25 Pages < 1 2 3 4 > »
> Recall-uri
aphophis
post 7 May 2009, 23:12
nu a aparut bine camaro-ul ca deja e rechemat in service, datorita unui cablu de la baterie, ce facea ca masina sa nu mai porneasca
Camaro5 forum member Bumleb drove his brand new 2010 Chevy Camaro SS about 40 miles when it suddenly just shut down (that's his car above being trailered back to the dealer on a flat bed). The culprit turned out to be a battery cable run from the trunk. Its insulation had broken down from rubbing up against the starter and eventually just shorted out, which ultimately caused the car itself to shut down. Before this was known, however, the forums blew up with speculation about what could be the cause and Mustang and Challenger fanboys had a field day. It turns out, however, that what happened to Bumleb's new Camaro may not be an isolated incident. General Motors has reportedly issued a voluntary product safety recall for any 2010 Chevy Camaro equipped with a V8 engine to ensure this doesn't happen again.
The recall is a pretty easy fix, but GM is reportedly offering two options for owners: a temporary fix that requires a second visit to a dealer and a permanent fix. The temporary fix involves wrapping the battery cable with protective insulating tape and rerouting it to ensure enough clearance between it and the starter. The permanent fix involves the same thing, except will use a new engine wiring harness that's being shipped to all dealers by May 11. Thus, owners can choose the temporary fix and keep driving their Camaro or just leave it at the dealer until the new wiring harnesses arrive.
The real question is whether or not this recall will damage the Camaro's reputation and ultimately hurt sales. Every aspect of GM is under the microscope, so what does it say when such an important new product launches with a recall right out of the gate? Thanks for the tip, Mark!
UPDATE: The AP reports that GM has built about 1,400 Camaros equipped with a V8 that are affected by this issue, but only 300 have been sold and are therefore under recall. The rest will be fixed before they're delivered to dealers.
http://www.autoblog.com/2009/05/06/report-...ry-cable-issue/
Kia Rio - --- 2021
aphophis
post 9 May 2009, 20:40
recall minor pentru sandero, in spania cred,pt nu stiu ce martor care nu se aprinde
Dacia has been with a call to revision for the Sandero at the worse possible moment. Agreeing with the presentation in Barcelona of the Stepway version, the National Institute of Consumo has issued an official notice to warn that the compact one made in Rumania could have a “possible failure in the witness of the control panel that would not ignite in case it failed the electronic distributor of braking”, reason through which their proprietors will have to go through the factory. In order to facilitate the repairs, Renault will be put in contact with the owners of the affected vehicles.
Dacia se ha encontrado con una llamada a revisión para el Sandero en el peor momento posible. Coincidiendo con la presentación en Barcelona de la versión Stepway, el Instituto Nacional del Consumo ha emitido un comunicado para avisar de que el compacto fabricado en Rumanía podría tener un "posible fallo en el testigo del cuadro de mandos que no se encendería en caso de que fallara el repartidor electrónico de frenado", motivo por el cual sus propietarios deberán pasarse por el taller. Para facilitar las reparaciones, Renault se pondrá en contacto con los dueños de los vehículos afectados.
http://es.autoblog.com/2009/05/09/dacia-sandero-a-revision/
Kia Rio - --- 2021
aphophis
post 12 May 2009, 22:00
recall-uri gm pentru:
CODE
CADILLAC / ESCALADE 2009
CADILLAC / ESCALADE ESV 2009
CADILLAC / ESCALADE EXT 2009
CHEVROLET / AVALANCHE 2009
CHEVROLET / COLORADO 2009
CHEVROLET / SUBURBAN 2009
CHEVROLET / TAHOE 2009
GMC / CANYON 2009
GMC / YUKON 2009
GMC / YUKON XL 2009
CHEVROLET / TRAVERSE
RECALL NOTICE
Vehicle Make / Model: CHEVROLET / CAMARO
Model Year(s): 2010
Manufacturer: GENERAL MOTORS CORP.
Mfr's Report Date: MAY 06, 2009
NHTSA CAMPAIGN ID Number: 09V155000
Component: ELECTRICAL SYSTEM:BATTERY:CABLES
Potential Number of Units Affected: 1243
Summary:
GM IS RECALLING 1,243 MY 2010 CHEVROLET CAMARO EQUIPPED WITH A V8 ENGINE. THE POSITIVE BATTERY CABLE MAY CONTACT THE STARTER MOTOR HOUSING AND CAUSE WEAR ON THE CABLE INSULATION. IF THE INSULATION WEARS THROUGH TO THE CABLE, IT COULD CREATE A SHORT.
Consequence:
A SHORT COULD RESULT IN A NO START CONDITION, CAUSE THE VEHICLE TO STALL WITHOUT THE ABILITY TO RESTART, OR RESULT IN AN ENGINE COMPARTMENT FIRE.
Remedy:
DEALERS WILL REROUTE THE POSITIVE BATTERY CABLE TO ENSURE ADEQUATE CLEARANCE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE MAY 6, 2009. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 OR AT WWW.GMOWNERCENTER.COM.
