29 Pages « < 8 9 10 11 12 > »
> [VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051
post 14 Aug 2010, 14:58
Post #271
LISTA REACTUALIZATA,REPERE ADAUGATE,PRETURI REDUSE,
Alternator --------------------------------------------------190ron
Antifurt capace roti Dacia---------------------------------15ron
Anvelopa Kumho-185/65/R14 86T,1buc-NOU--------100ron/buc
Anvelope Kumho-185/65/R14 86T,4 buc(rulat 3400Km)----80ron/buc
Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc
Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc.
Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron
Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron
Bascula spate -----------------------------------------------25ron
Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron
Bec 21W/5W(dublu filament) ---------------------------1ron/buc
Biele motor(set 4 buc) -------------------------------------180ron
Bieleta antiruliu Prems ---------------------------------------7ron
Bloc diode(mari) --------------------------------------------21ron
Bloc diode(mici) --------------------------------------------15ron
Borne acumulator(bronz) --------------------------------7ron/set
Brida radiator -------------------------------------------------2ron
Bucsa ax volan----------------------------------------------2.5ron
Bucsa bascula inf.(Fartec) ------------------------------------7ron
Bucsa caseta directie(teflon) ----------------------------1ron/buc
Bucsa cauciuc bascula spate -------------------------------3.5ron
Bucsa cuplaj volan(Fartec)-----------------------------------6ron
Bucsa tirant(Fartec)- ----------------------------------12ron/4buc
Burduf planetara(mare) --------------------------------------3ron
Burduf planetara(mic) ----------------------------------------3ron
Buson baie ulei -----------------------------------------------3ron
Buson radiator ------------------------------------------------2ron
Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron
Butuc roata fata Dacia(3 prezoane)---------------------------50ron
Cablu ambreiaj 1310 -----------------------------------------17ron
Cablu frana mana -------------------------------------------25ron
Cala carburator textolit -------------------------------------0.8ron
Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set
Camere Victoria 145/155/165-13 ----------------------------5ron
Camere Victoria 175/185/195-14 ----------------------------6ron
Capac delcou Dacia -------------------------------------------4ron
Capac pompa apa Scornicesti -------------------------------55ron
Capsula vaccum ----------------------------------------------5ron
Carbuni alternator Urziceni -----------------------------------5ron
Carbuni electromotor Dacia-Oltcit ----------------------------6ron
Carburator Dacia 1400(27)(S.H.)-----------------------------65ron
Ceas presiune ulei--------------------------------------------10ron
Centuri retractabile fata -------------------------------------60ron
Cheie combinata buson ulei baie+c.v. Dacia---------------15ron
Chiulasa neechipata 1310/1410 ---------------------------400ron
Cilindrii receptori --------------------------------------------13ron
Cleste dezizolator multifunctional----------------------------2,5ron
Cleste dezizolator cablu profesional-------------------------27ron
Comutator semnal. directie 1310/1410 ----------------------9ron
Condesator delcou --------------------------------------------2ron
Cric hidraulic 2 tone -----------------------------------------30ron
Cui pontou Carfil---------------------------------------------14ron
Culbutori ---------------------------------------------------10/buc
Curea trapez.dintata GATES6213MC AVX10x825La---------13ron
Curea trapez.SUPER 9.5x950 -------------------------------11ron
Curea ventilator Fartec 10x6x1000 --------------------------5ron
Curea ventilator Fartec 10x8x1218 --------------------------9ron
Cutie Dacia Papuc 4tr.S.H ---------------------------------130ron
Cutie sigurante 10 cai ----------------------------------------8ron
Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron
Diuze spalator parbriz RENAULT(+,,T''pt.cuplare furtune)---------12ron
Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron
Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron
Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron
Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron
Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron
Garnitura capac ppa.apa -------------------------------------2ron
Garnituri cilindrii receptori spate ----------------------------1ron
Garnituri motor 1410(set)-----------------------------------20ron
Inele sincron C.V.--------------------------------------------25ron
Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc
Motor stergator parbriz ARO 10------------------------------35ron
Oala planetara(dinspre roata) -------------------------------35ron
Oglinda ext.dreapta -----------------------------------------20ron
