[VAND]piese DACIA noi-REDUCERE DE PRETURI
valy051 |
#301
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
x
x
x
- x
valy051 |
#302
LISTA REACTUALIZATA,REPERE ADAUGATE,PRETURI REDUSE,
Alternator Dacia---------------------------------------170ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Capsula vaccum ----------------------------------------------5ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------370ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie Dacia Papuc 4tr.S.H ---------------------------------120ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Piulite INOX prezon roata DACIA(geometrie antifurt+cheie speciala)12buc+cheie--45ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Placuta protectie uzura placa presiune Dacia-------------------15ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V ----------------------20ron Releu tensiune mecanic Sacele(1411)12V -----------------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#303
Alternator Dacia---------------------------------------170ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Capsula vaccum ----------------------------------------------5ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------360ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie Dacia Papuc 4tr.S.H ---------------------------------120ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Piulite INOX prezon roata DACIA(geometrie antifurt+cheie speciala)12buc+cheie--45ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Placuta protectie uzura placa presiune Dacia-------------------15ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V ----------------------20ron Releu tensiune mecanic Sacele(1411)12V -----------------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
Ov |
#304
salut,
ti-am trimis si mesaj camere 155/13 (4 bucati) mai ai? in ce stare este cauciucul? |
valy051 |
#305
x
x
x
- x
vick_supernova |
#306
![]() Membru Dacia Group: Members Posts: 238 Joined: 3 November 09 ![]() |
cablu de kilometraj electronic de supernova ? si care ar fi pretu ? multumesc
Supernova
2001/comfort
- VL 03 WXS
valy051 |
#307
Nu am cablu km.de supernova.
x
x
x
- x
valy051 |
#308
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------350ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie Dacia Papuc 4tr.S.H ---------------------------------120ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Placuta protectie uzura placa presiune Dacia-------------------15ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V ----------------------20ron Releu tensiune mecanic Sacele(1411)12V -----------------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#309
x
x
x
- x
valy051 |
#310
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------330ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie Dacia Papuc 4tr.S.H ---------------------------------120ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Placuta protectie uzura placa presiune Dacia-------------------15ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V ----------------------20ron Releu tensiune mecanic Sacele(1411)12V -----------------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
anecula_08 |
#311
![]() Membru autentic Group: Members Posts: 3.871 Joined: 3 March 08 From: Bucuresti ![]() |
Salut, cumpar eu ceasul de presiune ulei si sonda de ulei pt ceas. In ce zona a Bucurestiului te pot gasi? O poza cu ceasul se poate?
This post has been edited by anecula_08: 2 Dec 2010, 14:04 |
Dacia Solenza
Europa cu AC - 1.4 MPI / Renault Laguna 2
Facelift - 1.6 16v / Dacia Logan Stepway - 1.0 TCE
valy051 |
#312
Aveti foto anecula_08Sonda_presiune_ulei_ceas_.02jpg.jpg ( Size: 94.64k )
Sonda_presiune_ulei_ceas_.04jpg.jpg ( Size: 101.9k ) Number of downloads: 1987 This post has been edited by valy051: 6 Dec 2010, 19:25 |
x
x
x
- x
tudorache1982 |
#313
Membru incepator Group: Members Posts: 28 Joined: 9 December 10 ![]() |
M-ar interesa alternatorul de dacia 1310 daca este de 50A, in ce stare se afla si o poza daca se poate.
1997
valy051 |
#314
Alternatorul este de 50A si este nou.
Aveti foto mai jos: Alternator_Dacia_50amperi.jpg ( Size: 101.99k ) Number of downloads: 1959 Alternator_Dacia_50amperi.01jpg.jpg ( Size: 100.63k ) Number of downloads: 1924 Alternator_Dacia_50amperi.02jpg.jpg ( Size: 96.8k ) Number of downloads: 1905 Alternator_Dacia_50amperi.03jpg.jpg ( Size: 113.58k ) Number of downloads: 130 Alternator_Dacia_50amperi.04jpg.jpg ( Size: 107.51k ) Number of downloads: 138 Alternator_Dacia_50amperi.05jpg.jpg ( Size: 113.58k ) Number of downloads: 131 |
x
x
x
- x
valy051 |
#315
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------330ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie Dacia Papuc 4tr.S.H ---------------------------------120ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru ulei UAMT-DACIA(mare) ---------------------------------------6ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Placuta protectie uzura placa presiune Dacia-------------------15ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V ----------------------20ron Releu tensiune mecanic Sacele(1411)12V -----------------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#316
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------330ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------35ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------25ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#317
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---110ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------65ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie+evacuare ---------------------------------50ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#318
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
adryan |
#319
Membru autentic Group: Members Posts: 341 Joined: 9 May 06 From: BUCURESTI ![]() |
Presa pentru comprimat arcuri mai ai?