Notes:
GM RECALL NO. 090121. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
RECALL NOTICE
Vehicle Make / Model: CHEVROLET / TRAVERSE
Model Year(s): 2009
Manufacturer: GENERAL MOTORS CORP. Mfr's
NHTSA CAMPAIGN ID Number: 09V153000
Component: PARKING BRAKE
Potential Number of Units Affected: 15393
Summary:
GM IS RECALLING 15,393 MY 2009 CHEVROLET TRAVERSE VEHICLES FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 135, "PASSENGER CAR BRAKE SYSTEMS." THESE VEHICLES MAY HAVE A PARK BRAKE CABLE LINK (CONNECTOR) THAT IS NOT TO SPECIFICATION. THIS CONNECTOR MAY FRACTURE WHEN THE PARK BRAKE PEDAL IS DEPRESSED.
Consequence:
IF THE TRANSMISSION SHIFT LEVER IS IN THE PARK POSITION, THERE WILL BE NO UNINTENDED VEHICLE MOVEMENT. HOWEVER, IF THE KEYS ARE LEFT IN THE IGNITION, THE TRANSMISSION SHIFT LEVER IS IN ANY POSITION OTHER THAN PARK, AND THE VEHICLE IS PARKED ON A SUFFICIENT SLOPE, IT COULD RESULT IN UNINTENDED VEHICLE MOVEMENT. THIS COULD RESULT IN A CRASH WITHOUT PRIOR WARNING.
Remedy:
DEALERS ARE TO REPLACE THE PARK BRAKE CABLE LINK (CONNECTOR) FREE OF CHARGE. GM ANTICIPATES THAT THE DEALER BULLETIN WILL BE SENT MAY 5, 2009 AND OWNER LETTERS WILL BE MAILED IN JUNE 2009. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438, OR AT WWW.GMOWNERCENTER.COM.
Notes:
GM RECALL NO. 09045. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
RECALL NOTICE
Vehicle Make / Model: Model Year(s):
GMC / CANYON 2009
GMC / YUKON 2009
GMC / YUKON XL 2009
NHTSA CAMPAIGN ID Number: 09V154000
Component: FUEL SYSTEM, GASOLINE
Potential Number of Units Affected: 27188
Summary:
GM IS RECALLING 27,188 MY 2009 CADILLAC ESCALADE, ESCALADE HYBRID, ESCALADE ESV, AND ESCALADE EXT; CHEVROLET AVALANCHE, SUBURBAN, TAHOE, TAHOE HYBRID, AND COLORADO; AND GMC YUKON, YUKON HYBRID, YUKON XL, AND CANYON VEHICLES. THE FUEL SYSTEM CONTROL MODULES MAY HAVE A CONDITION IN WHICH AN ADHESIVE SEPARATION OF THE ROOM TEMPERATURE VULCANIZING (RTV) SEAL BETWEEN THE SEAL AND THE HOUSING MAY ALLOW WATER TO SEEP INTO THE MODULE.
Consequence:
WATER IN THE MODULE COULD CAUSE A SHORT OR OPEN CIRCUIT, ILLUMINATION OF THE SERVICE ENGINE SOON LAMP, SETTING OF DIAGNOSTIC TROUBLE CODES OR THE ENGINE MAY BE HARD TO START, MAY NOT START OR MAY STALL INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL INSTALL A NEW FUEL SYSTEM CONTROL MODULE FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE MAY 18, 2009. OWNERS MAY CONTACT CADILLAC AT 1-866-982-2339, CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463 OR AT WWW.GMOWNERCENTER.COM.
Notes:
GM RECALL NO. 08411. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
http://www.autoblog.com/2009/05/12/gm-reca...various-faults/
Kia Rio - --- 2021
aphophis
post 17 May 2009, 15:03
recall mitsubishi outlander si mitsubishi lancer, cu probleme la sistemul de franare (daca am inteles bine):
Today we bring a handful to you of new calls to revision for “cheering” the weekend. Several models of Mitsubishi and Volvo have appeared in the European network of alert by technical problems that they will have to be corrected in the factory.
Beginning by Mitsu, the Outlander and Lancer CW5W, CX3A, CX4A, CY2A, CY3A, and CY4A can present/display a problem in the control valve of the servo brake. The symptoms are difficulties to tighten the brake pedal after to have left parked the vehicle during several hours, as well as a hardening of the same circulating at low speed. The models with change of marches manual are not affected, but the rest is under suspicion and will have to be reviewed by the house.
http://babelfish.yahoo.com/translate_url?d...TrUrl=Translate
Kia Rio - --- 2021
aphophis
post 22 May 2009, 17:38
recall vw jetta
Volkswagen has announced that it will recall some 25,594 examples of its 2006-2009 Jetta over a potential driveshaft issue. According to the National Highway Traffic Safety Administration, cars with the company's 2.0-liter inline-four may have driveshaft cover plates that weren't manufactured properly, with the consequence that their screws may not be torqued correctly. If the screws back out, drivers may experience a knocking sound while in motion. In the extreme, the driveshaft could conceivably detach from the gearbox, which could cause all kinds of problems that might lead to a crash.
Owners of 2006-2009 Jettas with the 2.0-liter engine should contact their VW dealer for a free inspection and/or replacement of the screws. Affected parties can also contact Volkswagen directly at 1-800-822-8987 to learn more. The recall is set to officially begin on June 19, 2009. The full NHTSA report is after the jump.
