problema frana pe zapada
tdan08 |
JUST A MEMBER Group: Members Posts: 464 Joined: 18 November 08 From: B A C A U ![]() |
Ford Mondeo
Renault Clio
2019 .
cris06 |
![]() Mester Group: Members Posts: 597 Joined: 7 October 08 From: Iasi ![]() |
Tu de ABS ai auzit?
![]() This post has been edited by cris06: 25 Dec 2008, 22:46 |
Daewoo
- IS.06.---
77sky |
![]() Membru ocazional Group: Members Posts: 182 Joined: 22 March 08 ![]() |
Daca are laureat (conform semnaturii)...nu are ABS (corect?)
Daca are laureat+ da, atunci are ABS. Asteptam confirmarea/infirmarea... ![]() |
_
_
_______________ Logan Ambâț 1.5 DCi, 70HP (dopat la 95), JR5 AH, vara lu' 2007 nasterea & "Taz" 1.6 dCi 160 CP, Ints EDC, tot vara, dar lu' 2016
iulic' |
![]() Membru Group: Members Posts: 168 Joined: 28 January 07 ![]() |
Bine zis "afon", stai linistit este doar ABS-ul care isi face treaba.java script:emoticon('<_<')
Laureate 1.5 dCI , 2006
- IF 90 ULI
tdan08 |
da, am citit si m-am lamurit. si eu rad de mine acum
![]() This post has been edited by tdan08: 25 Dec 2008, 23:02 |
Ford Mondeo
Renault Clio
2019 .
77sky |
Totusi...ce model de echipare ai?
![]() Si...ai grija cu acele anvelope,,,sunt excelente pe zapada..."drept sanie" ![]() |
_
_
tdan08 |
da, era doar abs ul care se ruga de mine si mai ca nu imi dadea in cap sa o las mai moale cu frana brusca pe zapada batatorita azi pe la izvorul muntelui. multumesc pt raspunsuri.
26 Dec 2008, 00:05: am laureate cu abs. This post has been edited by tdan08: 25 Dec 2008, 23:05 |
Ford Mondeo
Renault Clio
2019 .
77sky |
adica...Laureate+...mdea...(ar fi bine sa fie pus in semnatura)
Poate folosi in alte posturi... ![]() |
_
_
tdan08 |
gata, m-am conformat, am adaugat si echiparea. multumesc pt timpul acordat pt a-mi raspunde.
26 Dec 2008, 10:15: se poate inchide.multumesc This post has been edited by tdan08: 26 Dec 2008, 09:15 |
Ford Mondeo
Renault Clio
2019 .
Dsign |
si schimba prostiile alea de amvelope
D
2004 Preference 1.6MPI Egee
Alexu7 |
DACIA POPnituita
1310 L
1998
bobo77 |
Laureate 1,6 mpi
2008 ph 2
tdan08 |
asa este
This post has been edited by tdan08: 27 Dec 2008, 10:43 |
Ford Mondeo
Renault Clio
2019 .
cristy90 |
![]() Membru incepator Group: Members Posts: 66 Joined: 5 October 08 From: CONSTANTA ![]() |
PLZ HEELP!!!
De ceva timp am o problema cu ABS’ul adica intra mai repepde decat inaine, azi cand a dat prima fulguiala hai sa ies si eu cu masina si am ramas mirat ,cum apasam pedala de frana, cum intra ABS parca ma dadeam cu sania ![]() ![]() |
EX DACIA
AMBITION 1.6 MPI 2006
- CT xx BCI
ArtVandelay |
![]() Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova ![]() |
de la piciorul tau..
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
bobo77 |
@cristy90 nu este o problema tehnica, este normal ce se intimpla stai linistit.
Laureate 1,6 mpi
2008 ph 2
aammmmmmggggggg |
![]() Membru incepator Group: Members Posts: 42 Joined: 2 November 06 ![]() |
Poti sa ai si cele mai performante cauciucuri de iarna,daca e gheata pe sosesa te tot duci cu tot cu abs.Asa ca ai grija
11.2005-ambition
- BR
cristy90 |
o sa merg luni sa imi cumpar anvelope de iarna…sper sa nu mai intre abs’ul la cea mai mica franare
![]() @ bobo o sa fiu present la intalniri din ianuarie ![]() |
EX DACIA
- CT xx BCI
liviu2004 |
Cine are nevoie, nu mai e folositor ABS-ul:
normal_img_0180.jpg This post has been edited by liviu2004: 30 Dec 2008, 16:34 |
Tigra Twintop
ATM |
![]() 1948 Tucker Torpedo Group: Members Posts: 596 Joined: 28 December 05 From: Bucuresti ![]() |
1. parca bull-barurile aftermarket au fost interzise prin lege.
