30 Pages < 1 2 3 4 5 > »
Closed TopicStart new topic
> "Corabia" mea...., de la Nissan la Logan
kossak
post 29 Sep 2009, 23:49
Post #61
O brosura din Australia.
A se vedea ultima poza: 12 luni garantie, 20.000 km si 36 luni anticoroziune smile.gif
Despre pret..date luate de pe un forum
"C32...1985 Nissan Laurel 3.0V6 SGX Hardtop. Had the VG30S single carburettor engine. Only available as 4 speed overdrive auto. These were sold new in NZ between 1984-1987, and were a very expensive car. $65,000 NZ dollars. (a top model Nissan Bluebird sold for about $28,000 NZD) Had the rear seat radio controls as standard, electrically operated drivers seat, huge bumpers compared to the JDM Laurels, independant rear suspension, 4 wheel disc brakes and 15" alloys. Tilt and slide sunroof was standard on the hardtops only. Even the rear seat could be slid forward and back for comfort, and had removeable rear headrests."
This post has been edited by kossak: 30 Sep 2009, 00:07
Honda Civic 1.8 Sport, ex Dacia Logan 1.4 Laureate
"Whenever you find yourself on the side of the majority, it is time to pause and reflect"
kossak
post 2 Oct 2009, 18:31
Post #62
Azi am primit (intr-un final) cei 15 litri de ulei de cutie Castrol Dexron 3.
Am procedat prin metoda clasica: bag ulei pe la joja si il scot la furtunul de la radiator.
Am consumat 12 litri de ulei pana a iesit curat pe furtun.
Daca aveam o garnitura noua, demontam capacul de la cutie dar fiinda a fost deja dat de 2 ori fara a schimba garnitura nu am vrut sa ma risc.
Si niste poze:
Asa a aratat ulei scos din cutie la final:
Si la final:
Pret ulei: 345 RON
Impresii: deocamdata merge OK, schimba mult mai fin. Ramane de vazut daca se schimba ceva dupa ce fac "rodaj" la ulei.
This post has been edited by kossak: 2 Oct 2009, 18:32
alecsnissanlaurel
post 4 Oct 2009, 10:35
Post #63
Salutare!
In primul rand felicitari pentru masina si pentru pasiunea investita in ea, in al doilea rand constatarea mea este ca aceasta masina merita sa fie intretinuta intrucat este poate una din cele mai "fidele" masini de care am auzit. Detin un model c31 din 1981 cred ca este ca cea a tatalui tau...impresii le prezint, concluziile le trageti voi... 2800 cm3 eu stiam de 90 cp, cutie manuala 5 trepte - consum 90-100 km/h(aprox 2200-2300 rot/min) - 5.5-6.//110-120 - aprox 6.2/6.5(2900-3000 rot/min). in 3 ani am schimbat consumabile - ca student fac naveta saptamnal buzau-bucuresti (aprox 260 km dus intors plus aprox 80 km saptamanal in bucuresti), schimbat ulei si filre in jur de 80.000 km. ca probleme pot semnala diferentialul care mai arunca ulei pe la simeringul de la cupla - completez aprx 1 l la 2000- 2300 km in ceea ce priveste rugina exista un singur loc pe caroserie unde este atacata....la arcada aripei de pe stanga spate unde a fost efectuata repartie si s-a sudat o alta tabla....
In ansamblu...la modul obiectiv nu pot face comparatie decat cu Cielo( pe care il detine tata) si un alt model de niisan - mai tanar - Almera 2002.
In ceea ce priveste confortul nu se poate discuta de niciuna dintre cele doua masini, la drum lung Laurel-ul ofera cea mai confortabila pozitie(poti sta relaxat cu piciorul stang....il poti intinde complet) - ca stabilitate - nu intra in discutie Cielo si nici la cap consum...cielo a batut recordul in traficul bucurestean peste 12 l!!!!!!!!.
Nu stiu...sunt multe de spus dar cu siguranta nu imi vin toate in minte acum. piese pt laurel se gasesc mai greu ce e drept elemente de caroserie.
Vad ca esti din cluj - mi-ar face placere sa discutam la o cafea pt ca voi ajunge mai des la cluj- aah mi-am amintit de o problema care mi-a dat ceva de furca dar bineinteles din vina mea: am schimbat curea de la alternator si servodirectie dar am uitat complet de cureaua de la pompa de motorina....cu care am facut peste 150 000 km...si pe dealul feleacului a murit....asta e s-a rupt...problema a fost ca s-a intamplat la 450 km de casa....in fine s-a rezolvat -cureaua a fost 30 ron....!!!
