[VAND] piese renault noi originale la superpret
lily_efs_2000 |
27 Dec 2009, 06:23
#121
Membru autentic Group: Members Posts: 366 Joined: 4 August 09 |
renault
megane
- is 25 via
lily_efs_2000 |
4 Jan 2010, 13:18
#122
Pt orice piesa am nevoie de datele de pe placuta ovala. Exceptie fac stergatoarele.
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator Clio I,II,III, Modus, Kangoo,Twingo cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025 3 bucati 120 lei Aripa fata stanga tabla Twingo II cod: 77 82 170 227 1 bucata 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo) 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 20 cm, 18 dinti) cod: 77 01 476 973 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) cod: 77 01 477 032 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc cod: 77 01 475 971 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 3 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R19, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (Lucas) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421/77 01 209 841/77 01 207 69577 01 209 735 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Laguna II (pt masini fabric. pana in 2005 inclusiv) cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 130 lei placute frana spate(Lucas) Trafic II , Vivaro, vel satis, nissan prima star cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306, nissan kubistar,citroen cod: 77 01 208 142/77 01 205 513/77 01 205 995/77 01 205 996/77 01 206 811 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 8 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 8 seturi 60 lei Tampon Motor Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid 5,Twingo,Express,Megane I,break, R 19, R 21 (diam. 23,8 cm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 28 cm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II,classic/break,coupe,Scenic,Modus,Scenic II,ClioII,III,Kangoo,Laguna I,II,Laguna Nevada (5k 1199 latime=18mm) cod: 82 00 034 396 4 bucati 40 lei Termostat clio I,II,III, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat Avantime, Logan,Clio I,II,III,Laguna I,II, Laguna Nevada,Espace IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Solenta,Supernova,Trafic II,Kangoo,Vel Satis Cod: 77 00 872 554 1 bucata 70 lei Becuri Halogen H7 Renault, Ford cod: 77 01 057 737 4 bucati 25 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I,II,break,coupe,scenic, Kangoo,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic I,II cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Clio II,Espace IV,Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo,Mascott/Master Propulsion cod: 77 01 205 665 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 10 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata - cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
bulls_lx |
5 Jan 2010, 17:14
#123
Membru autentic Group: Members Posts: 205 Joined: 19 January 08 |
M-ar interesa daca ai buton de avarie pt LagunaII
renault laguna 2
privilege
- tm27kkk
xexe |
6 Jan 2010, 09:08
#124
Membru incepator Group: Members Posts: 81 Joined: 11 November 04 From: Bucuresti |
Salut si LA MULTI ANI! M-ar interesa pentru "placuta ovala atasata" (Scenic II 1,5 dCi, 2005 la inceput) urmatoarele: - bielete de directie; - pivoti ; - placute fata (mai de calitate ) Multumesc This post has been edited by xexe: 6 Jan 2010, 09:09 |
Scenic II 1.5 dCi, 2005, 101 CP |
lily_efs_2000 |
6 Jan 2010, 18:29
#125
bulls_lx, nu am decat ceea ce e trecut in lista.
xexe, bieletele de directie le-am avut la 60 lei/buc trw, pivoti nu am si nici nu am avut, iar placute de frana am pt fata Ferodo originale renault la 140 lei setul (la reprezentanta sunt 344 lei) si daca vrei am si pt spate Lucas la 130 lei (la reprez sunt 270 lei). Daca te hotarasti sa le iei trebuie sa-mi dai adresa unde vrei sa ajunga si iti spun si tarifele pt posta sau curierat. Pt orice piesa am nevoie de datele de pe placuta ovala. Exceptie fac stergatoarele. id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
lily_efs_2000 |
8 Jan 2010, 10:52
#126
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator Clio I,II,III, Modus, Kangoo,Twingo cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025 3 bucati 120 lei Aripa fata stanga tabla Twingo II cod: 77 82 170 227 1 bucata 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo) 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 20 cm, 18 dinti) cod: 77 01 476 973 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) cod: 77 01 477 032 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc cod: 77 01 475 971 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 3 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R19, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (Lucas) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421/77 01 209 841/77 01 207 69577 01 209 735 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II (pt masini fabric. pana in 2005 inclusiv) cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 130 lei placute frana spate(Lucas) Trafic II , Vivaro, vel satis, nissan prima star cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306, nissan kubistar,citroen cod: 77 01 208 142/77 01 205 513/77 01 205 995/77 01 205 996/77 01 206 811 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 8 