bord digital
bord digital
anndi |
#121
Membru autentic Group: Members Posts: 932 Joined: 13 December 04 From: Timisoara ![]() |
Megane GT220
GrandTour 2014
mihai1677 |
#122
![]() Membru autentic Group: Members Posts: 1.369 Joined: 23 December 03 From: Bucuresti ![]() |
aprinderea asta a ta cum este:
1 delco plus bobina normala 2 delco plus bobina gen gti (dacia injecie 4 fise) 3 turometrul este cel de fabrica? |
Renault 5 Campus,
Hyundai Sonata,
1988 / 2001
beby1300 |
#123
![]() Membru incepator Group: Members Posts: 74 Joined: 19 November 03 From: Bucuresti ![]() |
Tocmai am terminat dupa 1 AN
![]() PicProjectAuto: Pic16f877/4Mhz, Display Lcd 4*20/backlight, viteza/3 digiti, turatie/4 digiti, temperatura motor 20-100 grade C, temperatura interior 0-50 grade C, interfata PC serial-bootloader (update software local). ![]() ![]() This post has been edited by beby1300: 15 Nov 2005, 14:45 |
-------------------- ***B-07-XTS***B-07-XTS***B-07-XTS***B-07-XTS***B-07-XTS***B-07-XTS***
Dreamer |
#124
![]() Un visator hoinar ... Group: Members Posts: 1.750 Joined: 23 September 05 From: Brasov ![]() |
Niste poze nu ai, sa ne arati si noua cum arata dupa ultimile teste ?
Ex Renault
Megane 1, 2 si 4
beby1300 |
#125
am sa fac maine cateva poze sa le postez aici.
beby1300 |
#126
am rezolvat mai repede....
![]() detalii: in dreapta doua convertoare frecventa-tensiune. centru sus din lipsa de spatiu aglomerat.... conversia si normarea pt senzorii de T cu 2*OA. niste fire de alimentare... intrare senzori T si un mic simulator de RPM. Attached thumbnail(s) S3010024.JPG ( Size: 803.75k ) Number of downloads: 1732 S3010025.JPG ( Size: 795.17k ) Number of downloads: 2160 |
B31AYZ |
#127
Membru autentic Group: Members Posts: 647 Joined: 1 April 04 ![]() |
Salut ,
Vreau si eu unul . Crezi ca se poate ? Daca nu , o schema ceva detalii ? Multumesc. |
1300 din 1980
- B31AYZ
beby1300 |
#128
din pacate este unicat
![]() deocamdata il las asa... macar sa il vad pus pe masina. poate doar un update software la interfata grafica... cel mai bine este sa te apuci tu de unul... inveti f multe in timp ce il faci si apoi il poti modifica cum vrei. tot ce itzi trebuie este un pik de electronica, o picatura de asm pentru programarea PIC-ului si mult mult timp si rabdare. ca documentatie este de ajuns datasheet-ul de la microcip pt PIC16f877 si datasheet-urile pt senzori si convertoare. |
Dreamer |
#129
Super faina ideea, mult mai practica si mai estetica decat ceea ce aveam acum pe masini, vorba ta... daca mai lucrezi la grafica afisajului o sa iasa ceva misto.
Felicitari ! Pont : termina prototipul apoi fa modificarea de care ti-am zis si lanseaza un post pe forum ... te-ai scos de o afacare pe cinste ... partea mea ... un 5 % din cifra de afaceri ... pentru idee ![]() |
Ex Renault
Megane 1, 2 si 4
beby1300 |
#130
mmmda, chestia cu afacerea itzi dai seama ca a aparut inaite de a monta prima componenta sau de a scrie prima linie de cod.... totusi sunt de acord cu cei 5% pt tine cu conditia sa ii investesti 110% in dezvoltarea viitoare a proiectului!!!
