7 Pages  1 2 3 > »
> [VAND] Module impuls, Module impuls comanda geamuri electrice
OldMan
post 13 Apr 2008, 09:48
Module impuls pentru comanda geamurilor electrice.
Pret 50 lei/ buc, la 2 bucati pretul este 45lei/buc
Pentru cei care pot sa-si faca singuri acet montaj pot trimite schema electrica, PCB, microcontrolerul programat si instructiuni de montaj. Restul componentelor se pot procura de la orice magazin de componente electronice.
Pret 25lei/buc.
This post has been edited by OldMan: 13 Apr 2008, 13:17
Logan 1,5 dci ABS plus 2007 - SV-91-KUL
angel-boy
post 13 Apr 2008, 09:50
Ovidiu
si poze?
This post has been edited by angel-boy: 13 Apr 2008, 10:17
Renault Laguna II 1.9dci 2002
Daewoo AGC-1220RF-A ,boxe Cabasse,subwoofer BOSE
EX : Volkswagen GOLF III 1996 1.6 MPI - 1996
EX : DACIA 1310 TX - 1991
OldMan
post 13 Apr 2008, 09:57
Iluminare la ce? Cred ca trebuie sa citesti mai atent.
O sa fie si poze
This post has been edited by OldMan: 13 Apr 2008, 10:05
Retype
post 13 Apr 2008, 10:19
Himera
cum isi da seama cand a ajuns geamul sus si sa nu-l mai forteze?
daca pun mana in timp ce se inchide se opreste?
multumesc
Dacia Logan 2006/ Audi 6.0 quattro 2006/ Mio a701 cu MioMap
C a t a l i n
post 13 Apr 2008, 10:25
______________________
"Monitorizează" consumul de curent. Da.
This post has been edited by MAERSK: 13 Apr 2008, 10:25
OldMan
post 13 Apr 2008, 12:46
si filmuletul cu montarea si functionarea
http://www.dailymotion.com/video/x524tb_mo...re-geamuri_tech
<span class='edit'>13 Apr 2008, 12:48:</span>
QUOTE(Retype @ 13 Apr 2008, 10:19)
multumesc
QUOTE(MAERSK @ 13 Apr 2008, 10:25)
MaersK stima. Multumesc pentru promtitudine
Monitorizeaza si consumul de curent si nici nu afecteaza daca aveti alarma cu modul ridicare geamuri. Vedeti in filmulet.
This post has been edited by OldMan: 13 Apr 2008, 12:49
rero
post 14 Apr 2008, 17:43
salut,
Merge pe laguna 2?
Renault Captur II 2022/Intens
OldMan
post 14 Apr 2008, 18:34
teoretic ar trebui sa functioneze pe orice masina la care comanda motoarelor de la macaralele geamurilor sunt la modul direct, adica butonul comanda direct motorulfara alt modul intermediar. Modul care sa faca detectia pentru cresterea curentului pe motor in momentul cand e la capete de cursa sau cand intalneste in tampul cursei un "obstacol".
Daca are aceesi comanda ca la Logan, merge, se reconfigureaza suntul pentru citirea consumului de curent ....
Nu am testa pe laguna , i-mi pare rau nu pot sa-ti dau un raspuns exact.
15 Apr 2008, 17:40:
up
This post has been edited by OldMan: 15 Apr 2008, 17:40
bobi19xx
post 15 Apr 2008, 17:43
dar de exemplu daca vreau ca geamu sa se deschida decat jumate cum il opresc(solenza scala)
Dacia Solenza 2003 - B-34-PMN
OldMan
post 16 Apr 2008, 19:05
QUOTE(bobi19xx @ 15 Apr 2008, 17:43)
...e suficient sa mai apesi o data scurt pe buton si se opreste, sau tii apasat continuu pe coborare si se deschide cat ai nevoie.
La fel si pe urcare.
bobi19xx
post 16 Apr 2008, 19:10
esti din bucuresti
Mihai R
post 16 Apr 2008, 19:42
Daca ne trimiti cele mentionate in primul post, ce mai trebuie sa cumparam in-afara de mufa?