in rest e o masina care imi place din toate punctele de vedere(exceptand faptul ca nu am AC vara...)cuntumul impozitului se amorseaza vand in vedere fiabilitatea si consumul foarte mic(am facut o gramada de teste prietenilor care nu au crezut c este posibil ca motorul asta sa aiba un consum atat de mic)
Mi-ar placea sa tinem legatura...in ceea ce prioveste piesele daca mai ai farul vechi spart am putea sa incercam sa il reconditionam la ploiesti - exista un atelier in care baietii se ocupa de asa ceva...iar parbrizul il poti face dc ni gasesti in alta parte la Gerom buzau ar trebui sa il schimb si eu si daca tot facem matrita putem comanda doua...orium discutam.
aah problema cu fumul la mine s-a rezolvat mai ales dupa ce am schimbat cureaua de la pompa de motorina si am reglat-o pe dntii pe care ii recomanda manualul de reparatii.
Nissan Laurel Nissan Laurel 1981
kossak
post 4 Oct 2009, 11:30
Post #64
Salut!
Ma bucur ca mai e cineva caruia ii place Laurel-ul.
Daca zici ca ai C31, probabil e identic cu cel pe care l-a avut tata.
Initial l-am tinut in garaj vreo 3 ani in speranta ca tata va rezolva cu numerele vechi si mai era nevoie de mici reparatii dar intr-un final a renuntat la idee si am tras-o la "ferma"
Cureaua aia de care ai zis tu ca ti s-a rupt cred ca e de fapt cea care "mana" pompa de injectie, am citit ca intervalul de schimb e 60k mile. La mine nu stiu daca a fost schimbata vreodata, cred ca ar fi o idee buna sa o schimb inainte sa se rupa.
Din cate am citit e destul de greu sa-ti faci access la ea, trebuie demontat un capac.
Ai un consum foarte bun! ( de fapt am mai citit pe ceva forumuri si se pare ca intr-adevar se poate sa scoti asa putin cu cutie manuala)
Esti sigur ca la 2900-3000 rpm ai doar 120 la ora?
La mine cam asta a fost maximul:
Mi-ar placea si mie sa tinem legatura, poti sa iei un ID de la profilul meu smile.gif .
Bafta!
This post has been edited by kossak: 4 Oct 2009, 11:37
Merced
post 4 Oct 2009, 11:39
Post #65
om al munților
Are alte rapoarte cutia automata fata de cea manuala.
it's a kind of peace.
kossak
post 4 Oct 2009, 11:42
Post #66
Adevarat. Si in plus si diferentialul de diferit (e mai "de fuga" la automata)
Am auzit ca e o combinatie tare sa cuplezi o cutie manuala la un diferential de automata.
alecsnissanlaurel
post 4 Oct 2009, 13:30
Post #67
Salutare dinnou! voi pune si poze cat de curand momentan nu pot saptamna viitoare cu siguranta.
Intr-adevar diferentialele sunt diferite. Nu am cablu de kilometraj,nu stiu dc am spus dar masina a depasit milionul de km....nu am facut reparatii la motor si da....inca merge acum ma gandeam ca nu am reglat tachetii cel putin eu niciodata in 155.000 de km nu stiu daca e nevoie...viteza am masurat-o cu gps-ul ..am observat la alte masini ca e o eroare de aprox 10 km/h intre viteza indicata de gps si ceasul de bord probabil vitezometrul ar fi aratat 130....oricum maximul aratat de gps a fost de 152 km/h - 3500 rot/min dar nu e o masina pe care sa o fugaresti atat de mult avand in vedere venerabila varsta...ma multumesc cu 120 viteza de croaziera...
Tinem legatura...!
4 Oct 2009, 13:39:
Am uitat este vorba de cureaua de distributie a pompei de motorina...faci comanda si costa 30 lei este facuta de italieni, se demonteza grila fata, radiator, racoardele, filtrul de aer cu tubulatura cu tot, capacul acela albastru si se pune la 20 de dinti intre semnele de pe curea si la semnul de pe volant..in orice caz discutam atunci cand vrei sa faci operatiune intr-adevar este de munca aprox 2-3 ore dar macar stai linistit si nu patesti ca mine... sa ramai cu ochii in soare la cine stie ce distanta. trebuie pusa exact la semn pt ca asa reglezi si avansul in caz contrar ori scoate fum, ori "bate" mai urat ca un Aro ori nu trage sau trage dar scoate un fum de gzezi tot in urma ta . Ca sfat nu umbla la reglajul debitului la motorina, reglajul se face doar pe bancul de proba din fabrica si de aceea este si sigilat nu vei mai putea sa il nimeresti daca umbli acolo.
This post has been edited by alecsnissanlaurel: 4 Oct 2009, 13:39
ydaniel
post 4 Oct 2009, 13:41
Post #68
Adrenaline junkie!
Oriunde, oricand... ARO!
