Tuning motor 1.4/1.6 MPi, se poate imbunatati performanta Logan-ului?
DomnulK |
#1351
Laureate 1.6 MPI
2004 Asfalt Uscat!
han_1.6 mpi |
#1352
![]() Membru autentic Group: Members Posts: 1.273 Joined: 8 May 06 From: bucuresti ![]() |
poate fac o confuzie dar din cate stiam in reprize valorile acelei sonde sunt ignorate.
dacia,ford,
logan,mondeo
- B-00-000 protejati biciclistii in trafic!
#1353
![]() - Group: Members Posts: 22.542 Joined: 19 April 05 From: Romania ![]() |
Nu faci nici o confuzie.
PaulT |
#1354
Nu am anulat sonda.Am verificat consumul la pompa.Inainte de plecarea la Mioveni am umplut rezervorul pana sus.Ieri am repetat operatiunea.CB arata 21 l consumati,iar la pompa au intrat 21,5l .Consum mediu 7.0 l /100km(alergat pe autostrada plus fatait prin Pitesti si Bucuresti).Jumatate din km facuti cu softul original,jumatate cu celalalt.Pare destul de ok.
Dacia/Mitsubishi
2006 Laureate/1973/2008
- B-00-xxx
#1355
Ai facut testul de drum? Sa inveti ecu ...
PaulT |
#1356
Facut.
Dacia/Mitsubishi
- B-00-xxx
gogota_69 |
#1357
![]() JUST ME Group: Members Posts: 438 Joined: 5 July 06 ![]() |
Ce sa inveti???
LOGAN 1.5 DCI
PREFERANCE
- B-51-W U D GOGOTA
AR-18-MOS |
#1358
ECU=Engine Control Unit.
BMW
730Ld
'07 High Executive
DomnulK |
#1359
pai si cand e luata in calcul de catre ecu acea sonda?
Laureate 1.6 MPI
2004 Asfalt Uscat!
Corbu' |
#1360
#1361
Ce se invata si pe banc de motoare ...
Sunt in continuare, dar m-am plictisit si de semnatura si de masina ... This post has been edited by IRONICK: 20 Feb 2008, 23:11 |
DomnulK |
#1362
Laureate 1.6 MPI
2004 Asfalt Uscat!
Doc |
#1363
![]() Specialist Chiptuning Group: Members Posts: 2.072 Joined: 4 September 04 From: Bucuresti ![]() |
Sa faca playback!
Honda
Civic TypeR FK2 2.0 TURBO 340CP+
2016 Ofer servicii de chiptuning (resoftare) pentru orice model Renault. Preturi in PM. ROTAC 2018 Tuned class Champion Audi TT powered by OBDTUNING.
#1364
![]() fan Dacia Group: Members Posts: 21.366 Joined: 12 November 05 From: Bucuresti ![]() |
Invata motorul ce corectii de avans si dozaj sa faca. Adica in plus sau in minus fata de harta din memorie (pe principiul ca socoteala din fabrica nu se potriveste cu aia de pe sosea).
- negru pe alb
DomnulK |
#1365
si in ce consta aceasta sau aceste proceduri?
Laureate 1.6 MPI
2004 Asfalt Uscat!
#1366
De fapt sunt doua teste rutiere. Unul pentru "corectari" si altul identic cu cel facut dupa schimbarea senzorului care citeste de pe volanta ...
This post has been edited by IRONICK: 21 Feb 2008, 15:57 |
madhorsefuzzy |
#1367
Da, dar iti cam trebuie autostrada ...
Laguna Grandtour
2011 4Control 2.0dci
#1368
pentru corectari ...
DomnulK |
#1369
bun. in ce constau aceste teste.... o descriere a procedurilor se poate?
Laureate 1.6 MPI
2004 Asfalt Uscat!
Corbu' |
#1370
Si pe mine ma intereseaza in ce constau aceste teste si sa va spun de ce (unii stiu deja). Acum un an mi-am facut resoftare, totul a fost OK la o proba scurta dupa aceea, dar in drum spre casa cam la 100KM, dupa cateva depasiri in panta cu acceleratia la podea si urcat pana spre 5000 rpm au aparut zgomote de avans, parca sunau clopotei. Zgomotele au persistat apoi cat timp am avut respectivul soft pe masina, se atenuau dar nu dispareau doar cand puneam benzina OVM Carrera 100. Am trecut inapoi la softul original si zgomotele suspecte au disparut.
