Jurnal de Pilif (sau Filip), Un jurnal despre travel car and expierience.
Filip |
4 May 2021, 21:12
#841
Forumist Group: Members Posts: 2.905 Joined: 23 July 09 |
Attached thumbnail(s) Capture.JPG ( Size: 94.02k ) Number of downloads: 935 |
tomageorgian |
6 May 2021, 12:23
#842
Membru autentic Group: Members Posts: 1.335 Joined: 22 February 10 From: Franta |
. Latitude 2.0dCI
Laguna 3 2.0dCI ex C5 x7 2.0hdi Logan 1.6mpi Bmw e39 530D Laguna 3 2.0dCi Qashqai 1.5dCI Twingo 2 1.2i Bmw e28 520i |
CT-05-DGP |
7 May 2021, 13:26
#843
Membru autentic Group: Members Posts: 243 Joined: 26 January 07 |
Filip , so pe ea...solnita.
Pune poza cu laguna la lumina zilei. |
Megane 4 Estate
1.5 dci Ex. Renault Laguna 2 1.9 dci Ex. Renault Clio Symbol 1.4 mpi
dizzy |
7 May 2021, 14:58
#844
O Dracie Leberta doriti? Am zarit una, pare abandonata dar daca ii dai de-o bere, cred ca o vinde
Whirpool
ex Dacia Logan
Muttley |
7 May 2021, 17:14
#845
__________________ Group: Members Posts: 12.998 Joined: 4 September 04 From: - |
Am vazut o Liberta astazi, Dacia 1325 intreaga, visinie, toate elementele la locul lor, numere de Brasso.
Era oprita pe marginea drumului, soferake un batran, sotia era afara, posibila incontinenta. Chiar imi pare rau ca n-am oprit ca s-o sperii pe femeie si sa-i felicit pentru masina. Dar aia nu-i de Pilif. This post has been edited by Muttley: 7 May 2021, 17:14 |
1310 TLX
Victorine |
7 May 2021, 17:29
#846
Inaintr sa montezi clapeta aia la loc ar trebui sa iei in considerare sa schimbi si garniturile astea. Toate.
L.e. mamă, ce m-am bronzat la pescuit de Paște ... This post has been edited by Victorine: 7 May 2021, 17:32 Attached thumbnail(s) 20210507_182654.jpg ( Size: 2.64mb ) Number of downloads: 793 |
Toyota
Auris Touring Sports HSD
2014
Filip |
8 May 2021, 08:47
#847
Dap, am schimbat garniturile alea 4 + cea in forma de ou (care devenise rigida de la caldura banuiesc, si cand am scos-o din galerie, a iesit pe bucati).
Numai ca nu am luat originale, ca cele din poza ta, sunt negre... a avut originale pe ea (mai putin garnitura in forma de ou, care era aftermarket tot neagra). Dar sunt ok, aveau aceleasi dimensiuni. Garniturile alea mari de la corpul clapeta le-am luat pe original. EDIT: Pe capota la solenza aia cred ca s-a turnat diluant de aia s-a exfoliat vopseaua asa. EDIT 2: Deci am avut un vis... ca lucrez de noapte si dupa ce am dat reply-ul asta cu garniturile, m-am pus sa dorm. Am visat ca mi-am loat prima mea masina noua. Dar nu oricum, am gasit un kit-car de la chinezi, si ma apucasem eu sa-l asamblez. Si era ca un reliant robin, adica cu 3 rotzi, avea motor 2 cilindri cam ca lastunul, dar fitzi atenti aici, spatele avea un design de Logan 1 pre-facelift, cu portbagaju ala al ei de berlina, dar nu avea geam pe spate, avea soft top de la jumatatea plafonului in spate (ca la un Landaulet) si soft-top-ul se plia in spate ca la fiat 500. Si avea 4 usi. Deci nu ca Reliant Robin, mai rau, si mai grea caroserie pentru motorasul meu. Si cum asamblam eu asa in spatele blocului au