Prețuri piese, Numai piese NOVA
C a t a l i n |
Executron |
Tripla spate (dispersor/geam stop) = 20 RON
Semnal Fata = 14 RON Semnal Lateral = 7 RON Sursa = Vitan Filtru Aer Nova original = 13 RON Cablu Ambreiaj = 30 RON Bloc Lumini Original = 250 RON Bloc Lumini Import = 50 RON Sursa = Magazin Dacia EDIT: Ar trebui facut Lipicios! This post has been edited by Executron: 1 Feb 2008, 14:01 |
VW Passat
apollo |
![]() Membru autentic Group: Members Posts: 1.881 Joined: 20 August 05 From: Focsani ![]() |
Rulment Fata - 35 RON(Alexandria)
Fulment Spate - 28 RON(Alexandria) Calorifer Nova(Import) - 47 RON Calorifer Nova (Original) - 180 RON Disc Ambreiaj(Import) - 78 RON Etrier Nova - 105 RON Bucsa Timonerie - 2 RON/buc Bucsa amortizor(prindere cu puntea spate) - 5,5 RON Tripla Nova/SuperNova - 68 RON Port Fuzeta - 155 RON Rulment Presiune - 40 RON Cheder Parbriz - 30 RON Electro valva carburator stock - 40 RON Carburator dublu corp - 550 RON Radiator - 450 RON Bieleta Topoloveni - 65 RON Bucse bara anti ruliu - 2,5 RON/buc Pivot ASAM - 18 RON Bucse bascula - 5 RON Furtun frana - 16 RON Bloc lumini import - 60 RON Bloc lumini original - 180 RON Maneta stergator - 80 RON Cadru motor - 350 RON Set fete usi Nova/SuperNova(4 buc) - 350 RON Schelet lateral fara usi si aripi(doar stalpii,semiaripile si pragurile) - 500 RON(nu stiu cum se numeste exact aceasta piesa) Amortizor fata - 130 RON Amortizor spate - 100 RON Amortizor hayon - 32 RON Set incuietori(Usi-hayon-buson) - 180 RON Cablu acceleratie - 25 RON Cablu deschidere capota - 20 RON Siguranta capota - 20 RON Pompa benzina import (carburatie) - 45 RON Sursa - Focsani LE - Sa incercam sa spunem si producatorul pentru ca sunt piese bune si mai putin bune, ca sa stim dupa ce sa ne orientam. This post has been edited by apollo: 1 Feb 2008, 15:27 |
Ex - Dacia
Nova GT 1.6 L
1997
- VN - ?? - ???
Oelash |
Membru incepator Group: Members Posts: 47 Joined: 19 May 07 From: Ploiesti ![]() |
hmm...cred ca mai este un topic asemanator...numai ca e pt SN
![]() Bobina inductie - 350 ron Iatsa Campina Motorasul acela cu shocul electric - 300 ron undeva din ploiesti |
nova
1.6 2000
- ph-69-plm
MIHAI8888 |
![]() Membru autentic Group: Members Posts: 392 Joined: 1 September 07 ![]() |
motoras relanti 220 RON (bosch)
pompa benzina import 125RON originala 185RON maner deschidere usa interior 20RON tablou bord complet 300RON releu far 5 RON set bucse electromotor 4 RON cap planetara portfuzeta 65 RON sursa ; diverse magazine de piese din iasi |
vw golf
fost nova
1998 gti
vioara |
Membru autentic Group: Members Posts: 212 Joined: 1 November 07 From: Bucuresti ![]() |
pompa benzina cu returul taiat 61 ron
Clio 1.5
barbutu |
![]() Membru autentic Group: Members Posts: 466 Joined: 22 May 07 From: pitesti ![]() |
-filtru aer RomCarbon-10 lei
