Fac chei pentru Supernova, Solenza si Logan, preturi accesibile
spiridon |
#271
![]() Membru autentic Group: Members Posts: 786 Joined: 5 May 05 From: Iasi ![]() |
Dacia Supernova
- IS- inginer - frezez si programez chei, repar telecomenzi, immo off 0741024494
spiridon |
#272
Oferta pentru SUPERNOVA si SOLENZA:
Set de 2 chei briceag legate direct in decodor plus 2 cipuri miniaturale la 250 roni ! Doar mufati decodorul si aveti chei briceag functionale (cip si telecomanda) ! E inclus tot (frezare lame si fixare in cheile briceag, legarea modulului direct in decodor, programarea cipurilor) ! Immo off (masina merge fara cipuri in chei) 100 roni !!! set de 2 telecomenzi chei briceag si immo off 150 roni !!! 2 cipuri pentru rezolvarea pornirii cu ambele chei 200 roni ! This post has been edited by spiridon: 5 Mar 2012, 10:48 |
Dacia Supernova
marius marius |
#273
Membru incepator Group: Members Posts: 6 Joined: 6 December 11 ![]() |
saallllll vio
megan 2
megan 2
- b 123 ali
spiridon |
#274
Carcase de schimb orice model Dacia 30 roni plus 7 roni transport prin posta !
Dacia Supernova
spiridon |
#275
OFERTA SOC PENTRU SUPERNOVA SI SOLENZA:
1.Repararea cheilor originale ale masinii care nu mai pornesc motorul (clipeste ledul des) prin programare de cipuri noi: 1 cip 150 roni, 2 cipuri 200 roni. 2.Immo off (masina porneste si merge fara cipuri in chei) 100 roni !!! 3.set de 2 telecomenzi clasice legate in decodor si immo off 150 roni !!! 4.set de 2 telecomenzi chei briceag legate in decodor si immo off 180 roni !!! 5.set de 2 telecomenzi chei briceag legate direct in decodor plus 2 cipuri pornire motor 280 roni ! Doar puneti la loc calculatorul si decodorul si aveti chei briceag sau telecomenzile functionale ! Manopera inclusa:frezare lame si fixare in capul escamotabil al cheilor briceag, legarea modulului direct in decodor, programarea cipurilor ! This post has been edited by spiridon: 28 Mar 2012, 11:35 |
Dacia Supernova
ginelsandu |
#276
Membru incepator Group: Members Posts: 2 Joined: 1 December 07 ![]() |
Multumesc, Dl. Viorel pentru cele doua chei briceag, merg perfect. Recomand cu incredere
Supernova
2001,rapsodie
- gr 19 any
spiridon |
#277
Ca sa numai spunem ca domnul Ginel si-a pus si deschidere electrica portbagaj din telecomenzile briceag (au buton special pentru asa ceva !)
Dacia Supernova
didytel |
#278
Membru incepator Group: Members Posts: 17 Joined: 19 February 09 ![]() |
Salut, la supernova nu imi mai merge inchiderea centralizata si nu imi mai recunoaste o cheie. Mi-ar place ideea cu cheile briceag. Cum imi recomanzi?
SuperNova
spiridon |
#279
Va recomand set de 2 telecomenzi chei briceag si un cip 200 roni.
Doar mufati decodorul si aveti toate functiile ! Fara alte plimbari la electricieni..! |
Dacia Supernova
didytel |
#280
Nu pot trimite PM; imi explicipi putin cum ar trebui sa procedez? sa inteleg ca trebuie sa iti trimit decodorul? de ce 1 cip? al doilea il iau de pe cealalta cheie? Ms
SuperNova
spiridon |
#281
Pentru detalii suplimentare va rog sa ma sunati pe 0741024494 (orange).
Dacia Supernova
spiridon |
#282
Calculator de injectie 1.4 benzina cu immo off pentru Supernova sau Solenza 350 roni plus transport !!!
Doar il puneti pe masina si merge cu orice cheie se invirte in contact ! This post has been edited by spiridon: 4 May 2012, 17:16 |
Dacia Supernova
dj_ionutz |
#283
![]() Membru autentic Group: Members Posts: 283 Joined: 1 February 09 ![]() |
carcasa cheie cu lamela fara cip ai? poti sa imi faci copie pe lamela de fier dupa cheia mea?
C
li
o Cautati siguranta? Circulati cu sandero.
spiridon |
#284
Ce fel de carcasa ? cu un buton sau simpla ?
This post has been edited by spiridon: 8 May 2012, 08:20 |
Dacia Supernova
dj_ionutz |
#285
C
li
spiridon |
#286
Am carcasa la 30 roni plus 7 roni transport; daca doriti lama frezata costa 20 roni !
Dacia Supernova
dj_ionutz |
#287
pai si cum facem copia dupa cheia mea originala? prin posta nu as putea sa o trimit ca alta nu mai am sa mai plec cu masina
C
li
spiridon |
#288
Astept sa va decideti !
