7 Pages « < 3 4 5 6 7 >
> Vand discuri de frana si placute EBC Brakes, made in UK, discount de 25%
ebcbrakes
post 7 Feb 2011, 12:46
Post #121
QUOTE(ThunderRa @ 6 Feb 2011, 18:17)
Salut,
Vreau si eu o oferta pentru un Megane Sedan 2.2 1.6 16v 2008 la urmatoarele:
Discuri fata / discuri spate / placute fata-spate
Exclude, te rog, variantele standard. Merci
SALUT!
Placute standard EBC Blackstuff : 41 Eur/set fata si 18 Eur/set spate
Placute upgrade EBC Greenstuff : 68 Eur/set fata si 46 eur/set spate
Placute standard ATE: 232 ron/set - fata si 157 ron/set - spate
Placute standard TRW: 161 ron/set - fata si 81 ron/set - spate
Placute standard LPR: 72 ron/set - fata si 50 ron/set - spate
Discuri standard EBC UPR: 100 Eur/set fata si 197 Eur/set spate(cu rulment)
Discuri upgrade EBC TurboGroove/USR : 164 Eur/set fata
Discuri standard ATE: 192 ron/buc - fata si 411 ron/buc - spate(cu rulment)
Discuri standard ATE Power Disc: 353 ron/buc - fata
Discuri standard Brembo: 165 ron/buc – fata
Discuri standard Brembo MAX: 222 ron/buc - fata
Discuri standard Zimmerman: 168 ron/buc - fata
Discuri standard Zimmerman perforat: 287 ron/buc - fata
Discuri standard LPR: 117 ron/buc - fata
Cu placere! O zi buna!
QUOTE(boditza @ 6 Feb 2011, 21:43)
Sunt si eu interesat de discuri pt un opel omega din 2002 motor de 2,2 diesel 88kw. in principiu as vrea pt fata dar sa imi spuneti si pretul la cele de pe spate, de asemenea si la placute fata cu senzor si spate . cele de pe spate nu sunt ventilate
Salut!
Placute standard EBC Blackstuff : 29 Eur/set fata si 18 Eur/set spate
Placute upgrade EBC Greenstuff : 61 Eur/set fata si 48 eur/set spate
Placute ceramice EBC Redstuff : 71 eur/set fata si 56 eur/set spate
Placute circuit EBC Yellowtuff : 74 eur/set fata si 54 eur/set spate
Placute standard ATE: 249 ron/set - fata si 97 ron/set - spate
Placute standard FERODO: 129 ron/set - fata si 82 ron/set - spate
Placute standard TRW: 158 ron/set - fata si 84 ron/set - spate
Placute standard LPR: 87 ron/set - fata si 44 ron/set - spate
Discuri standard EBC UPR: 99 Eur/set fata si 105 Eur/set spate
Discuri upgrade EBC TurboGroove : 197 Eur/set fata
Discuri standard Zimmerman: 209 ron/buc - fata si 137 ron/buc – spate
Discuri standard LPR: 178 ron/buc - fata si 118 ron/buc – spate
Senzor uzura ATE: 39 RON/buc
O zi buna!
Fiat X1/9 1984
surveyor
post 9 Feb 2011, 22:00
Post #122
salut!
niste preturi pentru:
megane sedan II.1 1.5dci 82cp
LM0F R247453
EA2 SAN913 EPACK
NV676 DRAP02 HARM01
TLROUM ACGS VY5W
- cap bara stanga Febi
- burduf bieleta axiala ( caseta-bieleta) Lemforder
- set bucsi bascule inferioare stanga si dreapta Febi
- placute standard FERODO fata+spate
- Discuri standard Brembo fata+spate
- daca exista si faruri lupa
renault megane dec.2005, 1.5 dci, 82CP
oct 2009-139.000 km
feb 2011-150.000 km
nov 2011-160.000 km
nov 2015-200.000 km
4turbo
post 10 Feb 2011, 11:14
Post #123
Salut!