venit vecinii sa-mi fure din piese si am facut scandal si a venit politia da si politistu care venise era de fapt fals politist si ala mi-a furat ce mai ramasese din kit-u ala de masina ce il asamblam eu in spatele blocului. Si asta fu visu. Doamne daca aveam talent la desen faceam o schitza cu masina, era smechera rau. Small three wheeler cu 4 usi landaulet cu spate de logan (portbagaju ala ridicat, stopurile si bara spate). Dar fiiind copie chinezeasca doar designu era de logan, asa toata masina era mai mica ca un logan, si bara spate se asambla din 3 bucati la la daciile alea CN2 cu bari de plastic patratoase. Un vis ce sa mai! EDIT 3: de ce n-am visat ca am asamblat-o la curte ca era gata acu. SI din fatza arata frumos, roata aia din fatza era mai expusa ca la reliant, avea aripa ca la scuteru Vespa, si in spatele ei grila la motor si partea din fatza arata cam ca la un Plymouth Prowler. This post has been edited by Filip: 8 May 2021, 14:14 |
dizzy |
8 May 2021, 21:44
#848
Whirpool
ex Dacia Logan
CT-05-DGP |
10 May 2021, 11:16
#849
QUOTE(dizzy @ 8 May 2021, 22:44) Ce caterinca, cu putina imaginatie poate sa iasa ceva frumos din ea. |
Megane 4 Estate
GBX |
10 May 2021, 11:21
#850
Membru autentic Group: Members Posts: 581 Joined: 26 May 13 From: aproape de Cluj |
Puntea spate e visul oricărui constructor. Lăsând frumusețea, incontestabilă, la o parte, cred că și stabilitatea es de vis.
ex. Renault
19 Europa
1997
bucatzel |
10 May 2021, 11:35
#851
Membru plictisit Group: Moderatori Posts: 6.224 Joined: 19 May 08 From: Timisoara |
Babaieti, amu' sincer, ala e prototip. O fi strutocamila de dacie cu aro, dar tot prototip e. ca si asta, de altfel. Cat naiba sa ceara pe ea, bani de o pizza?
1981
bion |
10 May 2021, 11:52
#852
Un aro 10- tusea si caroserie de dacia-junghiul
SLZ Scala
Muttley |
10 May 2021, 11:53
#853
Nu e unicat Dacia+Aro=Love ala. Eu am vazut si live, cand eram copil.
1310 TLX
marksman |
10 May 2021, 12:27
#854
Post mortem nihil est Group: Members Posts: 7.462 Joined: 1 November 04 From: sat |
Au făcut vreo 10 în total, majoritatea destinate MApN. Coana Leana a obiectat că mașinile sunt urâte și în RSR nu se vor fabrica mașini urâte.
Opel / Mazda
Crossland X / CX-30
2019 / 2020 Charlie Foxtrot
AmunDei |
10 May 2021, 13:20
#855
Fără turbo viața e pustiu... Group: Members Posts: 1.985 Joined: 8 June 07 From: Cucuveieni Deal |
QUOTE(bucatzel @ 10 May 2021, 11:35) Babaieti, amu' sincer, ala e prototip. O fi strutocamila de dacie cu aro, dar tot prototip e. ca si asta, de altfel. Cat naiba sa ceara pe ea, bani de o pizza? Eu nici degeaba nu as lua-o. O gramada de fier inutil. Ar fi buna de cotetz de gaini si asta, totusi, ca alta utilitate nu-i vad. |
10 May 2021, 13:23
#856
fan Dacia Group: Members Posts: 19.908 Joined: 12 November 05 From: Bucuresti |
Ala a fost suv inainte sa se faca vitara.... istorie!
cj98czh |
10 May 2021, 13:29
#857
Membru de la Cluj ... Group: Moderatori Posts: 22.852 Joined: 27 March 06 From: Cluj-Napoca |
ooo da ... este tata SUV-urilor te pomenexti ...
