Mio Moov 500 Ro - opinii
Alydor |
- Igo8 - C520
service_reno |
Membru Group: Banned Posts: 133 Joined: 26 July 09 ![]() |
La imaginea pe care ai prezentat-o: dublu clic pe fisierul MioAutoRun, al 3-lea de sus in jos. Se va instala MioPocket.
renault
megane
Alydor |
imaginea prezentata este luata de pe calculator. pe calculator poti sa dai dublu clik pana behai ca nu se instaleaza pe aparat...
@avani banuiesc ca nu ai citit fisierul Miopoket readme.txt... care zice asa: " 4B) Mio Moov models only: i. Create, in the root of your SD card, a folder with one of the following "Cobia" names, depending on your model (Note: filenames ARE case-sensitive): * Moov 150 (European: Cobia_300L_32, North American: Cobia_300L_32_NA, Australian: Cobia_300L_32_AU) * Moov 200 (European: Cobia_300_32, North American: Cobia_300_64_NA, Australian: Cobia_300_32_AU) * Moov 210 (European: Cobia_T300_32, North American: Cobia_T300_64_NA, Australian: Cobia_T300_32_AU) * Moov 300 (European: Cobia_400_64, North American: Cobia_400_64_NA, Australian: Cobia_400_64_AU) * Moov 310 (European: Cobia_T400_64, North American: Cobia_T400_64_NA, Australian: Cobia_T400_64_AU) * Moov 330 (European: Cobia_410_64, North American: Cobia_410_64_NA, Australian: Cobia_410_64_AU) * Moov 360 (European: Cobia_420_64, North American: Cobia_420_64_NA, Australian: Cobia_420_64_AU) * Moov 370 (European: Cobia_T420_64, North American: Cobia_T420_64_NA, Australian: Cobia_T420_64_AU) * Moov 500 (European: Cobia_500_64, North American: Cobia_500_64_NA, Australian: Cobia_500_64_AU) * Moov 500 R2 (European: Cobia500R2, North American: Cobia500R2_NA, Australian: Cobia500R2_AU) * Moov 580 (European: Cobia_T550_64, North American: Cobia_T550_64_NA, Australian: Cobia_T550_64_AU) * Knight Rider: KITT_USA Example: \Storage Card\Cobia_400_64_NA" Suma respectelor, Alydor |
- Igo8 - C520
Avani |
![]() Membru autentic Group: Members Posts: 2.133 Joined: 23 October 07 From: Capitala gri ![]() |
Nu am citit readme
. Think forward !
service_reno |
Avani: te-ai descurcat?
Alydor: ce harta a europei ne recomanzi? |
renault
megane
Alydor |
eu folosesc europa pe bucati... nu folosesc harta mare a europei, cea care cuprinde toate tarile... cea pe care o am eu este de 22 de Mb
- Igo8 - C520
tzepesch |
Pt convertirea MIO MOOV 500 in PPC, folosti MIO POCKET 3.0 R55 . azi l-am instalat si eu, se poate pune pe card SD sau Flash-ul device-ului. F F usor de instalat, f util dupa aceea.
Arata f bine softul, IGO 8 merge perfect pe el, chiar si cu cei 64RAM ai sai, poti pune si GARMIN daca vrei, ai o carca de aplicatii office, joace, si alte prostioare. Va recomand un stylus Iar ecranul de 4.7" e un deliciu pt PPC. pacat ca n-are Audio OUT, atat ar fi fost necesar. F dragut ca TV in masina cand ai de asteptat dupa lume in parcari. Bafta. This post has been edited by tzepesch: 10 Dec 2009, 17:08 |
DELTA GALIDI Station Wagon
- B-xx-xxx
1982 - 1310 - 4VIT. De ce caraie cioara in zbor? ... Schimba vitezele
tmanbone |
Membru incepator Group: Members Posts: 39 Joined: 22 March 06 ![]() |
Am deblocat si eu un Moov 500 cu Navman Unlock si a mers perfect. Apoi l-am reblocat, folosit acelasi soft si am incercat ulterior cu MioPocket 3.0 Release 55 si nu prea-mi iese. Instalarea incerc sa o fac pe flash disk, iar cand incerc sa-l pornesc imi zice:
"There is no application associated with "Program Files\MioMap\MioMap" Run the application first, then operate this file from within the application." Dupe ce inchid alerta respectiva de 3 ori.. aparatul se restarteaza si o ia de la capat. Aveti vreo sugestie? (Cu Google n-am gasit mare lucru). Pot sa-l readuc usor la setarile initiale, fara sa ma mai complic cu MioPocket, dar sunt curios de ce nu-mi merge... |
Dacia / Opel -
1310 / Astra Caravan -
1991 / 2001
Alydor |
Cine v-o fi invatat sa instalati programe pe PNA?
