Door problem
Door problem
bougie |
3 Aug 2009, 17:52
Membru incepator Group: Members Posts: 10 Joined: 3 February 09 |
2008 sedan
mario1980 |
11 Sep 2009, 10:52
Membru autentic Group: Members Posts: 437 Joined: 8 April 05 From: Iasi |
For sure the door isn't bending or deforming. Check the latch mechanism, especially the bolt on the B-pillar. It's supposed not to move from it's position, because it's nut is welded to the pillar. In your case, the welding might be broken. So you could get a torx, and reposition that bolt if needed.
dci Preference 2006
- SV ?? ??? Adesea, aproape fiecare om tolereaza prostia celui de linga el, atit timp cit nu ii uzurpa propria prostie.
bougie |
29 Dec 2009, 22:34
hi no worries i had exactly the same problem. on the inside of your b pillar there is a locking bolt that the door "hangs on to" this apparently comes loose easily out of the factory. Your garagist needs to realign it and use some sort of special glue i dont remember the name because simply tightening does not help it will get loose again.
2008 sedan
dacia socrates |
23 May 2010, 11:35
Membru incepator Group: Members Posts: 2 Joined: 23 May 10 |
QUOTE(bougie @ 30 Dec 2009, 03:34) hi no worries i had exactly the same problem. on the inside of your b pillar there is a locking bolt that the door "hangs on to" this apparently comes loose easily out of the factory. Your garagist needs to realign it and use some sort of special glue i dont remember the name because simply tightening does not help it will get loose again. hi , look , u use the term , such a - b pillar - how u know that ?! from where can i know that ? or can i dawnload some book about exactly my car ? if u know , then guide me please ! |
logan mcv 1,5 cdi
2010 socrates
LuluMOB |
23 May 2010, 18:47
Membru cu pedale. Group: Members Posts: 1.136 Joined: 28 October 05 From: Iași |
ABS+ AC 1.4MPI 06/2007
variable_dynamics |
27 May 2010, 13:32
Membru autentic Group: Members Posts: 976 Joined: 24 May 07 From: Bucuresti |
EX Dacia
Nova GTi
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th May 2024 - 17:22 |