Ford Mondeo
Titanium, bi-turbata, 2018
/ Mazda 3 , 2018
10 May 2021, 13:32
#858
http://masinistul.ro/filme/aro-16-crossoverul-ancestral/ era o ironie!
marksman |
10 May 2021, 14:42
#859
QUOTE(AmunDei @ 10 May 2021, 13:20) Eu nici degeaba nu as lua-o. O gramada de fier inutil. Ar fi buna de cotetz de gaini si asta, totusi, ca alta utilitate nu-i vad. Dac-aș face un muzeu al autoturismelor românești, poate că aș da banii, să vadă lumea ce s-a putut face pe vremurile socialismului multilateral dezvoltat. |
Opel / Mazda
Crossland X / CX-30
10 May 2021, 15:00
#860
este unu la dl Hagi, la Campulung.
dizzy |
10 May 2021, 15:23
#861
Whirpool
ex Dacia Logan
CT-05-DGP |
10 May 2021, 15:30
#862
TV-urile erau cele mai frumoase.
Megane 4 Estate
dizzy |
10 May 2021, 16:23
#863
Calutul cocosat ala?
Desenat la betie? Singura care arata nehidos e TV35 cu punte cu roti jumelate https://www.promotor.ro/stiri-auto/tv-prima...-video-14924616 Avea un prieten de familie o firma la care cumparase 3 troace din astea Una nu mergea, alta nu frana, una mergea acceptabila, o benzinara dar manca ca porcu; niste gunoaie. A luat intai un VW T2 , ala mergea cat cele 3 TV-uri la un loc. apoi un T3 , Apoi a luat DAMAS. Tico pe steroizi acuma are vreo 6 T5-uri This post has been edited by dizzy: 10 May 2021, 16:38 |
Whirpool
ex Dacia Logan
Muttley |
10 May 2021, 16:53
#864
QUOTE(dizzy @ 10 May 2021, 17:23) La cum arata, asta-i vine manusa lui Pilif, asa, nostalgic cum e el. Ar dormi, manca si... rezolva rebusuri in ea |
1310 TLX
CT-05-DGP |
13 May 2021, 14:41
#865
Cand aveam 3 luni daca imi dadeai un creion si o foaie tot desenam o masina mai frumoasa decat tv
Filipe unde esti bro? mai zii si tu ceva, ce ai mai facut cu masinile |
Megane 4 Estate
Filip |
14 May 2021, 16:38
#866
Nu prea am mai avut ce sa postez...
Attached thumbnail(s) scurge_fierrari.JPG ( Size: 62.75k ) Number of downloads: 444 |
17 May 2021, 07:57
#867
foarte fin parcata totusi...
wolfin |
17 May 2021, 11:08
#868
n-am gasit cu dacia Group: Members Posts: 7.905 Joined: 2 December 05 From: Bucuresti |
asa am parcat si eu..sambata fin...vineri sunt la constatare...bandou roata spate..usa pasager si oglinda (nu sticla ..ca aia a ramas intreaga)
This post has been edited by wolfin: 17 May 2021, 11:13 |
pegas
3120
Filip |
30 May 2021, 23:00
#869
Intre timp Laguna mea functioneaza f bine. Ma lasa la scara blocului, se suie pe borduri, nu se aburesc geamurile cand ploua si daca selectez incalzire oglinzi nu am treaba, stergator luneta, hatchback mare, ce mai e masina ideala. Si merge blana deci n-ai treaba. Directie, frane, suspensie, motor - n-ai treaba cu ea. Deci nici nu simt ca am masina asa bine merge. Nu ma streseaza cu nimic.
Attached thumbnail(s) 20210530_211559_HDR.jpg ( Size: 81.15k ) Number of downloads: 267 20210530_211614_HDR.jpg ( Size: 76.84k ) Number of downloads: 166 20210530_211633_HDR.jpg ( Size: 148.1k ) Number of downloads: 170 |
dandobre |
31 May 2021, 07:26
#870
Membru autentic Group: Members Posts: 3.120 Joined: 3 August 12 From: Ilfov |
Ce bine îi stă la ghena de gunoi...
Ford, Suzuki
Focus 3 combi, SxCross
2016, 2018
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th April 2024 - 02:32 |
