Un altfel de ARO, facut la rusi
tache |
![]() Membru incepator Group: Members Posts: 33 Joined: 22 November 04 ![]() |
paulp |
![]() Bagator de seama! Group: Members Posts: 3.098 Joined: 31 July 03 From: Iasi ![]() |
Ce naiba-i asta? S-a ciocnit un ML cu un Hummer si a iesit dracia asta?
Fiat
Linea
- PAD
Active, 2011
adostar |
![]() Membru autentic Group: Members Posts: 419 Joined: 12 October 04 From: Galati ![]() |
New company set up by local vodka producer.
![]() astia trageau vodka la greuceanu cand au facut cutia asta ! ![]() ![]() |
gaz
cazan
- gaz/porc
1980
Slider |
![]() Membru autentic Group: Members Posts: 1.279 Joined: 5 December 03 From: Cernavoda ![]() |
Chiar ca ii de panarama....Parca-i o cutie de ambalaj...
Ambiance
- CT-xx-xxx
GeorgeB |
![]() the 7 stars of Pleiades constellation Group: Members Posts: 1.870 Joined: 7 January 03 From: Bucuresti ![]() |
parca un hummer cu un G
SUBARU
Legacy 2.5
bomicabomic |
![]() Ex-membru DaciaClub Group: Members Posts: 1.072 Joined: 7 September 04 ![]() |
Mai nu rideti, ca daca-l aduc la noi si-l iau la pila, sa vedeti ce masina iese.
![]() Sa mor,daca nu arata, cu o masina de carat morti. This post has been edited by bomicabomic: 18 Feb 2005, 13:44 |
x
x
- x
Slider |
Si ce nume....cowboy....macar daca ii puneau ceva mai rusesc...
Ambiance
- CT-xx-xxx
bomicabomic |
Natasha. Ivan...
This post has been edited by bomicabomic: 18 Feb 2005, 13:49 |
x
x
- x
Mihai_E |
![]() Membru autentic Group: Members Posts: 687 Joined: 21 October 02 From: Bucuresti ![]() |
da Aro le furnizeaza platformele sau le-au piratat baietii ?
Megane Sedan
2006 1.5dCi 100 CP Shit happens!
kaspersky |
![]() maistru Zen Group: Members Posts: 1.063 Joined: 23 April 03 From: Cluj-Napoca ![]() |
Oricum pt. 11000$ (cu motor Peugeot) nu-i foarte scumpa!
KIA
Cee'd SW 1.6 GSL
Base 2008 "Să fii patriot în România înseamnă să puți a iesle în timp ce constați că toate celelalte popoare ne sunt inferioare."
draku |
![]() Membru autentic Group: Members Posts: 293 Joined: 3 November 04 From: Bucuresti ![]() |
"cowboy"-ul asta rusesc se face pe sasiu de aro, cu motoare rusesti sau de la grupul PSA
vedeti ceva mai multe la http://www.gardianul.ro/index.php?a=eveniment2005021501.xml |
ex Dacia Nova
Barkas B1000
- Barkas
1989 Io stiu ca sunt prost, da' cand ma uit in jurul meu prind curaj...
Stefan.A |
Membru autentic Group: Members Posts: 431 Joined: 21 June 04 ![]() |
faceti voi misto de ei da io' mor de spume ca nu l-au facut astia de la Campulung.
cum pana mea sun in stare ametitiii astia sa faca treaba la -25 de grade si cu votca'n cap si noi le vindem platforma, ca-i mai usor. sau punem un motor tapan dar tot pe caruta aia de aro din '70. si cica nu-l prea vor americanii. panarama aia de perez zice ca nici n'are nevoie de airbag ca oricum nu prea vor merge pe sosele cu ele. ma doare stomacu' de nervi cand ma gandesc ca io speram sa-mi cumpar candva un suv romanesc. |
bomicabomic |
Stefane, fii serios, cind faceau ARO cu motor Toyota, Pejo si Ford, ce succes au avut? Vindeau 1000 de masini/an si alea la armata si politie.
x
x
- x
...Roadrunner... |
![]() Membru fondator "Skija Klan (c)" Group: Members Posts: 751 Joined: 27 September 02 From: Bucuresti ![]() |
Sincer .... daca as stii ca-i la fel de fiabila si are performante in teren accidentat la fel ca un Hummer, poa' sa arate si mai urit de atit. Ca sa ma-ntelegeti mai bine ... Range Rover Discovery ... un exemplu in acest sens.
MeganeII
- B-81-RoadRunner Bip... Bip... !!!