[Source: NHTSA]
Press Release:
Report Date : May 21, 2009 at 03:41 PM
NHTSA CAMPAIGN ID Number: 09V164000
VOLKSWAGEN / JETTA 2006-2009
Manufacturer: VOLKSWAGEN OF AMERICA, INC Mfr's Report Date: MAY 13, 2009
NHTSA CAMPAIGN ID Number: 09V164000 NHTSA Action Number: N/A
Component: POWER TRAIN:DRIVELINE:DRIVESHAFT
Potential Number of Units Affected: 25594
Summary:
VOLKSWAGEN IS RECALLING 25,594 MY 2006-2009 JETTA 5TH GENERATION EQUIPPED WITH 2.01 ENGINE. THE FASTENING SCREW CONTACT SURFACES ON THE DRIVESHAFT COVER PLATE MAY NOT HAVE BEEN MANUFACTURED TO FACTORY SPECIFICATIONS. SOME SCREWS MAY NOT HAVE BEEN TORQUED PROPERLY DURING ASSEMBLY AND COULD LOOSEN OVER TIME, CAUSING A KNOCKING SOUND WHEN THE VEHICLE IS IN MOTION. THE DRIVESHAFT SCREWS COULD LOOSEN TO THE POINT WHERE THE DRIVESHAFT DETACHES FROM THE GEARBOX.
Consequence:
IF THE VEHICLE IS MOVING WHEN THIS HAPPENS, THE DETACHED DRIVESHAFT COULD CAUSE DAMAGE THE GEARBOX HOUSING. A DAMAGE GEARBOX HOUSING COULD LEAK GEARBOX OIL ONTO THE STREET AND CREATE A RISK OF A VEHICLE CRASH FOR BOTH THE DRIVER AND OTHER MOTORISTS.
Remedy:
DEALERS WILL INSPECT THE DRIVESHAFT SCREWS AND REPLACE THE SCREWS FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR BEFORE JUNE 19, 2009. OWNERS MAY CONTACT VOLKSWAGEN AT 1-800-822-8987.
Notes:
VOLKSWAGEN RECALL NO. 40J2/S4. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
http://www.autoblog.com/2009/05/22/vw-reca...ty-driveshafts/
Kia Rio - --- 2021
aphophis
post 23 May 2009, 20:34
recall-uri pentru nissan murano, dacia logan si suzuki grand vitara
Ya es sábado, y eso significa que toca hablar de llamadas a revisión. Hoy son tres los nombres que nos proporcionan el sistema de alertas de la Unión Europa y el Instituto Nacional del Consumo: Nissan Murano, Dacia Logan y Suzuki Grand Vitara.
El SUV de Nissan se ha visto afectado por un defecto mecánico que podría causar un mal funcionamiento del motor, llegando incluso a pararse en pleno funcionamiento. Concretamente, esto es lo que dice el informe: El conducto de entrada de aire del motor, que está conectado al resonador intermedio del sistema de entrada de aire al motor, se puede soltar del resonador. Esto puede provocar un ralentí inestable o una aceleración pobre y en caso extremo, el motor puede pararse en marcha.
La solución consiste en cambiar dicho conducto de aire, para lo cual Nissan ya está informando a consumidores y talleres.
En cuanto al Dacia Logan, se repite exactamente el mismo defecto visto hace dos semanas en el Sandero. El testigo que indica un posible fallo en el sistema de freno podría no iluminarse. Todas las unidades afectadas fueron fabricadas entre el 26 de mayo y el 12 de noviembre de 2008.
Finalmente, en el Suzuki Grand Vitara 1.9 se ha detectado que las camisas de parte del cableado del motor podrían deteriorarse al rozar con el tornillo de la tapa de la correa de distribución, pudiendo causar un cortocircuito y en el peor de los casos, llamas. Los modelos bajo sospecha tienen los siguientes números de identificación: JSAJTD44V00106868 a JSAJTD44V00223811 (5D), y JSAJTA44V00107438 a JSAJTA44V00208921 (3D). Su fecha de producción está comprendida entre junio de 2005 y el 28 de febrero de 2007
http://es.autoblog.com/2009/05/23/llamadas...uzuki-grand-vi/
Kia Rio - --- 2021
aphophis
post 24 May 2009, 21:03
recall pontiac g8, pt probleme electronice
Cerca de 35.000 unidades do Pontiac G8, anos de fabricação 2008 e 2009, estão envolvidos em um recall, onde os donos do sedã esportivo serão chamados para resolver alguns problemas eletrônicos.
http://www.noticiasautomotivas.com.br/gm-f...iac-g8-nos-eua/
Kia Rio - --- 2021
Modus
post 25 May 2009, 13:08
Recall Audi A3 2.0 TDI http://www.automobiletv.ro/event.php?id=299
This post has been edited by Modus: 25 May 2009, 15:01
Renault Clio GTLine 1.5 dCi EDC 2018
post 25 May 2009, 13:12
Eu as zice ca este vorba de volanta bimasica, care face ravagii si la passat 2.0tdi aka eternul pacient ... (monument de fiabilitate tedei rulez asta radmasa.gif )
This post has been edited by IRONICK: 25 May 2009, 13:22
CUGIR Albalux 11 (©SanGiorgio) - B-11-LUX 1982
aphophis
post 26 May 2009, 23:17
recall hyundai sonata 2002, 2003, implica 91.000 de masini
When opening a door, one expects to grab the handle and pull without the risk of injury. If you own a 2002 or 2003 Hyundai Sonata with chrome handles, you may not have that luxury, says the National Highway Traffic Safety Administration. As a result, Hyundai is recalling 91,000 Sonatas because the chrome plating on the upper edge of the interior handle may wear, "causing cracking or separation between the chrome plating on the inboard and outboard surfaces of the handle." NHTSA says the sharp edge can cause "laceration injuries to anyone using the door handle." Ouch.