VW
Golf V
2005/1.6 MPI
valy051 |
#320
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
Nu dle.adryan
Alternator Dacia---------------------------------------160ron Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------170ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 145/155/165-13 ----------------------------5ron Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 This post has been edited by valy051: 12 Jan 2011, 21:36 |
x
x
x
- x
valy051 |
#321
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------160ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni alternator Urziceni -----------------------------------5ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 |
x
x
x
- x
bdansutu84 |
#322
Membru incepator Group: Members Posts: 10 Joined: 20 December 10 ![]() |
Salutare. M-ar interesa daca aveti punte diode alternator 50A, carbuni alternator (pret) si o poza cu ele daca se poate. Multumesc!
1995
valy051 |
#323
Aveti PM dle.bdansutu84
x
x
x
- x
Lde 2100 |
#324
![]() CFR-ist Group: Members Posts: 391 Joined: 17 November 10 From: Slanic ![]() |
Va salut,si pe mine ma intereseaza o punte de alternator 50A,si pretul.
1310 TLX
1989/Dacia 1300 1977/Dacia 1307 2001/Nissan Xtrail
bdansutu84 |
#325
Ok, atunci astept pm-ul dvs. cand ajungeti in Bucuresti!
1995
valy051 |
#326
x
x
x
- x
valy051 |
#327
x
x
x
- x
bdansutu84 |
#328
Dl. Valy ati ajuns in Bucuresti?
1995
valy051 |
#329
Antifurt capace roti Dacia---------------------------------12ron Anvelopa Hankook-185/65/R14 86T,1buc-NOUA---100ron Aparatoare roata noroi(1buc fata+1buc spate) ---------4ron/buc Arc spiral auto(L=345mm;Fi int.arc 105mm;Fi Ext.arc 135mm;Grosime sarma fi 16mm;Pas spira 50mm--------100ron/2buc. Ax pompa apa Dacia(INOXIDABIL) -------------------------10ron Bascula inf cu pivot(rebucsata Fartec)D.Papuc-------------50ron Bascula spate Dacia--------------------------------------25ron Bascula sup.cu pivot(rebucsata Fartec)D.Papuc------------35ron Bec 21W/5W(dublu filament) ---------------------------1ron/buc Biele motor(set 4 buc) -------------------------------------160ron Bieleta antiruliu Prems ---------------------------------------7ron Bloc diode(mari) --------------------------------------------20ron Bloc diode(mici) --------------------------------------------15ron Borne acumulator(bronz) --------------------------------7ron/set Brida radiator -------------------------------------------------2ron Bucsa ax volan----------------------------------------------2.5ron Bucsa bascula inf.(Fartec) ------------------------------------7ron Bucsa caseta directie(teflon) ----------------------------1ron/buc Bucsa cauciuc bascula spate -------------------------------3.5ron Bucsa cuplaj volan(Fartec)-----------------------------------6ron Bucsa tirant(Fartec)- ----------------------------------12ron/4buc Bucsi electromotor Dacia--------------------------------------6ron/set Burduf planetara(mare) --------------------------------------3ron Burduf planetara(mic) ----------------------------------------3ron Buson baie ulei -----------------------------------------------3ron Buson radiator ------------------------------------------------2ron Butuc roata fata D.Papuc(3 prezoane)(tractiune spate)----55ron Butuc roata fata Dacia 1310/1410(3 prezoane)-------------50ron Cablu ambreiaj 1310 -----------------------------------------17ron Cablu frana mana -------------------------------------------25ron Cala carburator textolit -------------------------------------0.8ron Camasi cilindru DACIA 1300 si 1400 din teava foraj sonda(pentru cunoscatori)4+4buc--150ron/set Camere Victoria 175/185/195-14 ----------------------------6ron Capac delcou Dacia -------------------------------------------4ron Carbuni electromotor Dacia-Oltcit ----------------------------6ron Carburator Dacia 1400(27)(S.H.)-----------------------------55ron Ceas presiune ulei--------------------------------------------10ron Centuri retractabile fata -------------------------------------60ron Cheie combinata buson ulei baie+c.v. Dacia---------------15ron Chiulasa neechipata 1310/1410 ---------------------------310ron Cleste dezizolator multifunctional----------------------------2,5ron Cleste dezizolator cablu(profesional)-------------------------27ron Comutator semnal. directie 1310/1410 ----------------------10ron Cui pontou Carfil---------------------------------------------12ron Culbutori ---------------------------------------------------10/buc Curea trapez.dintata GATES6213MC AVX10x825La---------13ron Curea trapez.SUPER 9.5x950 -------------------------------11ron Curea ventilator Fartec 10x6x1000 --------------------------5ron Curea ventilator Fartec 10x8x1218 --------------------------9ron Cutie sigurante 10 cai ----------------------------------------8ron Cuzineti palier ST R1 Dacia1310/1410 -----------------------25ron Diuze spalator parbriz originale RENAULT(+,,T''pt.cuplare furtune)--12ron Extinctor auto(cu pulbere si gaz propulsor CO2)1Kg.