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 8 seturi 60 lei Tampon Motor Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid 5,Twingo,Express,Megane I,break, R 19, R 21 (diam. 23,8 cm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 28 cm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II,classic/break,coupe,Scenic,Modus,Scenic II,ClioII,III,Kangoo,Laguna I,II,Laguna Nevada (5k 1199 latime=18mm) cod: 82 00 034 396 4 bucati 40 lei Termostat clio I,II,III, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat Avantime, Logan,Clio I,II,III,Laguna I,II, Laguna Nevada,Espace IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Solenta,Supernova,Trafic II,Kangoo,Vel Satis Cod: 77 00 872 554 1 bucata 70 lei Becuri Halogen H7 Renault, Ford cod: 77 01 057 737 4 bucati 25 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I,II,break,coupe,scenic, Kangoo,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic I,II cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Clio II,Espace IV,Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo,Mascott/Master Propulsion cod: 77 01 205 665 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 10 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata - cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
lily_efs_2000 |
10 Jan 2010, 00:31
#127
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator Clio I,II,III, Modus, Kangoo,Twingo cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025 3 bucati 120 lei Aripa fata stanga tabla Twingo II cod: 77 82 170 227 1 bucata 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo) 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 20 cm, 18 dinti) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) cod: 77 01 477 032 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc cod: 77 01 475 971 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 2 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R19, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (Lucas) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421/77 01 209 841/77 01 207 69577 01 209 735 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II (pt masini fabric. pana in 2005 inclusiv) cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 130 lei placute frana spate(Lucas) Trafic II , Vivaro, vel satis, nissan prima star cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306, nissan kubistar,citroen cod: 77 01 208 142/77 01 205 513/77 01 205 995/77 01 205 996/77 01 206 811 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 8 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 8 seturi 60 lei Tampon Motor Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid 5,Twingo,Express,Megane I,break, R 19, R 21 (diam. 23,8 cm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 28 cm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II,classic/break,coupe,Scenic,Modus,Scenic II,ClioII,III,Kangoo,Laguna I,II,Laguna Nevada (5k 1199 latime=18mm) cod: 82 00 034 396 4 bucati 40 lei Termostat clio I,II,III, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat Avantime, Logan,Clio I,II,III,Laguna I,II, Laguna Nevada,Espace IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Solenta,Supernova,Trafic II,Kangoo,Vel Satis Cod: 77 00 872 554 1 bucata 70 lei Becuri Halogen H7 Renault, Ford cod: 77 01 057 737 4 bucati 25 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I,II,break,coupe,scenic, Kangoo,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic I,II cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Clio II,Espace IV,Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo,Mascott/Master Propulsion cod: 77 01 205 665 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 10 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
Villanueva |
10 Jan 2010, 08:08
#128
Membru autentic Group: Members Posts: 582 Joined: 4 June 09 |
Sanse pentru o cotiera de Megane II ? Multumesc !
Bongiovi |
11 Jan 2010, 13:18
#129
Membru autentic Group: Banned Posts: 283 Joined: 30 December 08 From: Braila |
salut ma intereseaza un suport tampon motor pentru un renault laguna 2 an fabr 2001 motor 1,9 dci e o bucsa care are un suport de aluminiu si e deasupra motorului il tine din lateral pentru vibratii codul renault este : 8200367493
multumesc frumos |
Laguna 2
2002 / Privilege
- BR - 61 - ELA
lily_efs_2000 |
12 Jan 2010, 09:02
#130
Villanueva, nu pot aduce cotiera.
Bongiovi, am un tampon motor pt Laguna I fabricatie 98 - 2001 motor 1,9 diesel. Atasez niste poze daca crezi ca e ok ti-l trimit. Pret - 100 lei. Alt tampon nu am. Pt orice piesa am nevoie de datele de pe placuta ovala. Exceptie fac stergatoarele. id: pieserenault2009 tel: 0748.300.479 0725322850 Attached thumbnail(s) DSC00125.JPG ( Size: 1.22mb ) Number of downloads: 573 DSC00126.JPG ( Size: 1.21mb ) Number of downloads: 529 DSC00127.JPG ( Size: 1.18mb ) Number of downloads: 530 DSC00128.JPG ( Size: 1.21mb ) Number of downloads: 299 DSC00129.JPG ( Size: 1.29mb ) Number of downloads: 46 DSC00130.JPG ( Size: 1.18mb ) Number of downloads: 29 |
renault
megane
- is 25 via
Bongiovi |
12 Jan 2010, 23:21
#131
multumesc frumos dar nu e acela nu se potriveste
Laguna 2
2002 / Privilege
- BR - 61 - ELA
bambu |
13 Jan 2010, 19:48
#132
RS club Group: Members Posts: 649 Joined: 31 December 07 From: Bucuresti |
Salut. Placute de frana fata+spate megane rs si filtru polen?
