[VAND] DIVERSE, trusa sudura,motor elect.,etc,etc.
valy051 |
#61
Membru autentic Group: Members Posts: 2.667 Joined: 9 April 09 From: Bucuresti ![]() |
Attached thumbnail(s) Accesorii_FUS_22_Motor_electric_01.jpg ( Size: 81.21k ) Number of downloads: 560 Accesorii_FUS_22_Motor_electric.jpg ( Size: 82.03k ) Number of downloads: 576 Trusa_alezaj_15_35.jpg ( Size: 102.56k ) Number of downloads: 604 Trusa_alezaj_50_160.jpg ( Size: 93.6k ) Number of downloads: 612 |
x
x
x
- x
valy051 |
#62
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------350ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#63
Vand:
x
x
x
- x
valy051 |
#64
Vand:
x
x
x
- x
valy051 |
#65
Vand:
x
x
x
- x
valy051 |
#66
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------350ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 This post has been edited by valy051: 13 Dec 2010, 21:16 |
x
x
x
- x
valy051 |
#67
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------350ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1300ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#68
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------320ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 This post has been edited by valy051: 3 Jan 2011, 15:52 |
x
x
x
- x
valy051 |
#69
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------320ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 |
x
x
x
- x
valy051 |
#70
Vand:
x
x
x
- x
valy051 |
#71
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------300ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 |
x
x
x
- x
tutu |
#72
Membru autentic Group: Members Posts: 454 Joined: 19 June 07 From: Bucuresti ![]() |
Aveti PM !
Renault 25 GTX
Dacia Break
1987
- B-08-BYP
valy051 |
#73
Aveti cateva poze dle.tutu
REzervor_1100L.jpg ( Size: 14.38k ) Number of downloads: 481 Rezervor_1100L_1_.jpg ( Size: 15.46k ) Number of downloads: 62 Rezervor_1100L_2_.jpg ( Size: 13.13k ) Number of downloads: 58 |
x
x
x
- x
valy051 |
#74
Vand:
x
x
x
- x
valy051 |
#75
Vand:
x
x
x
- x
valy051 |
#76
Vand:
x
x
x
- x
dorul3t |
#77
![]() Aviator DACIAClub Group: Members Posts: 396 Joined: 10 November 09 From: Bucuresti ![]() |
cati amperi scoate alternatorul de jetta?
1310 L + GPL
11.1999
- TR-21-REB bla bla bla....
Leo0608 |
#78
QUOTE(valy051 @ 16 May 2010, 18:59) Vand: Alternator Volkswagen Jetta-S.H.-----------------------------90ron cati amperi are alternatorul de vw jetta? ii poti face proba la el? e functional? This post has been edited by R19/16v: 6 Feb 2011, 09:40 |
pentru?
200x
- X XX XXX
valy051 |
#79
Vand:
x
x
x
- x
valy051 |
#80
Vand:
x
x
x
- x
nyente |
#81
Membru incepator Group: Members Posts: 1 Joined: 18 February 11 ![]() |
salut o poza cu placytele widia ce model sunt?
1989
- b 56 bmw
valy051 |
#82
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------300ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron Telef.0722.121.520 Pentru user nyente Fotografii_0021.jpg ( Size: 67.01k ) Number of downloads: 101 |
x
x
x
- x
valy051 |
#83
Nu mai sunt de actualitate:
Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron. Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron |
x
x
x
- x
valy051 |
#84
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------300ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 500------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron |
x
x
x
- x
valy051 |
#85
Vand:
x
x
x
- x
valy051 |
#86
Vand:
x
x
x
- x
valy051 |
#87
Vand:
x
x
x
- x
valy051 |
#88
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron Alternator Volkswagen Jetta-S.H.-----------------------------90ron Element filtru ulei avion(inoxidabil)---------------------------40ron Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron Placute Widia------------------------------------------------5ron/buc Trusa pentru sudura oxiacetilenica--------------------------300ron Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron Polizor trifazic(380V) dublu PD 300------------------------450ron Dulap metalic tip fiset---------------------------------------250ron Dulap metalic 2 usi------------------------------------------400ron Masina gaurit cu coloana(380V)---------------------------1200ron Pompa picior(1cilindru)------------------------------------------12ron Pompa picior(2cilindrii)-------------------------------------------22ron Cutite strung vidia--------------------------------------------------5ron/buc. Set placute vidia(10buc/blister)(12x12)---------------------------150ron Semeringuri FARTEC-----110x130x13--------------10ron ------80x100x13----------------------------------------8ron ------50x70x10------------------------------------------7ron -------35x50x8--------------------------------------------5ron --------26x42x10------------------------------------------4ron Manometru presiune0-250atm.-------------------------------------10ron Manometru presiune 0-60atm---------------------------------------8ron Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc Cutite strung 10x10--------------------------------------------------5ron/buc Stativ magnetic ceas comparator---------------------------------100ron Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur Legenda: Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009 Electromotor Motostivuitor Bulgaria---------------------------------------------250ron Bucsi biela,simeringuri supapa pt.motor 3 cil.Bulgaria-------------------------50ron Capete bara,pompa ulei,pompa frana Motostivuitor 3 cil.Bulgaria-----------100ron Radiator Motostivuitor motor 3 cilindrii------------------------------------------150ron |
x
x
x
- x
valy051 |
#89
Vand:
x
x
x
- x
valy051 |
#90
Vand:
x
x
x
- x
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 08:06 |
