[VAND] piese renault noi originale la superpret
Vallybz |
30 Nov 2011, 14:42
#511
Membru autentic Group: Members Posts: 1.475 Joined: 26 October 08 From: Buzau/Bucuresti |
Megane 1 Facelift, 1.6, 16v
Coupe 1999 K4M-A7-00
- BZ 87 BVM
Catalinmodena |
5 Dec 2011, 00:00
#512
Membru autentic Group: Members Posts: 2.547 Joined: 7 April 08 From: Aproape de Craiova |
Salut.Ma intereseaza termostat pentru VIN: VF1 LM1 S0H 382 441 34.
Multumesc! |
megane sedan
manager 1.4 16v 2007
lily_efs_2000 |
10 Dec 2011, 09:14
#513
Membru autentic Group: Members Posts: 366 Joined: 4 August 09 |
Vallybz si Catalinmodena aveti pm.
Pt orice piesa am nevoie de datele de pe placuta ovala sau codul de original de pe piesa. Lichidare de stoc. Ultimul set de discuri de frana fata originale renault pt Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 la pretul de 150 lei/set. Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 250 lei Alternator 90 amperi Bosch – motorizare 1.2 Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 970 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 250 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 120 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 35 lei CALCULATOR AIRBAG Kangoo, Twingoo cod: 82 000 98 401 500 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 90 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 110 lei Discuri frana fata neventilate Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 150 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 40 lei Far complet Kangoo 200 lei Faruri complete R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 150 lei Filtre Motorina Master II, Master III, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 40 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.5 - 2.8 DTI si D (98-2001) diam.240/242 mm – pt masini cu 59 kw si 84 kw cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ 77 01 475 597 opel-45 01 617/ 916 19 17 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master III 3000cc, Opel Movano, Nissan Interstar 3000cc TDI si DCI – diam. 242 mm; dinti = 21 pt masini cu 100 kw cod: 77 01 475 971/ opel-4415884/ Vauxhall-931 83 687 700 lei Kit Proiectoare Ceata Clio Grandetour, Clio II, Clio III, Espace IV, Laguna II, Laguna II Grandtour, Modus, Symbol, Vel Satis, Nissan X-Trail, Qasqai, Primera, Micra, Almera II cod: 77 11 236 164/ 82 00 00 24 70 + 82 00 00 24 69/ 82 00 30 10 27 + 82 00 30 10 26 400 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II, Laguna II cod: 77 01 474 997 150 lei Oglinda Laterala stg. Electrica incalzita Kangoo, Megane Scenic, Scenic II cod: 77 01 048 401 70 lei placute frana fata(Textar) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 60 lei placute frana fata(TRW) Clio III, Modus, Clio Grandtour – pt masini fabricate dupa 02.08-prezent (1.2; 1.5 dCi si 1.6), nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 100 lei placute frana fata (Lucas/Ferodo) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 110 lei placute frana fata(Textar) Kangoo, Peugeot 206, 306,405, Nissan Kubistar cod: 41060-00QAF si 41060-00QAG, Citroen cod: 77 01 208 142 90 lei placute frana fata(Ferodo) Master II, Opel Movano cod: 7701207166 110 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 3200 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412189/ 77 01 045 718 140 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 40 lei Set Centura Siguranta Kangoo cod: 82 00 522 693 75 lei Set Centura Siguranta Kangoo cod: 82 00 522 689 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 250 lei Set jaluzele laterale Scenic II, etc – dimensiuni: sus – 45 cm, jos – 48 cm, h – 45 cm + 3 cm partea din plastic, partea din plastic de jos – 66 cm cod: 77 11 223 898 200 lei Set jaluzele laterale Modus, etc – dimensiuni: sus – 49 cm, jos – 61 cm, h – 50 cm + 3 cm partea din plastic, partea din plastic de jos – 71 cm cod: 77 11 227 497 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 100 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 20 lei Termostat lichid racire pt motorizari de 1.2 si 1.4 clio I,II,III,symbol, kangoo, twingo, modus cod: 77 00 110 716 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 70 lei id: pieserenault2009 tel: 0740/43.19.86 Attached thumbnail(s) 77_01_204_282.JPG ( Size: 245.4k ) Number of downloads: 770 77_01_204_282_.JPG ( Size: 282.85k ) Number of downloads: 749 |
renault
megane
- is 25 via
ALIN-ADRIAN |
14 Dec 2011, 18:26
#514
Membru incepator Group: Members Posts: 15 Joined: 11 December 10 |
Am nevoie de pret pt. set complet rulment amortizor + lagar de cauciuc la Laguna 3, 2008, 1.5 DCI, VIN: VF1BT1A0639392368.Aparatoare noroi dreapta spate.
