New MCV & running in the engine.
ziggyplod |
19 Feb 2009, 15:31
Membru incepator Group: Members Posts: 4 Joined: 20 January 09 From: Murcia Spain |
logan break
- don´t know yet
alex_d9 |
19 Feb 2009, 19:34
Membru MCV-ist Group: Members Posts: 78 Joined: 30 September 07 From: romania |
they run the every engine on the test bench in the factory, you can see this by looking on youtube. the thing with keeping it below 2500 revs and under 85 km/h is part of the warranty, every new engine must be used under this circumstances in the first 6000 km or so .
logan mcv 1.5 dCi
2007 - préferénce
- VL 05 ---
roland |
20 Feb 2009, 09:18
Membru autentic Group: Members Posts: 2.704 Joined: 18 November 04 |
Are you sure? I the user guide it says that for the MPI engines you are not allowed to go over 3000-3500rpm (equivalent to 130km/h in 5th gear) for 1000 km.
For diesel engines it is more km (I quess 1500km, not sure) and the rev is lower. So, from where is the 85km/h and 6000 km? Don't think so... |
Barrie |
22 Feb 2009, 05:41
Membru incepator Group: Members Posts: 42 Joined: 15 April 08 |
Hi Dave,
It does give running in advice in the handbook, the motors don't loosen up until at least 3000kms, and even then it payes to avoid full thottle operations. This has paid dividends with my MCV, which now runs perfectly after 12,000kms. I had the oil changed after 3000kms, this is not required, and scorned by others, but I'm sure it's beneficial if you plan to keep the car a long time. Try to stick to the running in period, and enjoy the rewards later. Kind Regards, Barrie. |
Logan MCV Diesel
- Not known yet
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th May 2024 - 22:50 |