![]() treaba cu grafica are si ea o limita dar se mai poate lucra... dar cred ca mai interesant ar fi sa reusesc sa implementez si restul de functii de baza ale masinii, cum ar fi.. consum/100Km, avans, presiune ulei, etc. adica mai mult timp mai multi bani si poate un microcontroler mai puternic. |
mumulacke |
#131
![]() Membru Group: Members Posts: 116 Joined: 19 January 05 From: Sibiu ![]() |
QUOTE(beby1300 @ 15 Nov 2005, 20:26) mmmda, chestia cu afacerea itzi dai seama ca a aparut inaite de a monta prima componenta sau de a scrie prima linie de cod.... totusi sunt de acord cu cei 5% pt tine cu conditia sa ii investesti 110% in dezvoltarea viitoare a proiectului!!! ![]() treaba cu grafica are si ea o limita dar se mai poate lucra... dar cred ca mai interesant ar fi sa reusesc sa implementez si restul de functii de baza ale masinii, cum ar fi.. consum/100Km, avans, presiune ulei, etc. adica mai mult timp mai multi bani si poate un microcontroler mai puternic. am si eu o rugaminte: o schema cat mai usoara pentru a constui un termometru care sa masoare temperatura din interior si eventual si cea de afara... |
1310L
1997
- SB-25-CIP Mitac Mio A701
marianrec |
#132
![]() membru drept Group: Members Posts: 330 Joined: 30 March 04 From: Galati ![]() |
Si cam la ce bani ai vinde softul???
1990, 1994
- GL03WWT & GL07NAT bau
Siconi |
#133
Nu e chiar asa de usor sa fdaci ceva unic si apoi sa-l vinzi. Chiar daca e ceva simplu sau complicat (cu atat mai mai mult)Iti ia ceva timp. Si, in general, al doilea montaj va fi diferit de primul. Cu toate aste, va rog, dati-mi si mie ceva scheme pt microcontrolerul asta ca as incerca si eu ceva experimente. Am tot urmarit pana acum discutia de pe forum si vine in perfect acord cu ceea ce voiam sa fac si eu acum cativa ani, cand nu se prea stia de microcontrolere cu multiple functii si d-astea.
Anyway, sunt happy ca se mai gandeste careva la cosmetizarea Daciei si optimizarea comdusului unei D1300 si nu numai. Personal am incercat si eu ceva schem, dar m-am lasat pagubas ca nu se prea gaseau piesele pe care le aveam eu in scheme, de prin reviste rusesti si frantuzesti (bineinteles ca erau traduse). As mai vrea sa incerc, deci daca mai e cineva interesat sa ajute un biet pasionat de DACIA 1300 ('75), scrieti-mi pe siconi.digitall.com@gmail.com. Multe multumiri ![]() |
Mercury
Mariner Premier 3.0L V6 4WD
beby1300 |
#134
QUOTE(Siconi @ 16 Nov 2005, 01:53) Nu e chiar asa de usor sa fdaci ceva unic si apoi sa-l vinzi. Chiar daca e ceva simplu sau complicat (cu atat mai mai mult)Iti ia ceva timp. Si, in general, al doilea montaj va fi diferit de primul. Cu toate aste, va rog, dati-mi si mie ceva scheme pt microcontrolerul asta ca as incerca si eu ceva experimente. Am tot urmarit pana acum discutia de pe forum si vine in perfect acord cu ceea ce voiam sa fac si eu acum cativa ani, cand nu se prea stia de microcontrolere cu multiple functii si d-astea. Anyway, sunt happy ca se mai gandeste careva la cosmetizarea Daciei si optimizarea comdusului unei D1300 si nu numai. Personal am incercat si eu ceva schem, dar m-am lasat pagubas ca nu se prea gaseau piesele pe care le aveam eu in scheme, de prin reviste rusesti si frantuzesti (bineinteles ca erau traduse). As mai vrea sa incerc, deci daca mai e cineva interesat sa ajute un biet pasionat de DACIA 1300 ('75), scrieti-mi pe siconi.digitall.com@gmail.com. Multe multumiri ![]() e adevarat ca inainte resursele pentru un asemenea proiect erau de negasit. azi situatia e cu totul alta. un pic il gasesti incepand cu 10RON, un display se poate lua de pe oride device dezafectat care are asa ceva din costructie, resul de componente se gasesc si sunt la preturi f f acceptabile, cat despre documentatie internetul afera tot ce trebuie chiar mai mult.... chestia asta poate fi pusa pe orice masina.... la daciile berline cu injectie este chiar mai usor pt ca datele pt pic se iau direct de pe ECU sau de pe senzorii existenti pe masina. QUOTE(marianrec @ 15 Nov 2005, 22:04) nu cred ca pun problema vanzarii soft-ului dar exista posibilitatea vanzarii pic-ului cu programul gata scris adaptat pe cerintele cumparatorului (mesaje personalizate, ordine ecrane, date analizate, configurare pt display-ul existent). trebuie doar sa ai posibilitatea realizarii hardware. QUOTE(mumulacke @ 15 Nov 2005, 21:58) am si eu o rugaminte: o schema cat mai usoara pentru a constui un termometru care sa masoare temperatura din interior si eventual si cea de afara... cred ca cea mai simpla solutie este un termometru digital din comert, cu un mic montaj care sa faca comutatia pe doi senzori afara/interior. daca vrei sa il construesti tu.... sunt o gramada de scheme pe internet pt termometre digitale. exista chiar integrate specializate care sa faca acest lucru. |
beby1300 |
#135
update la grafica....
randul de jos este indicatorul grafic de turometrum in cifre RPM*1000.... ce pacat ca nu e color display-ul!!!! Attached thumbnail(s) S3010027.JPG ( Size: 168.78k ) Number of downloads: 2223 |
Dreamer |
#136
Daca ai reusi sa faci si un indicator de consum care sa fie functional arat la relenti cat si in sarcina ar fi superb. Un asemenea indicator m-ar interesa si pe mine
![]() Mai este un topik deschis in legatura cu indicatorul de consum ![]() Pana acum ce ai realizat este frumos si sunt sigur ca o sa reusesti mai mult. Termometre digitale gasesti in comert, au senzor pentru interior si unul pentru exterior; sunt destul de ieftine ... pe la 200-300k. |
Ex Renault
Megane 1, 2 si 4
gti98 |
#137
QUOTE(goguf @ 1 Feb 2005, 06:17) Traductorul pentru viteza si kilometraj intentionez sa il montez pe cablul de kilometraj (apropo stie cineva care este nr de rotatii al cablului pt o rotatie a rotilor ?) , pt. kilometraj am gasit o schema ce foloseste numai 3 V la alimentare, astfel pot fi inclusi in schema 2-3 acumulatori de 1,2 V care sa alimenteze integratele atunci cind e deconectata bateria. Detalii dupa ce le voi realiza efectiv (si voi vedea ca functioneaza) Cablul "de kilometraj" care actioneaza vitezometrul si totalizatorul (kilometrajul) face 1 rotatie pentru 1 metru parcurs cu roti cu pneuri 155 sr 13. Informatia este disponibila si pe spatele "ceasului" care integreaza cele 2 functii pomenite mai sus. Ideea cu acumulatorii e f buna! |
Dacia Nova GTI
GTI 98
- IS 57 ENB
gti98 |
#138
