Coil change, Do you have to change coils in pairs on 1.6 16V?
Aali |
10 Dec 2009, 20:48
PAT PAT Group: Members Posts: 41 Joined: 20 July 08 From: Kerman, IRAN |
Iran Khodro
2008-2013 Logan facelift Automatic
marksman |
11 Dec 2009, 11:06
Post mortem nihil est Group: Members Posts: 7.473 Joined: 1 November 04 From: sat |
I only know that shock absorbers should be changed in pairs, e.g. you change a shock absorber in the rear, you should change the other one in the rear too. I guess you could apply the same rule for the coils.
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot
C a t a l i n |
11 Dec 2009, 11:12
I think by coils he means the electric ignition coils for the ignition system, not the springs.
I don't know how is the coil configuration for the 1.6 16v engine. It might have a separate coil for each cylinder (so 4 coils in total), or 2 coils in the same enclosure, each giving electric power for 2 cylinders at the same time. In the first case, I don't see any reason to change 2 coils, you need to change only the faulty one. In the second scenario, you have to replace the coil unit, which contains both coils. Later Edit: I guess that you have a separate ignition coil for each cylinder, and it's located between the spark plug and the spark plug cable, on the engine block. That means you need to change only the faulty one. Hope it helps! This post has been edited by C a t a l i n: 11 Dec 2009, 11:26 |
11 Dec 2009, 12:29
fan Dacia Group: Members Posts: 19.949 Joined: 12 November 05 From: Bucuresti |
Coils are physicaly separate, but work in pairs (waisted spark). When one goes, it ruins the other one (with no resistance in one of them, the current is higher in the other one). Change them in pairs, it's better in the long run.
This post has been edited by einstein1984: 11 Dec 2009, 15:11 |
marksman |
11 Dec 2009, 15:20
Sorry, my bad
Opel / Mazda
Crossland X / CX-30
Aali |
14 Dec 2009, 16:29
Hi everyone my car has 4 seperate coils also known as coil on plugs system.I also googled wasted spark and it usually is two spark plugs per coil like my father's camry V6 engine which has 3 coils only instead of 6 and these systems also use precious metal spark plugs on both central and ground electrodes i.e. double platinum spark plugs as is the case with my father's car and change interval is longer(my father's car need changing every 80000 Km).Some other Renaults use coils on single spark plugs firing in pairs ,What I was asking was from your experience having logans longer than me or as workshop mechanics working with logans that have you seen this practice or my friend is mistaken?
Aali |
Iran Khodro
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 11th May 2024 - 17:14 |
