 13 September 04 |
FRATELLO |
21 Apr 2011, 21:00
#272
Membru autentic Group: Members Posts: 920 Joined: 7 November 06 From: PLOIESTI |
Multumim ! PASTE FERICIT !
old 1.5 dCi-E4 ; now 1.2 @ 16V
Marius4d |
4 Feb 2012, 18:07
#273
Membru incepator Group: Members Posts: 16 Joined: 17 January 12 From: Buzau |
Cateva idee pt potentiometrul de reglaj temporizare stergatoare
This post has been edited by Marius4d: 4 Feb 2012, 18:09 Attached thumbnail(s) 2012_01_29_15.28.01.jpg ( Size: 676.21k ) Number of downloads: 2848 2012_01_29_15.26.43.jpg ( Size: 637.41k ) Number of downloads: 2499 2012_01_27_08.04.01.jpg ( Size: 488.12k ) Number of downloads: 2487 2012_01_19_16.19.53.jpg ( Size: 426.29k ) Number of downloads: 2445 2012_01_19_14.51.23.jpg ( Size: 509.72k ) Number of downloads: 837 2012_01_19_13.38.30.jpg ( Size: 492.25k ) Number of downloads: 877 |
2005 Ambition
- BZ 26 SMF
Bujor Stefan |
4 Feb 2012, 22:29
#274
Membru autentic Group: Members Posts: 712 Joined: 17 March 06 From: Bucuresti |
Unde ai gasit modelele alea de potentiometre?
2006 Ambition 1,6
- B
Marius4d |
5 Feb 2012, 17:57
#275
Cel cu butonul care iese in afara e de la Espero. Rotita de la o Lancia. Merge si cel de la Cielo caci are tot 100Kohmi dar trebuie adaptat.
Attached thumbnail(s) 2012_01_27_08.03.27.jpg ( Size: 492.57k ) Number of downloads: 860 2012_01_19_13.38.08.jpg ( Size: 918.6k ) Number of downloads: 716 |
2005 Ambition
- BZ 26 SMF
Bujor Stefan |
6 Feb 2012, 20:48
#276
Multumesc, imi aduc aminte acum de butoanele alea de pe Espero.
2006 Ambition 1,6
- B
sandulescumarius |
12 Mar 2012, 15:33
#277
Membru incepator Group: Members Posts: 1 Joined: 12 March 12 |
te-as ruga daca mai poti sa pui odata hex-ul pentru pic 12F629
electrica2000 |
24 May 2012, 17:12
#278
Membru incepator Group: Members Posts: 35 Joined: 30 April 11 |
sall ce temporizare fac loganisti aici eu am pe preferans ,nu stiu la ce temporizare va referiti eu dau pe treapta 1 si merg singure la intervale de cateva sec, nu mai pun mana pe maneta decat sa le opresc definitiv sau pt treapta 2 care merge mai repede.
eu am modificat la setergatoare sanu mai dau pe treapta 1 pt stergere ,doar trebui sa ridic de maneta si ami da lichid parbriz si la 1 sec pleaca stergatoarele singure fara a mai da de maneta + ca merg ca si anainte. pt asta se aduce un fir din uch la mufa din maneta stergatoarelor |
logan 1.4
2007 1.4
24 May 2012, 17:34
#279
Nu vrei sa ne descrii procedura, poate unii de pe aici nu o cunosc.
PS: vezi ca la inceput de cuvant se foloseste î (din i) nu â (din a). |
kti |
24 May 2012, 18:05
#280
,,hobyst,, Group: Members Posts: 123 Joined: 20 May 08 From: CRAIOVA |
si dai la maneta intruna ?
si ramai si fara apa. aaa...stai ca ploua ... spor |
1.4/gpl/stag200-4 ,1,5 diesel
- xx-70-xxx
LuluMOB |
24 May 2012, 22:15
#281
Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași |
O, doamne, ce dor mi-era de un electric din asta...