Renault/Citroen
Megane RS/C5 eHDI
2.0T 2008/2012
- RRS viata-i greu, lumea-i hotu!
www.shoetique.ro www.anularefiltrudeparticule.ro |
lily_efs_2000 |
14 Jan 2010, 08:27
#133
bambu, filtru de folen nu am, iar pt placute de frana imi trebuie datele de pe placuta ovala, motorizare, an fabricatie, modelul masinii si cat kw are masina. Daca vrei sa le primesti cat mai repede, lasa-mi si un nr de tel.
Pt orice piesa am nevoie de datele de pe placuta ovala. Exceptie fac stergatoarele. Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/77 00 411 047/77 00 822 620/77 00 802 607/77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/77 01 476 000/77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) diam.240/242 mm cod: 77 01 477 032/77 01 472 001/77 11 134 856/opel-45 01 617/916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc – diam. 242 mm; dinti = 21 cod: 77 01 475 971/opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 2 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 7 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 8 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid 5,Twingo,Express,Megane I,break, R 19, R 21 (diam. 23,8 cm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 28 cm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II,classic/break,coupe,Scenic,Modus,Scenic II,ClioII,III,Kangoo,Laguna I,II,Laguna Nevada (5k 1199 latime=18mm) cod: 82 00 034 396 4 bucati 40 lei Termostat clio I,II,III, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat Avantime, Logan,Clio I,II,III,Laguna I,II, Laguna Nevada,Espace IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Solenta,Supernova,Trafic II,Kangoo,Vel Satis Cod: 77 00 872 554 1 bucata 70 lei Becuri Halogen H7 cu lupa Renault, Ford cod: 77 01 057 737 2 bucati 25 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I,II,break,coupe,scenic, Kangoo,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic I,II cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Clio II,Espace IV,Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo,Mascott/Master Propulsion cod: 77 01 205 665 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata - cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
bambu |
14 Jan 2010, 10:04
#134
Stiu ca la clio si megane RS si la F1 sunt aceleasi si nu am mai specificat. Datele din talon:
an 2008, 165kw, motor F4R-27, VF1BM0MO639427355 |
Renault/Citroen
Megane RS/C5 eHDI
2.0T 2008/2012
eagle_flyaway |
16 Jan 2010, 01:29
#135
Membru incepator Group: Members Posts: 31 Joined: 3 July 09 From: Cluj-Napoca |
Mp3 player pt Megane 2.2 ?
Megane 2 CC
Zapa |
17 Jan 2010, 18:59
#136
Membru incepator Group: Members Posts: 14 Joined: 1 November 09 |
Pentru Lily_efs_2000,
Placute de frana pt. Renault Megan Scenic I an 2000, sunt actualmente pt. sistemul TRW marca Bendix L=130 mm, H=60 mm, Grosime = 15 mm fata (dimensiunile sunt aproximative , masurate de mine cu rigla). Pt. spate nu stiu exact , dar sunt tot Bendix. |
Megan Scenic I
2000- RXE 1,6/16v
- xxx
lily_efs_2000 |
17 Jan 2010, 21:19
#137
bambu, imi trebuie datele de pe placuta ovala, nu ce mi-ai trimis tu.