QUOTE(goguf @ 29 Jan 2005, 06:13) Am inceput sa fac un bord cu indicatoare digitale Ca principii generale: - sondele pentru tensiunea acumulatorului, nivelul combustibilului, presiunea uleiului, temperatura apei dau aproape direct informatia sub forma de tensiune, citita si afisata fie cu un voltmetru digital, fie cu un VU-metru - turometrul se poate realiza fie cu un frecventmetru digital, fie cu un convertor frecventa-tensiune si citita cu un voltmetru digital (sau 2 VU-metre) -vitezometrul. aici problema este mai complicata, se poate realiza mai greu cu un frecventmetru si mai usor cu un convertor frecventa-tensiune si voltmetru digital (sau 2 VU-metre) - kilometrajul- cu un numarator digital+altele Preturi estimative (integrate si alte piese mai importante): - VU-metru 100k - voltmetru digital 230k - frecventmetru 300k - numarator 250k - convertor frecventa-tensiune 150k (25k o varianta mai slabuta) Pina acum am realizat efectiv un indicator pentru nivetul combustibilului, cu VU-metru, adaptabil si pt tensiune acumulator, temperatura apa, presiune ulei, si am inceput realizarea turometrului. Cine doreste sa incerce ii pot da link-urile catre schemele respective precum si constatarile mele. Bre draga! Pai sau e digital (digit=cifra) adica numeric sau e ANALOGIC, fie cu ace (limbi!!!!) fie cu bar-graph-popular: vu-metru!!! Da??? Doi Un aparat numeric se justifica pentru masuratori de Precizie; ar merge pe vitezometru si pe turometru ( alea analogice cu ace au scara mare, gradatii, etc.). Alelalte au indicatii mai aproximative: Benzina: un sfert, jumate, trei sferturi, plin; uleiu, racirea, tensiunea: prea putin, bine, prea mult. Chestia e ca la volan ai de privit si impiedicatii din fata, si bagaretii din spate, si aia din laterale care le-a crescut barba de cand acorda prioritate, si semaforu si gagica in jeansi mulati si,..si,... si la bord se mai uita sfantul duh! Asa ca daca mai si arata ca la avion cu 439 de ceasuri, ala esti!! Solutii exista: a) avertizoare acustice. Pentru astea nu e nevoie sa te uiti la ele. Chestia e insa sa le folosim DOAR pentru urgente; nu-i presiune la ulei, fierbe apa, etc. de-astea de-ti crapa jucaria. (intra aci si frana de mana cu care merg unii sistematic-trasa si farurile alea cu care-i acu mare moda lasate ziua ca boul in parcare sa descarce bateria...) Eu am o alta sugestie: un bord care afiseaza 1-2 max 3 marimi odata de ex. viteza, temperatura, benzina, sau turatia, presiune ulei si ce vreti voi, dar care poate afisa la comanda si alte chestii de ex. sa comute intre seturile de mai sus. Problema cea mai mare sunt TRADUCTOARELE. Daca turatia o luam de la aprindere, viteza se obtine relativ simplu de la iesirea de km. iar tensiunea o masuram cu un banal voltmetru-banal, banal, da' daca nu-l conectezi unde trebuie citesti tensiunea arteriala a lu' bunicu, mort in celalalt cincinal... Nasol e cu un nivel de benzina-informatie data dracu': fie mergi cu +10litri ca acolo se aprinde becu' si stie si fomeea ca gata tre'sa-i bage benzina, fie arata intotdeauna un sfert de rezervor da' te trezesti in intersectie c-ai ramas in pana aia a p**** de te-njura toti. Cu micro sistem-ca-i PIC, ca-i Z80, poti sa faci multe, da tot traductoarele-s cuiul. |
Dacia Nova GTI
GTI 98
- IS 57 ENB
raptordivx |
#139
![]() Membru autentic Group: Members Posts: 335 Joined: 26 November 04 From: Suceava ![]() |
Sunt interesat daca exista sau daca a facut cineva o schema electronica cu un afisaj electronic care sa indice macar pe aproape nivelul benzinei din rezervor. Si daca da il rog mult de tot sa il puna aici sa mergem si noi la un electronist sa nil faca, sau daca vrea un ban gramada sa il faca el.