ABS+ AC 1.4MPI 06/2007
kti |
25 May 2012, 00:48
#282
nene electric sa te vad cand sunt inghetate lamelele si dai din reflex de maneta sau cu lichid pe parbriz sa vezi atunci ,,distractie,,...
eu unul m-am lecuit |
- xx-70-xxx
cris06 |
25 May 2012, 11:21
#283
Mester Group: Members Posts: 597 Joined: 7 October 08 From: Iasi |
QUOTE(hash @ 21 Apr 2011, 20:22) Schema de mai sus nu e putin gresita? Alimentezi releul de 12V la 5V? |
Daewoo
- IS.06.---
hash |
25 May 2012, 23:05
#284
Nu, merge si asa. De 5 ani.
kti |
1 Jun 2012, 16:18
#285
- xx-70-xxx
hash |
4 Jun 2012, 14:20
#286
QUOTE(kti @ 1 Jun 2012, 17:18) nu-i corect dar merge sunt scheme simple f bune si fara releu <span class='edit'>1 Jun 2012, 16:28:</span> poti explica te rog ce stie sa faca aceasta schema? Pai nu stiu ce sa zic. Avand in vedere ca ma combati, ar cam trebui sa stii cam ce face schema - adica nu mare lucru: alimenteaza un uC, furnizeaza o tensiune la un pin, respectiv ia un semnal de la un pin si cu el comanda un amarat de releu. Rezistentele nu sunt decat pentru a 'trage' potentialul la masa respectiv la Vcc si pentru limitarea curentilor de intrare. Programul este cel care 'stie', in functie de comanda data pinului de intrare, sa formeze un semnal dreptunghiular cu un factor de umplere variabil, ca sa poti avea temporizare variabila pentru stergatoare - sa porneasca stergatoarele la un interval oricat de fin vrei, de la sub o secunda pana la .. am uitat, dar cred ca vreo 4 minute Bibliografie: orice curs de electronica digitala, respectiv datasheet-ul 16F84. |
X@by |
4 Jun 2012, 21:33
#287
Membru autentic Group: Members Posts: 249 Joined: 8 June 08 From: Tg Mures |
Cum se seteza timpul?
LOGAN/SOLENZA
2008,Preference 1.5DCI 90CP/2003,Clima 1.4MPI GOD IS MY CO-PILOT!
hash |
8 Jun 2012, 23:51
#288
Maneta stergatoarelor sta la punctul mort. Pe prima pozitie ea 'stie' sa dea impulsuri la 4 secunde. Am schimbat aceasta functionalitate.
Odata ce maneta a fost mutata de la punctul mort la prima pozitie, circuitul cronometreaza timpul scurs intre cele doua evenimente - ultima punere la punctul mort respectiv trecerea in pozitia 1. In felul acesta ai temporizare variabila fara nici o modificare exterioara vizibila, fara potentiometre. Sper sa fi fost destul de explicit. Functionalitate de Golf III. |
alexis |
3 Jul 2012, 17:29
#289
daciot Group: Members Posts: 204 Joined: 30 June 05 From: Bucuresti |
Dupa o lunga perioada de folosire a temporizatorului 'Hash' pe fostul meu Logan si dupa un experiment esuat pe Duster (pe care am incercat sa montez o maneta de Megane I break + releu temporizator), m-am decis sa transplantez temporizatorul 'Hash' pe noul meu Duster.
It works like a charm! Hash, inca o data iti multumesc pentru foarte eleganta solutie de temporizator! |
Spring
2021
- B XX HXX
mariuscond |
5 Jul 2012, 08:27
#290
Membru incomod Group: Members Posts: 1.373 Joined: 3 November 05 From: Bucuresti |
QUOTE(hash @ 8 Jun 2012, 23:51) ...Odata ce maneta a fost mutata de la punctul mort la prima pozitie, circuitul cronometreaza timpul scurs intre cele doua evenimente - ultima punere la punctul mort respectiv trecerea in pozitia 1. In felul acesta ai temporizare variabila fara nici o modificare exterioara vizibila, fara potentiometre. Sper sa fi fost destul de explicit. Ce se intimpla daca maneta e comutata de pe pozitia "temporizare" pe pozitia de viteza I sau II continuu si apoi, inapoi pe pozitia temporizare? Mai "tine minte" temporizarea stabilita anterior sau e necesara o noua memorare a perioadei? |
dizăl
- B52
shtrumphy83 |
19 Aug 2012, 20:04
#291
Membru Group: Members Posts: 118 Joined: 28 September 10 |
si eu unul as merge pe varianta lui hush,cred ca urmatorul gadget va fi asta
felicitari celor care si-au stors creierii ptr asa ceva numai bine! |
renault
laguna 3, 1.5dci 110 HP
2011 live to ride
shtrumphy83 |
20 Aug 2012, 20:35
#292
azi am testat varaianta lui hash la un opel combo de la lucru care aveam eu dubi ca temporizarea functioneaza asa si surpriza... chiar asa functioneaza,daca duc maneta din pct O in pct I si o las acolo balearea se face din 20sec in 20sec iar daca procedez asterfel:
1. ducem maneta din pct O in pct I si o lasam de ex.5sec,timp in care stergatoarele isi fac cursa normala 2. dupa cele 5 sec ducem maneta in pct O si o readucem in pct I si o lasam aici.Din momentul asta stergatoarele la fiecare 5sec fac o cursa hash ai un ID de mesenger? ca eu nu pot trimite PM ...sunt inca incepator pe forum numai bine! |
renault
2011 live to ride
shtrumphy83 |
28 Aug 2012, 21:14
#293
nimic....