Sonata owners can take their vehicle to any Hyundai dealership to have their handles repaired free of charge beginning in June. To find out if your car is eligible for the repair, call 1-800-633-5151. Hit the jump to view the official press release.
http://www.autoblog.com/2009/05/26/hyundai...-to-sharp-chro/
27 May 2009, 21:06:
recall mercedes m-class in brazilia,16.000 de unitati implicate
Os donos dos modelos ML 320 CDI, ML 350, ML 500 e ML 63 AMG aqui do Brasil, fabricados entre julho de 2008 e março de 2009, deverão comparecer a uma concessionária da marca. Um recall está sendo feito por problema na lanterna traseira.
Os chassis afetados são 9WDC1641221A4442562 a 9WDC1641861A5113108. Essas unidades tem que trocar a vedação da lanterna traseira. Segundo a fabricante, pode ocorrer infiltração de água no módulo de acionamento da tampa do porta-malas e causar um curto-circuito no equipamento, com risco de princípio de incêndio.
No dia 16 de março publicamos aqui no NA esse mesmo recall, que estava sendo feito lá no exterior, e que envolvia mais de 16.000 unidades dos Classe M. Já aqui o número de carros envolvidos deverá ser mínimo. Maiores informações no telefone 0800-9709090 ou no site www.mercedes-benz.com.br.
http://www.noticiasautomotivas.com.br/clas...terna-traseira/
This post has been edited by aphophis: 27 May 2009, 21:06
Kia Rio - --- 2021
aphophis
post 31 May 2009, 09:20
recall-uri pt hyundai i20 (probleme la cauciucuri, problema la ventil daca nu ma insel, se desumfla roata), fiat scudo, tesla roadster si lotus exige
Para no perder la costumbre, esta semana los talleres volverán a tener trabajo con un nuevo lote de llamadas a revisión. Uno de los vehículos afectados, además, tiene muy poco que ver con la plebe, demostrando una vez más que la invulnerabilidad de las marcas premium es un mito como otro cualquiera. Grandes y pequeños, todos caen por igual.
Empecemos si te parece por el Tesla Roadster. La estrella de los coches a baterías tendrá que ser revisada debido a un defecto de origen. Los operarios de Lotus, que fabrican el biplaza bajo encargo, no apretaron con la fuerza suficiente los tornillos de los bujes de las ruedas, algo que podría notarse inmediatamente en forma de ruidos y vibraciones. En total, son 345 las unidades a reparar, todas ellas fabricadas antes del 22 de abril de 2009. Este problema también afecta a varias unidades de los Lotus Exige y Elise.
Volviendo a la tierra, Fiat tendrá que ocuparse de cierto asuntillo relacionado con el Scudo. El problema se encuentra en la válvula del servofreno, que podría perder efectividad con el tiempo, endureciendo el pedal e incluso pudiendo ocasionar un accidente. Las unidades 2.0 JTD 16V con chasis 4004001 a 4019385 deberán pasarse por la consulta del médico.
Finalmente, se ha detectado que algunos neumáticos del Hyundai i20 tienen válvulas defectuosas. El resultado, obviamente, sería una fuga de aire. Las unidades con llantas de acero de 15" fabricadas hasta el 31 de marzo de 2009 se encuentran bajo sospecha. Los números de identificación son los siguientes:
    * MALBB51BP9M000992 a MALBB51BP9M031200
    * MALBB51CP9M003103 a MALBB51CP9M028064
    * MALBB51SP9M012597 a MALBB51SP9M019167
http://es.autoblog.com/2009/05/30/llamadas...y-elise-fiat-s/
Kia Rio - --- 2021
aphophis
post 6 Jun 2009, 19:46
recall Volvo S40, V50, C30, C70, S80 y V70 cu motor 2.0d , probleme la servofrana
Volvo no es una marca que nos tenga acostumbrados por sus avisos a revisión, pero últimamente está acumulando unos cuantos. El último emitido por el servicio de alertas de la UE llama la atención sobre un problema técnico en los S40, V50, C30, C70, S80 y V70 modelo 2009 con el motor 2.0 D. Todos estos vehículos se encuentran bajo sospecha de equipar unos servofrenos defectuosos, cuya efectividad podría verse reducida a bajas temperaturas con el consiguiente riesgo de accidente.
La verdad es que este problema se ha convertido casi en habitual durante las últimas semanas (son ya muchas las marcas con servofrenos despistados), así que no nos extrañaría ni un pelo que algún proveedor de componentes común hubiera metido la pata en alguna parte.
http://es.autoblog.com/2009/06/06/llamadas...-c70-s80-y-v70/
Kia Rio - --- 2021
aphophis
post 10 Jun 2009, 08:23
probleme cu rugina la kia optima, 36.538 masini rechemate
The 2001-2004 Kia Optima is being recalled in several states for corrosion of the front subframe. The recall covers some 36,538 examples sold in the U.S. in the following states: Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin, and the District of Columbia – all areas typically noted for being high rust threats due to their difficult winters and use of road salt.