Multumesc! |
LAGUNA 3 1,5DCI
dj_ionutz |
14 Dec 2011, 21:09
#515
Membru autentic Group: Members Posts: 283 Joined: 1 February 09 |
ai set yale(yale contact buson benzina porbagaj cele doua chei) pt clio symbol?
C
li
o Cautati siguranta? Circulati cu sandero.
lily_efs_2000 |
19 Dec 2011, 18:52
#516
ALIN-ADRIAN ai pm.
dj_ionutz, am un set chei yale, dar nu stiu sigur daca e ok pt masina ta. Atasez cateva poze, iar daca vrei alte detalii contacteaza-ma. Pretul e de 250 lei pe set si sunt originale renault. Pt orice piesa am nevoie de datele de pe placuta ovala sau codul de original de pe piesa. id: pieserenault2009 tel: 0740/43.19.86 Attached thumbnail(s) DSC02548.JPG ( Size: 757.3k ) Number of downloads: 704 DSC02550.JPG ( Size: 782.41k ) Number of downloads: 675 DSC02551.JPG ( Size: 751.79k ) Number of downloads: 650 DSC02552.JPG ( Size: 865.05k ) Number of downloads: 72 DSC02553.JPG ( Size: 829.67k ) Number of downloads: 73 DSC02555.JPG ( Size: 642.09k ) Number of downloads: 53 DSC02562.JPG ( Size: 777.4k ) Number of downloads: 51 DSC02561.JPG ( Size: 820.96k ) Number of downloads: 62 DSC02560.JPG ( Size: 794.28k ) Number of downloads: 55 DSC02559.JPG ( Size: 878.95k ) Number of downloads: 70 DSC02558.JPG ( Size: 825.27k ) Number of downloads: 76 DSC02557.JPG ( Size: 871.31k ) Number of downloads: 55 |
renault
megane
- is 25 via
victor89 |
19 Dec 2011, 19:29
#517
Membru incepator Group: Members Posts: 21 Joined: 19 December 11 |
Salut ma intereseaza si pe mine pretu la o aripa stanga fata pt un renault megane 2.1 cabrio seria vf1emrg0633653155
renault
megane cc
lily_efs_2000 |
25 Dec 2011, 12:00
#518
victor89, ai pm.
Pt orice piesa am nevoie de datele de pe placuta ovala sau codul de original de pe piesa. id: pieserenault2009 tel: 0740/43.19.86 |
renault
megane
- is 25 via
adrian.petrov |
8 Jan 2012, 02:45
#519
Membru autentic Group: Members Posts: 485 Joined: 19 March 08 From: Bucuresti |
Salutare, piesa asta o gasesc la tine??
Attached thumbnail(s) IMG_0527.JPG ( Size: 409.35k ) Number of downloads: 86 |
RENAULT MEGANE ;
RENAULT MEGANE ;
2004 -1.9 DIESEL , 2004 1.6 16V BENZINA ;
- B Nu poti face supa de PUI, daca pui numai gainat de pui
Axe |
8 Jan 2012, 09:07
#520
Membru autentic Group: Members Posts: 3.669 Joined: 24 February 08 |
VF1LA0N0525198596
Kit distributie(role ina si curea conti/bosh) pompa apa garnitura chiulasa prezoane chiulasa chiulasa set supape + simeringuri multumesc anticipat |
Megane
1.5dci, 2013, 90CP inca vii...