-filtru benzina RomCarbon-12 lei -pompa benzina electrica-90 lei -capota-220 lei -aripa fata-85 lei -rulment fata-30 lei -capat de bara-20 lei -saboti frana(de srl)-45 lei -parbriz-145 lei -cheder parbriz-30 lei -incuietoare capota-39 lei -siguranta capota-10 lei -semnalizari-9 lei Preturile sunt valabile in pitesti,preturile variaza in functie de magazin,pentru piese de origine si ieftine recomand un magazin care se afla pe centura situat la intrarea intr-un service auto(dupa statia peco Petrom pe partea dreapta este un magazin mare) |
megane
2010
vioara |
bujii sinterom 14 np 18 16 ron
capac delcou 7 ron |
Clio 1.5
*SouL*PAnaIT* |
![]() Membru incepator Group: Members Posts: 68 Joined: 20 January 08 ![]() |
-Caseta directi(am pus de super nova) -150 RON
-Electromotor -80 RON -Stopuri spate complete -120 RON -Semnal fata dreapta 14 RON -Majoritatea sunt din Vitan,iar restul Magazin dacia din Buftea. |
NOVA
GT 1.6L 1997
- IF89PAN
ALPU |
Membru Group: Members Posts: 197 Joined: 2 August 07 ![]() |
Electromotor 80 ron la sh poate nu?Ca nou e 500 ron in iasi la Trio-Rom Podu de Piatra
Daewoo
matiz
- xx- xx- xxx
*SouL*PAnaIT* |
Normal ca la SH in bani astia,si sunt foarte multumit de el;)
NOVA
GT 1.6L 1997
- IF89PAN
crystygye |
![]() Membru autentic Group: Members Posts: 392 Joined: 14 August 06 From: Bucuresti ![]() |
Capac pompa apa 50 Ron
Pinion cablu kilometraj 5 Ron Intrerupator usi 3 Ron Magazin piese originale Dacia de langa statia de metrou Dristor 2. |
Fiesta
2007 facelift 1.3 benzina, 51kw, jh1 https://portalultautv.net
lvl100 |
Membru incepator Group: Members Posts: 45 Joined: 5 November 06 ![]() |
servo frana = 90
pompa frana - 130 cilindru frana - 40 A mai vazut cineva prin magazine macara de geam (cea de la sofer in special) sau nu mai exista asa ceva prin magazine ? This post has been edited by lvl100: 3 Feb 2008, 10:07 |
Nova GT
1998
apollo |
Macara geam fata - 85 RON(am vazut toamna trecuta in Buzau) - acum nu stiu daca mai au asa ceva.
Ex - Dacia
Nova GT 1.6 L
1997
- VN - ?? - ???
gti98 |
Off topic: macarale sunt mai multe modele; daca nu vreti sa umblati cu macaraua in mana si cu masina cu geamul scos in parcare, aveti in vedere ca piesa care se uzeaza e angrenajul dintre axul manivelei si spirala care actioneaza geamul (mai precis pinionul de pe axul manivelei) eu am cumparat o macara care nu mi s-a potrivit (am dat in jur de 50 de lei acum un an) si i-am taiat cele 4 nituri care fixau axul cu pinion al manivelei pe care l-am inlocuit; am pus 4 suruburi de 5 cu contrapiulite. Axul e un pic mai lung, dar nu ma deranjeaza foarte tare (am facut o rotatie cu un ax de la o macara spate)
Defectul era foarte suparator: cadea geamul in mers, iar in parcare geamul putea fi deschis apasind cu palma in jos... Scuze!!! |
Dacia Nova GTI
GTI 98
- IS 57 ENB
mihail_73 |
Membru Group: Members Posts: 106 Joined: 21 June 07 ![]() |
Frana de mana = 62 RON
Filtru ulei = 8 RON Filtru aer = 12 RON Carburator Carfil de 1400 = 265 RON Electropompa parbriz ~ 30 RON Stergator parbriz = 7 RON Langa Autogara Militari Ptr vioara: la nova se foloseste Sinterom 14NP21. 14NP18 nu rezista mult in timp |
NOVA GT 1600
1998
crystygye |
Cumparaturi azi:
Aparatori vant (disponibil in 3 culori:rosu,albastru,fumuriu (fumuriu mi-am luat) , set pentru toate 4 geamurie + cadou un suport de numar reflectorizat 45 ron Maneta deschidere usa interior 25 ron buc Manivela interior deschidere/inchidere geamuri 6 ron bucata Claxon 2 sirene una groasa una subtire (se aude tare rau) 13 ron "Nuca" schimbator de viteze cu marsalier pentru nova 20 ron Husa schimbator viteze 5 ron Targ Vitan |
Fiesta
*SouL*PAnaIT* |
Sergatoare 10 ron
Mi lea furat in parcare:)))) |
NOVA
GT 1.6L 1997
- IF89PAN
smecheras |
![]() Tuning Fanatic ... Dacia rullz Group: Members Posts: 268 Joined: 18 September 06 ![]() |
Nova GTi
2000 1.6
- B 60 FGD
C a t a l i n |
QUOTE(MAERSK @ 1 Feb 2008, 13:23) Pentru o căutare ușoară, cred că ar fi indicat ca în acest topic să se scrie doar prețuri piese, [B]nu și întrebări legate de unde găsesc, nu știți cât costă, etc...[/B] Dacă aveai bunăvoința să cauți puțin, găseai care este diferența... Că de asta e totul amestecat pe aici, de lene... |
apollo |
MAERSK , tot respectul pentru topicul acesta.
As vrea sa mai adaug ceva ca sa nu mai apara off-topic-uri.Scuze pentru al meu. Pentru orice piesa, sau orice detaliu legat despre o piesa/piese, folositi PM-ul(Private Message). Si daca se poate, sa incercam sa punem mai multe piese intr-un post. MAERSK, ceva de adaugat? Scuze pentru off-topic, again ![]() |
Ex - Dacia
Nova GT 1.6 L
1997
- VN - ?? - ???
smecheras |
mdea...
n-are rost... set motor dacia 1600 - 400 RON Sonda presiune ulei - 32 RON ms apollo pt pm This post has been edited by smecheras: 9 Feb 2008, 16:23 |
Nova GTi
2000 1.6
- B 60 FGD
Paul Gabriel |
![]() Membru autentic Group: Members Posts: 590 Joined: 16 October 07 From: Cluj-Napoca ![]() |
Se mai adauga
pereche pinionul viteza 5: 120 lei rulment viteza 5: 20 lei furca viteza5: 30 lei furca viteza 1-2: 72 lei din magazin, 140 lei adusa la ''comanda'' manopera: 280 lei semering planetara: 4 lei placa presiune: 122 lei |
Suzuki/Audi
GSXR/A4
- CJ XX RUN -----------
ALPU |
Smecheras setul motor de 1600 este nou si original dacia la 400 lei?
Daewoo
matiz
- xx- xx- xxx
Executron |
Filtru Ulei - 25 RON (nu mai stiu ce tip, era rosu)
Filtru benzina - 10 RON (scrie renault pe el) Sursa Vitan. |
VW Passat
smecheras |
dap setul motor este nou si original dacia 400 ron
am vazut luna trecuta la magazinu din fata la crist tim (bucurestii noi) placa presiune 150 ron |
Nova GTi
2000 1.6
- B 60 FGD
mihai0070 |
preturi piese:
supape evacuare (identice ca la ori ce dacie): 45 ron carnitura chiuloasa + garnitura evacuare : 25 ron pompa ulei (nu originala) 35 ron pinion kilometraj si bucsa : 20 ron (origine) sursa , magazin oltenitie berceni (la intersectia cu calea vitan) |
Dacia Nova LPG
Benzina
1997 GT Rosu 1600cc
- 1-B-5550
vioara |
bujii sinterom 14 np 21 20 lei
Clio 1.5
nikssark |
![]() Membru incepator Group: Members Posts: 57 Joined: 4 April 06 ![]() |
Are cineva idee cat costa aripile spate contraaripile spate si daca cumva exista protecti aripi spate pentru nova?
nova gt
99 decembrie
apollo |
Sonda Lambda - 140 RON
Ex - Dacia
Nova GT 1.6 L
1997
- VN - ?? - ???
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th June 2025 - 04:40 |