cap de bara Febi : 98ron/buc
burduf bieleta Lamforder : 73ron/buc
bucsi bascula Febi : 44+43+pivot 76ron/pe brat
placute fata Ferodo : 138ron/set
placute spate Ferodo : 66ron/set
placute fata EBC BlackStuff : 95ron/set
placute fata EBC GreenStuff : 258ron/set
placute spate EBC Blackstuff : 77ron/set
placute spate EBC GreenStuff : 198ron/set
placute fata LPR : 72ron/set
placute spate LPR : 50ron/set
discuri fata LPR : 117ron/bucata
discuri fata Brembo : 165ron/bucata
discuri spate Brembo : 362ron/bucata cu rulment
discuri fata EBC UPR : 430ron/set
discuri fata upgrade EBC USR/TurboGroove : 705ron/set
discuri spate EBC UPR : 240ron/set fara rulment sau 880ron/set cu rulment
far cu lupa doar pt facelift 06+
dacia logan 2006
adrian_74
post 11 Feb 2011, 21:21
Post #124
Salut! Pentru un RENAULT Laguna2, 1,9dci, 88kw(120cp), an2003 un set de placute de frana fata, o oferta? Multumesc anticipat!
renault laguna2 expression2003 - b545hnj
1,9dci galben 270k km, sunt in crestere!
ebcbrakes
post 16 Feb 2011, 14:13
Post #125
Salut!
Placute standard EBC Blackstuff : 29 Eur/set fata si 27 Eur/set spate
Placute upgrade EBC Greenstuff : 85 Eur/set fata si 54 eur/set spate
Placute ceramice EBC Redstuff : 98 eur/set fata si 60 eur/set spate
Placute circuit EBC Yellowtuff : 0 eur/set fata si 62 eur/set spate
Placute standard ATE: 244 ron/set - fata si 157 ron/set - spate
Placute standard FERODO: 156 ron/set - fata si 131 ron/set - spate
Placute standard TRW: 118 ron/set - fata si 93 ron/set - spate
Placute standard LPR: 104 ron/set - fata si 77 ron/set - spate
Discuri standard EBC UPR: 117 Eur/set fata si 107 Eur/set spate(fara rulment) / 203 Eur/set (cu rulment)
Discuri standard ATE: 291 ron/buc - fata
Discuri standard Brembo: 203 ron/buc – fata
Discuri standard Zimmerman: 173 ron/buc - fata si 179 ron/buc – spate(fara rulment) / 458 ron/buc (cu rulment)
Discuri standard LPR: 138 ron/buc - fata si 385 ron/buc – spate(cu rulment)
Diametrul discurilor pe care ti le-am ofertat este de 280mm fata. Daca ai discuri de 300MM, va rog sa-mi spuneti sa va refac oferta! O zi buna!
This post has been edited by ebcbrakes: 16 Feb 2011, 14:14
Fiat X1/9 1984
mic&rau
post 17 Feb 2011, 09:03
Post #126
Salut,
Ma intereseaza si pe mine pentru un logan 1.6 16v din 2007 placute de frana si cu discuri de frana.Mersi frumos
Dacia logan 1.6 16v Dacia logan 1.6 16v Prestige 2007 - B -- TOX
ebcbrakes
post 17 Feb 2011, 10:46
Post #127
mic&rau :
Salut !
Placute :
EBC BlackStuff : 77ron
EBC GreenStuff : 145ron
EBC YellowStuff : 220ron
ATE : 130ron/set
FERODO: 67ron/set
TRW : 100ron/set
LPR: 75ron/set
Discuri :
EBC Upr : 320ron/set
EBC TurboGroove/USR : 570ron/set
ATE : 187ron/buc
BREMBO : 118ron/buc
ZIMMERMAN : 146ron/buc
LPR : 89ron/buc
Fiat X1/9 1984
dantes
post 17 Feb 2011, 16:11
Post #128
Salut.
Ce oferte sunt disponibile pentru o laguna 3, 1.5 dci, an 2008, set placute fata si set discuri fata?
Multam
O masina oarecare . - .