Cand esti bun ,nu-si amintesc
Cand esti rau ,nu te uita!
alecsnissanlaurel
post 4 Oct 2009, 13:49
Post #69
Am uitat sa te intreb, mai sunt astfel de modele de nissan in cluj? da modelul meu este ca cel al tatalui tau. ceea ce am auzit eu este ca nu este compatibila transmisia finala(diferential, ax cardanic etc) intre cutia automata si manuala adica daca schimbi cu manuala pui tot de la cutie si pana in spate inclusiv planetare( nu se potrivesc cele pe care le ai pe nissanul rosu cu ce ai pe cel cu cutie automata)Ti-am dat add pe mess
4 Oct 2009, 13:55:
din poza ta la 140 km/h vad ca ai volanul putin spre stanga ..banuiesc ca mergeai in linie dreapta ...te intreb pt ca asta este si pozitia volanului la mine...nu trage, nu am joc in caseta de directie(probabil este din cupla de la volan), nu imi toceste dar si-a modificat pozitia...ai incercat sa rezolvi problema asta sau macar sa gasesti cauza?
This post has been edited by alecsnissanlaurel: 4 Oct 2009, 13:55
C a t a l i n
post 4 Oct 2009, 14:57
Post #70
______________________
QUOTE(MAERSK @ 23 Sep 2009, 09:49)
Bunicul meu a avut așa ceva, și ar fi trebuit să devină prima mea mașină... Dar a vândut-o până să am eu permis, pe nimic...sad.gif
O să incerc să o descriu, din ce-mi mai amintesc, și poate găsesc și vreo poză.
Era model 1985, motor pe benzină, 6 cilindrii în linie, transmisie automată. Alte cifre nu cunosc. Era echiparea de top, avea trapă, full electrică în interior, aer condiționat, până și ștergătoare pe faruri. Tabla era imaculată, niciun punct de rugină în 17 ani, și era acoperită cu un lac gros, ca un scotch. Avea jante de aluminiu pe 15" parcă, anvelope cu talon înalt. Mașina mergea impecabil, era destul de leneșă, precum o balenă, dar impunea un respect deosebit când trecea pe șosea.
Cam de atunci am început să mă uit după mașini japoneze. Din păcate, între timp Nissan s-a aliat cu Renault, și pe piața europeană au scos numai bălării...
Singura poză pe care o mai am cu mașinuța... E făcută prin 2000, cu un aparat foto clasic.
This post has been edited by MAERSK: 4 Oct 2009, 14:58
post 4 Oct 2009, 18:22
Post #71
..asta da masina de mers la costum si cravata, imi inchipui cum ar fi aratat asa la cravata intr-o Dacie 1300 tongue.gif
kossak
post 4 Oct 2009, 19:14
Post #72
MAERSK, foarte faina masina! E modelul C31 si 100% are dotari full, avand in vedere jantele alea de aluminiu. Probabil avea frana pe discuri si pe spate si alte minuni.
argon, exact asa privesc si eu masina asta: e pt mers la cravata biggrin.gif . Un tuning de cocalari nu ar avea ce cauta pe asa ceva. Sunt de parere ca tipul de jante de pe masina de mai sus sunt cele mai potrivite pentru asa o "corabie" smile.gif
Alex: peste un milion de km? Holly s...! asta e ceva.
Legat de treaba cu volanul: da, mergeam pe drum drept si trebuia sa-l tin putin intr-o parte. Nu simteam sa traga masina in nicio parte, dar am observat ca mi se uza cauciucul din dreapta pe exterior. Dupa ce am reglat directia, pot sa tin volanul drept.
In Cluj am vazut doar 2 Nissan-uri d-astea: un C31 ca si al tau, acu' vreo 2 ani parcat undeva in centru si unul ca si al meu iarna trecuta. In rest tacere totala.
Cu viteza nici eu nu trec de 120-130, nu-mi place sa vad acul la 3000 de ture. Maxim i-am dat o data 150 si mi-a fost destul. In schimb in oras o calc destul de bine, probabil de aici am si consumul mare. Am incercat sa merg batraneste dar am luat flashuri si am renuntat dry.gif
Legat de cardane: e diferenta de lungime intre manual si automat. Cel de automata e mai scurt. Daca ar fi sa fac conversia la cutie manuala mi-ar trebui ceva timp...si cum vine anotimpul rece n-am chef sa fac asta acum. Si in plus mi-ar trebui o pompa de ambreiaj noua, un cilindru nou, sa schimb volanta, pedalele etc...mi-ar lua cateva zile sa fac asta.