eagle_flyaway, mp3 nu am. Zapa, mai am comanda de placute de frana pt acelasi tip de masina. Pt o verificare sa fiu sigur imi trebuie datele de pe placuta ovala (se afla pe stalpul portierei de la pasager, e formata din 4 randuri cu cifre si litere) si lasa-mi un nr de tel. In proportie de 99% am placute de frana pe spate TRW la 140 lei/setul, iar pt fata nu cred ca am. Iti pun cateva poze cu placutele pt spate. Ti le pot trimite luni prin curierat sau posta. Pt orice piesa am nevoie de datele de pe placuta ovala. Exceptie fac stergatoarele. Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/77 00 411 047/77 00 822 620/77 00 802 607/77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/77 01 476 000/77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) diam.240/242 mm cod: 77 01 477 032/77 01 472 001/77 11 134 856/opel-45 01 617/916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc – diam. 242 mm; dinti = 21 cod: 77 01 475 971/opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 2 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 7 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 8 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid 5,Twingo,Express,Megane I,break, R 19, R 21 (diam. 23,8 cm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 28 cm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II,classic/break,coupe,Scenic,Modus,Scenic II,ClioII,III,Kangoo,Laguna I,II,Laguna Nevada (5k 1199 latime=18mm) cod: 82 00 034 396 4 bucati 40 lei Termostat clio I,II,III, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat Avantime, Logan,Clio I,II,III,Laguna I,II, Laguna Nevada,Espace IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Solenta,Supernova,Trafic II,Kangoo,Vel Satis Cod: 77 00 872 554 1 bucata 70 lei Becuri Halogen H7 cu lupa Renault, Ford cod: 77 01 057 737 2 bucati 25 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I,II,break,coupe,scenic, Kangoo,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic I,II cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Clio II,Espace IV,Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo,Mascott/Master Propulsion cod: 77 01 205 665 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata - cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 Attached thumbnail(s) Megane_Scenic.JPG ( Size: 1.05mb ) Number of downloads: 60 Megane_break_Scenic_spate_TRW.JPG ( Size: 1.1mb ) Number of downloads: 69 |
renault
megane
- is 25 via
lily_efs_2000 |
20 Jan 2010, 08:52
#138
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/ 77 00 411 047/ 77 00 822 620/ 77 00 802 607/ 77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/ 82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/ 77 01 476 000/ 77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) diam.240/242 mm cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ opel-45 01 617/ 916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc – diam. 242 mm; dinti = 21 cod: 77 01 475 971/ opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 2 bucati 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/ 77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 7 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 5 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 3 seturi 150 lei Discuri Frana Spate Megane Grandtour, Scenic II (diam. 274 mm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II(1.4/1.5dci/1.6),classic/break(1.4/1.5dci/1.6), coupe(1.6),limuzina(1.4/1.5dci/1.6), grand Scenic(1.5dci si 1.6),Modus(1.4/1.5dci/1.6), ScenicII,ClioII(1.5dci),III(1.5dci), Kangoo(1.5dci),Laguna I,II,Laguna Nevada,Master II(2.5D si 2.8 DTI),Vauxh Movano pt motorizare de 2.2 DTI, 2.5 D, 2.5 DTI, 2.8 TDI si 2.8 DTI (5k 1199 latime=18mm) cod: 82 00 034 396/ 77 00 300 347 4 bucati 40 lei Termostat lichid racire clio I,II,III,symbol, kangoo, twingo, modus pt motorizari de 1.2 si 1.4 cod: 77 00 110 716 4 bucati 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 1 bucata 70 lei Module Bujii (Bobina inductie) Clio I,II,,Megane I,II,break,coupe,scenic, Modus, Scenic II,Kangoo +laguna I,II - pt benzina cod: 82 00 380 267 2 bucati 140 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412 189/77 01 045 718 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
lily_efs_2000 |
21 Jan 2010, 10:19
#139
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/ 77 00 411 047/ 77 00 822 620/ 77 00 802 607/ 77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/ 82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/ 77 01 476 000/ 77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) diam.240/242 mm cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ opel-45 01 617/ 916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc – diam. 242 mm; dinti = 21 cod: 77 01 475 971/ opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 1 bucata 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 37 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/ 77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 7 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 5 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 3 seturi 150 lei Discuri Frana Spate cu rulment inclus Megane Grandtour, Scenic II (diam. 274 mm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II(1.4/1.5dci/1.6),classic/break(1.4/1.5dci/1.6), coupe(1.6),limuzina(1.4/1.5dci/1.6), grand Scenic(1.5dci si 1.6),Modus(1.4/1.5dci/1.6), ScenicII,ClioII(1.5dci),III(1.5dci), Kangoo(1.5dci),Laguna I,II,Laguna Nevada,Master II(2.5D si 2.8 DTI),Vauxh Movano pt motorizare de 2.2 DTI, 2.5 D, 2.5 DTI, 2.8 TDI si 2.8 DTI (5k 1199 latime=18mm) cod: 82 00 034 396/ 77 00 300 347 4 bucati 40 lei Termostat lichid racire pt motorizari de 1.2 si 1.4 clio I,II,III,symbol, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 1 bucata 70 lei Module Bujii (Bobina inductie) Clio I,II,,Megane I,II,break,coupe,scenic, Modus, Scenic II,Kangoo +laguna I,II - pt benzina cod: 82 00 380 267 2 bucati 140 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412 189/77 01 045 718 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set curea de distributie(curea, rola int, ghidaj) Avantime,Clio I,II,Espace IV,Express, Kangoo, Laguna I,II,Nevada,Master,Megane I,II,coupe,break,scenic,Pick-up,Scenic II,Solenta,Trafic II - 1,9 diesel cod: 77 01 471 866 1 bucata 300 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
lily_efs_2000 |
23 Jan 2010, 07:33
#140
renault
megane
- is 25 via
lily_efs_2000 |
25 Jan 2010, 02:18
#141
renault
megane
- is 25 via
CristianFlorea |
25 Jan 2010, 10:18
#142
Membru autentic Group: Members Posts: 298 Joined: 15 December 09 |
Sunt interesat de o oferta pentru un injector motorina (nou sau reconditionat Delphi - garantie) si de o aripa stanga fata plastic pentru Renault Megane Sedan II 1,5 dci. Masina este fabricata in 2004.