------20ron Filtru ulei Daewoo 1# 9479774069(Korea) ----------------10ron Filtru ulei Mapco-Mann-DACIA(mare) ------------------------------13ron Filtru uleiTECNOCAR(Italy)R175(pt.diesel)Croma td,Fiorino D,Delta td,prisma D/td,Dedra D/td,Ibizad,Malaga d,Ibiza New Style1.7DUno D 1697,Td,RitmoD/Td,Regata D/td,Tipo D/td ---13 ron Garnituri cilindrii receptori spate ----------------------------1ron Garnituri motor 1410(set)-----------------------------------20ron Intrerupator lampa martor frana mana--------------------2.5ron Inele sincron C.V.--------------------------------------------25ron Jicloare 1300/1400 Carfil(diferite)-------------------------3ron/buc Maneta schimbare semnal directie Dacia------------------7ron/buc Motor stergator parbriz ARO 10------------------------------35ron Oala planetara(dinspre roata) -------------------------------35ron Oglinda ext.dreapta -----------------------------------------15ron Organe asamblare Dacia(saibe,portpiulite,bolturi balama usa,stift planetare,etc,etc)--25ron Patent 200mm-------------------------------------------------5ron Pinion delcou(Brasov) ----------------------------------------10ron Pistol aer cu manometru(0,5-10bar)(Italia) ----------------30ron Pistol spalat si terosonat(rezervor metalic)-----------------25ron Pistol de lipit electric 100watti--------------------------------20ron Pivot inf. -----------------------------------------------------15ron Platina --------------------------------------------------------4ron Prese DACIA,demontat/montat bucsi bascule,cuplaj volan,planetare,etc---120ron Proiectoare H3-12v/24v-70w(cu grila)Raba,Saviem,Aro,Dacia,etc----25ron/set Releu far(4pic.) ---------------------------------------------2.5ron Releu protectie halogene 30A(Italy) -------------------------8ron Releu semnalizare Sacele -----------------------------------10ron Releu tensiune mecanic Bulgaria-12V(pt.DACIA)----------20ron Rotor electromotor D.Sacele --------------------------------90ron Rotor alternator D.Sacele------------------------------------60ron Rulment ambreiaj Fi180(39060) ---------------------------12ron Rulment biconic Mare(35305)C.V---------------------------25ron Rulment biconic Mic(35405)C.V.----------------------------16ron Rulment conic302/37 -----------------------------------------7ron Rulment roata fata 6207 -------------------------------------9ron Rulmenti cutie viteza(5tr) -------------------------------80ron/set Saboti frana 1310----------------------------------------50ron/set roata Semeringuri FARTEC-----110x130x13-------------------------10ron -------------------------80x100x10-------------------------8ron -------------------------50x70x10--------------------------7ron --------------------------35x50x8---------------------------5ron --------------------------26x42x10--------------------------4ron Set sigurante(8A-16A)---------------------------------------2ron Set garnituri motor 1400cc ---------------------------------17ron Set reparatie pompa apa ------------------------------------12ron Set Yalle usi+portbagaj1310 --------------------------------40ron Set capse ferodouri saboti spate-----------------------------3ron Simering priza C.V. 17x28x7/13F ----------------------------2ron Sonda litrometrica 5726 ------------------------------------20ron Sonda ulei ceas ----------------------------------------------22ron Stator alternator ---------------------------------------------55ron Stergatoare SACA 400mm/16''(set) ------------------------10ron Supapa servomecanism frana--------------------------------2.5ron Supape admisie set ,supape evacuare set------------------40ron/set Suporti motor Dacia----------------------------------------25ron Stifturi planetara--------------------------------------------6ron/set Termostat Dacia ---------------------------------------------10ron Tija culbutori(set) -------------------------------------------24ron Tripla Dacia 1310(stg.+drp)DSP-8 --------------------35ron/buc Triunghi reflectorizant ---------------------------------------20ron Valve tubeles -------------------------------------------------1ron Telef.0722.121.520 This post has been edited by valy051: 3 Feb 2011, 12:28 |
x
x
x
- x
741852963 |
#330
![]() Membru Group: Members Posts: 100 Joined: 22 March 10 ![]() |
Scaunul fata dreapta il mai si si cum se prezinta.
Multumesc. |
DACIA 1400
Dacia 1400
1997
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 20:43 |
