K9 Classic, Are cineva manualul de utilizare?
mariusrusu |
Membru incepator Group: Members Posts: 33 Joined: 18 February 08 From: Galati ![]() |
Laguna III 2.0 DCI
2008 Dynamique
mmgmarius |
![]() Invisible to everyone Group: Members Posts: 418 Joined: 21 December 07 ![]() |
Salut, manualul de utilizare il am eu. Sunt cam multe pagini, nu stiu cum sa ti-l dau. Poate reusesc sa il scanez. Tinem legatura si se rezolva.
Symbol Music 1.4 8V
dec 2007 Numai cei ce ies din tipar intra in istorie.
mariusrusu |
Ar fi minunat, poate reusesti.
Multumesc |
Laguna III 2.0 DCI
2008 Dynamique
mmgmarius |
uite manualul scanat
28 Feb 2008, 22:39: Vezi ca am pierdut ceva timp sa scanez manualul asta. M-as bucura sa aflu ca nu am pierdut timpul de pomana. Succes in ceea ce vrei sa faci si sa ne anunti si pe noi ce a iesit. This post has been edited by mmgmarius: 28 Feb 2008, 22:39 Attached thumbnail(s) scan0001.jpg ( Size: 939.87k ) Number of downloads: 4344 scan0002.jpg ( Size: 1015.68k ) Number of downloads: 4659 scan0003.jpg ( Size: 811.89k ) Number of downloads: 4344 scan0004.jpg ( Size: 888.56k ) Number of downloads: 4189 scan0005.jpg ( Size: 812.61k ) Number of downloads: 3886 scan0006.jpg ( Size: 935.11k ) Number of downloads: 1615 scan0007.jpg ( Size: 828k ) Number of downloads: 1459 scan0008.jpg ( Size: 970.45k ) Number of downloads: 1325 scan0009.jpg ( Size: 774.76k ) Number of downloads: 1911 scan0010.jpg ( Size: 1.02mb ) Number of downloads: 1948 scan0011.jpg ( Size: 993.25k ) Number of downloads: 1426 scan0012.jpg ( Size: 985.92k ) Number of downloads: 1401 scan0013.jpg ( Size: 745.48k ) Number of downloads: 1505 scan0014.jpg ( Size: 798.59k ) Number of downloads: 1552 scan0015.jpg ( Size: 528.59k ) Number of downloads: 1494 scan0016.jpg ( Size: 955.97k ) Number of downloads: 1795 |
Symbol Music 1.4 8V
marianrec |
![]() membru drept Group: Members Posts: 330 Joined: 30 March 04 From: Galati ![]() |
QUOTE(mariusrusu @ 27 Feb 2008, 11:50) Va rog sa ma ajutati cu manualul de utilizare pentru alarma K9 Classic. Vreau sa montez inchidere centralizata, nu stiu daca merge combinata cu alarma asta... Inchiderea centralizata merge legata la orice tip de alarma existenta pe piata. La K9Classic este o mufa cu 2 fire : unul vrede.. comanda pt inchis si unul albastru comanda pt deschis. Comanda este pe minus. |
- GL03WWT & GL07NAT
1990, 1994 bau
mariusrusu |
Multumesc mult de tot.
Bine inteles ca o sa va anunt cum a iesit treaba. ![]() |
Laguna III 2.0 DCI
2008 Dynamique
mmgmarius |
Incep sa cred ca nu prea ti-au fost de ajutor. Poate ii va prinde bine cuiva pe viitor. Nu de alta dar nu vreau sa cred ca am pierdut timpul scanand manualul ala.
O zi buna tuturor! |
Symbol Music 1.4 8V
zeu_4u_sweety |
Membru autentic Group: Members Posts: 793 Joined: 7 December 07 ![]() |
sa stii ca mie chiar mi-a folosit! un singur lucru nu am gasit, si anume cum se programeaza telecomenzile!
