boxe dacia, :D
boxe dacia, :D
Crow45 |
![]() Membru incepator Group: Members Posts: 14 Joined: 16 February 08 ![]() |
1997
mad toz |
![]() fan dacia-reno Group: Members Posts: 1.334 Joined: 26 January 07 From: Bucuresti ![]() |
Cu "soricelu'".
This post has been edited by mad toz: 23 Feb 2008, 23:14 |
1998-Berlina Motor 1,6 8v ,72 HP , 125 Nm 2004 Renault 1.9 8v , 120 HP , 300 Nm
Sergeant Pulatchewsky |
![]() Membru incepator Group: Members Posts: 83 Joined: 23 February 08 ![]() |
Soricelu???? (Mouse)?
Mai bine taie cu fexu si dupa aia cu pila faci frumos rotud. Spor la treaba. ![]() This post has been edited by Sergeant Pulatchewsky: 23 Feb 2008, 23:18 |
Berlina
1998/1310
mad toz |
Asa zice baietii.
Fierastrau pendular.E mai bine? ![]() Cu flexul te chinui ,mai ales dupa sa mai dai si cu pila. Vezi ca la fierastraul ala trebuie sa pui panza de fier ca sa tai tabla aia. |
Rafi |
![]() e doua bleu!! Group: Members Posts: 1.204 Joined: 27 November 07 From: ™Bucharest™ ![]() |
scoti bancheta scoti si lemnu ala care se afla in spatele banchetei faci un sablon dupa difuzor te pui la plaja in portbagaj faci semn dupa sablon dai cateva gauri(sa poti baga panza) da vezi sa nu spargi luneta si o iei incet incet cu soricelu. BAFTA nu e greu nu dureaza mult.
PS sfat de la mine poate au facut si alti asta pune un placaj de 3 4mm peste tabla si prindel in nituri o sa faca bine la bass. ![]() ![]() ![]() |
Dacia™
1310----CN----
--1996-- Daewoo™ Nubira II --CDX-- --2006--
mad toz |
Stiu ca sablonul il gasesti in cutia de la boxe.
Daca face bine la bass, atunci neaparat trebe bagat placaj.
Berlina
1998/1310
adrianne |
Membru autentic Group: Members Posts: 518 Joined: 9 September 05 From: Bucuresti ![]() |
Dacia are caroseria moale, gaurile o slabesc. Eu am boxe aplicate pe spate.
1310 L
1996
- B44UCJ parerea unui amator...
razvan_3asy |
![]() membru cu permis :D Group: Members Posts: 569 Joined: 3 August 06 ![]() |
De bass ai nevoie, sa cada tabla dupa ea
![]() ![]() on: in vitan 30ron si ti le monteaza aia, asta daca n-ai butelie de gaz (ar costa 50ron). |
2008 Laureate 1.4 benzina :X B-50-HCR
Rafi |
Dacia™
1310----CN----
ANTIdacie |
![]() Membru autentic Group: Members Posts: 407 Joined: 13 December 05 ![]() |
sau mai poti taia si cu o foarfeca de dabla asa cum am facut eu dupa ce m-am chinuit cu un flex!
Harb de dacie
- DMITHEONE
SebyAvrig |
![]() Membru autentic Group: Members Posts: 351 Joined: 28 October 07 ![]() |
si io miam taiat tablaraia tot cu ferastrau pendular,dar urmatoarele 3 zile am fost surd total
VW
Golf
1993 GT 1.8 Prietenii imi bat in geam.Nu-i aud…am termopan
iuly82 |
Membru Group: Members Posts: 167 Joined: 17 July 07 From: Pitesti ![]() |
ce fel de panza ati folosit baieti? banuiesc ca nu din aia penala pentru lemn.....
- AG
Rafi |
eu am folosit una ordinara dar era pt fier oricum e bine sa ai 2 3 dupa tine ca nu se stie eu am rupt una m-am incapatanat sa tai cumva mai stramb si sa rupt panza
Dacia™
1310----CN----
GARFIELD 87 |
![]() Membru autentic Group: Members Posts: 212 Joined: 6 May 07 From: ploiesti ![]() |
eu am taiat cu flexul dar nu prea recomand din cauza aschilor de metal care s-ar in urma taierii aceste se lipesc de luneta si geamurile laterale si foarte greu se curata eu si aacum mai am ceva ramase din cauza ca se curata f.greu ... dar in lipsa de altceva merge si cu flexu
1410 8 valve
1998
- ph 00 aby
Sorin_18 |
![]() Membru autentic Group: Members Posts: 1.370 Joined: 26 November 07 ![]() |
1998
- B 29 AVR
viorel 77 |
![]() Membru Group: Members Posts: 169 Joined: 30 January 08 From: Bucuresti ![]() |
eu am taiat cu foarfeca de tabla. Dar trebuie sa indrepti marginea dupa.
