> [VAND] Scopemeter TPI 440 6 Instruments in 1
rastaman
post 19 Aug 2008, 20:31
1. Auto Ranging 4000 Count True RMS DMM - TPI's 440 has 9 measurement functions and 0.3% basic DC accuracy. True RMS capability allows the user to obtain accurate measurements of non-sinusoidal AC voltage and current waveforms.
2. 1 Mhz Oscilloscope - View industrial power signals with clarity on the scopemeter display. Simple-to-operate oscilloscope function provides a "picture" of voltage or current waveforms making it easy to detect system problems such as harmonics and waveform distortion.
3. Trend Mode - Graph reading over a predetermined time period to check for the presence of undesirable voltage or current variations.
4. Component Test - (Curve Tracer) Check voltage current signatures on capacitors, resistors, and semiconductors.
5. Logic Tests - Indicates TTL and CMOS logic level tranisitions up to 2 Mhz.
6. Frequency Counter - Measure frequency from 1 Hz to 2 MHz and display duty cycle, pulse width, and period.
Aparatul este nou in cutie ,cu tipla pe ecran ,manual ,incarcator ,testere .Masoara f bine ,partea mai slaba este osciloscopul ,oricum mult peste HPS10 de ex care se vinde cu 8 mil .
Poate fi folosit pe teren ,acumulatorii tin cam vreo 2 ore ,pentru diagnoza auto sau altceva pentru depanare tv este usor depasit ,vezi SVCC doar daca te astepti sa l vezi ,insa de ex semnalul de 15 khz de comanda linii se vede f bine .
Nu fac schimburi ,expediez oriunde ,cumparatorul plateste transportul.Am pregatita pentru el o cutie de 10 ori mai mare plina cu airbaguri .
Am asa ceva de vanzare ,il gasiti aici :
http://www.okazii.ro/catalog/6467870/elect...nstruments.html
DAEWOO TICO 1999 - BT03SND
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 24th May 2024 - 23:38