Plăcuța ovală : LMOFR101674 EA4SAN913EPACK NVG32DRAP04HARM02 TLROUM ACHS VY5W nr. identificare sasiu: VF1LM0FC531926152 Motor tip: K9K-D7 Serie motor: D222641 email: cristianflorea@yahoo.com Tel: 0720.912.505. sau 0764.444.301. |
Laguna GT line 2.0 dci
dec 2009 Ex: Megane III Sporttourer 1,5 dci 105CP
Actual: Renault Laguna 3 - 2.0 dci Actual: Skoda Octavia 3 - 2.0 tdi 150 CP mai 2014 |
lily_efs_2000 |
27 Jan 2010, 08:25
#143
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/ 77 00 411 047/ 77 00 822 620/ 77 00 802 607/ 77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/ 82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/ 77 01 476 000/ 77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.8 DTI (98-2001) diam.240/242 mm cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ opel-45 01 617/ 916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master 3000cc, Opel Movano 3000cc – diam. 242 mm; dinti = 21 cod: 77 01 475 971/ opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 4 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 1 bucata 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 36 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/ 77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 7 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 5 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 3 seturi 150 lei Discuri Frana Spate cu rulment inclus Megane Grandtour, Scenic II (diam. 274 mm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II(1.4/1.5dci/1.6),classic/break(1.4/1.5dci/1.6), coupe(1.6),limuzina(1.4/1.5dci/1.6), grand Scenic(1.5dci si 1.6),Modus(1.4/1.5dci/1.6), ScenicII,ClioII(1.5dci),III(1.5dci), Kangoo(1.5dci),Laguna I,II,Laguna Nevada,Master II(2.5D si 2.8 DTI),Vauxh Movano pt motorizare de 2.2 DTI, 2.5 D, 2.5 DTI, 2.8 TDI si 2.8 DTI (5k 1199 latime=18mm) cod: 82 00 034 396/ 77 00 300 347 4 bucati 40 lei Termostat lichid racire pt motorizari de 1.2 si 1.4 clio I,II,III,symbol, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 1 bucata 70 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412 189/77 01 045 718 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 CristianFlorea, injectoarele s-au terminat, iar pt portiera nu gasesc cod echivalenta. Eu am 77 01 473 025/77 01 471 380, iar tie iti trebuie 77 51 473 728+77 11 22 44 13 - aripa stg fata. |
renault
megane
- is 25 via
FDR |
27 Jan 2010, 09:28
#144
Membru Authentique Group: Members Posts: 647 Joined: 28 June 07 From: BV |
senzori presiune roti - Laguna II
policioara portbagaj cu jaluzea - Laguna II hatchback. astept preturile. multumesc |
Laguna III
2011 2.0dci
- BV 24 ___
lily_efs_2000 |
28 Jan 2010, 13:07
#145
Membru autentic Group: Members Posts: 366 Joined: 4 August 09 |
FDR, am doar ceea ce e trecut in lista.
renault
megane
- is 25 via
lily_efs_2000 |
29 Jan 2010, 19:29
#146
Pt orice piesa am nevoie de datele de pe placuta ovala (se afla in partea dreapta la pasager, pe stalpul dintre portiere). Exceptie fac stergatoarele.
renault
megane
- is 25 via
lily_efs_2000 |
31 Jan 2010, 08:26
#147
Pt orice piesa am nevoie de datele de pe placuta ovala (se afla in partea dr a masinii pe stalpul dintre portiere). Exceptie fac stergatoarele.