Dacia 1310
Break
- B 26 DKR
Minel |
QUOTE(GARFIELD 87 @ 24 Feb 2008, 22:05) eu am taiat cu flexul dar nu prea recomand din cauza aschilor de metal care s-ar in urma taierii aceste se lipesc de luneta si geamurile laterale si foarte greu se curata eu si aacum mai am ceva ramase din cauza ca se curata f.greu ... dar in lipsa de altceva merge si cu flexu ![]() Asta s-a intamplat pt ca nu ai protejat luneta si geamurile spate , si eu tot cu flexu' mi-am taiat locasul pt boxe 6x9 si nu au fost probleme, intr-adevar iti trebuie putintica rabdare si ochelari de protectie neaparat ![]() |
1310-L /VW Passat
1995/1397cmc
8429kyd |
Membru incepator Group: Members Posts: 26 Joined: 21 January 06 ![]() |
Eu am dat cu bormasina gaura langa gaura(burghiu mic 3mm parca) apoi cu un patent rupi legaturile ramase,finisezi si cam atat.
Fiat
Albea
- CT-62-PVV
Kruger |
Membru autentic Group: Members Posts: 1.660 Joined: 18 August 05 From: Bucuresti ![]() |
Am fost la un atelier specializat. Mi-au luat 100 RON (acum un an) si au taiat si montat absolut totul.
Honda
Accord
2005, Sport Tourer Automatic 2.0 VITEZA NU UCIDE
OPRIREA BRUSCA DA |
psihoursu |
![]() posesor de Bugatti 1310 Group: Members Posts: 139 Joined: 15 August 07 ![]() |
poti sa o faci si cu flexu daca vrei sa schimbi si luneta
This post has been edited by argon: 25 Feb 2008, 19:01 |
1310/
1997
- B 04 MOC
Minel |
QUOTE(psihoursu @ 25 Feb 2008, 13:43) S-ar intampla daca ai doua maini stangi ,cu putina indemanare si rabdare poti face o treaba buna daca intr-adevar vrei sa faci cu mana ta si nu te dau banii afara ,daca nu ....la service si alti bani alta distractie ! |
1310-L /VW Passat
1995/1397cmc
Cu burghiul din gaura in gaura, tabla se gaureste usor si nu dureaza asa mult cum s-ar crede. Sau un pendular cu o lama pentru metal..asta e ideal.
psihoursu |
daca tai cu flexul sar putea sa iti arda geamul scanteile care sar de la flex
1310/
1997
- B 04 MOC
dani_devito |
![]() Membru extradat Group: Members Posts: 249 Joined: 24 October 06 From: Dublin ![]() |
Eu zic sa folosesti pendularu , desi si eu am rupt vreo 4 panze dar e mai "usor" si mai sigur decat cu flexu.
Dacia / Fiat
Berlina Li / Punto SX
2003 / 2000
- SB 87 SDI .... 70 % din problemele masinii se datoreaza piesei dintre volan si scaun.
thedragon |
![]() Sange de modovean aka GALATI Group: Members Posts: 583 Joined: 4 February 07 ![]() |
poate fi pus ceva pe luneta ca sa o protejeze de scantei
1989
kalyyyyyy |
![]() Membru autentic Group: Members Posts: 739 Joined: 1 November 06 From: Bucuresti ![]() |
Dupa ce am incercat cu flexul,bormasina, si un pendular(soricel) neprofesional am facut o pomana si am dat 30 de lei la service unde au injurat aia vre-o juma de ora.Ei au taiat tot cu pendularul si au rupt vre-o 4 panze(care daca nu ma insel sunt scumpe).Daca vrei adresa serviceului da-mi pm.
Clio
3
2007, dci 70cp
nicodinyss |
![]() Membru incepator Group: Members Posts: 9 Joined: 31 January 08 ![]() |
cel mai simplu este sa dai gaura langa gaura dar nu inainte sa te asezi confortabil in portbagaj si sa iti faci rost de o pereche de ochelari de protectie..... spor la treaba!!!:d
berlina cn
1999 1.4
- bh-05-yss
iuly82 |
si spanul acela incins iti cade pe fata......
- AG
AR-18-MOS |
@nicodinyss, si cu spanul ce iti intra in gura si iti cade pe fata ce faci?
BMW
730Ld
'07 High Executive
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 19th July 2025 - 03:25 |
