DIAGNOZA, parametrii, erorile si interpretarea lor
alymyr |
Membru Group: Members Posts: 122 Joined: 8 May 10 ![]() |
djtirzi |
![]() Renault Megane Group: Members Posts: 262 Joined: 20 August 10 From: Sibiu ![]() |
serviccom stiu ca am promis ca o sa pun si eu parametrii masinii mele dar am avut probleme cu alternatorul
Cum vi se pare ca merge motorul? Attached thumbnail(s) POza_noua.jpg ( Size: 112.67k ) Number of downloads: 914 2.jpg ( Size: 121.59k ) Number of downloads: 978 5.jpg ( Size: 104.47k ) Number of downloads: 940 6.jpg ( Size: 74.52k ) Number of downloads: 927 7.jpg ( Size: 96.8k ) Number of downloads: 898 8.jpg ( Size: 107.32k ) Number of downloads: 141 9.jpg ( Size: 71.29k ) Number of downloads: 146 10.jpg ( Size: 41.34k ) Number of downloads: 148 11.jpg ( Size: 81.77k ) Number of downloads: 177 12.jpg ( Size: 134.2k ) Number of downloads: 202 13.jpg ( Size: 126.73k ) Number of downloads: 184 14.jpg ( Size: 71.46k ) Number of downloads: 175 |
Grand Scenic 2.2
Expression
- SB 17 AID Renault Megane Classic Expression 2002 SB-13-TDF
Complicat de simplu! |
Str82Hell |
![]() Membru Group: Members Posts: 112 Joined: 17 March 08 From: Bucuresti ![]() |
SuperNova
2001 Clima
- B - x x - S P V
djtirzi |
Am mai multe versiuni e baze de date, atunci cand am pus pozele aveam baza de date din 2005 acuma am si cea din 2007 si parca am gasit si una mai noua!Momentan am laptopul la bunici si nu mai am cu ce ma juca!
Se poate activa cu DDT2000 sa mi se stinga si mie plafoniera progresiv?Si am inteles ca pot vedea daca am probleme la unul din cilindrii, cum pot face asta? Se poate accesa si UCE decodorul?eu am fisierele acelea cu SAGEM ar nu pot accesa nimica la masina chiar daca le dechid!Gresesc eu ceva? |
Grand Scenic 2.2
Expression
smaci |
Membru incepator Group: Members Posts: 11 Joined: 18 January 10 ![]() |
Am facut recent diagnoza si am constatat la mine la sectiunea "Etat des Entrées"- sectiunea Bonne prédiction de passage de l'arbre a cames MAUVAISE.
22 Mar 2014, 17:11: Ce am mai observat fata de diagnoza la voi, la mine am avans de aprinder care se schimba intre 9- 12. Avance a l allumage a chaque PMH (V) 11,25. Mi se pare ca e prea mare. Ce parere aveti? This post has been edited by smaci: 22 Mar 2014, 17:11 Attached thumbnail(s) Etat_des_Entr_es.jpg ( Size: 96.17k ) Number of downloads: 175 |
Logan PH2
2008.09/ Laureate
- MS-08-WTJ
gabi_g |
Membru autentic Group: Members Posts: 286 Joined: 21 November 05 From: Targoviste ![]() |
QUOTE Am facut recent diagnoza si am constatat la mine la sectiunea "Etat des Entrées"- sectiunea Bonne prédiction de passage de l'arbre a cames MAUVAISE Nu-i bai, ecu poate fi configurat sa utilizeze si informatia de la un senzor de pozitie al arborelui cu came, ceea ce la motorul de fata nu-i cazul. |
Solenza Scala
- B-20-PFU
Solenzul |
![]() Membru curios Group: Members Posts: 404 Joined: 18 March 08 From: Campulung-Muscel ![]() |
Dar cum putem sa imbunatatim predictia? Ce rol are?
Solenza 2004 Clima ;
Duster Explorer 2017 ;
- AG-09-***, AG-26-***
gabi_g |
Nu ai ce sa imbunatatesti. Trebuie sa ai senzorul de turatie in stare buna si volantul la fel.