This post has been edited by spiridon: 13 May 2012, 11:31 |
Dacia Supernova
kti |
#289
![]() ,,hobyst,, Group: Members Posts: 123 Joined: 20 May 08 From: CRAIOVA ![]() |
QUOTE(spiridon @ 8 Feb 2012, 10:17) Rezolv orice problema de cheie cu garantie pe viata la LOGAN, SOLENZA, SUPERNOVA in 48 de ore prin curier rapid ! Pentru siguranta, plata ramburs ! salut vreu si eu o cheie cu butoane pt un logan diesel AC din februarie 2011 . am doar una disponibila si ma descurc greu cu una. am inteles ca mai exista una la banca cum sa procedez ? ma poti ajuta ? multam |
1.4/gpl/stag200-4 ,1,5 diesel
- xx-70-xxx
spiridon |
#290
Din pacate Logan 2011 nu pot, inca ! Doar la reprezentanta !
Dacia Supernova
spiridon |
#291
Calculator de injectie 1.4 benzina facut immo off (merge indiferent daca sunt recunoscute cheile de decodor - clipeste ledul) pentru Supernova sau Solenza 300 roni plus transport !!!
Doar il puneti pe masina si merge cu orice cheie se invirte in contact indiferent de problemele decodorului (nu recunoaste cheia si clipeste ledul, e plin de apa sau ars, lipseste de tot ! This post has been edited by spiridon: 29 May 2012, 10:06 |
Dacia Supernova
spiridon |
#292
Pentru Supernova si Solenza:
1.Repararea cheilor originale ale masinii care nu mai pornesc motorul (clipeste ledul des) prin programare de cipuri noi: 1 cip 150 roni, 2 cipuri 250 roni. 2.Immo off (masina porneste si merge fara cipuri in chei) Supernova 150 roni, Solenza 100 roni 3.set de 2 telecomenzi clasice legate in decodor 140 roni !!! 4.set de 2 telecomenzi chei briceag legate in decodor 180 roni !!! 5.set de 2 telecomenzi chei briceag legate direct in decodor plus 2 cipuri pornire motor 400 roni ! Doar puneti la loc calculatorul si decodorul si aveti chei briceag sau telecomenzile functionale ! Fara alt drum la electrician ! Manopera inclusa:frezare lame si fixare in capul escamotabil al cheilor briceag, legarea modulului direct in decodor, programarea cipurilor ! |
Dacia Supernova
danutzv |
#293
![]() Membru incepator Group: Members Posts: 38 Joined: 18 May 10 From: Petrosani ![]() |
M-ar interesa carcasa de cheie de logan te rog da-mi un PM cu nr de tel sa te contactez. ms.
Solenza Scala 1.4 Mpi
- HD-06-CNN
spiridon |
#294
Rezolv orice problema de chei si telecomenzi la Supernova Solenza Logan !
Preturi decente ! |
Dacia Supernova
Dacus_Malus |
#295
![]() OM Group: Members Posts: 757 Joined: 24 July 07 From: Brasov / Rasnov ![]() |
pentru un scenic din 2001 puteti "clona" o cheie?
am o cheie buna si mai vreau una! este modelul cu un singur buton. |
Toyota
Prius 2
2006 Toyota Prius 1 - 2002
Autorulota Citroen C25 SanRemo - 1990 |
Maskatu |
#296
Cu ocazia trecerii mele prin iasi, l-am contactat pe domnul spiridon pentru reparatia cheii ce nu mai era cunoscuta de uce. In 10 minute aveam doua chei functionale si eram gata de drum. Ieftin si rapid. Recomand cu caldura. Domnul este foarte serios.
0.9 TCE - 2019
crysty93 |
#297
Membru incepator Group: Members Posts: 3 Joined: 31 May 12 ![]() |
salut spiridon.
am o solneza din 2003 care nu imi mai recunoaste cheia cu inchiderea (este cea cu un singur buton ). cealalta cheie este simpla (aceasta nu are probleme). ce rezolvare imi recomanzi? |
2003 rapsodie
spiridon |
#298
Daca va mai merge telecomanda va recomand sa va faceti un cip la cheia cu pricina, daca nu va mai merge telecomanda atunci un set de 2 chei briceag plus inca un cip e o solutie super pentru a avea 2 chei pefect functionale ! Si va ajunge undeva la 280 roni.
Dacia Supernova
Dacus_Malus |
#299
revin cu intrebarea mea:
pentru un scenic din 2001 puteti "clona" o cheie? am o cheie buna si mai vreau una! este modelul cu un singur buton. |
Toyota
Prius 2
spiridon |
#300
Sorry, dar chiar v-am crezut "bandit" !
Cipul din cheia dvs. se poate clona intr-o cheie cu asa numitul cap electronic (cipul e de fapt o placuta un pic mai mare - cit plasticul de la o cheie obisnuita, singurul dezavantaj e ca nu poate fi pus intr- o cheie cu telecomanda si ca are o baterie care trebuie schimbata la 2-3 ani ! De copiat se poate copia la orice atelier de chei serios ! Pot sa va copii si eu cheia dar cu transportul dus-intors iesiti mai scump decit daca o rezolvati pe plan local ! This post has been edited by spiridon: 13 Aug 2012, 19:06 |
Dacia Supernova
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 15th July 2025 - 07:14 |