Stefan.A |
QUOTE(bomicabomic @ 18 Feb 2005, 16:48) Stefane, fii serios, cind faceau ARO cu motor Toyota, Pejo si Ford, ce succes au avut? Vindeau 1000 de masini/an si alea la armata si politie. pai si io ce zic?? ia sa vezi daca puneau un motore de toyota,ford,etc pe o alta rabla, updatata imbunatatita, macar solenza, nu logan. eu unul ma gandeam serios sa-mi iau, asteptam momentul si stiu multi tentati de idee. dar asa las' ca stam ca muta si ne uitam cum vinde rusu.eventual ajungem sa si importam o masina cu o platforma pe care noi o avem. intre timp ne plangem ca ne jecmanesc francezii cu logan, americanii cu autostrada si omv cu petromul. cah |
costi |
QUOTE(...Roadrunner... @ 18 Feb 2005, 14:55) Sincer .... daca as stii ca-i la fel de fiabila si are performante in teren accidentat la fel ca un Hummer, poa' sa arate si mai urit de atit. Ca sa ma-ntelegeti mai bine ... Range Rover Discovery ... un exemplu in acest sens. Hummer 1 poate ca 2-ul pierde rotile mai ceva ca Loganul. |
DSN/SLZ
bomicabomic |
Mai aveti grija ce ziceti de Logan, ca se string cetele.....
x
x
- x
costi |
hi, hi, hi
de cind cu "plasticile pe Logan" am facut o fixatie sa ma uit dupa fiecare sa vad daca are ![]() |
DSN/SLZ
Lucian123 |
![]() Membru autentic Group: Members Posts: 240 Joined: 25 August 04 From: Bucuresti ![]() |
Problema la Aro e este ca nu sunt masinile bune, ci faptul ca nu au organizare. Lor le trebuia un proprietar serios care sa stie ce vrea, nu un vantura - lume ca Perez ala.
In anii 70-80 ARO era una din masinile de teren bune. Multe masini de teren cu pretentii nu te duc unde te duce un ARO. Ceea ce lipseste de la Aro este fiabilitatea si aspectul. Cu toate ca nu sunt rele, mai ales astea noi cu motoare straine. |
DACIA LOGAN
Laureate 1.4 Rosu
- B40XXX
costi |
Lucian s-a terminat cu Aro; tu te referi doar la istorie;
Aro este mort si la fel este orice topic pe aceasta tema. Este ne neinteles pozitia AVAS; uzina trebuie "nationalizata" si subventionata la greu; cind s-o pune pe piciare or s-o poata vinde unei firme de renume nu unor titriie briu ca Perez. |
DSN/SLZ
bomicabomic |
QUOTE(Lucian123 @ 18 Feb 2005, 19:51) Eu am fost la ARO si am vazut o macheta, copiata dupa Pajera, bine ei nu recunosteau. Dar n-a fost niciodata realizat, macar, prototipul. Explicatie simpla, lipsa banilor si statul, ca actionar, n-a avut interes. Costi ce s-o mai nationalizeze si s-o revinda, cind acum e facuta zdrente. Anul trecut, am fost la matrite, era singura sectie din tara care facea matrite mari pentru auto. faceau matrite pentru Logan si SLZ, chiar Reno era interesat sa o cumpere, dar pina la urma, a luat-o unul pe 2 lei si 15 bani. Asa ca......la noi ca la neniminea. |
x
x
- x
musicall |
![]() musicall Group: Members Posts: 547 Joined: 6 February 05 From: Braila ![]() |
un container ambulant !!!
Fiat
Punto Classic |
- delfinul.com
Blogu personal Va salut dintr-o clinica de dezintoxicare pentru dependentii de webdesign!
skoda |
Membru incepator Group: Members Posts: 89 Joined: 10 October 04 ![]() |
Dumnezeule mare cum arata !
Proiectantul design-ului la aceasta masina a fost atat de sarac incat nu si-a permis un compas, asa ca toate liniile caroseriei le-a tras numai cu rigla. Norocul a venit la roti unde era cat pe ce sa le faca hexagonale, dar a folosit o moneda imprumutata de la un vecin. |
Laureate 1.4
- Toreador
Ake |
![]() Morderator Group: Moderatori Posts: 1.040 Joined: 6 July 04 From: Bucuresti ![]() |
EDGE-DESIGN se cheama stilul. si e chiar la moda de cand cu Stealthul ala americanesc.
(si) Dacia
Sony |
Ake, edge-design este o combinatie de curbe si muchii ascutite (a se vedea Ford K, Ford Fiesta). Acolo e ceva foarte dubios.
Pacat ca rusii nu sunt in stare sa deseneze masini la fel de frumoase ca avioanele lor! Mi-as fi cumparat o Lada care sa semene cu Suhoi 27! ![]() |
Caruta
cu doi cai frumosi
1945
Ake |
Eu faceam misto, de aia am si pus smiley-ul la coada.
(si) Dacia
Sony |
Da, dar nu ar strica o masina ce se ridica deasupra masinilor care ruleaza bara la bara!
Caruta
cu doi cai frumosi
1945
bogdanescu |
![]() Membru Group: Members Posts: 181 Joined: 21 August 03 From: Bucuresti ![]() |
tre' sa recunoasteti ca rusii astia au un stil inconfundabil... |
renault
megane 2.2 sedan 1.5dci 80cp
skoda |
...ei si copii mici care pana la 5 ani tot asa deseneaza masinile la concursul de creta pe asfalt, cu paribrizul la 90 de grade de capota....
Laureate 1.4
- Toreador
ydaniel |
sincer mie imi plac masinile "cutii"si asta chiar ar fi buna (de fapt perfecta pt mine),apropos aro e chiar parfum la design in comparatie cu mama siberia!!!
Oriunde,
oricand...
Cand esti rau ,nu te uita! |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 02:17 |
