Probleme senzor viteza
Ciochy |
2 Sep 2009, 01:39
Membru Group: Members Posts: 103 Joined: 15 February 08 |
Oltcit
Club
1993
didosdoru |
2 Sep 2009, 06:47
Membru autentic Group: Members Posts: 414 Joined: 2 July 05 |
Tragi de el cu putere in sus, dar inaite scoate mufa si curata-o bine , s-ar putea sa fie oxidata.
Dacia/Opel
Pick-Up/Logan MCV/Astra G
2003/2009/2000
- GL O6 HKV / 53 DGD
boobybooby23 |
2 Sep 2009, 22:49
Membru autentic Group: Members Posts: 713 Joined: 3 January 09 |
ai pe partile laterale ale locasului unde intra senzoru doua orificii,bagi doua tije sau doua surubelnite in acele locasuri si tragi de senzor,altfel poti sa tragi de el pana il rupi
LS0A
2005,stock
- nt 05 zac
Ciochy |
3 Sep 2009, 13:13
ms mult cred ca asa e mult mai corect
Oltcit
Club
1993
Pedala |
18 Jun 2010, 13:04
pedal2theMetal Group: Members Posts: 78 Joined: 24 June 04 From: Galati |
Asta e singura schema care am gasit-o in manualul de service Dacia despre acest senzor, si se numeste senzor tahimetric. Priviti screenshot-ul.
Unde sunt cele doua gauri in care trebuie sa bagi surubelnita? Attached thumbnail(s) senzor_viteza.jpg ( Size: 264.38k ) Number of downloads: 6451 |
Dacia & Opel
Logan 1.4 Laureate 2005, 1310 CL 1.4
- AstraG 1.6i 3 usi "Fac sport extrem cu Dacia, o calc, imi place senzatia!" - Ombladon. - posesor Dacia 1310 CL
dorul3t |
18 Jun 2010, 13:13
Aviator DACIAClub Group: Members Posts: 396 Joined: 10 November 09 From: Bucuresti |
la ce foloseste senzorul asta? are si dacia 1310 asa ceva?
1310 L + GPL
11.1999
- TR-21-REB bla bla bla....
Pedala |
18 Jun 2010, 14:19
Topicul este la catergoria DaciaClub - Forum Dacia > Dacia Logan > Probleme tehnice - Dacia Logan
deci este vorba despre Logan. This post has been edited by Pedala: 18 Jun 2010, 14:28 |
Dacia & Opel
dorul3t |
18 Jun 2010, 14:21
pfuu.. lipsa de experienta... scuzati de deranj... azi sunt blond(a) )
1310 L + GPL
11.1999
boobybooby23 |
18 Jun 2010, 17:33
gaurele sunt oleaca mai jos de senzor si sunt pozitionate in stanga si in dreapta lui
LS0A
2005,stock
- nt 05 zac
Pedala |
4 Nov 2010, 16:27
Am verificat senzorul de viteza pe pe cutia de viteze de la Loganul meu. Treaba nu sta bine deloc.
Am scos senzorul cu mana si au cazut bucatele din el, practic, carcasa plasicului din care este facut senzorul se dezintegreaza, se macina. Nu am putut sa-l decuplez de firul care il leaga de circuitele electrice ca sa-l analizez mai clar. [attachmentid=1627669883] Altcineva a mai facut progrese? |
Dacia & Opel
kvy |
4 Nov 2010, 17:50
Membru autentic Group: Members Posts: 229 Joined: 19 September 08 From: BUCURESTI |
A inlocuit cineva reperul pina acum ?
Daca da e rugat sa ne spuna in regim propriu sau service si cit a costat. 10x. |
MLS
87
Pedala |
8 May 2011, 14:11
problema ramane deschisa, a mai facut cineva progrese cu senzorul tahimetric?
Dacia & Opel
vi_escu |
8 May 2011, 19:48
Membru somnambul Group: Members Posts: 1.996 Joined: 13 November 04 From: republica procurorilor |
Mai posteaza odata poza aia daca se poate. Cu o surubelnita mica gen ceasornicar se scot foarte usor mufele.
This post has been edited by vi_escu: 8 May 2011, 19:49 |
ABS plus 1,6MPi
. 2007 Decat mult si fara rost mai bine putin si prost!
Pedala |
9 May 2011, 16:55
Am pus doua poze, una pe 18 Jun 2010, 13:04, care este inca disponibila pe aceasta pagina, si inca una care vad ca nu mai e. Diagnosticarea problemelor la vitezometru.
vitezometru_0.jpg ( Size: 199.61k ) Number of downloads: 6297 Daca mai apapre problema de forum si nu se vede atasamentul, doar eticheta lui, am folosit un site public de upload vitezometru0.th.jpg Uploaded with ImageShack.us Eu nu inteleg cum sa pun in practica asta: Asigurați funcționarea corespunzătoare a releului injecție (1047). Verificați izolarea, continuitatea și absența rezistenței parazite a legăturii: Releu injecție (1047) Pin A5 Pin A al senzorului tahimetric N-am vazut o schema a senzorului tahimetric ca sa stiu care-i sunt pinii. As vrea un cod de piesa, o schita, o imagine, ceva. This post has been edited by Pedala: 9 May 2011, 16:57 |
Dacia & Opel
9 May 2011, 17:52
Pentru a nu mai avea probleme senzorul se desface si se lipeste firele de la mufa direct pentru a elimina problemele respective dupa aceea se toarna a+b , rasina etc.