![]() ![]() ![]() Suma respectelor, Alydor |
- Igo8 - C520
Avani |
. Think forward !
tzepesch |
este f explicit pe situl de mai sus cum se instaleaza.
e flore la ureche. eu mi-am pus filme, muzia, poze, carti pe el, am baza de date agenda tel/mail, etc. e un deliciu daca ti-e lene sa inveti la un examen. Igo merge perfect, MioMap la fel, cateva utilitare de gps. Garmin inca nu am reusit sa-l instalez. PS: nu incercati sa instalati Garmin QUE ca nu-l mai scoateti. nu se mai dezinstaleaza. In afara de Wireless, si Audio out functioneaza f bine pe post de PPC. spor. ps: a aparut release 56 a lui Miopocket v3 This post has been edited by tzepesch: 15 Dec 2009, 15:36 |
- B-xx-xxx
Manuchao |
Membru incepator Group: Members Posts: 22 Joined: 16 April 08 ![]() |
Salut, am instalat si eu MioPocket pe Moov 500, am folosit Moov Unlocker. Problema este ca acum nu-l mai vede calculatorul cand ma conectez la el, cum procedez ca sa adaug ceva pe card?? trebuie sa cumpar card reader sau nu este normal sa nu il vada??
Si inca o intrebare, gps-ul nu mai vede satelitii, zice ca se conecteaza si astept...sa fie oare din cauza vremii??mentionez ca folosesc tot MioMap ca celelalt nu stiu sa le pu ![]() Nu mai am probleme cu semnalul, probabil a fost din cauza vremii. M-am conectat la calculator dupa ce i-am dat restart, am pus cate ceva pe card dar nu mai am optiunea " safe remove" ( nu mai vede cardu ca inainte sa instalez Miopocket-ul, acum porneste un programel Microsoft ActiveSync si prin intermediul lui copiez pe cardul SD ) si sunt nevoit sa scot USb-ul normal, iar cand pornesc Gps-us imi da o eroare cum ca nu vede cardul si sunt nevoit sa resetez si sa inslalez iar ..voi cum procedati?? treb sa folosesc un card reader? multumesc This post has been edited by Manuchao: 16 Dec 2009, 23:00 |
Clio 3
2008/Dynamique
tzepesch |
f simplu.
il pui pe off, din butonu slide de sus, ii bagi cablul si-l vede ActiveSyncu. Altfel o da in balarii. MioPocket are optiunea la Settings, la Usb nush-cum sa selectezi sa se conecteze ca ActiveSync sau ca MassStorage. Dar ca mass, ii balareste miopocketu cand se conecteaza. |
- B-xx-xxx
Manuchao |
multumesc pentru raspuns tzepesch, asa procedez, il pun pe off si ii conectez USB-ul, dupa care se aprinde singur, pun ce am nevoie pe el iar cand scot cablul se stinge.Apoi il pornesc si imi apar 2 erori, cea de-adoua imi spune ca nu vede cardul, dau ok si porneste dar nu pot sa fac nimic pe el, imi da erori cand intru in aplicatii si trebuie sa instalez iar MioPocket.
Alta problema - dupa ce il folosesc, il dau pe off de la buton (daca ii dau shut down trebuie sa instalez iar MioPocket cand il pornesc ca nu il mai vede), si cand il pornesc nu imi recunoaste unele aplicatii, adica nu vrea sa le porneasca sau uneori imi da si eroare, iar daca a fost lasat pe MioMap nu vrea sa mai iasa, dar functioneaza Gps. Sigur am gresit ceva, va rog sa-mi spuneti unde, ce trebuie sa fac sa functioneze calumea, sa nu trebuiasca sa instalez de fiecare data MioPocket-ul. Multumesc tzepesch- stiu optiunea despre care vorbesti, este setat pe ActiveSync. This post has been edited by Manuchao: 18 Dec 2009, 17:11 |
Clio 3
2008/Dynamique
Forestman |
![]() Membru Group: Members Posts: 120 Joined: 25 August 06 From: Suceava ![]() |
Salut !
Stie cineva cum se procedeaza pas cu pas pentru instalearea IGO sau MIOMAP pe MOOV 500? Din ceea ce am citit mai sus nu am prea inteles. Ma chinui de 2 zile si numai nu reusesc. L-am deblocat si am instalat MioPocket. Dar cum fac cu softurile de navigatie. Le folosesc pe aceleasi care-mi merg pe un PDA Mio A501. Numai pe asta nu vrea sa mearga. Sunt softuri diferite pt. PDA si pt. PNA? Unde gresesc? Am nevoie urgenta de ajutor! Multumesc mult ! |
Logan 1.5dci
2006, Ambiance; Ford Ka; MIO A501
sorin_ |
![]() Membru Group: Members Posts: 131 Joined: 7 July 06 From: Constanta ![]() |
Forestman ai PM cu cateva adrese utile pentru instalare igo si Amigo + ultimele harti.