ionutz_87 |
14 Jan 2012, 20:33
#521
ionutz_87 Group: Members Posts: 1.027 Joined: 21 February 09 From: pantelimon(ilfov)-roman(neamt) |
aripa fata dreapta
grila radiator(calandru) poate fi si de rs Tip auto : RENAULT CLIO Symbol, 1.4 An fabricatie : 2003 Tip caroserie : Berlina Nr. identificare : VF1LB0BC529696760 Observatii : +AC, +ABS, +SD, -CA, -4X4, 4 USI Cilindree ( cmc ) : 1390 Putere max. ( kw ) : 55 / 75 Tip motor : K7J-A7 Serie motor : R192727 This post has been edited by ionutz_87: 14 Jan 2012, 20:38 |
CLIO
2003/LB0C5/CLIO
- IF 03 DAP Grand scenic 2004 1.6
S4b1n |
14 Jan 2012, 21:00
#522
Membru Symbolist Group: Members Posts: 937 Joined: 27 February 10 From: Craiova/Bucuresti |
Buna seara !
M-ar interesa un pret pentru termostat pentru Clio Symbol VF1LB8N0538830785 , motor 1.5 dci K9K- 718 62kw Multumesc |
Renault Symbol
1.5 dCi 62 kW
- ~ 155000 km
ionutz_87 |
16 Jan 2012, 12:04
#523
77 00 112 818
furca debraiere ambreiaj |
CLIO
2003/LB0C5/CLIO
hordy |
19 Jan 2012, 03:22
#524
Membru autentic Group: Members Posts: 349 Joined: 13 June 10 From: Bistrița |
Salut. M-ar interesa pret pentru urmatoarele
Rola ghidaj curea transmie Intinzator curea transmisie RENAULT SCENIC I (09.1999-08.2003) 1.9 dCi (75 / 102; 1870; F9Q 732, F9Q 733) |
- BN40RDY Ex : Megane 1.4 16v - 1999 hatchback
Ex : Opel Vectra A 2.0i - 1990 berlină Ex : Renault Scenic 1,2 1.9Dci - 2001 Van |
lily_efs_2000 |
20 Jan 2012, 09:39
#525
Aveti pm.
LICHIDARE DE STOC - DISCOUNT INTRE 40-80% DOAR PIESE NOI ORIGINALE RENAULT Pt orice piesa am nevoie de datele de pe placuta ovala sau codul de original de pe piesa. Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 250 lei Alternator 90 amperi Bosch – motorizare 1.2 Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 970 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 250 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 120 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 35 lei CALCULATOR AIRBAG Kangoo, Twingoo cod: 82 000 98 401 500 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 90 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 110 lei Discuri frana fata neventilate Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 150 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 40 lei Far complet Kangoo 200 lei Faruri complete R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 150 lei Filtre Motorina Master II, Master III, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 40 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.5 - 2.8 DTI si D (98-2001) diam.240/242 mm – pt masini cu 59 kw si 84 kw cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ 77 01 475 597 opel-45 01 617/ 916 19 17 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master III 3000cc, Opel Movano, Nissan Interstar 3000cc TDI si DCI – diam. 242 mm; dinti = 21 pt masini cu 100 kw cod: 77 01 475 971/ opel-4415884/ Vauxhall-931 83 687 700 lei Kit Proiectoare Ceata Clio Grandetour, Clio II, Clio III, Espace IV, Laguna II, Laguna II Grandtour, Modus, Symbol, Vel Satis, Nissan X-Trail, Qasqai, Primera, Micra, Almera II cod: 77 11 236 164/ 82 00 00 24 70 + 82 00 00 24 69/ 82 00 30 10 27 + 82 00 30 10 26 400 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II, Laguna II cod: 77 01 474 997 150 lei Oglinda Laterala stg. Electrica incalzita Kangoo, Megane Scenic, Scenic II cod: 77 01 048 401 70 lei placute frana fata(Textar) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 60 lei placute frana fata(TRW) Clio III, Modus, Clio Grandtour – pt