S-a mai vorbit acum mult timp. |
9 May 2011, 21:23
djasu82-ule, tu vorbesti de senzorul de viteza (tahimetru) sau de ala de turatie? Ca-s 2 lucruri diferite, nu de alta.
vi_escu |
9 May 2011, 22:26
Pedala,
ce ai tu la postul #10 ca [attachmentid=1627669883] am crezut ca este o poza cu senzorul dezintegrat, etc. Ai o imagine cu contactele senzorului. Sunt 3 contacte doua in linie si unul deasupra. Ala stingher este A, celelalte B1 si B2. Citeste si asta This post has been edited by vi_escu: 10 May 2011, 00:07 Attached File(s) 250_1.PDF ( 14.43k ) Number of downloads: 1858 |
ABS plus 1,6MPi
Pedala |
25 May 2011, 14:13
vi_escu, mult au mai scris prietenii cu reno twingo pe topicul aratat de tine.
Rezumatul este acesta: Logan-ul are 2 tipuri de cutii JH1 si JH3, in consecinta 2 tipuri de captoare de viteza (numele dat de reno) / senzor tahimetric: unul are codul: 7700418919 unul are codul: 8200436025 Eu l-am luat pe primul de pe carfrance.ro cu 200ron plus transport. Ieftin, scump? Am citit ca s-ar gasi si copii chinezesti cu 60ron in Vitan. IMG00216_20110525_1310.jpg ( Size: 272.19k ) Number of downloads: 5776 La Twingo senzorul este prins cu o clema de metal, la Logan se pare ca este bagat prin presare si sta prins in doua cleme. Sa vad cum o sa reusesc sa-l scot pe cel vechi. |
Dacia & Opel
djPM |
14 Nov 2012, 14:37
Membru incepator Group: Members Posts: 3 Joined: 14 November 12 |
Am avut si eu o problema cu acest senzor (captor viteza), problema consta in defectarea frecventa a acului de la vitezometru (in mers) si s-a rezolvat prin inlocuirea acestui senzor cu unul nou; vreau sa atrag insa atentia asupra pretului acestor senzori, care difera exagerat de la un magazin la altul: daca la primele 3 magazine la care am intrebat care este pretul acestui captor de viteza am primit raspunsuri in intervalul 180 ... 230 de lei, si aici ma refer la magazine de piese auto nu la reprezentante Dacia, la urmatorul magazin am gasit acest senzor la un pret de 40 lei, concluzia - l-am cumparat acesta, si am multumit in gand primelor 3 magazine care nu il avusera pe stoc. Problema s-a remediat in acest moment, in ideea ca acul vitezometrului nu mai "moare" in mers.
1.6 MPI
bobo77 |
14 Nov 2012, 22:25
........................... Group: Members Posts: 7.213 Joined: 27 January 06 From: Mangalia |
Nu te bucura inca, sa vedem cat tine smecheria, pretul este suspect de mic...
Laureate 1,6 mpi
2008 ph 2
- CT _ _ _ _ Multa lume,putini oameni...
djPM |
26 Nov 2012, 14:58
bobo77 a trebuit repede sa zici sa nu bucur , bucuria a fost de scurta durata - in sensul ca acum acul kilometrajului nu mai moare; baiul acum e ca acul kilometrajului nu mai urca lin in momentul accelerarii ci tot in valuri (suisuri rapide + coborari ) plus ca in unele momente are anumite fluctuatii (sus-jos ), oare o fi de la calitatea "indoilenica" a acului ?) sau montajul lui se putea realiza mai bine ??? precizez ca mecanicul mi-e prieten . Bucuria insa acum este ca pot sa-mi urmaresc consumul masinii linistit, faza care fara un ac al kilometrajului activ e imposibila,deoarece calculatorul de bord o ia razna in privinta consumului care poate ajunge la 20-25 l/100km . Deci astept pareri : o fi slaba calitatea captorului sau montajul a lasat de dorit?
1.6 MPI
MyKe89 |
26 Nov 2012, 15:04
Membru RFG Group: Members Posts: 3.013 Joined: 16 December 07 From: Bucuresti |
Tu ce crezi? Sau alea la 180-230 de lei erau replici?
'23 Honda
CR-V
e:HEV ‘23 Honda NC750XA
djPM |
27 Nov 2012, 08:07
Nu erau replici, am gasit la 180 lei - Valeo. Deci inclin sa cred ca "Scumpul mai mult pagubeste"
1.6 MPI
bobo77 |
27 Nov 2012, 22:16
Pai de la 40 la 180 te plictisesti numarand...