Airbag Pasager Fata Renault Clio II, Clio RS V6 cod: 82 00 505 999 1 bucata 750 lei Alternator 90 amperi Clio I,II,III, Modus, Kangoo,Twingo II cod: 82 00 429 898 1 bucata 970 lei Amortizoare Spate Clio1 (de carbon Delphi x 57 Sauf M5 Poland lung=41 cm) cod: 77 00 427 536/ 77 00 411 047/ 77 00 822 620/ 77 00 802 607/ 77 00 802 609 2 bucati 190 lei Amortizor Dreapta Fata Twingo (lung = 49 – 50 cm) cod: 82 00 041 572/ 82 00 013 146 1 bucata 140 lei Amortizor spate Laguna II (lung=59-59,5 cm APA – KYB SPANIA) cod: 82 00 283 393 1 bucata 220 lei Amortizoare suspensie Motrino fabr. In Mexico lung = 33 cm cod: 86 71 001 075 2 bucati 250 lei Aripi fata stanga plastic Modus cod: 77 01 475 515 1 bucata 120 lei Aripi fata stanga plastic Clio II cod: 77 01 473 025/ 77 01 471 380 3 bucati 120 lei Faruri R11, R9, Maserati Biturbo coupe cod: 77 01 034 897 (061278 valeo)/ 77 01 03 17 92/ 77 01 03 48 96 2 bucati 150 lei Kit Ambreiaj Valeo complet Clio II,III,Kangoo,Laguna I,II,Nevada,Megane I,II,break,coupe,scenic,Modus, Scenic II - placa de presiune, discul (82 00 344 044) (diam. 200 mm; dinti = 26) – pt motoare de 1.4 si 1.6 benzina cod: 77 01 476 973/ 77 01 476 000/ 77 01 474 519 2 seturi 300 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Safrane, Master II, Trafic II, Movano 2.5 - 2.8 DTI si D (98-2001) diam.240/242 mm – pt masini cu 59 kw si 84 kw cod: 77 01 477 032/ 77 01 472 001/ 77 11 134 856/ opel-45 01 617/ 916 19 17 3 seturi 600 lei Kit Ambreiaj Valeo Mascott/Master Propulsion, Master III 3000cc, Opel Movano, Nissan Interstar 3000cc TDI si DCI – diam. 242 mm; dinti = 21 pt masini cu 100 kw cod: 77 01 475 971/ opel-441 5884/Vauxhall-931 83 687 1 set 700 lei Module Bujii (Bobina inductie) Avantime, Clio II, Megane I, Megane II, Kangoo, Laguna I, Laguna II, Espace III, Scenic, Trafic II, Vel Satis, Opel Vivaro, Nissan Primastar cod: 82 00 380 267/ 82 00 154 186 A 2 bucati 140 lei Captuseala Schimbator Renault Clio II cod: 77 00 431 905 1 bucata 90 lei Maner Portiera(argintiu)+sensor (cand vede cartela in apropiere deblocheaza portierele) Megane II, Scenic II cod: 77 01 474 997 1 bucata 420 lei Oglinda Laterala 155 mm stg. Kangoo, Express cod: 77 01 039 896 1 bucata 60 lei Oglinda Laterala stg. incalzita Kangoo, Megane Scenic cod: 77 01 048 401 1 bucata 70 lei Oglinzi Laterale Dreapta incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 753 3 bucati 75 lei Oglinzi Laterale Stanga incalzite Megane II, Scenic II, Laguna II, Clio III, Vel Satis cod: 77 01 054 752 1 bucata 75 lei placute frana fata(Bosch) Clio, Super 5, R9, R19, R 20, R21, R 21 Nevada cod: 77 11 130 034 4 seturi 80 lei placute frana spate (TRW) Scenic II, Megane II, Clio III, Laguna II cod: 77 01 208 421 5 seturi 130 lei placute frana fata(TRW) Clio III, Modus, nissan micra, suzuki swift 3 – cod: 41060-AX625; D1060AX60A; Honda- cod: 43022TL0G50 cod: 77 01 208 422 36 seturi 100 lei Placute Frana FATA TRW Logan, Clio II, Express, Megane I, break, coupe, scenic, Twingo cod: 77 11 130 071/ 77 01 207 066 3 seturi 85 lei Placute Frana Ferodo fata