Patent 200mm------------------------------------------------6.5ron
Pinion delcou(Brasov) ----------------------------------------10ron
Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron
Pistol spalat si terosonat ------------------------------------25ron
Piulite INOX prezon roata DACIA(geometrie antifurt+cheie speciala)12buc+cheie--45ron
Pistol de lipit electric 100watti--------------------------------28ron
Pivot inf. -----------------------------------------------------15ron
Platina --------------------------------------------------------4ron
Placuta protectie uzura placa presiune Dacia-------------------15ron
Prese demontat/montat bucsi bascule,cuplaj volan,planetare,etc---130ron
Presa demontat pivoti ---------------------------------------40ron
Pompa spalator parbriz Dacia---------------------------------10ron
Releu far(4pic.) ---------------------------------------------2.5ron
Releu protectie halogene 30A(Italy) -------------------------8ron
Releu semnalizare Sacele -----------------------------------10ron
Releu tensiune mecanic Bulgaria-12V ----------------------30ron
Releu tensiune mecanic Sacele(1411)12V -----------------30ron
Rotor electromotor D.Sacele --------------------------------90ron
Rotor alternator D.Sacele------------------------------------60ron
Rulment ambreiaj Fi180(39060) ---------------------------12ron
Rulment biconic Mare(35305)C.V---------------------------25ron
Rulment biconic Mic(35405)C.V.----------------------------16ron
Rulment conic302/37 -----------------------------------------7ron
Rulment roata fata 6207 -------------------------------------9ron
Rulmenti cutie viteza(5tr) -------------------------------80ron/set
Saboti frana 1310----------------------------------------50ron/set roata
Semeringuri FARTEC-----110x130x13-------------------------10ron
-------------------------80x100x10-------------------------8ron
-------------------------50x70x10--------------------------7ron
--------------------------35x50x8---------------------------5ron
--------------------------26x42x10--------------------------4ron
Set sigurante(8A-16A)---------------------------------------2ron
Semicuzineti palier+biela R1 BORGO -------------------------110ron
Set garnituri motor 1400cc ---------------------------------17ron
Set motor DACIA 1400cc SETCAR(etansare cauciuc) ----320ron
Set reparatie pompa apa ------------------------------------12ron
Set Yalle usi+portbagaj1310 --------------------------------40ron
Simering priza C.V. 17x28x7/13F ----------------------------2ron
Sonda litrometrica 5726 ------------------------------------20ron
Sonda ulei ceas ----------------------------------------------22ron
Stator alternator ---------------------------------------------55ron
Stergatoare SACA 400mm/16''(set) ------------------------10ron
Supape admisie+evacuare ---------------------------------50ron/set
Suporti motor Dacia----------------------------------------25ron
Termostat Dacia ---------------------------------------------10ron
Tija culbutori(set) -------------------------------------------24ron
Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc
Triunghi reflectorizant ---------------------------------------20ron
Valve tubeles -------------------------------------------------1ron
Telef.0722.121.520
x x x - x
valy051
post 21 Aug 2010, 19:49
Post #272
Up!
x x x - x
WGX
post 22 Aug 2010, 10:13
Post #273
Dacia 1310 Owner
nenea valy,cablul de frana de mana are acelasi pret ca si la inceputul anuntului??
Dacia Batranul REnAult Kombi 1999/1310 CL - WGX'u
ex:Dacia 1310 CL Break, Diamond Silver ,Gasoline with Gotronic Ignition Sensor inside
now: Opel Astra G Caravan 1.6 16V 101 HP
vali09
post 24 Aug 2010, 20:17
Post #274
ma intereseaza un T-eu la sonda de apa si o sonda de apa pentru indicator cu ac
indicatorul cu ac....si un electroventilator de dacia...toate pentru un papuc din 2004 care nu le are.
cateva preturi?
multumesc
dacia logan 2005
valy051
post 25 Aug 2010, 16:20
Post #275
Pt.WGX
Banuiesc ca da.
Pt.vali09
Nu am ce doriti dumneavoastra.
x x x - x
valy051
post 1 Sep 2010, 10:27
Post #276
Anvelopa Hankook-185/65/R14 86T,1buc-NOU--------100ron/buc
Anvelope Hankook-185/65/R14 86T,4 buc(rulat 980Km)----80ron/buc
Telef.0722.121.520
x x x - x
valy051
post 3 Sep 2010, 15:53
Post #277
Alternator Dacia---------------------------------------190ron
Anvelopa Hankook-185/65/R14 86T,1buc-Nefolosita---130ron
Bascula spate Dacia--------------------------------------25ron
Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron
Cleste dezizolator cablu(profesional)-------------------------27ron
Comutator semnal. directie 1310/1410 ----------------------10ron
Pistol spalat si terosonat(rezervor metalic)-----------------25ron
Telef.0722.121.520
This post has been edited by valy051: 3 Sep 2010, 15:55
x x x - x
valy051
post 5 Sep 2010, 13:12
Post #278
Up!
x x x - x
bashtalu
post 7 Sep 2010, 01:19
Post #279
alternatorul de cati amperi este? producator? este nou sau sh?