Old school
tonyzg
post 17 Feb 2011, 21:54
Post #129
Salut
ma intereseaza un set de placute frana spate , bieleta directie stanga si bieleta antiruliu pentru un citroen C5 II din 2004 , motor 1.8 benzina 85kw
multumesc
Clio Symbol 1.5 dci 85cp 2008
Dacia 1310 1997
4turbo
post 21 Feb 2011, 12:18
Post #130
@dantes
Disc frana EBC fata : UPR 135euro/set
Placute fata :textar 243ron/set
Zimmerman 141ron/set
LPR 105ron/set
21 Feb 2011, 13:13:
@tonyzg
salut
Bieleta bara stabilizatoare Lemforder 86ron , delphi 76ron
Bieleta de directie lemforder :103ron , Delphi 91 ron
Placute EBC spate: blackstuff 17euro/set , greenstuff 36euro/set
placute spate ATE 177ron/set
Textar 199ron/set
LPR 62ron
Ferodo Premier :129ron/set
This post has been edited by 4turbo: 21 Feb 2011, 13:13
dacia logan 2006
adrian_88_21delta
post 22 Feb 2011, 21:33
Post #131
Salut, ma intereseaza o oferta de placute si discuri , ambele fata spate,pentru un mondeo mk 3 2.0 tdci an 2006.
multumesc anticipat
Ford Mondeo mk3 2006
ebcbrakes
post 23 Feb 2011, 12:14
Post #132
SALUT
Placute standard EBC Blackstuff : 32 Eur/set fata si 44 Eur/set spate
Placute upgrade EBC Greenstuff : 69 Eur/set fata si 54 eur/set spate
Placute ceramice EBC Redstuff : 80 eur/set fata si 60 eur/set spate
Placute circuit EBC Yellowtuff : 82 eur/set fata si 62 eur/set spate
Placute standard ATE: 177 ron/set - fata si 234 ron/set - spate
Placute standard FERODO: 130 ron/set - fata si 125 ron/set - spate
Placute standard TRW: 130 ron/set - fata si 147 ron/set - spate
Placute standard LPR: 84 ron/set - fata si 84 ron/set - spate
Discuri standard EBC UPR: 100 Eur/set fata si 69 Eur/set spate
Discuri upgrade EBC TurboGroove/USR : 197 Eur/set fata si 122 Eur/set spate
Discuri standard ATE: 229 ron/buc - fata si 176 ron/buc - spate
Discuri standard Brembo: 161 ron/buc – fata si 186 ron/buc-spate
Discuri standard Zimmerman: 189 ron/buc - fata si 107 ron/buc – spate
Discuri standard Zimmerman perforat: 319 ron/buc - fata
Discuri standard TRW: 199 ron/buc - fata si 232 ron/buc – spate
Discuri standard LPR: 136 ron/buc - fata si 117 ron/buc – spate
Fiat X1/9 1984
ebcbrakes
post 16 Mar 2011, 14:16
Post #133
Anunt valabil !
Fiat X1/9 1984
drag_osh
post 19 Mar 2011, 12:52
Post #134
Buna,
Niste preturi(mai mici), te rog, pentru urmatoarele piese?
- disc frana de 280 mm
- placute frana fata (cu urechile in sus)
- kit reparatie etrieri fata
- semering cutie de viteza (schimbator)
Megane 1 an 2003, 1.9 dci ; 75Kw
Multumesc
This post has been edited by drag_osh: 20 Mar 2011, 11:47
Renault Megane I 2003 - expression - 1870cc diesel
mlm
post 20 Mar 2011, 09:45
Post #135
Salut,
Ma intereseaza si pe mine pentru masina mea Renault Clio Symbol cu urmatoarele caracteristici:
LBOPC5,CLIO 2 cu 4 usi-modelExpression 1,4 ; 16V; 98 CP-Tip motor: K4J712
placute de frana
discuri de frana
Mersi frumos
This post has been edited by mlm: 20 Mar 2011, 09:45
Renault Clio Symbol Expression 2005 1,4 16V 98CP
alin_gsm
post 20 Mar 2011, 17:29
Post #136
pt un ford galaxy din 97 1.9tdi (ahu) 90 cai o oferta pt frane fata spate discuri + placute.vreau ceva peste performantele standard gen ebc.mersik.
