Logan technical problems, Is there any problems you encountered...
icatenej |
9 Sep 2005, 10:11
Membru incepator Group: Members Posts: 51 Joined: 15 July 05 From: Belgrade, Serbia |
LGN 1.4 Amb. Pack
- BG 694 668
marksman |
9 Sep 2005, 13:04
Post mortem nihil est Group: Members Posts: 7.473 Joined: 1 November 04 From: sat |
Hello,
As far as I am concerned there are two major problems that I've had so far (in 6460 km - since November 1st 2004): 1. The inside door handles have cracked around the screw (I suspect that the screw was too tight and put pressure on the handle; plus the heat and vibrations => cracks in the front door handles). Replaced under warranty. 2. The back-right shock absorber (damper) failed around 6350 km. This caused a noise when driving and occasionally, in curves there was a POP like noise. Replaced under warranty. No other mechanical or electrical problems have developed so far... |
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 23rd May 2024 - 07:08 |
