[ Iasi ] Service Auto - prezentare, Doar pentru intretinere si schimb de piese!
CRyS` |
![]() Membru autentic Group: Members Posts: 458 Joined: 13 July 09 From: _-= IASI =-_ ![]() |
Megane 2 1.5 dCi 82 CP by [ CompletCHIP]
markon |
Membru incepator Group: Members Posts: 63 Joined: 6 February 08 From: iasi ![]() |
cat costaa o diagnoza pt un megane classic?
renault
clio 1
1998
bogdanel88 |
![]() Membru autentic Group: Members Posts: 491 Joined: 17 October 09 ![]() |
ce promotii?fii mai explicit te rog.mersi
solenza/scala
2003 noiembrie
CRyS` |
CRyS` |
In continuare Service Auto "ALL MOTORS" va ofera piese de schimb pentru:
MOTOR Garnituri • Set complet garnituri • Garnitura chiuloasa • Garnitura capac supape • Simering supapa • Garnitura galerie admisie • Garnitura galerie evacuare • Garnitura carter • Garnitura baie ulei • Garnitura circuit ulei • Simering arbore cotit / Ax cu came Chiuloasa / Piese • Garnitura chiuloasa • Garnitura / Capac supape • Garnitura / Galerie admisie / Galerie evacuare • Ghid supapa / Simering supapa / Reglaj supapa • Surub chiuloasa Control distributie • Curea distributie / Rola tensionare / Rola ghidare • Curea de distributie • Set curea de distributie • Ax cu came • Culbutor / Tachet hidraulic • Tampon / Bara / Tub • Supapa / Reglare / Accesorii / ansamblu culbutori Ungere • Filtru ulei • Baie ulei / Garnitura baie ulei / Accesorii • Comutator presiune ulei / Senzor / Supapa Control gaze evacuare • Reciclare gaze de evacuare (EGR) • Control gaze de evacuare (EGR) • Supapa recirculare gaze esapament • Comutator temperatura - Curea transmisie / Set Curea de transmisie cu caneluri Set / Brat de tensionare/Curea distributie / Set curea distributie /Rola intinzatoare - Reparatie ambreiaj complet / Placa de presiune ambreiaj / Disc ambreiaj / Rulment de presiune ambreiaj / Role / Intanzator / Comanda ambreiaj / Cablu ambreiaj Faruri / Elemente • Far/insertie • Bec,far • Elemente, faruri Lumini • Lumini spate / Elemete • Lampa spate / Piese / Bec lampa spate • Lumini frana / Elemente / Bec lampa stop • Semnalizare / Elemente /Bec semnalizare • Iluminare placa inmatriculare • Lumini placa inmatriculare • Bec, iluminare numar inmatriculare • Lumini ceata spate / Elemente / Bec lampa ceata spate • Lumini mers inapoi / Elemente / Bec lampa marsalier Iluminari auxiliare /Elemente • Far ceata / Elemente • Proiector ceata / Montare • Bulb proiector ceata - Planetara / Articulatie / set Burduf - Filtru ulei / Filtru aer / Filtru combustibil Sistem injectie benzina • Senzor • Sonda • Control mers in gol Control emisie gaze de esapament • Reciclare gaz esapament (RGE) • Management RGE - Arc spirala / Amortizor / Reglaj garda la sol / Suspensie hidraulica Rulment sarcina / Set element directie complet / Elemente suspensie / Fuzeta Amortizor / Componente - Bieleta directie / Piese Burduf / Granitura Articulatii directie / Caseta directie / Pompa servodirectie / Legaturi directie Directie / Bucsi / Elementi • Elemnet edirectie • Bieleta directie, antiruliu, cap bara • Bucsa Stabilizare / Rigidizare • Stabilizator • Bieleta antiruliu • Bara torsiune • Rigidizari Butuc roata / Lagar • Prezon roata • Rulment roata • Simering planetara - Articulatii / Rotula inferioara, superioara / Suport ansamblu amortizor-arc / Articulatie / Set reparatie Suport / Corp / Montant ax • Corp ax • Suport ax Frana disc • Disc frana • Set placute frana • Componente / Accesorii frana - Etrier / Piese etrier / Suport etrier Frana tambur • Tambur frana • Material frictiune sabot frana / Sabot frana • Piese disc tambur - Parghie / cablu Frana de mana / Indicator de uzura placute de frana / Cilindru receptor frana / Furtun frana / Servofrana / Pompa centrala frana / Rezervor lichid frana / Piese Regulator forta de frana / Control al dinamicii de rulare - Sistem de evacuare complet / Toba de esapament / Teava de esapament - Pompa apa / Garnitura Termostat / Garnitura Radiator racire apa / Ulei / Piese Radiator incalzire interior / Sonda temperatura apa / Releu / Ventilator radiator Sistem pornire / Electromotor Generator / Alternator / Elemente • Alternator • Regulator tensiune • Acumulator etc. Si multe multe multe alte piese de schimb! Ca tot a venit primavara va asteptam pentru revizii la preturi promotionale! |
powerx |
![]() Membru Group: Members Posts: 192 Joined: 2 March 04 From: Iasi sau Vaslui ![]() |
Cat ar ajunge o revizie de 4 ani pt Logan 1.6 8v ambition, cu tot cu piese?