dacia logan 2005 - is 07 rxx
4turbo
post 21 Mar 2011, 15:39
Post #137
QUOTE(drag_osh @ 19 Mar 2011, 12:52)
Buna,
Multumesc
Salut,
Discuri frana fata :
ATE :190ron/buc
Brembo 153ron/buc
Zimmerman 168ron/buc
TRW 163ron/buc
LPR 120ron/buc
EBC standard(UPR) 100euro/set
EBC Upgrade (turboGroove/USR) 164euro/set
Placute Fata:
ATE : 98ron/set
TRW :85ron/set
LPR: 81ron/set
Ferodo premier 97ron/set
EBC standard (blackstuff) 22euro/set
EBC upgrade :Greenstuff 60euro/set
21 Mar 2011, 15:56:
QUOTE(mlm @ 20 Mar 2011, 09:45)
Salut,
placute de frana
discuri de frana
Mersi frumos
Salut
Discuri Fata:
ATE :185ron/buc
Brembo Max : 213ron/buc
Brembo: 112ron/buc
Zimmerman: 149ron/buc
TRW 129ron/buc
LPR 120ron/buc
EBC Standard (UPR):75euro/set
EBC upgrade(turbogoove/USR) :162euro/set
Placute fata:
ATE 129ron/set
TRW 95ron/set
LPR 48ron/set
Ferodo premier :64ron/set
EBC Standard(blackstuff) 18euro/set
EBC upgrade: Greenstuff 46euro/set , yellowstuff 52euro/set
21 Mar 2011, 16:00:
QUOTE(alin_gsm @ 20 Mar 2011, 17:29)
Salut
Disc EBC : fata 99euro/set , spate 84euro/set
Placute EBC fata:Blackstuff 28euro/set , greenstuff 78euro/set
Placute EBC spate: Blackstuff 18euro/set , greenstuff 46euro/set
This post has been edited by 4turbo: 21 Mar 2011, 16:00
dacia logan 2006
solidconvert
post 23 Mar 2011, 18:19
Post #138
Donator
Salut! Set placute frana fata Megane 2.2 1.5 dci an 2006, tip motor K9K-F7,74kw...
Ma intereseaza variante si preturi...
Audi A4 B9 S-tronic TFSI...
Gîndirea corectă vine din experiență. Experiența, la rîndul ei, provine din gîndirea greșită.
ebcbrakes
post 24 Mar 2011, 11:53
Post #139
Salut!
Placute standard TEXTAR: 218 ron/set - fata si 91 ron/set - spate
Placute standard FERODO: 125 ron/set - fata si 68 ron/set - spate
Placute standard TRW: 145 ron/set - fata si 84 ron/set - spate
Placute standard LPR: 114 ron/set - fata si 51 ron/set - spate
O zi buna!
Fiat X1/9 1984
ebcbrakes
post 4 Apr 2011, 13:36
Post #140
Anunt valabil !
Fiat X1/9 1984
balanel
post 4 Apr 2011, 16:35
Post #141
Transmisie automata - confort si siguranta.
Salut.
As dori pentru un Renault Symbol/ Thalia, 2007, diesel, discuri si placute (fata).
Discurile de origine sunt ventilate. Masina are ABS. Nu este prevazuta cu senzori de uzura la placute.
Ma intereseaza o configuratie in care discurile sa se uzeze cat mai putin, iar placutele sa fie cele care se uzeaza mai mult. Deci discuri cat mai dure, si placute cat mai moi.
Mai jos ai seria caroseriei si motorului:
Discuri: diametru 238mm, ventilate, grosime 20.1, 4 gauri.
Placute: latime 100 mm, inaltime 64.8 mm, grosime 18.2 mm.
Multumesc.
This post has been edited by balanel: 4 Apr 2011, 21:59
chevrolet aveo sedan t300 LT+ a14xer - 1.4 benzina aspirat 100 CP/ 2013 (in curand alta masina, cu transmisie automata)
Mwe Louis-Rene Panhard si Emile Levassor, inventatorii transmisiei manuale.
Fan Mircea Badea.
ebcbrakes
post 7 Apr 2011, 09:10
Post #142
Am raspuns pe PM !
Multumesc !
