It is snowing, Would using reinforced snow chains damage ABS
Aali |
![]() PAT PAT Group: Members Posts: 41 Joined: 20 July 08 From: Kerman, IRAN ![]() |
Iran Khodro
2008-2013 Logan facelift Automatic
![]() fan Dacia Group: Members Posts: 20.115 Joined: 12 November 05 From: Bucuresti ![]() |
I have seen more than one Logan ABS sensor wire riped by snowchains, even when used for 100m. Stick to good winter tyres and you should be fine.
- negru pe alb
fnp |
![]() Membru autentic Group: Members Posts: 446 Joined: 5 November 03 From: Bucuresti ![]() |
I used snow chains at mountain for about 8 km with no problem. Watch out the correct size and montage. Remember to check and tight again after the first 100m of driving with them.
And also watch out on clean road (no snow or very few). Is danger to rip off the chain and this will make some damage to the car. This post has been edited by fnp: 22 Dec 2009, 09:33 |
MCV 1.5 DCI 70CP
2007 Laureate + ABS
- B
martin245 |
![]() EX PAT Group: Members Posts: 913 Joined: 1 April 06 From: Karlsbad Germany (again) ![]() |
You dont need to use snow chains nowdays just get a good set of winter tyres and you will be ok (or even better all weather tyres)
Stu |
logan 14 mpi Simply RED
- GB 1 Bessy Regs
VyRuZ |
![]() Chauffeur du Renault Group: Members Posts: 1.099 Joined: 3 December 09 From: București ![]() |
Forget about all-weather tyres. They're no good on snow or ice. Just get yourself a proper set of WINTER tyres. The difference, you'll find, is amazing.
As for the chains, if you install them properly, no damage shall occur to your ABS sensors. |
Megane 2.2 Coupe, 1.5 dCI, 63 KW,
09/2007
- B-***-**F If it ain't broke, don't fix it.
martin245 |
I have driven with Winter Tyres now for over 28 years on and off and I have tried the All weather from Conti and they are Very Good we have come a long way now regarding Tyres
Chains should only be used as a last resort .I would not recomend them though But if you MUST fit them remove them ASAP |
- GB 1 Bessy Regs
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th June 2024 - 10:54 |