Audi A4 2005
valy051
post 7 Sep 2010, 18:00
Post #280
Alternatorul are 50A,fabricat EP Sacele(de uzina) si este nou.
x x x - x
bashtalu
post 7 Sep 2010, 20:53
Post #281
ma intereseaza
poate ne auzim maine la telefon
multumesc,
Audi A4 2005
valy051
post 8 Sep 2010, 11:53
Post #282
Astept telef.dumneavoastra.
x x x - x
valy051
post 11 Sep 2010, 18:16
Post #283
Telef.0722.121.520
x x x - x
kog
post 14 Sep 2010, 10:27
Post #284
epuri orijinali
un radiator mic cu termocupla nu ai?
valy051
post 15 Sep 2010, 11:18
Post #285
Nu.
x x x - x
valy051
post 19 Sep 2010, 15:48
Post #286
Telef.0722.121.520
x x x - x
valy051
post 24 Sep 2010, 10:42
Post #287
Chiulasa neechipata 1310/1410 ---------------------------390ron
Telef.0722.121.520
x x x - x
valy051
post 27 Sep 2010, 08:25
Post #288
Up!
x x x - x
valy051
post 30 Sep 2010, 14:17
Post #289
Up!
x x x - x
valy051
post 2 Oct 2010, 18:39
Post #290
Telef.0722.121.520
x x x - x
Tomytzul
post 5 Oct 2010, 10:25
Post #291
Sal caut set cuzineti cota 0 pentru arbore cu palier marit (biela,palier),din greseala arbore cu palier marit ai
Merci
Dacia 1310 Berlina 1989 - B-23-TUR
ghitza
post 5 Oct 2010, 20:12
Post #292
pentru berlina pe injectie un senzor T-aer ai cumva?este cel de deasupra injectorului
valy051
post 8 Oct 2010, 16:06
Post #293
Nu,dlor. ghitza si Tomytzul.
x x x - x
br0klyn
post 8 Oct 2010, 17:29
Post #294
Ai PM!
Dacia Solenza 2005
valy051
post 9 Oct 2010, 13:13
Post #295
Aveti raspuns in PM.
x x x - x
valy051
post 11 Oct 2010, 21:21
Post #296
Telef.0722.121.520
x x x - x
valy051
post 14 Oct 2010, 18:55
Post #297
Anvelopa Hankook-185/65/R14 86T,1buc-Nefolosita---120ron
Telef.0722.121.520
x x x - x
valy051
post 16 Oct 2010, 19:34
Post #298
Telef.0722.121.520
x x x - x
alinworm
post 18 Oct 2010, 21:45
Post #299
Platina
Condesator delcou
Shtutz+ furtun apa circuit chiuloasa carburator?
burduf planetara mare
SUNT?
multumesc!
This post has been edited by alinworm: 18 Oct 2010, 21:55
Dacia/Skoda 1300/Octavia 1977/2004 - BZ77UAP
DACIOARA 1310
valy051
post 19 Oct 2010, 13:20
Post #300
Pt.alinworm
Platina-DA
Garnitura capac ppa.apa-NU(Am numai in set garnituri motor)
Filtru ulei UAMT-DACIA-DA
Condesator delcou-DA
Capac pompa apa Scornicesti-DA
Shtutz+ furtun apa circuit chiuloasa carburator?-NU
burduf planetara mare-DA
Alternator Dacia---------------------------------------180ron
Antifurt capace roti Dacia---------------------------------12ron
Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---120ron
Biele motor(set 4 buc) -------------------------------------170ron
Bloc diode(mari) --------------------------------------------20ron
Bucsi electromotor Dacia--------------------------------------6ron/set
Chiulasa neechipata 1310/1410 ---------------------------380ron
Cui pontou Carfil---------------------------------------------12ron
Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron
Intrerupator lampa martor frana mana--------------------2.5ron
Maneta schimbare semnal directie Dacia------------------7ron/buc
Oglinda ext.dreapta -----------------------------------------15ron
Prese demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron
Releu tensiune mecanic Bulgaria-12V ----------------------25ron
Releu tensiune mecanic Sacele(1411)12V -----------------25ron
Set capse ferodouri saboti spate-----------------------------3ron
Supapa servomecanism frana--------------------------------2.5ron
Stifturi planetara--------------------------------------------6ron/set
Telef.0722.121.520
x x x - x
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 14th July 2025 - 20:16
