Subwoofer + Amplificator ( Blaupunkt )
Dragman |
![]() Membru incepator Group: Members Posts: 50 Joined: 19 December 07 From: BUCURESTI ![]() |
Attached thumbnail(s) 29_01_08_1248.jpg ( Size: 264.18k ) Number of downloads: 606 DSC06783.JPG ( Size: 1.81mb ) Number of downloads: 681 |
2005 AMBITION 1.6 MPI,DimmSport,Blaupunkt,Infinity
- b-42-dnx
bogidan21 |
![]() Lipsa de inspiratie Group: Members Posts: 188 Joined: 12 August 06 From: Brasov Romania ![]() |
Imi zice si mie cineva daca are ceva daca pun statia direct pe tabla? as dori sa o pun in portbagaj intre boxe.
preferance 2006 Noiembrie 19
- BXXRXI Bleah
silviu_79 |
![]() Membru Autentic Group: Members Posts: 1.252 Joined: 27 June 06 ![]() |
nu are nimic, si eu am avut statia intre boxe, direct pe tabla prinsa in suruburi.
mazda
3
2007 ...::zoom - zoom::...
bogidan21 |
Eu intreb deoarece s-a intamplat o chestie ciudata odata. A fost prinsa de tabla si cand am bagat ceva in portbagaj am agatat firul de minus de la statie dar ea inca mergea fara firul de masa.M-am speriat si de atuinci o tin jos intr-un colt dar o lovesc mereu cu diferite obiecte si as vrea sa o pun la loc.Voi ce recomandati?
- BXXRXI Bleah
Marso |
![]() ***Membru*** Group: Members Posts: 547 Joined: 1 September 06 From: Bu***esti ![]() |
confectioneaza'i niste tampoane de cauciuc si pune'le intre statie si tabla in zona unde se face prinderea...de exemplu la fiecare surub pui cate un strat de cauciuc subtire a.i sa nu'ti mai atinga statia de tabla...desi nu e normal sa se intample ce povestesti tu aici
Laureate 1.6 MPI
2006 Gri Perla + GPL Renault Megane Privilege 1.6 16V Bleu
MCV Laureate 1.5 DCI 2007 Gri Platine |
tdan08 |
JUST A MEMBER Group: Members Posts: 464 Joined: 18 November 08 From: B A C A U ![]() |
intrebare de 10 puncte. ce inseamna "greierasi" la masina? tot am auzit de "greierasi". lamuriti-ma si pe mine
Ford Mondeo
Renault Clio
2019 .
AR-18-MOS |
Zgomote enervante, care se manfiesta la trepidatii si vibratii.
BMW
730Ld
'07 High Executive
CriSTI68 |
definitie generala
Greierasi = Logan de fabrica |
adiya |
![]() Membru autentic Group: Members Posts: 1.392 Joined: 12 June 05 From: Bucuresti ![]() |
QUOTE(Killlerbest @ 30 Mar 2008, 11:15) Salut ,poti detalia te rog de ce nu e recomandat adaptorul hi-low? Chair acum mi-am comandat si eu unul ,si as fi curios ce se intampla daca o sa il montez. Imi pare rau, nu am mai urmarit subiectul asa ca iti raspund acum; poate va folosi altcuiva. Nu se intampla nimic daca il montezi la modul ca nu se arde, sare in aer etc. Nu se recomanda in cazul asta adaptor high-low pentru ca ai la intrarea in statie semnal gata distorsionat de player, mai ales la volum mare. Acest adaptor e util atunci cand nu ai iesre low pentru statie. Cum ziceam si mai spre vara playerul de pe Logan are iesire low pe o mufa miniISO, nu ai nevoie decat de un adaptor. |
2007 ABS PLUS dci
- B-00-XXX
pyngi |
![]() Membru autentic Group: Members Posts: 242 Joined: 4 November 07 From: Tg-Mures ![]() |
adiya daca poti explica te rog mai detaliat cum este cu iesirea low pe playerul Logan. adica ii poti pune undeva in spate un adaptor (mini ISO to RCA ma gandesc) si il poti lega la un amplificator? Acesta se poate folosi doar pentru subwoofer sau sunt mai multe iesiri ca sa amplifici toate cele 4 difuzoare? Mersi
This post has been edited by pyngi: 10 Mar 2009, 20:25 |
Logan Kiss FM dCI 85 CP
2008 236.000 km Fara interventii la motor, cutie,ambreiaj. Da vorba unuia: "cu banii astia iti puteai lua si o Masina." (TDI bre)
Marcel-Nicolae |
Membru incepator Group: Members Posts: 1 Joined: 13 February 09 ![]() |
salut si eu mi-am pus un tub de bas si statie blaupunkt tot de la domo:D am mers la LOG TUNING in timisoara si mi le-or montat, bineinteles cu cablurile mele. de auzit se aude destul de bine cu Sony al meu din logan. in plus am pe el boxele originale, si fiind kissfm cred ca astia de la Dacia au pus alte boxe pe masina.
2007 Kissfm
AR-18-MOS |
Numai crezi ... Ca sunt aceleasi cartoane.
BMW
730Ld
'07 High Executive
W3f |
![]() Membru autentic Group: Members Posts: 221 Joined: 22 July 07 ![]() |
LGN ABS +
2008 (D)aca (A)i (C)ap (I)a-ti (A)lta
cosy |
Membru incepator Group: Members Posts: 6 Joined: 28 November 12 ![]() |
Nu stiu daca mai activeaza cine pe postul asta daca se vede,dar as fi interesat sa montez si eu ceva audio pe un logan dar nu cunosc prea multe detalii despre acest lucru. Rog pe marius80_eugen daca ma poate ajuta,eventual cu un PM cu mail/id-ul lui,deoarece pe mine nu ma lasa sa trimit PM. Multumesc!
Logan Facelift
andreypck |
Membru incepator Group: Members Posts: 28 Joined: 15 February 07 From: Bistrita ![]() |
QUOTE(adiya @ 25 Mar 2008, 23:35) Nu e obligatoriu si nici nu e recomandat hi-low. Se gaseste pentru acest tip de player adaptor miniISO-RCA. Adica iese semnal low dar pe alt tip de mufa. Foarte greu am gasit (pana la urma in piata) adaptorul miniISO-RCA cu 4 intrari (RR,RL, FR,FL) si fir REMOTE. (http://www.hobbielektronika.hu/forum/getfile.php?id=75213) Si cand toate au fost trase si puse la locul lor, am intrat in masina si conectam RCA-urile de la statie la CD-Player. Mufa miniISO-RCA s-a potrivit perfect, REMOTE-ul la conectat la firul galben parca, am bagat si RCA-urile, statia a pornit (s-a aprins led-ul de power) dar n-am avut semnat cu adaptorul asta. Ca sa nu plec cu buza umflata, le-am pus pe direct... ![]() De ce nu a functionat adaptorul, cum as putea face sa mearga??? Va rog sa ma ajutati, va multumesc mult! La multi ani! |
2008 LAUREATE 1.4MPI
- SV87AVA
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 14:38 |