According to the recall, internal corrosion of the front subframe can weaken the mounting points near the lower control arm, leading to everything from irregular tire wear to abnormal stress levels in the system that may contribute to a cras.
The recall begins this month, but neither Kia nor NHTSA have outlined a potential fix in the recall notice posted after the jump.
http://www.autoblog.com/2009/06/09/kia-rec...ne-states-over/
Kia Rio - --- 2021
aphophis
post 13 Jun 2009, 21:28
recall ford Focus, Focus CC, C-MAX, Kuga, Mondeo, S-MAX si Galaxy, cu motor diesel 2.0 duratorq, fabricate intre 1 noiembrie 2008 si 12 martie 2009, probleme la servofrana, putand duce la accidente. Si la volvo a fost recall pe acelasi motiv daca nu ma insel.
Una vez más, un defecto en una pieza concreta se extiende a los catálogos de múltiples marcas. Después de que la semana pasada Volvo tuviera que llamar a revisión a buena parte de su gama, Ford ha tenido que hacer lo mismo con los Focus, Focus CC, C-MAX, Kuga, Mondeo, S-MAX y Galaxy. Si has estado atento a las revisiones de los últimos días, ya te habrás imaginado que la causa se encuentra en los servofrenos.
El problema concreto, tal y como aparece en la notificación de la red de alertas de la Unión Europea, es que la válvula antirretorno del servofreno se puede quedar atascada durante el calentamiento del motor, resultando en un endurecimiento importante en el pedal y la consiguiente pérdida de frenada.
Los vehículos equipados con el motor 2.0 Duratorq (DW10, diésel) fabricados entre el 1 de noviembre de 2008 y el 12 de marzo de 2009 se encuentran bajo sospecha, por lo que el fabricante se pondrá en contacto con sus propietarios para la correspondiente visita al taller.
http://es.autoblog.com/2009/06/13/llamadas...ax-kuga-mondeo/
Kia Rio - --- 2021
aphophis
post 16 Jun 2009, 00:06
Audi a rechemat modelele A3 cu motor diesel 2.0 TDI in service pentru inlocuirea volantei si a discului de ambreiaj.
udi A3 cu defectiuni costisitoare la ambreiaj
Afectate de aceasta defectiuni sunt 73.000 de automobile Audi A3 cu 3 si 5 usi echipate cu motorul diesel 2.0 TDI. Defectiunea consta din desprinderea unui arc din volanta dubla, arc care poate distruge discul de ambreiaj si poate sparge carcasa ambreiajului. Aceasta defectiune se intalneste la A3 produse in intervalul Iunie 2003 si decembrie 2004. Reparatia este normata la cinci ore si este gratuita la toate aceste modele chiar daca automobilele nu mai sunt in garantie. Atentie: rechemarea inseamna inlocuirea volantei si a discului dar in cazul unei defectiuni service-ul va trebui sa inlocuiasca gratuit tote piesele defecte( volanta, disc, carcasa).
Kia Rio - --- 2021
aphophis
post 30 Jun 2009, 20:40
recall saturn vue (masina foarte inrudita cu opel antara si chevrolet captiva), din cauza ca usile se pot deschide in mers datorita.. vopsirii proaste ( ? )
Some 44,451 Saturn Vue models from the 2008 model year are being recalled, and yours might be a part of the action if it has body-color door handles. What's the deal? According to the National Highway Traffic Safety Administration, the handles may stick, preventing the door from properly latching.
NHTSA says an unbelted occupant could tumble out of the vehicle as a result of a door that refuses to latch, though one has to figure that you're sort of asking for it by ignoring the safety gear. In any circumstance, doors that pop open aren't acceptable, so the 44,451 vehicles affected will be give chrome door handles by dealers at no charge to customers. The recall goes into full effect by August 18th, plenty of time to get a can of Nevr-Dull to keep those shiny handles looking their best.
http://www.autoblog.com/2009/06/30/report-...vers-because-o/
Kia Rio - --- 2021
smailmiami
post 30 Jun 2009, 21:04
Stire de stire ... E valabil pentru nord-americani, nu ?
This post has been edited by smailmiami: 30 Jun 2009, 21:09
Daewoo Leganza - DJ-10-DKL 2004
paul_s
post 30 Jun 2009, 22:22
smile.gif) da tu chiar te oftici:))
smailmiami
post 30 Jun 2009, 22:52
Absolut deloc. Ma intrebam si eu daca asta este o stire, faptul ca-ti poate aluneca mana pe clanta ... Cred ca poti gasi cam 100 din astea pe zi.
aphophis
post 30 Jun 2009, 23:08
stirea nu e ca iti aluneca, ci ca se face recall pentru ca usa se poate deschide in mers si poti pica din masina. Si cred ca am inteles destul de bine articolul smile.gif
Kia Rio - --- 2021
aphophis
post 10 Jul 2009, 21:21
recall f rusinos pentru vw touareg, pentru spoilerul spate (sper ca am zis bine) al touaregului ce se poate desprinde de masina.