Ce rol are ce? This post has been edited by gabi_g: 16 Apr 2014, 13:53 |
Solenza Scala
- B-20-PFU
Solenzul |
Ma refeream la predictie, ce rol are predictia de trecere a arborelui?
Senzorul e in stare buna, iar volantul e bun, nu are dinti sariti si tot scrie MAUVAISE. Vreau sa scrie ca are predictie buna, vreau ca masina sa mearga ca un ceas elvetian. |
gabi_g |
Ecranul de mai sus reprezinta parametrii de intrare ai ecu-ului, ecu se autoconfigureaza dupa senzorii care sunt conectati pe masina. La Solenza si SN nu exista un senzor de pozitie al arborelui cu came si strategia softului din ecu nu ia in considerare acest senzor. Deci parametrul de mai sus cu fazajul arborelui cu came nu este un defect ci doar un parametru de intrare. Ca sa-ti mearga motorul ca un ceas elvetian te uiti in ecranul Info Moteur, Infos OBD si Pannes si-l auzi dupa ureche (plus masurare manuala de alti parametri, ex. compresie cilindri, presiune rampa injectie, etc). Daca chiar te intereseaza fazajul arborelui cu came nu poti sa-l vezi decat manual, adica demontezi pana vezi cureaua de distributie in toata splendoarea ei si apoi aduci motorul la PMS si verifici marcajele de distributie.
This post has been edited by gabi_g: 20 Apr 2014, 21:25 |
Solenza Scala
- B-20-PFU
smaci |
Cat trebuie sa fie avansul de aprindere la 1.6 16V ? La mine tot sare in ralanti inter 8,75-14,45. Nu sta incremenit in ralanti. La turatie pe la 3000 rot/min urca la 43. Distributie originala neschimbata o am, inca cum a iesit din fabrica.
22 Apr 2014, 17:47: Am schimbat senzorul de detonatie dar nici un rezultat, adica aceasi manifestare. This post has been edited by smaci: 22 Apr 2014, 17:47 |
Logan PH2
2008.09/ Laureate
- MS-08-WTJ
gabi_g |
verifica distributia, dar trebuie cu trusa aferenta motorului asta (blocare vilbrochen si arbori cu came), din ce am vazut pe net cureaua se mai intinde din cauza uzurii si rezulta un mic defazaj.
Solenza Scala
- B-20-PFU
adrianopolis1978 |
![]() Membru Group: Members Posts: 119 Joined: 24 November 13 From: Bucuresti ![]() |
Buna seara. Ce inseamna va rog urmatoarele erori:
- Panne mémorisée voyant alerte température eau - Pannes mémorisées sur une des sorties Multumesc Am un renault Symbol 1.4 55 kw din 2007 |
Symbol
2007, 1.4 benzina, 55kw
Maskatu |
-avarie stocata pentru indicatorul temperatura apa
-erori (sau anomalii) stocate pe iesire sau una din iesiri. |
0.9 TCE - 2019
adrianopolis1978 |
Symbol
gabi_g |
Mai degraba verifica firele de la martor temperatura apa sau martorul insusi.
Solenza Scala
- B-20-PFU
adrianopolis1978 |
Symbol
Maskatu |
Da...
0.9 TCE - 2019
gabi_g |
Nu, senzorul de temperatura apa este pe chiulasa, martorul (voyant) temperatura apa este in bord, pe ceasuri. Defectul tau iti spune de martorul sau indicatorul sau cum vrei tu sa-i zici, deci cel din bord. Vezi un fir pe acolo.
This post has been edited by gabi_g: 24 May 2014, 20:24 |
Solenza Scala
- B-20-PFU
adrianopolis1978 |
QUOTE(gabi_g @ 24 May 2014, 20:24) Nu, senzorul de temperatura apa este pe chiulasa, martorul (voyant) temperatura apa este in bord, pe ceasuri. Defectul tau iti spune de martorul sau indicatorul sau cum vrei tu sa-i zici, deci cel din bord. Vezi un fir pe acolo. Am sa verific si acolo. Dar senzorul de temperatura apa nu da semnal catre acul de la indicatorul de la bord? Acul functioneaza in parametrii normali ca la inceput. Arata temperatura motorului cum trebuie. Ma gandesc ca ar fi semnalul din senzor catre indicator. Am observat ca daca misc de senzorul de temperatura, acesta joaca foarte tare in jurul filetului din chiuloasa. This post has been edited by adrianopolis1978: 24 May 2014, 20:53 |
Symbol
gabi_g |
Ca sa fiu explicit martorul ( voyant) temp apa este un mic beculet in bord, asa cum este si cel de presiune ulei sau incarcare alternator, nu indicatorul cu ac.