In principal schimbat distributia, ulei, filtre, lichide(frana, racire, etc) Multumesc. |
Logan Ambition
Verde cameleon
- VS-23-XYZ Mic si rau, mai mult mic decat rau.
caktuss |
![]() Membru autentic Group: Members Posts: 1.433 Joined: 7 May 05 From: Iasi ![]() |
cat ma costa sa schimb un pivot de megane 2 , dar nu "la ciocan", ca m-a tinut o luna pivotul
Megane Sedan II
1.6 16v 05-2005
- numar cu gaura m2 sedan expression 1.6 16v 06/2005
20 000 km (1/09/2006) 33 600 km (26/09/2007) 45 000 km (o3/01/2009) 50 000 km (03/06/2009) |
CRyS` |
@ powerx
Ulei Castrol Magnatec 5w40 - 125 ron Filtre Mann - 110 ron Distributie + Pompa Apa = maxim 600 ron! Dar cel mai bine treci pe aici si mai discutam! Cat despre celelalte lichide (racire,frana,etc) sunt nesemnificative la pret! @caktuss Un pivot pe FEBI sau orice alt producator mai bun e undeva la 140 ron iar pe un low cost e 60 ron! Dar trebuie sa tii cont ca manopera e 150 ron!!Si nu are rost sa pui orice low cost! |
powerx |
Ok, multumesc pentru raspuns.
Cel mai probabil voi face o vizita dupa Pasti. LE: 110 RON filtrul de aer + filtrul de ulei? Cat costa kitul de distributie+curea accesorii, fara schimbat pompa de apa? Preturile includ si manopera? Multumesc. This post has been edited by powerx: 24 Mar 2010, 16:20 |
Logan Ambition
Verde cameleon
CRyS` |
@ powerx
Filtru Aer + Filtru Ulei = 65 ron Distributia fara pompa de apa nu o schimb! Producatorul de piese, importatorul de piese nu da garantie la o distributie daca nu schimb si pompa de apa (pentru ca e actionata de cureaua de distributie) ! Atunci cand Doamne fereste ai o problema, importatorul de piese si producatorul imi/iti cer factura pe care sa fie si pompa de apa! In caz contrar... stai pe tusha si mai platesti odata! Si platesti si pentru toate eventualele daune sunt! Da...in toate preturile de mai sus ai inclusa si manopera,care defapt pt filtre si ulei nu exista! Cureaua de accesorii costa undeva la maxim 50 ron! Vin-o sa verificam si setul de accesorii,sa vedem daca ai ceva probleme (role,rola intinzatoare,curea) |
CRyS` |
Avem o super promotie la: amortizoare, placute si discuri frana! Montajul este GRATIS!
Pentru alte detalii si preturi va astept cu intrebari! |
cmandrei |
![]() NEWSMAN Group: Moderatori Posts: 10.439 Joined: 9 March 05 From: Bucuresti/Targu Mures ![]() |
Promotie si la pret sau doar prin faptul ca e montaj inclus ? M-ar interesa un set pentru fata la masina din semnatura.
ex. Renault
Clio Symbol
2001 Dynamique (1.4 8V 75 cp K7J-A7)
- RO 33.722 km - 12.2004
178.691 km - 03.2013 Andrei |
CRyS` |
Si la pret! Dar ce "set"? Placute frana, discuri frana, amortizoare?
cmandrei |
![]() ![]() Este vorba de un pret pentru un set de amortizoare fata pentru masina din semnatura. Multumesc ![]() |
ex. Renault
Clio Symbol
CRyS` |
Poi.... Amortizoare
Monroe (ca cel de pe masina) - 185 ron bucata Manore Reflex (am si eu pe Meganel si se merita) 245 ron bucata! La amortizoare ai nevoie si de flanse de amortizor (in caz ca sunt distruse,desi ai sanse) si e undeva la 150 ron kitul, si ai nevoie de 2 (stanga/dreapta) ! |
cmandrei |
Monroe la 185 ron suna bine. Pana cand pot beneficia de aceasta oferta ?
Flansele le-am testat acum vreo luna si sunt ok. Nu sunt noi logic, ca au 145000 km dar nu au joc aproape deloc. M-am gandit sa le schimb de control dar pretul, din punctul meu de vedere e cam mare + ca in mod normal ar trebui schimbata doar "bucsa" de cauciuc din cadrul kit-ului (asta daca nu sunt probleme si cu rulmentul) ... presupun ca "pe bucati" nu se vinde nu ? Sau stai ... tu vorbesti de cea de jos sau cea de sus sau de toate in acest kit ? ... coduri renault exista separat pentru fiecare componenta. (hmmm m-am uitat mai atent si pare ca la masinuta mea nu e rulment in capul amortizorului ... sunt doar "cauciuce") |
ex. Renault
Clio Symbol
CRyS` |
Salut!