Succes |
Clio Symbol
- CT
2007 Dynamique 1.4 16v + clima
corbex |
QUOTE(Alydor @ 12 Dec 2009, 22:30) Cine v-o fi invatat sa instalati programe pe PNA? ![]() ![]() ![]() Suma respectelor, Alydor Am un GPS mai no name, cu WinCE 6.0 pe el, procesor YFAtlas4, la 500 Mhz, cu softul de navigatie exclusiv pe card. IGO merge brici, dar fiu-meu mi-a aratat o harta Garmin pe care sint trecute pina si crucile din cimitir. Stii cumva daca si ce versiune de Garmin ar fi compatibila cu scula asta? Undeva intr-un info scrie ceva de felul "YF INTERNATIONAL LTD". Posibil sa fie producataorul, un taiwanez destul de cunoscut, care face PNA-uri pentru oricine si sub orice marca, contra sumei potrivite. This post has been edited by corbex: 24 Dec 2009, 18:42 |
2005, cheala
GolfIII |
![]() Membru autentic Group: Members Posts: 506 Joined: 5 April 04 ![]() |
Nu prea vad legatura problemei tale cu subiectul topicului...
Dar in fine: poti sa iei 5.00.20 sau 5.00.30. Ambele merg ok. Ti-as recomanda 5.00.20 |
Volkswagen
Golf III
1995
tzepesch |
Salutam ipocrizia unor dictatori de admini care sterg posturile utile si carora le pute cand li se da pe la nas.
Revenind. Avand in vedere ca nu e un soft ilegal ( What is MioPocket? MioPocket is a frontend for Windows CE-based devices, mainly GPS navigation devices. It is an installable package of programs, scripts, registry files and skins to "unlock" PNA/GPS devices and allow them to be used for far more than just navigation (ex. for music, movies, appointments, multiple navigation apps, etc.). MioPocket is the most-packed and most-fully-featured unlock for PNAs available and is free and legal to use, as it consists 100% of freely-distributable content. What MioPocket is not is a replacement for MioMap, Mobile Navigator or any other OEM navigation software. It is just a frontend from which you may launch your device's navigation software or other navigation software that you've purchased. 6.4 License Do pretty much whatever you want with MioPocket. It's an open project. You're encouraged to add your own modifications on top of MioPocket and release them for all to use. If you do so, just maintain the spirit of the project: it's free to all and all may add to it. You may even poach MioPocket's ideas, scripts and other files for your own unlocks (just as MioPocket poached many things from earlier unlocks). Any way in which the MioPocket project can continue to give back to the community is welcome. Finally, the contributors of MioPocket are in no way liable for any damage that the software might make to your unit. You assume the risk when you put it on your device. ) NU IL MAI STERGETI, este in interesul tuturor. Iar daca iar mi se sterge topicul, care nu este sub nici o forma o ofensa adusa nimanui si care nu incalca nici o regula a forumului se adevereste faptul ca administratorii, unii, au o problema personala cu mine pt ca nu le permit sa se simta guru pe un forum public, free for all. Poate fi privit ca un manifest acest post. So, http://www.mediafire.com/?zmmi1gmogj2 |
- B-xx-xxx
GolfIII |
Asa este, MioPocket nu este ilegal. Multumim pentru arhiva.
Dar totusi nu era mai simplu un link de genul asta: http://lmgtfy.com/?q=MioPocket |
Volkswagen
Golf III
1995
Fratzica |
![]() Zen Group: Moderatori Posts: 2.925 Joined: 6 April 04 ![]() |
eu am sters postul, in urma unui report de postare warez. Intr-adevar se pare ca nu era cazul, imi cer scuze pentru decizia pripita.
In alta ordine de idei, nu exista probleme personale "virtuale" asa ca victimizarea nu isi are rostul. Un report sau un PM rezolva situatia foarte simplu si rapid. |
Kia
Sportage
T-GDI 2021 "The happier we are, the less we see." - some japanese guy
tzepesch |
E ok, nu aveam nimic cu tine, ci cu altuser cu care am avut ceva polemici. Si n-ar fi singurul, din motive f intemeiate.