Vezi firul care pleaca din pinul 9 de la ECU sa nu fie intrerupt sau in scurt. Martorul de temperatura apa nu este actionat de senzorul temperatura apa ci de ECU. Daca iti joaca senzorul insemna ca trebuie schimbat, dar nu o sa rezolvi cu eroarea de mai sus. This post has been edited by gabi_g: 24 May 2014, 21:09 |
Solenza Scala
- B-20-PFU
adrianopolis1978 |
Nu ma pricep prea bine sau sincer deloc, nici macar unde ar fi ecu ala. O sa merg la un service sa se uite un electrician. Dar daca mai merg asa cu eroarea aia este vreo problema? Afecteaza consum, motor, etc. Ca indicatorul imi arata bine temperatura motorului
Symbol
gabi_g |
#53
Ecu este calculatorul de injectie de langa baterie. Nu iti afecteaza mersul, consumul, dar daca o sa ai vreo problema la sistemul de racire al motorului, calculatorul o sa vrea sa-ti raporteze asta aprinzand acel martor, dar nu o sa poata sa-l aprinda si tu nu o sa stii ca ai vreun defect la racire.
Solenza Scala
- B-20-PFU
danciusergiu84 |
#54
NU exista eroare de diagnoza pentru nici un martor !! Daca masina e din 2007 asa stiu ca nu mai are becuri ci SMD-uri care nu au moarte.
Cel mai bine cand ai o eroare e sa memorezi codul acesteia, poate ti-l da in format universal de tip Pxxxxx si il cauti pe google si gasesti explicatii de toate felurile, sau poti scana motorul cu un tester generic nu dedicat reno ca sa primesti eroare in format universal daca eroare e legata de temperatura si senzorul acesta are joc atunci 100% eroarea provine de acolo, deci schimba senzorul, sterge eroarea si vezi daca mai apare imediat sau dupa un timp (dupa o zi doua de circulat) fiindca conteaza asta mult, si noteaza codul erorilor gasite fiindca e mai clar This post has been edited by danciusergiu84: 26 May 2014, 07:50 |
ex Dacia
ex Nova GTi
2000
adrianopolis1978 |
#55
O sa schimb senzorul de temperatura. Multumesc
Symbol
gabi_g |
#56
Senzorul de temperatura apa este intrare (entrée) pe cand voyant temperatura apa este iesire (sortie). Ecu raporteaza o eroare pe una dintre iesiri. Ti se aprinde martorul de temperatura apa cand pui contactul?
This post has been edited by gabi_g: 27 May 2014, 06:06 |
Solenza Scala
- B-20-PFU
adrianopolis1978 |
#57
Niciodata nu s-a aprins martorul si nu am avut probleme cu incalzirea
Symbol
gabi_g |
#58
Trebuie sa se aprinda cand pui contactul sau poti sa-l aprinzi din tester.
Solenza Scala
- B-20-PFU
adrianopolis1978 |
#59
Nu s-a aprins niciodata becul. O sa verific
Symbol
adrianopolis1978 |
#60
O intrebare am pus testerul ddt2000 pe masina unui prieten si e a mea, masini identice ca ani si motorizare. Au reiesit valori diferite la capitolul INFO MOTEUR, in sensul ca la amicul meu sunt pozitii care au cifra 0, iar aceleasi pozitii la mine nu au trecuta nicio cifra in dreptul lor. Oare de ce? Nu ar fi trebuit sa arate si la mine cifra 0 sau alta valoare macar?
In poza 2 este rezultatul de la masina mea Attached thumbnail(s) 1.jpg ( Size: 101.68k ) Number of downloads: 66 2.jpg ( Size: 100.27k ) Number of downloads: 61 |
Symbol
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 23:38 |