masini fabricate dupa 02.08-prezent (1.2; 1.5 dCi si 1.6), nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 100 lei placute frana fata (Lucas/Ferodo) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 110 lei placute frana fata(Textar) Kangoo, Peugeot 206, 306,405, Nissan Kubistar cod: 41060-00QAF si 41060-00QAG, Citroen cod: 77 01 208 142 90 lei placute frana fata(Ferodo) Master II, Opel Movano cod: 7701207166 110 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 3200 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412189/ 77 01 045 718 140 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 40 lei Set Centura Siguranta Kangoo cod: 82 00 522 693 75 lei Set Centura Siguranta Kangoo cod: 82 00 522 689 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 250 lei Set jaluzele laterale Scenic II, etc – dimensiuni: sus – 45 cm, jos – 48 cm, h – 45 cm + 3 cm partea din plastic, partea din plastic de jos – 66 cm cod: 77 11 223 898 200 lei Set jaluzele laterale Modus, etc – dimensiuni: sus – 49 cm, jos – 61 cm, h – 50 cm + 3 cm partea din plastic, partea din plastic de jos – 71 cm cod: 77 11 227 497 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 100 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 20 lei Termostat lichid racire pt motorizari de 1.2 si 1.4 clio I,II,III,symbol, kangoo, twingo, modus cod: 77 00 110 716 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 70 lei id: pieserenault2009 tel: 0740/43.19.86 |
renault
megane
- is 25 via
lily_efs_2000 |
3 Feb 2012, 15:39
#526
renault
megane
- is 25 via
paunescubo |
23 Feb 2012, 11:11
#527
Membru incepator Group: Members Posts: 8 Joined: 26 June 09 |
bare transversale Laguna 2 facelift fabricatie 2007 .Cred ca astea sunt codurile
cod: 7711219726 sau 7701410598 |
Laguna 2.0 dCi, 150hp
2007 Lux Pivilege
- B999GPB
pieserenault2009 |
5 Mar 2012, 10:01
#528
Membru incepator Group: Members Posts: 61 Joined: 17 October 09 |
paunescubo, nu am bare transversale.
LICHIDARE DE STOC - DISCOUNT INTRE 40-80% DOAR PIESE NOI ORIGINALE RENAULT id: pieserenault2009 |
renault
megane
- 98ran
aqua |
5 Mar 2012, 10:48
#529
Membru autentic Group: Members Posts: 2.244 Joined: 24 February 05 From: Bucuresti |
burduf de cauciuc dintre masina si capac portbagaj? pt megane 2
ex. megane dci,
ex. Sportage GDI
2017 Sportage 2020 AWD T-GDI
mihiaser |
5 Mar 2012, 10:53
#530
Membru incepator Group: Members Posts: 2 Joined: 14 September 11 |
Salut,
ma intereseaza o aripa fata stanga pentru Renault Symbol VF1 LB0P C534932502 an fabricatie 03.2006 De asemeni daca ma poti ajuta cu 1 bara fata (modelul cu bandourile de plastic negre si loc proiectoare) |
Symbol
george_scala_2004 |
6 Mar 2012, 11:51
#531
Membru autentic Group: Members Posts: 6.577 Joined: 16 April 09 |
Pentru un coleg:
Datele masinii PEUGEOT 206 Hatchback, 1.4 HDi eco 70 – 2002 1398 cm3 50Kw 68 cai Serie VF32A8HXF42161552 Tip motor : 8HX Piese necesare ar fi: 1) 1844A1 2) 1844A2 3) 184483 4) 1807CQ Acestea fiind codurile pe original Primele 3 piese reprezinta 3 mici tampoane din partea dreapta sus a masinii, in locul prinderii motorului in caroserie, iar piesa 4 care reprezinta tampon antibalans si se afla intre motor si caroserie, undeva sub motor si trece planetara dreapta prin el. Ma intereseaza, in principal, daca pot gasi ultima piesa... Multumesc, |
lily_efs_2000 |
10 Mar 2012, 16:40
#532
mihiaser, aripi pe partea stg am, dar pt motorizari 1.2 benzina - 43kw; 1.4 benzina - 55, 70, 72 kw; 1.6 benzina - 66, 79 kw; 1.9 diesel - 47, 59 kw si 2.0 benzina - 124 kw.