Volkswagen has proven that they understand the benefits of active aerodynamics – but a new recall in conjunction with the National HIghway Traffic Safety Administration centers on the potential for some completely unintentional and undesired active aero with the company's products.
According to NHTSA, VW will recall 14,416 2007-2009 Touareg SUVs because the vehicle's roof spoiler can jettison itself from the vehicle, potentially striking pedestrians or other vehicles. Apparently, the problem stems from the fastening struts on the spoiler which can crack, leading to the loosening or outright detachment of the aerodynamic element.
Owners of Touaregs covered under the recall can bring their vehicles to their local dealer, which will install reinforcement wedges to the assembly for free. Official recall information posted after the jump. Top tip, Jeff!
PRESS RELEASE:
VOLKSWAGEN / TOUAREG 2007-2009
Manufacturer: VOLKSWAGEN OF AMERICA, INC Mfr's Report Date: JUN 25, 2009
NHTSA CAMPAIGN ID Number: 09V248000
N/A
Component: STRUCTURE:BODY
Potential Number of Units Affected: 14416
Summary:
VOLKSWAGEN IS RECALLING 14,416 MY 2007-2009 TOUAREG VEHICLES. THE FASTENING STRUTS ON THE ROOF EDGE SPOILER CAN CRACK, CAUSING THE SPOILER TO BECOME LOOSE AND POSSIBLY DETACH FROM THE VEHICLE WITHOUT WARNING, EVEN THOUGH INITIALLY THE SPOILER MAY FEEL SECURE.
Consequence:
IF THIS HAPPENS, THE SPOILER COULD CAUSE INJURY BY STRIKING PERSONS OUTSIDE THE VEHICLE OR COULD BECOME AN OBSTACLE TO OTHER DRIVERS, POSSIBLY RESULTING IN A CRASH.
Remedy:
DEALERS WILL INSTALL REINFORCEMENT WEDGES TO THE ROOF EDGE SPOILER FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING JULY. OWNER MAY CONTACT VOLKSWAGEN AT 1-800-822-8987.
Notes:
VOLKSWAGEN RECALL NO.66D6/S5. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
http://www.autoblog.com/2009/07/10/over-ac...9-touareg-over/
Kia Rio - --- 2021
Squirrel
post 15 Jul 2009, 14:39
Captain of Black Pearl™…
E corect…doar cã nu e spoiler-ul de protecþie (cel cu ochii-de-pisicã), aºa cum am crezut eu la prima impresie, ci acel spoiler aerodinamic amplasat în partea superioarã a lunetei (aºa cum reiese din comunicatul oficial).
Dacia Duster - RO 44 AWD 2010 1,6 16v 4×4 Laureaté Noir Nacré
Fire, walk with me...in 4 strokes, water cooled.
aphophis
post 19 Jul 2009, 09:48
recall pentru bmw X5, X6, Seria 1 si Seria 3, probleme cu airbagurile laterale si cu franele:
BMW va rechema in service anumite modele X5, X6, Seria 1 si Seria 3 pentru a remedia doua probleme situate la nivelul discurilor de frana din spate, respectiv airbag-urilor laterale.
BMW a anuntat un recall pentru X5, X6, Seria 1 si Seria 3 zoom
BMW va face doua recall-uri separate in Statele Unite ale Americii pentru modelele Seria 1 si Seria 3 construite de la jumatatea lui 2007 pana in 2008, precum si pentru modelele X5 si X6 construite de la jumatatea lui 2008 pana in 2009. Modelele Seria 1 si Seria 3 au o problema la nivelul cablajului airbag-urilor laterale si al sistemelor de pretensionare al centurilor de siguranta, pe cand SUV-urile X5 si X6 au probleme la nivelul discurilor de franare de pe puntea spate.
Doar anumite modele vor fi chemate la acest recall, BMW urmand sa indexeze seriile de caroserie aferente rechemarii in service pentru a chema doar automobilele care ar putea avea probleme ulterior. Problema in cazul modelelor Seria 1 si Seria 3 apare din cauza unui conector incorect, care nu ofera o conexiune perfecta in toate momentele si poate sa nu declanseze airbag-urile laterale sau sistemul de pretensionare al centurilor de siguranta.
In cazul SUV-urilor X5 si X6, BMW anunta ca unele unitati produse in SUA ar putea avea probleme la nivelul discurilor de frana de pe puntea spate. Discurile de frana folosite la unele modele nu corepund calitatii cerute de BMW si s-ar putea sa nu ofere performante optime in fiecare moment. Recall-urile operate de BMW sunt gratuite pentru proprietarii modelelor cu probleme si constau in inlocuirea elementelor cu defecte din fabrica.
http://www.automarket.ro/stiri/bmw-a-anunt...ia-3-22868.html
textul in engleza:
MW has announced two separate recalls involving 2008 model year 1-Series and 3-Series models and 2009 model year X5 and X6 models. The 1- and 3-Series models are being recalled for a possible air bag problem while the X5 and X6 SUVs are being recalled for possible braking issues.
According to the National Highway Traffic Safety Administration, some 2008 model year 1-Series and 3-Series models could have incorrect air bag wiring. Some models may have been equipped with the incorrect crimp connector, resulting in an insufficient connection.
As a result, side air bags and seatbelt tensioners may not function properly in the event of a crash, possibly leading to the increased risk of injury.
