2 Pages < 1 2
> Dacia Factory, Dacia fabrică
nh1980ro
post 8 Feb 2008, 19:11
@alinushy Please read the topic (post #7).
alinushy
post 8 Feb 2008, 19:31
modeLator
Audi A4 ... 1.8T...quattro ;)
frunza verde solz de peste, uite ..... altu` ca citeste
martin245
post 10 Feb 2008, 01:15
EX PAT
Here is a great monitor cleaner and this works very well
my monitor is SUPER CLEAN
http://mirrored.flabber.nl/boob.cursor/ciagnijcycka.swf
stu
dacia logan 14 mpi Simply RED 2007 - GB 1
Bessy Regs
adrianne
post 21 Feb 2008, 22:07
I've just discovered I need a bigger monitor, eg. 21" or more... radmasa.gif
Dacia 1310 L 1996 - B44UCJ
parerea unui amator...
rashv
post 27 Apr 2008, 20:05
Hey, What happened to your head light issue??
Mahindra Renault Logan 1.6 GLX 2008 - TN 23 AE 6999
martin245
post 27 Apr 2008, 20:23
EX PAT
I hope to be having a set sent from India in May to Scotland
There is a French Girl who is also moving to the UK
who has kindly offered to help me
Now all I need is a Tacho in Miles ....or one from a scrapyard that I can
do myself .But we do not get any Logans onour scrapheaps
Stu
Bessy Regs
Twingoman
post 28 Apr 2008, 12:54
From memory, I think the actual dash unit may be the same as the Clio, although I may be wrong.
Renault Twingo 2002 Helios - WK51JVL
martin245
post 28 Apr 2008, 14:05
EX PAT
I will check that one out
Stu
Bessy Regs
ga!nusha
post 28 Apr 2008, 18:36
Still here
from what i know, some parts are the same, but the actual dashboard doens't fit...
Mazda 3 MPS ex: Logan Preference+AC 1.6 2oo8
Peja
post 29 Apr 2008, 18:27
I hope that some facory worker will read this question/problem:
I've ordered Logan 1.4 Preference+AC but because of strike in Dacia delivery will be late mad.gif .
Peja
This post has been edited by Peja: 29 Apr 2008, 23:35
Dacia Logan 1.4MPI Preference + AC Apr 2008
http://loganimprovements.blogspot.com
GabrielD
post 31 May 2009, 15:42
Hi Stu,
I think I have the same problem with my Logan. I am Romanian and I have been living for 3 months in UK. Now I want to register my Logan here in UK and some changes need to be done, including the headlights.
Would you please tell me how you did eventually manage to replace your Logan's headlights with RHD ones?
This would be a valuable piece of information for me as I am not sure how to proceed next. I think there aren't many Logan drivers in UK so your help would be much appreciated.
Also if you could advice me on speedometer and rear fog lights.
These days I am also looking for a Renault Center for my 60000 km servicing. I found Bristos in Ipswich, but they are not sure on what belts need to be replaced (alternator belt, cambelt).
Thank you very much for your help!
Any suggestions welcome!
Gabriel
This post has been edited by GabrielD: 31 May 2009, 16:07
Dacia Logan 2006 LaureatePlus(ABS) 1.4 MPI
post 31 May 2009, 16:51
If you use the romanian maintenance program, both belt kits should be replaced (that's timing and accesory). If you use the french one, change them at 120 000 km. Also, it would't be a bad ideea to change the water pump as well if you do the timing belt kit.
GabrielD
post 1 Jun 2009, 23:20
Thanks, Einstein!
Any idea about the headlights?
post 2 Jun 2009, 07:40
None whatsoever. All I cand do is get you the part numbers if you want them and see if a renault dealer can provide them for you (that's the hard part).
GabrielD
post 2 Jun 2009, 14:08
Ok, thank you. The part numbers should help me.
razvanamza
post 8 Dec 2009, 23:02
Membru Numarator
Hi there.....
I want to bring to your attention that not only the headlamps need to be changed, but also the tail lights. In England you get fog lamp on the right side of the car. In Romania it is on the left. Try contacting Mahindra Reanult....the have both the headlighs and the tail lamps. Or you can buy tuning ones, and cross-change the red plastic on your tail lights for the fog lamp and reverse...hope you understand by "turkised" english.
This post has been edited by razvanamza: 8 Dec 2009, 23:04
Dacia Oarecare Candva - Bz-00-xxx
(\__/)
(='.'=) This is Bunny. Copy and paste Bunny into your
(")_(") signature to help him gain world domination.
2 Pages < 1 2
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 17th July 2025 - 00:10