Vreau sa incerc iarasi o remapare cu alta versiune de soft, dar nu vreau sa vad ca nu e bun tot in drum spre casa. Vreau sa stiu ce trebuie sa fac la fata locului pentru a-mi da seama daca softul se pupa sau nu, din cate stiu as avea la dispozitie doua versiuni de soft modificat. Asadar, daca nu e cu suparare, cine stie EXACT ce trebuie facut, il rog sa posteze aici pasii. Multumesc. This post has been edited by Corbu': 21 Feb 2008, 17:34 |
#1371
Posibil sa fie de la inceput ... depinde de nivelul tau de incantare sau nu. Oricum ecu invata singur unele din ele si atunci probabil tocmai asta a facut ...
EL. Asta nu scuza faptul ca fila a fost facuta prost. This post has been edited by IRONICK: 21 Feb 2008, 17:45 |
Corbu' |
#1372
Pai bun, ECU invata singur, autocorecteaza avansul, etc. Dar la mine de ce a fost invers, se auzea din ce in ce mai urat? O luase rau pe aratura ECU ....
Si te asigur ca la inceput nu au fost prezente deloc zgomote aiurea, doar un pic mai zgomotos motorul la relanti. In rest NIMIC. |
DomnulK |
#1373
Domnule IRONICK, de ce sunteti asa secretos?
pierdeti ceva daca explicati pasii de invatare? This post has been edited by kAndrei: 21 Feb 2008, 17:48 |
Laureate 1.6 MPI
2004 Asfalt Uscat!
#1374
Corbu, in momentul ala ecu a invatat motorul. Stilul tau de mers in bucla, "forja" sau frana de motor a ajutat ecu sa invete motorul si senzorii. El tot timpul face o mediere a datelor. Si cum datele se "alterau", zgomotul crestea ...
This post has been edited by IRONICK: 21 Feb 2008, 17:55 |
Corbu' |
#1375
Mai nu stiu daca v-ati propus asta, dar vorbiti numai in dodii precum politicienii. Crezi ca ai inteles dar de fapt nu ai inteles nimic LOGIC. Pai cum adica stil de mers in bucla? Zgomotele au aparut la un pic de forja, in restul drumului schimbat normal la 2500-3000 rpm; nu forjez masina decat la depasiri cand e necesar.
In zona 2500 rpm facea rau scandal daca ii dadeam talpa, se mai domolea un pic cand cresteau turele, dar tot supara la ureche. Si dupa o luna zic eu ca trebuia sa ii treaca pandaliile, condusesem masina in toate felurile: in oras, in afara incet, cu depasiri. The works. Si tot facea pe nebunul. This post has been edited by Corbu': 21 Feb 2008, 18:17 |
DomnulK |
#1376
cred ca e un secret care nu trebuie sa se afle, am eu o vaga banuiala.
Laureate 1.6 MPI
2004 Asfalt Uscat!
AR-18-MOS |
#1377
Cred si eu ceea ce zice kAndrei ...
BMW
730Ld
'07 High Executive
sinaxis |
#1378
![]() Membru autentic Group: Members Posts: 388 Joined: 30 March 04 ![]() |
Nu stiu de ce sunt toti asa ingrijorati de zgomotele de avans. La 1.4 cand il aveam, daca benzina era proasta, se auzea, dar nu era ceva deranjant, doar in sarcina maxima. Acu la motorul de 16 cu 16v nu prea am mai auzit. Si, sincer, nu-mi prea place! Parca imi vine sa cred ca softul original nu a fost remapat ci ca a fost lasat la fel. Totusi acum o saptamana prin nu stiu ce minune, la o forja in panta, l-am auzit din nou... dar mai suav
tohan
stas
2012 full "as fi de parere ca ar trebui interzisi copiii din locurile publice (...). Un sugar stie doar sa manince, sa se cufureasca si sa urle" by Marty
DomnulK |
#1379
unde ti-ai facut resoftarea?
Laureate 1.6 MPI
2004 Asfalt Uscat!
sinaxis |
#1380
La Dimsport.
tohan
stas
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 8th May 2025 - 20:52 |