Separately, BMW is recalling 2009 X5 and X6 models for a potential brake disc problem. Some models may have been equipped with rear brake discs that are not up to spec, potentially leading to brake failure and the increased risk of crash.
Kia Rio - --- 2021
aphophis
post 22 Jul 2009, 20:45
recall honda civic si honda accord, pentru probleme la airbag, care se pot declansa mai tare decat ar trebui, explodand , chestie ce poate rani pasagerii, datorita resturilor imprastiate cu mare viteza:
Honda is recalling some of its 2001 model year Accord and Civic models due to excessively pressurized airbags. The National Highway Traffic Safety Administration says that certain airbags in the affected vehicles can deploy so violently that the inflator will rupture. When the bag is deployed, NHTSA says that metal shards from the excessive explosion could act like shrapnel, shoot through the bag and possibly injure vehicle occupants. We're no crash experts, but that sounds like it would hurt a lot.
Owners of affected 2001 Accords and Civics will be able to bring in their vehicle to their local Honda store where the inflator will be replaced free of charge. Honda hasn't yet released a notification schedule or disclosed how many of each model will be recalled, but owners can find out more info by calling Honda at 1-800-999-1009. Check out the galleries below and hit the jump to read the official NHTSA press release
http://www.autoblog.com/2009/07/21/2001-ho...s-that-are-eve/
Kia Rio - --- 2021
aphophis
post 28 Jul 2009, 22:32
recall subaru baja, 15.000 de unitati implicate:
The Subaru Baja never managed to win over the buying public, but those that own the little trucklet seem to downright adore Fuji Heavy's platypus, so they'll probably want to listen up, as their baby may be subject to a safety recall.
The National Highway Traffic Safety Association has discovered that cracks may develop in the Baja's fuel hose connection on the pressure side of the pump. The condition could result in a fuel leak, which could then lead to a fire. Beginning in September, Subaru is recalling 15,633 MY 2005-2006 Bajas and affected owners can bring their vehicles to any Subaru dealer to get the fuel pump bracket – including all nipples – replaced free of charge. Hit the jump to read over NHTSA's press release.
[Source: NHTSA]
PRESS RELEASE:
Vehicle Make / Model: SUBARU / BAJA Model Year(s): 2005-2006
Manufacturer: SUBARU OF AMERICA, INC. Mfr's Report Date: JUL 16, 2009
NHTSA CAMPAIGN ID Number: 09V277000
NHTSA Action Number: EA09007
Component: FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMP
Potential Number of Units Affected: 15633
Summary:
SUBARU IS RECALLING 15,633 MY 2005-2006 BAJA VEHICLES. CRACKS MAY DEVELOP IN THE FUEL HOSE CONNECTION ON THE OUTLET PRESSURE SIDE OF THE FUEL PUMP.
Consequence:
FUEL CAN LEAK FROM THE HOSE CONNECTION. A FUEL LEAK, IN THE PRESENCE OF AN IGNITION SOURCE, COULD RESULT IN A FIRE.
Remedy:
DEALERS WILL REPLACE THE FUEL PUMP BRACKET INCLUDING ALL NIPPLES WITH A NEW AND STRONGER DESIGN PART. THIS SERVICE WILL BE PERFORMED FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN DURING SEPTEMBER 2009. OWNERS MAY CONTACT SUBARU AT 1-800-782-2783.
Notes:
SUBARU RECALL NO. WVJ-20. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
http://www.autoblog.com/2009/07/27/subaru-...fuel-pump-woes/
Kia Rio - --- 2021
aphophis
post 2 Aug 2009, 10:30
recall-uri in europa pentru o gramada de masini , inclusiv honde si toyote:
Hoy venimos cargados de trabajo para los talleres oficiales. La red de alerta de la Unión Europea informa de llamadas a revisión para cinco vehículos de otras tantas marcas, que deberán acercarse por la consulta del médico lo antes posible. Comencemos si te parece por el más grande de todos.
Range Rover: Según lo informado en el último boletín, las autoridades han detectado varios parabrisas mal ajustados en el gran todoterreno del fabricante inglés. En caso de sufrir un impacto fuerte, la pieza completa correría el riesgo de separarse del vehículo, poniendo en peligro a sus ocupantes. El número de unidades afectadas se desconoce, pero la casa debería ponerse en contacto con los propietarios de los coches para proceder a su revisión.
Mercedes-Benz Clase M: Los todocaminos fabricados entre julio de 2008 y marzo de 2009 están bajo sospecha por riesgo de cortocircuito. Se ha detectado que las carcasas de los pilotos traseros no están selladas correctamente, por lo que podría entrar agua en el módulo de control del portón trasero. En el peor de los casos, podría originarse un fuego. Las unidades con números de chasis comprendidos entre A 371.944 y A 511.386 tendrán que ser revisadas.
Peugeot Partner: Problema con la fijación de los asientos. Más concretamente, la soldadura del asiento posterior izquierdo podría ser inadecuada, con el consiguiente riesgo de lesiones en caso de accidente. Las unidades a revisar están marcadas con los códigos VF37J9HTC6803535 a VF37P9HZC6803670.
Lancia Ypsilon: El italiano presenta un problema en sus ruedas. Al parecer, los pernos no están ajustados para soportar el par motor del coche, y podrían soltarse sobre la marcha. Si tienes un Ypsilon con un número de identificación entre 3255238 y 3257793, ya sabes lo que te toca.