Ramane de vazul cand isi da duhul automata asta, eu sper sa mai tina macar un an acuma ca i-am pus si ulei nou.
ydaniel: il duc la reciclat acasa la tara, sa aprinda ai mei focul in soba cu el icon_mrgreen.gif
This post has been edited by kossak: 4 Oct 2009, 19:27
C a t a l i n
post 4 Oct 2009, 19:18
Post #73
Avea tamburi pe spate din câte îmi aduc aminte. Mai sus am zis că avea trapă. În poză nu se vede pentru că, din motive pe care nu le cunosc, fostul proprietar a pus PESTE plafonul original alt plafon. În interior a astupat trapa cu pluș, dar comenzile au rămas vizibile. Plafonul avea altă tentă de culoare. Poza nu e grozavă.
Se mai poate observa un gemuleț din plexiglas la portiera dreapta spate. Un hoț a spart acel geam, dar n-a avut ce fura. Casetofonul (cu autoreverse tongue.gif) era integrat în consolă.
This post has been edited by MAERSK: 4 Oct 2009, 19:19
kossak
post 4 Oct 2009, 19:35
Post #74
La modeul meu au facut sa ocupe 2 locuri. Butoanele pentru antena electrica erau "integrate" in casetofon.
Pentru unele tari, a existat si o varianta "pillarless". Arata fain la 4 usi.
post 4 Oct 2009, 19:37
Post #75
kossak
post 4 Oct 2009, 19:40
Post #76
Neah...cred e UK sau Australia. In America nu a fost exportat. Ei au primit Maxima-ul tongue.gif
alecsnissanlaurel
post 5 Oct 2009, 02:10
Post #77
Asa cum am promis, cateva poze cu Nissan-ul din vara asta pe Transfagarasan
kossak
post 5 Oct 2009, 08:08
Post #78
Arata bine masinuta. Dar vad ca iti lipseste sigla cu "Datsun" de pe capota tongue.gif
driverx
post 9 Oct 2009, 11:02
Post #79
--- Membru cu ralanti ---
Ti-am vazut ieri "rabla". Trebuie sa zic ca arata ceva mai bine decat in poze. Mi-a atras atentia fara sa vreau. Mergeam eu cu gandurile mele si desi nu iti stiam numarul de inmatriculare, am vazut-o si ma gandeam ca e a ta.
Mitsubishi Lancer 2008
kossak
post 9 Oct 2009, 11:08
Post #80
M-ai vazut in mers? Daca da, sper ca nu te-am afumat prea tare icon_mrgreen.gif
driverx
post 9 Oct 2009, 20:10
Post #81
Nu. Parcata. Am vazut-o si azi la pranz. Stii tu pe ce strada.
alecsnissanlaurel
post 9 Oct 2009, 22:35
Post #82
Salutari calduroase din Cluj! Tocmai ce am ajuns pe meleaguri transilvanene bineinteles alaturi de Nissan Laurel:) M-am bucurat astazi de o plimbare linistita intr-o frumoasa zi de toamna, am admirat paleta multicolora a plaiurilor noastre, lasand-o pe batranica sa "ALERGE" in voia sa si m-a rasplatit - aprox 470 de km - 21.8 l:)....am facut plinul in buzau si plinul in cluj...atat a intrat....asta asa ca sa il oftic pe Florin:))
Salutari cu farurile!!!
kossak
post 9 Oct 2009, 22:56
Post #83
Hai bre nu-mi face in ciuda icon_mrgreen.gif Acul meu sta jos intr-una orice i-as face tongue.gif
Fan3
post 9 Oct 2009, 23:04
Post #84
ai cumva faruri de dacie pe masina ? no offence...
kossak
post 9 Oct 2009, 23:09
Post #85
Da, sunt faruri de dacie CN3 si la fel si semnalizatoarele....
10 Oct 2009, 20:04:
Normal, am facut poze. A fost un moment deosebit pt mine.
Motorul la 239k km
This post has been edited by kossak: 10 Oct 2009, 20:04
post 10 Oct 2009, 21:06
Post #86
vrei sa zici ca cea de Galati are peste 1 milion de km?
kossak
post 10 Oct 2009, 21:16
Post #87
post 10 Oct 2009, 21:19
Post #88
poate ne impartaseste mai multe proprietarul, sunt curios ce interventii a avut.
C a t a l i n
post 10 Oct 2009, 21:22
Post #89
Sârmă pe număr, atât! tongue.gif Bine, fie, și pseudo-proiectoarelea alea care îi strică aspectul...
l@u
post 10 Oct 2009, 21:39
Post #90
QUOTE(argon @ 10 Oct 2009, 22:06)
Masinile din Galati au frecvent peste un milion de km si inca mai merg , chiar mai bine decat ,,alte marci".......mai ales VW-urile radmasa.gif
Land Rover Freelander - Td4, HSE
Lo-Fi Version  Harta site  Parteneri  Jocuri online  Curs Valutar  HRH Haine din lana merinos Time is now: 4th August 2025 - 06:17