Laureate 1,6 mpi
2008 ph 2
electrica2000 |
16 Jul 2013, 21:10
Membru incepator Group: Members Posts: 35 Joined: 30 April 11 |
la logan 2007 1,4 pe unde se afla aceste saracii unul am anteles pe unde este ,al vitezometrului parca si cel al turometrului??
la mine rare ori ambele ace scade cate o liniuta fractiune de secunda apoi urca anapoi,nu ambele o data ,an rest e ok |
logan 1.4
2007 1.4
prollix |
25 Sep 2015, 21:55
Membru incepator Group: Members Posts: 19 Joined: 11 October 06 |
S-a produs si la loganul meu(1.5 dci, 2006, euro 3) "minunea" - vitezometrul nu mai indica. Dupa ce am citit pe forum, am mers la magazin si am cumparat un senzor tahimetric nou. Degeaba. Tot nu imi indica viteza.
Am rulat apoi testul intern si totul este ok. Ceasurile din bord se invart si baleeaza tot intervalul (turatii si viteza). Urmatorul pas a fost sa merg la un service. Dupa o ora de investigari concluzia a fost cea nedorita de mine: problema este in cutia de viteze. Aparent roaza dintata din plastic nu mai invarte senzorul tahimetric. Eu personal nu am uneltele necesare pentru a investiga stiintific (n-am nici tester si nici ampermetru/voltmetru) asa ca am incercat o metoda gasita intr-un alt post: am scos senzorul din cutie insa l-am lasat cu mufat, am pus contactul si am invartit de axul senzorului (si cu mana, si cu o bormasina). Intreabarea mea este: ar trebui ca ceasul de viteza din bord sa imi indice ceva? In testul facut de mine acul vitezometrului nici nu s-a miscat. Multumesc |
Logan Laureate
2006, dci
prollix |
19 Oct 2015, 21:51
Dupa mai multe teste (am eliminat pe rand cutia de viteze si senzorul de viteza de pe lista problemelor) am ajuns la concluzia ca lipseste alimentarea (cei +12V care ar trebui sa alimenteze captorul tahimetric). Unde as putea gasi o schema electrica pentru a identifica de unde pleaca firul de alimentare? Este vorba de un logan 1.5 dCI de 65CP din iulie 2006.
Logan Laureate
2006, dci
torquemada |
20 Oct 2015, 07:24
Dacă
n-am nici tester si nici ampermetru/voltmetru cum ai aflat că nu ai 12v la senzorul de viteză?! Dacă motorul pornește atunci ai 12v la senzor. Cablajul spre senzor e ok? Dacă DA cel mai probabil în senzor au apărut lipituri reci, ori îl repari pe ăsta(muncă de chinez bătrân) ori îl înlocuiești. Un laptop se mai găsește, la fel și un ddt iar un cablu kkl nu e scump - dacă acest rând ți se pare complicat mergi la service. This post has been edited by torquemada: 20 Oct 2015, 07:28 |
2012 / 0.9 TCe Laureate
prollix |
20 Oct 2015, 10:31
Povestea e asa:
1. Nu a mai indicat viteza -> am intrat pe forum si am citit 2. In 90% din cazuri este vorba de captorul de viteza -> am cumparat unul nou "de origine" 3. Dus masina in service ca sa schimbe senzorul (e mai rapid sa o ridice pe elevator si sa schimbe pe dedesubt) -> se constata ca vitezometrul nu indica 4. Alocat 2 ore catre service(contra cost-desigur) pentru a afla care e problema -> dupa o ora concluzia e: "am masurat si senzorul nu produce nimic pe iesire. Concluzia: este cutia de viteze de vina asa ca trebuie data jos si reparata" 5. Nu am avut incredere in concluzia lor asa ca am eliminat pe rand cutia de viteze ca si problema, apoi senzorul 6. Am dus masina inapoi in service cu concluziile mele si le-am mai dat niste timp sa mi le confirme. Se pare ca am avut dreptate: cutia de viteze invarte, senzorul functioneaza (l-au alimentat dintr-o sursa externa si se pare ca vitezometru a indicat ceva) 7. Concluzia lor: "senzorul nu primeste cei +12V. Am tras de fire, am miscat de mufe si nimic. Trebuie inlocuit firul, desigur, totul contra cost" 8. Am zis ca ma mai documentez eu intre timp si am ajuns sa postez aici. Mentionez ca totul se intampla intr-o alta tara unde service-ul, desi este autorizat Renault, nu are prea multa experienta cu modele mai vechi de Logan (asta este impresia mea). Ca sa scap de bani dati degeaba din cauza incompetentei lor, incerc eu sa vin cu cat mai multe informatii iar service-ul doar sa aplice. |
Logan Laureate
2006, dci
20 Oct 2015, 16:20
conform schemei senzorul de viteza are doua fire unul se duce la calculatorul de injectie pin 53 si la tabloul de bord si celalalt ia + 12V de la releul de injectie printr-o jonctiune care nu stiu unde este, senzorul nostru este notat cu 250 iar releul de injectie 1047 posibil ca problema sa fie la conectorul din instalatie pe care vine + sau firul intrerupt intre jonctiune si mufa
This post has been edited by bygy007: 20 Oct 2015, 16:22 Attached thumbnail(s) Untitled.jpg ( Size: 239.56k ) Number of downloads: 943 |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th May 2024 - 01:43 |