Megane II, Scenic II, Laguna II cod: 77 01 209 444 10 seturi 140 lei Placute Frana spate TRW Megane break, Megane Scenic, AudiA4, Passat,etc cod: 77 01 207 484 8 seturi 140 lei placute frana spate(TRW) Trafic II , Vivaro, vel satis, nissan prima star-cod:41060-00QAE si 77010-54771, Vauxhall cod: 9199257 cod: 77 01 054 771 9 seturi 110 lei placute frana fata(Bosch) Kangoo (fata), Peugeot 206, 306,405, nissan kubistar cod: 41060-00QAF si 41060-00QAG,citroen cod: 77 01 208 142 8 seturi 90 lei placute frana fata(Bosch) Master II, Opel Movano cod: 7701207166 9 bucati 110 lei Semnalizare laterala Clio1, Express, R 19, R 21, R 21 Nevada, Safrane cod: 77 01 047 516 2 bucati 40 lei Senzor Captor Viteza PE CUTIE Avantime,Clio II,Kangoo,Laguna I, Laguna Nevada,Megane I,break,coupe,scenic, Logan, Solenta, Twingo cod: 77 00 418 919 6 bucati 100 lei Pompa Injectie Bosch cod Bosch: 7700110395, 14228 R803 1,9 diesel Avantime,Clio I,II,Espace IV,Express,Kangoo,Laguna I,II,Nevada,Master,Megane I,II,Clasic/Break,Coupe,Megane Scenic,Scenic II,Trafic II cod: 77 11 134 385 1 bucata 3200 lei Set Centura Siguranta ? cod: 82 00 522 693 1 bucata 75 lei Set Centura Siguranta ? cod: 82 00 522 689 1 bucata 75 lei Set Chei (2) + Yale portiere + rezervor Twingo II cod: 77 01 367 377 1 set 250 lei Stergatoare Valeo Megane Scenic, Kangoo, Logan, Clio I, II, etc (600 mm + 400 mm) cod: 77 11 210 130 2 seturi 60 lei Stergatoare Valeo Master, Scenic, Megane II,Megane Scenic, Tranzit, Opel Movano, Vivaro, etc (600 mm) cod: 77 11 210 131 4 seturi 47 lei Stergatoare Valeo Laguna II, Megane I, II, Clio II, etc (600 mm + 500 mm) cod: 77 11 219 445 5 seturi 60 lei Tampon Motor/suport ventilator Avantime, Laguna I, Laguna Nevada 1.9dti, dci 1997-2001, Espace III 1.9 dti 02.1999-10.2002 cod: 82 00 021 529 1 bucata 100 lei Tija Sustinere Capota Kangoo cod: 77 00 309 115 1 bucata 20 lei Turbo Compresor Clio II, Clio III, Megane II, Megane Combi, Megane Limuzina, Kangoo, Modus, Scenic II 1,5 DCI 74 kw si Grand Scenic 1,9 DCI 88 kw – geometrie variabila cod: 77 01 476 183 1 bucata 2000 lei Turbo Compresor Clio II Grandtour, Nissan Tiida hatchback, Nissan Tiida Limuzina 1.5 DCI 78 kw – geometrie variabila cod: 77 01 476 883 1 bucata 2500 lei Discuri frana fata neventilate pt masini fara ABS Logan,Clio1,2,Megane1,Rapid,Super5,Twingo,Express,Megane I,break,Megane Scenic R9, R11, R19, R21 (diam. 238 mm, butucul de 14 cm, gaura de 6 cm) cod: 77 01 204 282/ 77 00 704 705 3 seturi 150 lei Discuri Frana Spate cu rulment inclus Megane Grandtour, Scenic II (diam. 274 mm, butucul de 8,2 cm exterior, gaura de 3 cm) cod: 77 01 208 230 1 set 350 lei Filtre Aer Master II, Traffic, Movano, Vivaro (93160736/4411637), Nissan – cod: 1640500QAB cod: 77 01 207 667 10 bucati 40 lei Curele Accesorii MeganeI,II(1.4/1.5dci/1.6),classic/break(1.4/1.5dci/1.6), coupe(1.6),limuzina(1.4/1.5dci/1.6), grand Scenic(1.5dci si 1.6),Modus(1.4/1.5dci/1.6), ScenicII,ClioII(1.5dci),III(1.5dci), Kangoo(1.5dci),Laguna I,II,Laguna Nevada,Master II(2.5D si 2.8 DTI),Vauxh Movano pt motorizare