BMW
318
1998/touring/M43
ionutdincolti |
Membru incepator Group: Members Posts: 2 Joined: 5 May 15 ![]() |
Scuze moderatorilor ca readuc la viata un topic vechi.
Detin(asa am gasit-o pe masina) o alarma k9 model AU-85TA. Modulul are o singura mufa cu patru iesiri. -rosu plus permanent -negru masa -albastru inchide cand e pus la masa -verde deschide cand e pus la masa. Si mai are o mufa cu antena cu cablu coaxial din acela subttire. Nu am iesire pt a lega goarna... Mai am butonul valet care practic e un switch si ledul aferent care iar nu au unde intra in modul alarma... Mai detine cineva acest model de alarma si schema la ea? Pe net nu am gasit dar va pun un link cu alarma http://www.installer.com/item/display_item.php?it=au-85ta Multumesc frumos. |
2000
aia din link este doar senzorul de soc ( geamuri sparte) si perimetru : Dual Zone Air Resonance Shock & Glass Breakage Sensor
This post has been edited by bygy007: 6 May 2015, 13:23 |
CAPTUR E-Tech full hybrid 145
- B 07 BGY
ionutdincolti |
Nu mai gasesc link-ul in care scria clar alarma k9 model au-85ta si nu arata ca ar fi continut altceva in afara de ce am eu si ce e in poze, asa ca l-am pus pe cel din postarea precedenta unde am vazut si eu ca zice ceva de senzor geam spart. etc.
Deci trebuie sa mai fie ceva..care eu nu il am pe masina si deci din cauza asta nu se ''pupau''. Practic mie imi lipseste modulul efectiv. Multumesc. |
2000
optiplex |
Membru incepator Group: Members Posts: 2 Joined: 23 September 14 ![]() |
QUOTE(mmgmarius @ 10 Mar 2008, 13:44) Incep sa cred ca nu prea ti-au fost de ajutor. Poate ii va prinde bine cuiva pe viitor. Nu de alta dar nu vreau sa cred ca am pierdut timpul scanand manualul ala. O zi buna tuturor! scunt de folos scan-urile tale chiar si dupa atata timp. ar fi insa de folos daca ai putea sa atasezi si manualul de utilizare (nu doar cel de instalare) fiindca nu stim cum se programeaza telecomenzile sau cum se anuleaza anumiti senzori, setari, mod valet, etc. Mersi, timpul pierdut de tine nu a fost pierdut, eu unul apreciez sincer! |
Daewooo
Espero
1995/1500
mmgmarius |
Salutare la toata lumea, am o problema la o telecomanda. S-a terminat bateria, i-am pus alta noua si nu vrea sa functioneze. Am incercat si cu alta baterie si tot asa face... se aprinde LED-ul de la ea dar nu deschide si nu inchide. Cealalta telecomanda functioneaza perfect. Aveti idee ce pot face?
Symbol Music 1.4 8V
mmgmarius |
Buna ziua, am o problema cu alarma
![]() Cand incerc sa armez/dezarmez nu ia comanda, adica uneori merge, uneori nu... nu inteleg de ce. Prima data a inceput sa-mi faca asta doar la una din telecomenzi, apoi dupa cativa ani m-am trezit ca face asa cu ambele. Bateriile sunt noi. Aveti idee cum pot rezolva situatia? |
Symbol Music 1.4 8V
Tataee89 |
Membru incepator Group: Members Posts: 1 Joined: 23 July 17 ![]() |
QUOTE(mmgmarius @ 28 Feb 2008, 22:34) uite manualul scanat <span class='edit'>28 Feb 2008, 22:39:</span> Vezi ca am pierdut ceva timp sa scanez manualul asta. M-as bucura sa aflu ca nu am pierdut timpul de pomana. Succes in ceea ce vrei sa faci si sa ne anunti si pe noi ce a iesit. Am mostenit un Symbol cu alarma asta care a obosit dupa mai bine de 16 ani. De mare ajutor sa inteleg toate cablurile. Multumesc! |
Symbol
2008 1.4 16V + GPL
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 08:26 |
