1.6 MPI 2005, Nu isi pastreaza relantiul
Luka2606 |
19 Feb 2024, 19:07
Membru incepator Group: Members Posts: 2 Joined: 19 February 24 |
Attached thumbnail(s) WhatsApp_Image_2024_02_20_at_17.28.30_acb34cec.jpg ( Size: 386.41k ) Number of downloads: 134 |
- GL26SNU
YRX |
20 Feb 2024, 18:03
Membru autentic Group: Members Posts: 4.877 Joined: 6 July 06 From: Bucuresti |
Acolo nu trebuie sa fie nimic, e rampa injectoarelor.
Ai o problema cu partea de aer. Fie a crapat galeria, fie vreun senzor din ea, fie corpul clapeta. Da jos carcasa filtrului si ia la verificat de la corpul clapeta in jos. |
2005 Ambition 1.6 MPI
Luka2606 |
9 Apr 2024, 16:11
Am fost cu masina la service , am schimbat senzorul de presiune si motorasul pas cu pas si masina porneste si merge normal, am cumparat un tester ulterior pentru o alta masina cu service key si am zis sa vad si checkul la logan (masina in cauza cu service key un renault megane 2 1.6 16v)
Urmatoarele erori: P0105 - Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - circuit malfunction P0135- Heated oxygen sensor (HO2S) 1, bank 1 ,heater control-malfunction Dupa stergere a reaparut doar P0135 Insa din pacate m-a parasit si evacuarea (sparta) , ma gandesc ca poate fi si asta . La imbinarea dintre cea finala si intermediara. WhatsApp_Image_2024_04_07_at_17.52.29_e124037e.jpg ( Size: 157.61k ) Number of downloads: 89 |
- GL26SNU
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 20th September 2024 - 23:15 |