2. cu bara asta noua (cam de Mitsubishi Pajero Sport, dupa cum o vede ochiul meu...sau poate de vreun tractor, cine stie), masina e mult mai lata, se pierde din manevrabilitate cand te strecori pe langa tramvaie si 3 (nu ma pot abtine): TARANIE COCLITA, FRATEEEEEE! Ii mai trebuia o sigla din aia de Mertan si mergea la vanatoare de biciclisti, ii lua la tinta. This post has been edited by ATM: 31 Dec 2008, 01:14 |
MITSUBISHI
COLT
Z30-2005 Inchiriez fiare de calcat, geamuri termopan, betisoare de urechi, aparate de ras. Rog seriozitate.
AR-18-MOS |
Inca nu ti-ai dat seama ca postul cu poza era la misto?
BMW
730Ld
'07 High Executive
ATM |
Paaaai...nu. Am prostul obicei sa cred de obicei ca o fotografie arata o secventa reala. In fine, daca e manarita, imi retrag comentariile...desi cred ca o exista si in realitate vreuna , la cat de inventiv e romanul.
MITSUBISHI
COLT
loganfan2008 |
![]() Volvo Group: Members Posts: 392 Joined: 6 May 08 ![]() |
QUOTE(tdan08 @ 25 Dec 2008, 23:03) da, era doar abs-ul care se ruga de mine si mai ca nu imi dadea in cap sa o las mai moale cu frana brusca pe zapada batatorita ... ![]() asa sa faci....in caz de urgenta sa nu cumva sa franezi brusc in conditii de aderenta scazuta ![]() by the way, noroc ca acum se fabrica la Dacia, pentru Romania, numai masini cu ABS... Ia vezi, intelegi ce zice asta aici (Cum sa franezi cu ABS)? PS: Logan + ABS + anvelope de vara + sofer incepator + zapada : This post has been edited by loganfan2008: 31 Dec 2008, 10:16 |
Volvo
S40
1996 Swedish car
dariusz |
![]() Membru autentic Group: Members Posts: 479 Joined: 13 February 07 From: baia-mare ![]() |
si mie imi cam tremura !sa fie abs-ul , sau discurile de frina?
supernova
2002 europa
- mm 13 ral membru cooperant
BoomPunk |
![]() Membru fara respect ptr lege si ``organ``! Group: Members Posts: 637 Joined: 20 March 06 From: Bucharest ![]() |
In mod cert e abs-ul,mai ales ca la supernova au pus abs serios de-abia din 2004...
de calcat
Zepter
dariusz |
QUOTE(BoomPunk @ 1 Jan 2009, 22:02) da , din 2004 au inceput sa puna phase2. eu am phase1 , la care apar probleme din cauza interferentei dintre senzorul abs cu cel de la esp. plus ca senzorii comunica intre ei prin intermediul sms-urilor , iar iarna , din cauza frigului , cade semnalul. |
supernova
2002 europa
C@talin |
Range Rover
V8 5.0
Vogue SE
loganfan2008 |
<span class='edit'>2 Jan 2009, 01:03:</span>
QUOTE(dariusz @ 31 Dec 2008, 16:10) este normal ca atunci cand faci franari d'alea 140 -> 50 km/h si apoi intrii cu rotile (discurile) prin apa sa se activeze ABS-ul ![]() PS: ma refer la autovehiculele Dacia, fabricate pana in 2007... ![]() This post has been edited by loganfan2008: 2 Jan 2009, 01:03 |
Volvo
S40
1996 Swedish car
Marius97fer |
![]() Membru cu IQ :) Group: Members Posts: 208 Joined: 12 October 06 ![]() |
Bun abs'u asta. Am reusit sa evit un microbuz. Deja ma vedeam pe la asigurari...
Opel / Rover
Astra / 25
2000 / 2001 hecibec nu sunt inteligent
dariusz |
QUOTE(loganfan2008 @ 2 Jan 2009, 02:02) <span class='edit'>2 Jan 2009, 01:03:</span> este normal ca atunci cand faci franari d'alea 140 -> 50 km/h si apoi intrii cu rotile (discurile) prin apa sa se activeze ABS-ul ![]() ce abs bre ? in cazul prezentat de tine mi se activeaza aws-ul. daca nu stii , mai bine stai deoparte , si nu mai dezinforma. |
supernova
2002 europa
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 24th May 2025 - 11:05 |
