Logan 1.6 AC malfunction, Air conditioner not working
IvanLogan04 |
Membru incepator Group: Members Posts: 3 Joined: 7 September 09 ![]() |
Logan 1.6MPI
- BG678...
Andy_ACS |
Hi, It may be the cooling agent from the compressor - you may need to refill it.
IvanLogan04 |
It was refilled in the workshop, but that was not the case apparently.
Logan 1.6MPI
- BG678...
mostafabakry |
Membru incepator Group: Members Posts: 14 Joined: 16 January 09 ![]() |
Hi,
it may be from a problem with the a\c fan may be it need to replaced or the sensor may need to be checked I guess that as you said that the problem appear when the engine is hot hope that you find the solution BR |
renault
rddg
![]() fan Dacia Group: Members Posts: 21.863 Joined: 12 November 05 From: Bucuresti ![]() |
cHeck if the engine cooling fan is working all right. It might prevernt the co,pressor clutch from engaging if it's not working.
- negru pe alb
Ronne |
![]() Membru incepator Group: Members Posts: 1 Joined: 21 January 11 ![]() |
hi guys,..
This site contains very awesome discussion and great sort of informative stuff useful one for many others needs this kind of stuff,.. |
assa
sa
as [url=http://www.tiffany-jewelry.biz]tiffany jewelry store[/url]
[url=http://www.tiffany-jewelry.us]tiffany jewelry store[/url] |
IvanLogan04 |
Completely forgot about this, nevertheless ….
It was a stupid A/C switch; It doesn’t look as small from the inside as from the outside. After replacement it AC was working fine. P.S. Sold the car, bought fiat, thinking of coming back to Logan duster, until then…. |
Logan 1.6MPI
- BG678...
maddogg127 |
Membru incepator Group: Members Posts: 1 Joined: 8 April 15 ![]() |
Hello IVAN LOGAN 04. I HAVE A LOGAN 1.6 AND AM FACING THE same ISSUE. THE compressor automatically switches off after 10 min. What switch i have to replace? ? Can u answer in detail.?
renault
2008 1.6 Glx
roland |
There is only one AC switch in the entire car. That one.
However, if you do not have other issues like cooling agent quantity, fan problems, ... |
DarioGTI |
![]() Membru incepator Group: Members Posts: 31 Joined: 14 February 10 From: Croatia/Germany ![]() |
Hi to all,
I have a Logan 1.6 2005 with 128.000km with AC. The AC worked really perfectly last summer, I used the AC last time somewhere in October. Now, a few days ago, I wanted to start the AC as usual, by pressing the AC button, but the AC doesn't start, and the LED near the switch doesn't glow. It glows only as I am holding the switch pressed ( I tryed holding it pressed for 10 seconds, the compressor starts running, the motofan started, and it started venting cold air in the interior). Has someone an idea what it can be? How to "test" the switch" ? |
SuperNova 2002 Europa /
Logan 2005 Laureate +
SupeRNova 2003 E7J Europa LPG -> 219 800 km (!) Logan MCV 2007 K4M Laureate LPG-> 55 000 km (sold) |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th September 2025 - 01:30 |