de 2.2 DTI, 2.5 D, 2.5 DTI, 2.8 TDI si 2.8 DTI (5k 1199 latime=18mm) cod: 82 00 034 396/ 77 00 300 347 4 bucati 40 lei Termostat lichid racire pt motorizari de 1.2 si 1.4 clio I,II,III,symbol, kangoo, twingo, modus cod: 77 00 110 716 4 bucati 80 lei Termostat lichid racire (se dechide la 89 grade, cu etansare) -pt motoare de 1.4/1.6/1.8/2.0 benzina Avantime,Logan,Sandero, Solenza-1.4,Clio I,II,III,Laguna I,II, Laguna Nevada,EspaceIII, IV,Master,Megane I,II,coupe,break,scenic,Modus,Scenic II,Supernova,Trafic II,Kangoo,Vel Satis, Opel Vivaro Cod: 77 00 872 554/ 82 00 772 985 1 bucata 70 lei Buson vas expansiune Clio I, Express, R 19, Super 5 cod: 77 01 018 380 2 bucati 35 lei Col fix turbo Avantime, Espace IV, Laguna I,II,Nevada, Master, Safrane, Trafic II, Vel Satis cod: 77 01 471 128 1 bucata 110 lei Electromotor Bosch Avantime,Clio I,II,Espace IV, Megane I-1.9,II,break,coupe,scenic, Kangoo 1.9,Express, Laguna I,II,Nevada,Master, Scenic II,Trafic-1.9D I,II,R9,R11,R19,R21,Rapid-1.6D,1.9D,Super5-1.6D, Symbol-1.9D cod: 77 01 499 804 1 bucata 540 lei Element fixare esapament Logan, Clio II,Espace IV(2.0 dCi),Laguna I,Nevada,Megane II,Safrane,Audi, Citroen, Ford, Bmw e46, e39 cod: 77 03 083 398 2 bucati 40 lei Proiector ceata stg Clio II,Kangoo,Master II,Megane coupe, Twingo(1.2),Mascott/Master Propulsion cod: 77 01 205 665/ 77 00 412 189/77 01 045 718 1 buc 140 lei Kit Proiectoare Ceata Clio III cod: 77 11 236 164 1 set 400 lei Set jaluzele laterale Scenic II cod: 77 11 223 898 1 set 200 lei Set jaluzele laterale Modus cod: 77 11 227 497 1 bucata 230 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 260 1 bucata 100 lei Set covorase mocheta Twingo, Kangoo cod: 77 11 225 266 1 bucata 100 lei Set covorase mocheta Clio III cod: 77 11 060 396 9 bucati 100 lei CALCULATOR AIRBAG Kangoo cod: 82 000 98 401 1 bucata 500 lei STOP DR SPATE PE HAYON laguna II cod: 82 000 02 476 1 bucata 60 lei Capac Retrovizor stg Laguna II cod: 82 00 000 508 1 bucata 50 lei Balama inferioara dr fata cod: 82 00 53 81 41 cod: 88 00 338 987 1 bucata 100 lei id: pieserenault2009 tel: 0748.300.479 0725322850 |
renault
megane
- is 25 via
lily_efs_2000 |
1 Feb 2010, 08:31
#148
renault
megane
- is 25 via
Ugly |
1 Feb 2010, 10:02
#149
Membru incepator Group: Members Posts: 99 Joined: 28 February 06 |
Salut.
Bobinele sint 2 la 140 ron? Ce marca sint? Macar teoretic, ce garantie au? In cit timp ajunge o comanda in Bucuresti? Edit: In legatura cu stergatoarele - nu reusesc sa trimit foto pe PM. Le atasez aici This post has been edited by Ugly: 1 Feb 2010, 20:47 Attached thumbnail(s) IMG_0669.jpg ( Size: 408.57k ) Number of downloads: 59 IMG_0667.jpg ( Size: 364.31k ) Number of downloads: 58 |
Megane II
2005 Hatchback Megane II Hatchback 1,4 16V Pack Authentique 2005
UXE |
1 Feb 2010, 20:48
#150
Modelator Group: Members Posts: 6.730 Joined: 21 June 06 From: Bucuresti |
vinzi si piese ptr seat ibiza mai vechi?
Symbol
2006 1.4 8v
- UXE Subaru Forester 2.5 XT - 230 CP
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 26th May 2024 - 02:57 |