Pentru Amortizoare...ai sanse si intr-o luna sa mai fie! Dar sunt facute la pret pt tine, ca ti le trimit prin curierat ca nu vii tu din B sau Tg. M. sa le montezi in Iasi! Flansele vin si in kit complet (cauciuc + rulment)dar vin si separat! In mare parte rulmentul e beleaua mai mare! Dar... sunt si separat! Iti pot face si pret separat.... dar...na...intelegi tu! Daca ar fi sa ti le trimit te costa si curieratul sau posta! Tinem legatura! CRyS` This post has been edited by CRyS`: 30 Mar 2010, 11:26 |
cmandrei |
Salut,
Multumesc mult pentru oferta, detalii si timpul acordat. Si sper sa revin cu o cerere ferma pentru, minim, amortizoare. Spor, cmandrei |
ex. Renault
Clio Symbol
CRyS` |
![]() O zi faina! CRyS` |
CRyS` |
De ce trebuie sa va verificati amortizoarele la fiecare 20 000 km?
1. Franarea: cu amortizoarele uzate inseamna o durata mai lunga de timp pana la oprirea masinii dvs. 2. Aderenta la drum: la o viteza de 57km/h incepti sa pierdeti controlul asupra masinii in viraje daca aveti amortizoare uzate! 3. Aquaplaning: cu amortizoarele uzate incepeti sa patinati la o viteza de 81 km/h. 4. Lumina orbitoare: amortizoarele uzate afecteaza eficienta farurilor dvs. Din cauza acestor 4 motive importante Service-ul ALL MOTORS va ofera amortizoarele Monroe la cel mai bun pret si fara manopera!! |
BimbOOO85 |
![]() Membru autentic Group: Members Posts: 238 Joined: 22 October 09 From: Iasi/Botosani ![]() |
va ocupati si cu reconditionarea de injectoare.megane 1.5 dci.multumesc si un pret va rog
II/Bicorp
CRyS` |
Hristos a Inviat!
Imi cer scuze celor ce mi-au scris si aici si in privat ca nu le-am raspuns,dar a fost Pastele si nu am avut timp de internet. In timpul zilei de maine le voi raspunde! CRyS` |
CRyS` |
#53
Ca dupa Pasti.... o super oferta!
Amortizoare MONROE pentru masina ta: la 4 amortizoare cumparate pentru aceeasi masina vei plati doar 3 ca al patrulea il primesti cadou de la noi si pe langa un amortizor gratuit ai si manopera pentru toate 4 gratuita! |
CRyS` |
#54
Diagnoza la doar 50 ron cu scanere-ul Launch X431 !
mihail75 |
#55
![]() mihail Group: Members Posts: 466 Joined: 12 October 03 From: Iasi ![]() |
Salut,
iti faci reclama buna, am aflat de service-ul tau printr-un flyer dat de o fata la semafor (+forumurile). In dorinta de a nu mai apela la vesnicul Caremil, parca as incerca revizia de 4 ani la All Motors (am un Logan, 1.4). Cam la cit m-ar duce o astfel de revizie, cu schimbat 1. filtre ulei, aer; 2. lichidele - frana, directie, ulei, racire; 3. bujii, placute de frana, plus verificare AC (eventual pus freon), insa fara distributie, ca mai poate astepta putin? Sigur, nu vreau un pret fix, ci macar ceva estimativ. Multam anticipat. This post has been edited by mihail75: 8 May 2010, 11:55 |
Laureat 1.4 MPI
- Is-YY-XXX mihail, fost cu Logan Laureat 1.4, acum cu Opel Astra Sedan 1.6
CRyS` |
#56
Ai PM la toate cele cerute!
CRyS` |
#57
A venit caldura!!! Super preturi pentru verificarea AC-ului si umplerea sa cu freon!!!
This post has been edited by CRyS`: 26 May 2010, 15:22 |
Axelinooo |
#58
![]() Group: Members Posts: 351 Joined: 3 September 08 From: Iasi ![]() |
Scenic II -2008-Confort Expression 1.5 dci 106 CP
(78KW) // Megane - 2004 - 1.5 dci 82 CP (60KW)
- IS-88-ACS // ex Clio
CRyS` |
#59
40% Reducere pentru:
Sistem climatizare: Revizie (proba vid si cu indicator de fisuri+incarcare freon+incarcare ulei compresor+control filtru de polen si curea compresor) Revizie climatizare gr.1 (freon inclus 800 g) 102 ron in loc de 170 ron Revizie climatizare gr.2 (freon inclus 1100 g) 112 ron in loc de 187 ron Revizie climatizare gr.3 (freon inclus 1500 g) 126 ron in loc de 210 ron |
mihail75 |
#60
am fost la All motors, am schimbat mai multe, inclusiv verificat climatizarea. 102 lei mi s-a parut un pret mai mult decit bun, merge AC-ul brici, baga aer rece ca la inceputuri. Eu unul am fost multumit de treaba facuta de acest service, daca o tin tot asa (respect fata de clienti, punctualitate, preturi rezonabile) nu au decit de cistigat.
Laureat 1.4 MPI
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 14th July 2025 - 16:37 |