Vad ca ai numar de suceava la semnatura. Cum pot intra in posesia lor si cam in cat timp?
Mersi!
Ford Focus Iunie 2008 Trend+OPTIONALE 1.6L 16v - B xx xxx
OldMan
post 17 Apr 2008, 05:58
In afara de modul nu se mai trebuie nimic. Se conecteaza intre buton si mufa care intra in buton. Acestea se gasesc pe masina.
In functie de comenzi va anunt pe PM cand s-au expediat.
Din acel moment totul e la latitudinea postei romane.
kristikapa
post 18 Apr 2008, 23:13
Acest modul ridica automat geamurile la inchiderea masinii folosind telecomanda de pe cheie?
Multumesc.
Dacia Logan Preference 2005 - MM-xx-JIH
C a t a l i n
post 18 Apr 2008, 23:26
Singur nu. Doar cu un modul adițional al alarmei.
kristikapa
post 18 Apr 2008, 23:31
De acelasi modul e nevoie si in cazul in care eu nu am alarma ci doar inchidere centralizata(Preferance)?
C a t a l i n
post 18 Apr 2008, 23:39
Din ce cunosc, nu se poate face așa ceva prin modulul de IC.
angel-boy
post 19 Apr 2008, 10:28
Ovidiu
... totusi daca geamurile sunt facute ? si nu detin acele mufe pe masina ce fac ?
C a t a l i n
post 19 Apr 2008, 10:30
angel-boy
post 19 Apr 2008, 10:31
Ovidiu
de exemplu eu ti-am montat motorase pe macara.. deci nu am nici o mufa smile.gif doar 2 fire de la motoras si 2 fire + . - ... deci cum fac montarea modulelor ?
OldMan
post 21 Apr 2008, 16:46
si care ar fi problema iti configurez modulul dupa ce ai pe masina.
Banuiesc ca butonul de actionare il ai montat (oricare ar fi el si oricum arata) ca doar cele doua fire nu le pui direct pe baterie?
La module iti anexez schema de montaj aferenta cazului personalizat.
Multumesc lui Maersk pentru promtitudine, e corect 100%
22 Apr 2008, 16:29:
up
23 Apr 2008, 16:06:
up
This post has been edited by OldMan: 23 Apr 2008, 16:06
XMihai
post 23 Apr 2008, 18:03
Carcotasu' de Serviciu
ma intereseaza un modul pt accent 2007, se poate?
merci
OldMan
post 24 Apr 2008, 06:15
I-mi pare rau da pe Hyundai nu am montat niciodata, am dat explicatii in Postare #8.
This post has been edited by OldMan: 24 Apr 2008, 06:28
Mihai.D.G.
post 24 Apr 2008, 17:50
Jupanu'
Pentru logan m-ar interesa. Am doarpe stanga fata dar e buton cu impuls. Nu prea inteleg cum ar veni montate... blush.gif
Renault Fluence 2010 1.5dci
OldMan
post 24 Apr 2008, 18:08
deci pe macaraua stanga fata ai un buton original cu impuls?
modulul face dintr-un buton cu actionare normala unul cu impuls.
Mihai.D.G.
post 24 Apr 2008, 18:22
Jupanu'
M-am uitat mai bine la montaj...Avem impresia ca nu o sa am unde sa-l bag, in bord, dar e deastul spatiu in spatele butoanelor. smile.gif
Christu
post 1 May 2008, 10:46
Pe Megane 2 se poate|?
Ca stiu ca era controlata treaba asta cu impulsul din UCH.........
Alfa Romeo 159
ex: Renault Megane Sedan 2007
OldMan
post 3 May 2008, 14:59
daca e prin UCH, am mai spus ca nu merge
romeod
post 5 May 2008, 19:35
Romeo
La Clio merge?
Renault Clio 2003 - B 94 RVR
Am bani de dat, am datorii la stat.........................
OldMan
post 6 May 2008, 06:23
La clio merge numai daca nu are trecuta comanda prin uch.
Ce varianta de clio, si ce an de fabricatie?
7 Pages  1 2 3 > »
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 17th July 2025 - 00:08
