Cruise control duster dci 110, Install a cruise control
friendxconnect |
20 Jul 2021, 11:45
Membru incepator Group: Members Posts: 1 Joined: 20 July 21 |
Duster
Dci 110 2013
alfabit |
21 Jul 2021, 06:49
Membru autentic Group: Members Posts: 447 Joined: 26 September 09 |
Yes this is true, diesel injection ecus fitted on Dusters include the mapping for cruise control / speed limiter from the early models DCM12, DCM34 to the latest EDC17Cxx-SID30x
We have around here a colleague that successful activated ccsl on a Logan 1 first generation diesel DCM12. The only issue for duster ( x79 ) ph1 is the dashboard which doesn`t accept displaying ccsl speed and you will set it "on blind" never know precise the speed you set for ccsl So for x79ph1 the dashboard not accept ccsl and you will have no speed displayed on the lcd, for the ecu is possible but it will be a nightmare to drive that car on ccsl engaged You never mentioned the generation phase for your duster, if x79 ph2 you are happy man, activate ccsl is straightforward you could modify that duster and the result is as the factory does. |
patru cilindri
201x
tavi_ro |
22 Jul 2021, 18:01
Membru autentic Group: Members Posts: 868 Joined: 11 September 05 |
Pe o interfata OBD eventual cu Bluetooth nu poate fi afisat pragul la care se seteaza cruise-ul ?
Duster
Laureate 2012-1.6 16V, 4x4, GPL Tomasetto Stag4
Q-Box plus Logan Laureate 2005-1.4 MPI
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th May 2024 - 07:23 |