Na-m apucat, dar voi urca o arhiva cu ultimulMioPocket exact cu folderele pt MioMoov500, device-ul in discutie aici, foldere care trebuiesc doar copiate pe card, apoi inserat in aparat. Fara nici un fel de explicatii&shiet. Plain and simple. |
- B-xx-xxx
tzepesch |
#53
Precum v-am promis,
Mio Pocket 3.56 MP356MioMoov500 rar Are in folderul de media si DEX-ul inclus. Bafta Un an nou fericit!!! |
- B-xx-xxx
shadow_x3x |
#54
Membru Group: Members Posts: 149 Joined: 28 December 09 From: Galati ![]() |
Eu am folosit navman unlocked si a mers de minune...
Honda
Civic 5D
tzepesch |
#55
pe voi cat va tine bateria?
Cu brightness-ul la minim dat din MioMap, MioPocket a raportat 3h30min, folosire 80%Igo, 20% jocuri si citit. |
- B-xx-xxx
vdragosh |
#56
Membru incepator Group: Members Posts: 1 Joined: 5 January 10 ![]() |
QUOTE(tzepesch @ 29 Dec 2009, 16:23) Precum v-am promis, Mio Pocket 3.56 MP356MioMoov500 rar Are in folderul de media si DEX-ul inclus. Bafta Un an nou fericit!!! La Multi Ani. Mi-am cumparat ieri un Mio Moov 500 . Am incercat sa pun MioPocket dar nu am reusit ( device-ul ignora cardul la bootare , se pare ca il baga in seama doar daca il scot si il bag la loc cand este deja pornit -> blocheaza MioMap ![]() Am incercat si cu arhiva ta -> acelasi rezultat ![]() Oare am eu o versiune mai noua care nu ma boot-eaza de pe card ? T510R2.V1.00.0010 Daca pornesc device-ul cand am cablul usb bagat in PC apar 2 fereste : 1. Fatal Application Error : Application auto.exe has performed an illegal operation and will be shutdown. If the problem persists, contact the program vendor . Program : auto.exe . Exception : 0xC0000005 . Adress : 00011838 2. Fatal Application Error : Application MortScript.exe has performed an illegal operation and will be shutdown. If the problem persists, contact the program vendor . Program : MortScript.exe . Exception : 0xC0000005 . Adress : 0005827C PS: merge crack-uit cu Mio_Moov_Unlock -> intra in windows si de acolo pot sa rulez MioMap . 5 Jan 2010, 12:06: Am uitat sa precizez : eu incerc sa instalez MioPocket pe un card SD This post has been edited by vdragosh: 5 Jan 2010, 12:06 |
chevrolet
kalos
- 1234567
tzepesch |
#57
Aceeasi problema am avut=o si eu cu cardul pe care l-am luat, Kingston 4Gb.
Am aceeasi versiune cu tine. Incerca sa-l formatezi intr-un card reader, nu in device. incerca si cu alt card, chiar de 512mb. nu uita!!! da-i reset din buton inainte sa bagi cardul cu miopocketul pe el. deci, copiezi folderele, scoti cardul, dai reset la device, on, il lasi sa conecteze miomapul la gps, bagi cardul, il lasi in pace sa-si faca bucataria. 6 Jan 2010, 02:37: CUM se instaleaza SYGIC pe Mio asta? Am incercat si vers 7.7 si nu vede hartile, si 7.60. ,7.60 incarca hartile dar nu le deblocheaza. Vad ca citeste numai harti cu format .mlm Hart RO este .pak. This post has been edited by tzepesch: 6 Jan 2010, 02:37 |
- B-xx-xxx
Alydor |
#58
Repet pentru a x+1-a oara. Pe PNA NU se instaleaza softuri.Singurul soft care se instaleaza este cel de unlock, adica miopoket sau unlocker Se pun doar softuri care functioneaza cu plug & play. ce vezi tu cu mlm nu sunt harti. Hartile Sygic sunt in format pak. Asadar o sa ai in folderul maps un fisier mlm si in acel folder ar trebui sa mai ai si un folder ROU care sa contina fisierul *.pak. Pe PNA sygic-ul se ruleaza din folderul drive/windowsCE/drive.exe
- Igo8 - C520
tzepesch |
#59
a mers
Cand ma intreaba de harta am selectat All maps si a luat-o. |
- B-xx-xxx
predutu |
#60
Membru incepator Group: Members Posts: 2 Joined: 18 January 10 ![]() |
Salut
Mi-am luat un Mio Moov 500 si are doar hartile pentru romania. Ma poate ajuta cineva pls sa pun hartile full europe (din 2009 daca se poate) pentru Miomap sau sa pun Igo 8 pe el? De unde pot lua miomap sau igo 8? Se poate si fara deblocare? Am un card SD de 4 GB merci |
nu
nu
- nu
nu
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 4th August 2025 - 03:22 |