1999 / 1.6 16v / concorde
- SV-10-SIS Vreau LAGUNA 2 :D
Giurisici Fabian |
#140
![]() Membru autentic Group: Members Posts: 1.123 Joined: 17 January 06 ![]() |
KIA
PROCEED GT
GT 2023
lucius |
#141
![]() Membru autentic Group: Members Posts: 216 Joined: 13 April 05 From: Bucuresti ![]() |
Nova GTT
- GTG
B31AYZ |
#142
1300 din 1980
- B31AYZ
raptordivx |
#143
Ase e .. sunt unii care e baieti rai .. sau pur si simplu nu stiu pentru ca a fost facut de altii si nu are de unde sa stie cum s-a facut. Noi asteptam ion continuare .. insa ma mira un lucru .. cum are rezervor de 128 litri ???
B31AYZ |
#144
Se pare ca e o eroare sau facatura .
1300 din 1980
- B31AYZ
Giurisici Fabian |
#145
aaaaaa
nu e nici o facatura din cauza ca am folosit integrate c 520D pentru voltmetre la un anumit timp se destabilizeaza pt o sec si arata 128 dar in rest imi arata 005,015,035 etcvapromit ca revin cu scheme sa le adun le pun cap la cap si vi le postez pe topic ca nu am secrete,totul e sa am timp ![]() |
KIA
PROCEED GT
GT 2023
B31AYZ |
#146
Cat ceri pt. lucrare sa iasa ca la tine ? Eu am turometru digital , eventual sa adaptezi afisajul , am si un vitezometru electronic care functioneaza bine pna la 80 Km/h si kilometraj electronic care functioneaza partial .Mai trebuie lucrat la el de un electronist .
Bafta!! |
1300 din 1980
- B31AYZ
Pedro |
#147
![]() Membru autentic Group: Members Posts: 551 Joined: 16 December 03 From: Bucuresti ![]() |
Giurisici Fabian fa un pustiu de bine si spune cum si ce ai facut de ti-a iesit asa
Dacia 1300 OFF ROAD
Berlina O zi trista pentru tara, mare victorie comunista, traiasca.......
yknot |
#148
![]() just turbo Group: Members Posts: 226 Joined: 29 September 04 From: Braila ![]() |
salut,
am facut rost de curand de un bord de kadett gsi, digital, si vreau sa fac rost de schema conexiunilor pt el, stie cineva de unde sa o iau? Multumesc anticipat. |
volvo
480 turbo
1990 ex. owner r5 GTT
raptordivx |
#149
stii ce ma mira pe mine cel mai mult ??? cum ai pus afisajul peste geamurile originale ?? Adica ziua nu se vede numic .. adica se vede prin sticla iar naoptea geamul ala se apuca si lumineaza el asa singurel .. de apar cifrele pe el ..sa mor de ma duce mintea .. cum ai reusit tu sa faci sa apara niste cristale lichide in mijlocul unui geam ?? Sau plexiglass ce o fi ala .. Fa si tu niste poze mai detaliate si ziua cum se vad .. noaptea fa cu un blitz ceva sa intelegem si noi. Eu de exemplu as avea loc in volan .. la mine se scoate capacul acela mare de pe mijloc .. si ar intra un afisaj electronic cu tot ce as vrea pe el .. da cine sa il faca ?
![]() ![]() This post has been edited by raptordivx: 17 Mar 2006, 18:33 |
nassus |
#150
![]() Membru autentic Group: Members Posts: 299 Joined: 24 June 05 From: Bistrita ![]() |
M-am apucat si eu de un bord electronic cu PIC am tot incercat sa dau de beby1300 poate poate ma ajuta si pe mine cu programul pe care il are el sa il studiez si un pic..
Daca mai are careva initiative si se pricepe la programare....HELLLPPP !! ca eu nu prea le am cu programarea... mersi |
Insignia Sport Tourer 163cp
2014
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 20th July 2025 - 02:38 |