Fiat X1/9 1984
marius.bunga
post 7 Apr 2011, 21:40
Post #143
placute spate scenic 2, vf1jmocoh32231188, 1.6, 16 valve
This post has been edited by marius.bunga: 8 Apr 2011, 19:30
Renault Scenic II 2005
4turbo
post 8 Apr 2011, 12:39
Post #144
Ce motorizare are masina?
dacia logan 2006
casper
post 8 Apr 2011, 13:48
Post #145
salut, aș dori o ofertă pentru un megane sedane 2.1 motor 1,5 dci 60kw an 2005 următoarele:
-discuri frână față /spate (nu știu cu ce vine mașina, diametru, grosime etc ... ar fi de ajutor un sfat raportat la cel ce vine original versus ceva mai bun, la un preț decent )
-plăcuțe frână față / spate (preferabil Lucas TRW)
mulțumiri anticipate !
MEGANE SEDANE 2005
megane sedan expresion 1,5 dci 80 cai - martie 2005
Cipryspeed
post 8 Apr 2011, 14:44
Post #146
Salut,ma intereseaza un set de discuri spate si placute tot spate pentru un Megane coach.Motor 2.0 16v F3RD7,an fabricatie 1997.astept oferta de pret.Multumesc!
renault megane 2000 coupe - AG 49 CIP
marius.bunga
post 8 Apr 2011, 19:32
Post #147
set placute spate renault scenic 2, 1.6, 16 v, vf1jmocoh32231188
ebcbrakes
post 11 Apr 2011, 10:13
Post #148
QUOTE(casper @ 8 Apr 2011, 14:48)
Salut,
Spune-mi te rog daca masina este cu facelift!
MS
QUOTE(Cipryspeed @ 8 Apr 2011, 15:44)
Salut,
Placute standard EBC Blackstuff : 25 Eur/set fata si 34 Eur/set spate
Placute upgrade EBC Greenstuff : 80 Eur/set fata si 46 eur/set spate
Placute ceramice EBC Redstuff : 93 eur/set fata si 51 eur/set spate
Placute circuit EBC Yellowtuff : 97 eur/set fata si 67 eur/set spate
Placute standard TEXTAR: 199 ron/set - fata si 98 ron/set - spate
Placute standard FERODO: 135 ron/set - fata si 66 ron/set - spate
Placute standard TRW: 156 ron/set - fata si 85 ron/set - spate
Discuri standard EBC UPR: 100 Eur/set fata si 56 Eur/set spate(fara rulment)
Discuri standard TEXTAR: 193 ron/buc - fata
Discuri standard Brembo: 151 ron/buc – fata
Discuri standard Zimmerman: 166 ron/buc - fata
Discuri standard LPR: 118 ron/buc - fata
Cu placere!
QUOTE(marius.bunga @ 8 Apr 2011, 20:32)
Buna ziua,
Placute standard TEXTAR: 183 ron/set - fata si 92 ron/set - spate
Placute standard TRW: 149 ron/set - fata si 84 ron/set - spate
Fiat X1/9 1984
casper
post 11 Apr 2011, 12:07
Post #149
QUOTE(ebcbrakes @ 11 Apr 2011, 10:13)
Salut,
MS
Salut,
nu este modelul cu facelift, este primul model de megane 2.1.
MEGANE SEDANE 2005
ebcbrakes
post 11 Apr 2011, 16:44
Post #150
Salut,
Placute standard EBC Blackstuff : 22 Eur/set fata si 18 Eur/set spate
Placute upgrade EBC Greenstuff : 60 Eur/set fata si 46 eur/set spate
Placute standard ATE: 253 ron/set - fata si 134 ron/set - spate
Placute standard FERODO: 138 ron/set - fata si 66 ron/set - spate
Placute standard TRW: 137 ron/set - fata si 84 ron/set - spate
Placute standard LPR: 73 ron/set - fata si 50 ron/set - spate
Discuri standard ATE: 191 ron/buc - fata si 416 ron/buc - spate(cu rulment)
Discuri standard ATE Power Disc: 357 ron/buc - fata
Discuri standard Brembo: 151 ron/buc – fata si 354 ron/buc-spate(cu rulment)
Discuri standard Zimmerman: 166 ron/buc - fata si 154 ron/buc – spate(fara rulment)
Fiat X1/9 1984
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 21st July 2025 - 03:59