renault
2011 live to ride
alexis |
28 Aug 2012, 21:50
#294
Cred ca e in vacanta; din Iulie n-a mai intrat pe forum.
Spring
2021
- B XX HXX
shtrumphy83 |
7 Sep 2012, 20:50
#295
nu se mai stie nimic de hash,are cineva un id de mess ,un nr de tel. al lui etc.i?cum putem lua legatura cu el...as vrea si eu un modul
numaio bine! |
renault
2011 live to ride
bobo77 |
7 Sep 2012, 21:39
#296
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Mai ai nevoie de o postare si ii poti da PM.
Laureate 1,6 mpi
2008 ph 2
shtrumphy83 |
8 Sep 2012, 23:30
#297
aha...merci
renault
2011 live to ride
shtrumphy83 |
12 Sep 2012, 22:35
#298
cred ca omul s-a suparat,nici pe privat nu mai da nici un semn de viata,mai asteptam
This post has been edited by shtrumphy83: 12 Sep 2012, 22:40 |
renault
2011 live to ride
shtrumphy83 |
14 Sep 2012, 13:32
#299
pana la urma face cineva module de genu lui hash,adi_stezar?sau tre sa ma las pagubas....
renault
2011 live to ride
marian_ariciuc |
19 Sep 2012, 16:56
#300
User Group: Members Posts: 322 Joined: 6 May 10 From: de obicei, acasa |
QUOTE(shtrumphy83 @ 20 Aug 2012, 20:35) azi am testat varaianta lui hash la un opel combo de la lucru care aveam eu dubi ca temporizarea functioneaza asa si surpriza... chiar asa functioneaza,daca duc maneta din pct O in pct I si o las acolo balearea se face din 20sec in 20sec iar daca procedez astfel: 1. ducem maneta din pct O in pct I si o lasam de ex.5sec,timp in care stergatoarele isi fac cursa normala 2. dupa cele 5 sec ducem maneta in pct O si o readucem in pct I si o lasam aici.Din momentul asta stergatoarele la fiecare 5sec fac o cursa hash, post#150: Circuitul este alimentat tot timpul. El are rolul de a memora intervalul de timp scurs intre 2 activari succesive ale manetei. Daca maneta sta activata (pozitia 1), circuitul comanda impulsuri cu perioada memorata anterior. Daca e dezactivata, inregistreaza durata. Cu cat sta dezactivata mai mult, cu atat perioada viitoarelor baleieri creste (pana in limita de 25s). Initial, la punerea contactului, perioada presetata este de 3s. Dar se poate schimba. Am folosit un PIC schiop .. de pin-ul 10. post# 288: Maneta stergatoarelor sta la punctul mort. Pe prima pozitie ea 'stie' sa dea impulsuri la 4 secunde. Am schimbat aceasta functionalitate. Odata ce maneta a fost mutata de la punctul mort la prima pozitie, circuitul cronometreaza timpul scurs intre cele doua evenimente - ultima punere la punctul mort respectiv trecerea in pozitia 1. In felul acesta ai temporizare variabila fara nici o modificare exterioara vizibila, fara potentiometre. Sper sa fi fost destul de explicit. vreau sa fac montajul, insa cel mai explicit in functionare a fost shtrumphy |
1.6 16V E5 Vand modul inteligent de geam pentru logan 1 si 2 si alte...
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 30th April 2024 - 00:10 |
