Engine and fuel system, Check fuel path
ekoproba |
26 May 2011, 20:25
Membru incepator Group: Members Posts: 2 Joined: 26 May 11 |
1.4 2006
26 May 2011, 22:57
faulty cranckshaft position sensor-CKP sensor !
try to unmount and clean it with a brake-cleaner spray ! 1-CKP sensor.... Attached thumbnail(s) senzor_turatie.jpg ( Size: 28k ) Number of downloads: 380 |
ekoproba |
28 May 2011, 19:02
Hi Sobolan!
Thank you for your help! I have cleaned the sensor but the problem remained. Do you have anyother suggestion for the problem? |
1.4 2006
pollux83 |
12 Jun 2011, 21:30
Membru incepator Group: Members Posts: 5 Joined: 21 September 10 From: SE France |
I think the suggestion of a faulty crankshaft position sensor is a good one. I had a similar problem (of the car not wanting to start, or cutting out) in a Renault Megane I which had the same type of engine. The most serious occurence was when the engine stopped in the middle of a wildlife park!
The sensor can deteriorate with time (I believe it's an electromagnetic device) and it's well worth replacing it, not just cleaning it, to see if it solves the problem. The sensor is not expensive (less than 40 euro I think). Hope it helps! Pollux |
2010
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 5th May 2024 - 12:06 |