Spoiler fata nu am. Daca te intereseaza am proiectoare ceata cu rame, becuri si cablurile aferente la 400 lei setul. Pe ele scrie Clio III, dar merg si pe masina ta. george_scala_2004 - piesele pe care le am sunt doar pt renault. LICHIDARE DE STOC - DISCOUNT INTRE 40-80% DOAR PIESE NOI ORIGINALE RENAULT id: pieserenault2009 Pt orice piesa am nevoie de datele de pe placuta ovala sau codul de original de pe piesa. Attached thumbnail(s) 7711236164_.JPG ( Size: 223.8k ) Number of downloads: 62 _7711236164.JPG ( Size: 249.98k ) Number of downloads: 36 DSC00472.JPG ( Size: 1.3mb ) Number of downloads: 35 DSC00473.JPG ( Size: 1.32mb ) Number of downloads: 40 DSC00474.JPG ( Size: 1.42mb ) Number of downloads: 42 DSC00475.JPG ( Size: 1.34mb ) Number of downloads: 25 DSC00477.JPG ( Size: 1.26mb ) Number of downloads: 28 |
renault
megane
- is 25 via
vali_mester |
11 Mar 2012, 10:22
#533
Membru incepator Group: Members Posts: 54 Joined: 24 October 10 From: Bucuresti |
Contactul de pedala frana la Clio bicorp 1,5dci.Multumesc
Renault Clio II
Bicorp-1,5dci
2004-BB08EF
- B02VHC
stoian87 |
12 Mar 2012, 20:45
#534
Stoian G Group: Members Posts: 9 Joined: 1 March 12 |
Salut,am un megane 1.6 16v, 2007 berlina si as dori sa stiu ce tip de electromotor are, pentru a.i schimba platoul carbuni.
nr identif. VF1LM1R0H38644449 TIP MOTOR K4M-D8... Va multumesc! |
Megane II
pieserenault2009 |
19 Mar 2012, 12:08
#535
Aveti pm.
renault
megane
- 98ran
oanavas |
19 Mar 2012, 18:27
#536
Membru autentic Group: Members Posts: 591 Joined: 14 April 09 From: Bacau |
Salutam, cumpar rola intinzatoare curea alternator motor k4m 812 1,6 16v cu clima
ai? codul pe original 8200608550 |
skoda fabia
Renault megane
2007 1,6 16 valve GPL
lily_efs_2000 |
26 Mar 2012, 15:11
#537
oanavas, nu mai am rola intinzatoare curea alternator motor k4m 812 1,6 16v cu clima. Este lichidare de stoc.
Attached File(s) piese_noi_originale_renault.doc ( 64.5k ) Number of downloads: 26 |
renault
megane
- is 25 via
L!nuX |
27 Mar 2012, 10:38
#538
Membru decent Group: Members Posts: 1.316 Joined: 4 January 08 From: Bucuresti |
Salut
Pentru un megane 1.6.16v 2007 82kw vf1lm1r0h38979174 placute frana fata pe sistem ATE - ma intereseaza ce producatori si preturi aferente aveti filtru polen - idem mai sus smile.gif |
Megane
1.6 16v - 2007
- Numar personalizat !
C R I S T I |
28 Mar 2012, 17:54
#539
Membru Group: Members Posts: 143 Joined: 27 March 12 From: Bucuresti |
Ma intereseaza si pe mine pt un Symbol 1.5 dCi din 2007, placute fata TRW, filtru motorina si un filtru de polen.
Multumesc anticipat! |
Clio Symbol 1.5 dCi
megane1 |
30 Mar 2012, 06:49
#540
Membru autentic Group: Members Posts: 793 Joined: 27 March 07 From: Moinesti |
salut. ma intereseaza placute de frana fata pt megane 2 1,6 16 v sin 2007. cred ca TRW sunt cele actuale; si discuri frana fata
renault
megane2.2
privilege 1,6 16v mai 2007 privilege, gris platine+mp3
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th June 2024 - 22:18 |
