Montaj cd player Renault, in locul radio cass Renault
hellcat |
![]() FrontYard Motorsport Group: Moderatori Posts: 5.628 Joined: 25 April 04 From: Dieppe ![]() |
Renault Clio
bicorp 1.4 16v
2002 expression Commencal Premier HD1
Amita |
![]() Membru autentic Group: Members Posts: 246 Joined: 12 May 10 From: Bucuresti ![]() |
oki, tks. mai incolo ma duc la masina si vad. te tin la curent....( nu 220)....
![]() 18 May 2010, 13:09: Mergeeeee!!!! yupiiii. Iti dau o bere ![]() Acu am si eu mai multe posturi ![]() Multam This post has been edited by Amita: 18 May 2010, 13:09 |
1999, 1,8 16v
- B95AJV
agache_drn |
Membru incepator Group: Members Posts: 8 Joined: 7 July 10 From: Tulcea ![]() |
salutare! am si eu o dilema, am un renault laguna 2, 2001 si am audio player(tuner list).daca il inlocuiesc cu un mp3 player la fel (update list) imi merg comenzile si display-ul? multumesc mult si astept raspuns cu nerabdare
Laguna 2
dan22y |
Membru autentic Group: Members Posts: 5.514 Joined: 7 June 06 From: B ![]() |
Nu o sa mearga, nici displayul nici comenzile de la volan.
Din 2005/2006 s-a trecut pe digital iar tu ai analogic acolo la interfata intre unitate si afisaj/telecomanda. |
R
M
8
- B
cosmin_69 |
![]() Membru autentic Group: Members Posts: 1.334 Joined: 16 February 10 From: Curtea de Arges ![]() |
As vrea sa stiu si eu daca sub cd-ul original pot sa mai pun un cd cu mp3 .
Stiu ca pierd comenzile din afisaj si de sub volan, insa vreau o imbunatatire, dar vreau sa stiu de unde trag firele pt conectarea celui de-al doilea ? 1 Sep 2010, 20:34: Eu am Tuner List, de aceea nu va mai merge afisajul la cel cu mp3. Oricum ramane si cel original. Si care modele de cd player se potrivesc si intra complet in locasul de sub cd-ul vechi ? This post has been edited by cosmin_69: 1 Sep 2010, 20:34 |
renault
Megane IV
2018 renault sedan IV ex. renault megane II si nou in renault megane sedan IV gris titan
dan22y |
In mod normal orice model de mp3 intra sub cel original, sa fie insa 1DIN si o sa trebuiasca o rama adaptoare ca sa completeze spatiul ramas.
Fire pentru cel de-al doilea ai putea lua din panoul de sigurante (un plus permanent, un plus de dupa contact si o masa). Nu e recomandat sa iei cele de mai sus de pe primul cd-player. |
R
M
8
- B
cosmin_69 |
Pt dan22y
Te rog fii putin mai explicit . ce inseamna 1DIN si de unde stiu asta ? Iar firele le trag de la panoul de sigurante de sub capota si de unde mai exact ? Cum identific sigurantele care trebuie ? |
renault
Megane IV
dan22y |
1DIN e dimensiunea standard la toate unitatile de pe masini.
Cele 2DIN sunt de obicei cele duble ca dimensiune (2DIN=2x1DIN) sunt cele cu navi si alte chestii pe ele cu ecran mare... Firele se trag de la panoul de sigurante din habitaclu. Trebuie doar identificate sigurantele. Trebuie sa caut si-ti spun. |
R
M
8
- B
Hack |
![]() Megan' ti-ai luat?! Group: Members Posts: 5.147 Joined: 12 April 07 From: The Moon ![]() |
QUOTE(cosmin_69 @ 1 Sep 2010, 21:32) De ce ai vrea sa faci asa ceva? ![]() Uite si un exemplu: PICT3872.JPG ( Size: 258.17k ) Number of downloads: 1446 This post has been edited by Hack: 2 Sep 2010, 09:28 |
Megan' Sedan 2.2
2007 Expression 1.6l/16V/110CP
cosmin_69 |
Pt. dan22y
Am inteles acum. Astept si referitor la sigurantele respective Pt. Hack As ramane eu numai cu cel original, dar este Tuner List si nu citeste MP 3. Trebuie sa fac numai trackuri si atunci au loc foarte putine melodii pe un CD. Max 18-20 piese. 2 Sep 2010, 13:44: Fata de ce am vazut in poza ta, la mine NU este Update List . This post has been edited by cosmin_69: 2 Sep 2010, 13:44 |
renault
Megane IV
Hack |
De ce nu inlocuiesti player-ul stock cu unul aftermarket?
Megan' Sedan 2.2
cosmin_69 |
Pt. Hack
Fiindca totusi vreau sa-mi ramana in functiune si afisajul din bord, iar asta numai daca pastrez cd-ul masinii(Tuner Listul) Oricum este un compromis fiindca decat sa schimb la reprezentanta totul ca sa fie Update List(m-ar costa enorm) mai bine asa. |
renault
Megane IV
Hack |
Eu zic ca poti renunta linistit si la afisaj si la comenzile de la volan, ai sa vezi ce repede te obisnuiesti fara ele. Si eu dupa ce am schimbat player-ul am vrut neaparat sa pastrez afisajul si comenzile de la volan si am luat un adaptor dar mi-e mult mai usor sa controlez totul de pe fata player-ului si nu prea folosesc satelitul de la volan, in fine faci cum crezi...
This post has been edited by Hack: 3 Sep 2010, 17:28 |
Megan' Sedan 2.2
sezalex |
Membru incepator Group: Members Posts: 2 Joined: 25 July 11 ![]() |
florin ,de pe ce site ai facut comanda de rama pt megane 1 ? uite un nr de tel sau raspunde-mi cat mai repede poti 0725505877 ca imi trebuie neaparat ms
megane
megane
- dj-55-wwo
ogleja |
Membru incepator Group: Members Posts: 1 Joined: 23 September 11 ![]() |
buna,
am luat un cd "tuner list" de la cineva si vreau sa-l montez pe un logan, ma ajuta si pe mine cineva cu introducerea codului, tinand cont ca nu am display si codul contine cifra 0. merci mult |
Dacus_Malus |
![]() OM Group: Members Posts: 757 Joined: 24 July 07 From: Brasov / Rasnov ![]() |
am si eu intrebare:
exista vreo setare la radiocdplayerul de Duster prin care atunci cand opresc masina din cheie sa se opreasca si radiocd-ul ? |
Toyota
Prius 2
2006 Toyota Prius 1 - 2002
Autorulota Citroen C25 SanRemo - 1990 |
espacern |
![]() ART-ist Group: Moderatori Posts: 17.610 Joined: 14 August 09 From: Mihalaya ![]() |
Daca este montat de origine posibil sa fie arsa siguranta la + dupa contact.
Daca s-a montat after....si siguranta este OK trebuie inversate firele rosu cu portocaliu/galben. @+ |
- . RENAULT are mistere pe care OMUL nu va reusi niciodata sa le afle!
Dacus_Malus |
E original, si a mers pana acum cateva zile....
Unde gasesc acea siguranta? |
Toyota
Prius 2
catalin1 |
![]() Membru autentic Group: Members Posts: 680 Joined: 4 July 13 From: Dobrich ![]() |
Acea siguranta este pe traseul unde ajunge alimentarea la player pe un fir rosu care are pe el o cutiuta de forma cilindrica sau dreptunghiulara de culoare neagra
Megane 1,4
2000 phase 2
- B 25 wiz Decat la o nunta falsa mai degraba la un divort distractiv
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 21:58 |