Toyota Avensis: Al parecer Toyota habría ajustado con demasiada fuerza los ganchos de remolque, hasta el punto de que los pernos podrían romperse bajo ciertas condiciones de uso. Están afectadas las unidades fabricadas entre el 29 de octubre de 2008 y el 10 de febrero de 2009 (solo aquellas con gancho de remolque, obviamente).
Por otro lado, Honda ha emitido un comunicado en EEUU para informar de la revisión de nada más y nada menos que 440.000 vehículos por culpa de un grave defecto el airbag del conductor. [b]Los Accord 2001-2002, Civic 2001 y Acura TL 2002-2003[b] habrían sido equipados con unos airbags pasados de presión. Tanto es así que el dispositivo de inflado podría romperse. Literalmente, esto podría hacer que "fragmentos de metal pasaran a través del material textil de la bolsa, posiblemente causando heridas o incluso la muerte a alguno de los ocupantes del vehículo". Por el momento y que se conozca, este aviso sólo está relacionado con las unidades comercializadas en Estados Unidos.
http://es.autoblog.com/2009/08/01/llamadas...m-peugeot-part/
This post has been edited by aphophis: 2 Aug 2009, 10:31
Kia Rio - --- 2021
aphophis
post 22 Aug 2009, 15:55
recall pentru masinile vag cu dsg, in statele unite:
Anybody who bought a Volkswagen in North America in the past year with a DSG gearbox will want to keep an eye on their mailbox in the coming weeks for a note from the home office in Herndon, Virginia. It seems there is an issue with a temperature sensor in the dual clutch transmission. Problematic sensors can give erroneous readings that cause warning lamps in the cluster to turn on or send the transmission into neutral.
The quick-shifting DSG is a popular option in the Jetta sedan, Sportwagen, GTI and Eos convertible. A total of 13,500 cars built between September 2008 and August 2009 are being brought in for inspection and possible repair. You can check out the complete VW press release after the jump.
http://www.autoblog.com/2009/08/21/volkswa...odels-over-sen/
Kia Rio - --- 2021
aphophis
post 24 Aug 2009, 21:33
Posibil risc de incendiu la Jeep Wrangler
utoritãþile federale americane au demarat o investigaþie ce are ce obiect 200.000 de unitãþi Jeep Wrangler, fabricate în perioada 2007-2008, care prezintã un risc de incendiu.
National Highway Traffic Safety Administration (NHTSA) anunþã cã este vorba de modele cu transmisie automatã, la care poate izbucni un incendiu. NHTSA a primit trei plângeri privind incendii provocate de supraîncãlzirea transmisiei care se aprinde sau curgerea lichidului hidraulic, care, odatã prelins pe catalizatorul încins, izbucneºte în flãcãri.
Chrysler precizeazã cã ºtia de aceastã problemã, însã a precizat cã avea informaþii legate de unitãþi vândute în China, unde au existat câteva incendii de mici proporþii, fãrã victime sau daune materiale însemnate, însã nu cunoºtea cã situaþia se regãseºte ºi în SUA.
În funcþie de rezultatele investigaþiei, NHTSA ar putea sugera producãtorului auto o rechemare în service pentru înlãturarea pericolului.
http://www.capital.ro/articol/posibil-risc...ler-123829.html
Kia Rio - --- 2021
aphophis
post 26 Aug 2009, 20:39
Toyota recheamã 700.000 de maºini pe piaþa chinezã
Producãtorul auto Toyota a anunþat cã a rechemat 700.000 de maºini vândute pe piaþa din China, din cauza unor probleme la sistemul electric de închidere a geamurilor.
Defecþiunea putea pune în pericol viaþa pasagerilor deoarece ar fi existat riscul producerii unui scurtcircuit ºi chiar a unui incendiu.
Rechemarea vizazã modelele Camry, Yaris ºi Corolla. Potrivit oficialilor companiei japoneze, aceste modele au fost construite în parteneriat cu firmele chineze Guangzhou Automobile Group ºi Tianjin FAW.
De asemenea, piesele folosite pentru producþia maºinilor respective au fost produse pe piaþa chinezã, fapt ce ridicã un semn de întrebare privind capacitatea Toyota de a menþine standardele de calitate.
Grupul japonez a mai rechemat în luna aprilie alte 250.000 de autovehicule Camry, din cauza unor probleme la sistemul de frânare.
Toyota a fabricat 547.000 de masini în China în  2008, destinate pieþei locale.
http://www.capital.ro/articol/toyota-reche...eza-124117.html
Kia Rio - --- 2021
Executron
post 26 Aug 2009, 21:42
Membru fan UAP
Multumim lui Aphophis ca ne tine la curent cu recall-urile din lume.
Ce mi se pare FOARTE interesant e ca recall-urile din state sunt destul de numeroase (chiar si la modele europene) fapt ce ma face sa ajung la urmatoarele concluzii...
Ori... Masinile americane se strica mai repede/sunt facute la standarde inferioare... (discutabil)
Ori.... Corporatiilor le e cam frica de modul optim in care se aplica legea (mai ales cea de protectie a consumatorului) si nu se risca.. (ca in alte tari bananiere)
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 9th September 2025 - 01:32
