F1 2010, by Codemasters
Solon |
![]() Membru autentic Group: Members Posts: 7.034 Joined: 16 December 04 From: Bucuresti ![]() |
3 japoneze
2 nemtoaice
si cam atat
Manuel |
Nu trebuie reinstalat Windows-ul pentru a pune SP3, se instaleaza deasupra.
This post has been edited by Manuel: 24 Sep 2010, 20:10 |
Astra J Sports Tourer Active
2013 / 2.0 CDTI / 165CP
- VS15CMA "Base e un bou betiv." (corbex)
biscu |
![]() ... Group: Members Posts: 500 Joined: 24 January 07 ![]() |
Salut, la fel pt Assasin Creed 2 zice ca trebuie sa ai SP3 instalat...uite ca mie imi merge si fara SP3
Clio III
Solon |
@Manuel: Cum se face?
@biscu: Pai imi zice ca trebe SP3 si gata! Iese din instalator! Deci nu prea am cum sa-l contrazic. |
3 japoneze
2 nemtoaice
si cam atat
DMP |
Iti iei SP3 de pe site de la Microsoft. Ii dai Install si astepti sa termine treaba.
1.5 dci 2006
xcss |
![]() Born to Be Epic Group: Members Posts: 1.669 Joined: 24 August 07 ![]() |
Desigur, functioneaza numai daca ai Windows cu licenta.
- Mit der Dummheit kämpfen Götter selbst vergebens.
ssilviu |
![]() F1 Man Group: Members Posts: 8.043 Joined: 11 June 04 From: Nicaieri ![]() |
Nu e adevărat. De fapt e suficient să dai la windows update. îți găsește el sp3-ul ca update separat.
Megane 2 GPL
2006 Renault Master 2
Renault Clio 4.1 1.2 EDC Renault Clio 4.2 1.2 EDC Dacia Dokker 1.6 SCE GPL Dacia Logan 1.4 GPL |
xcss |
Topicul fiind despre altceva, n-o sa insist asupra necesitatii de a trece de WGA check pentru a avea acces la Windows Update.
Markos |
Megan
Solon |
Jti lent rau, grecule!
3 japoneze
2 nemtoaice
si cam atat
DMP |
Senna e mai rapid ca el insa e dupa el.
1.5 dci 2006
koldun |
![]() un om Group: Members Posts: 763 Joined: 1 November 07 From: CT ![]() |
Captur
TCe 0.9 2016 Oh, I’m in no condition to drive! Wait a minute... I don’t have to listen to myself, I’m drunk...!
Homer Simpson |
vis-a-vis |
Dati-mi si mie jocu'
Logan MCV
Arhimede |
![]() Membru inferior, lung si tare Group: Members Posts: 2.294 Joined: 5 March 05 ![]() |
A aparut un patch. Rezolva niste buguri si imbunatateste frame rate-ul.
lgn
2005 Ambition 0% avertisment=0% divertisment
S4b1n |
![]() Membru Symbolist Group: Members Posts: 937 Joined: 27 February 10 From: Craiova/Bucuresti ![]() |
A jucat cineva F1 2011?
Am ramas blocat cand pe finalul primei curse de la Career am ramas fara gaz ![]() Fuel map-ul a fost pe standard toata cursa, iar cantitatea de gaz din rezervor nu poate fi reglata pentru cursa, ci numai pentru antrenamente si calificari. Ce naiba e de facut, sa schimb fuel map-ul in timpul cursei? Ar fi o idee dar mi-ar trebui a 3-a mana pentru ca joc din gamepad si n-am decat 8 butoane ![]() |
Renault Symbol
1.5 dCi 62 kW
- ~ 155000 km
Solon |
Ce ma bucur ca ai zis ceva! Habar n-aveam ca a aparut F1 2011! Luat deja de pe net!
3 japoneze
2 nemtoaice
si cam atat
S4b1n |
Am mai incercat azi cursa si am pornit cu fuel map 1 (adica low), si cand am intrat la boxe in tura 6 l-am dat pe standard. Ca sa imi spuna dupaia in ultimele 3 ture : go to fuel map full sau max, adica fuel map 3, maxim.
![]() N-am reusit sa termin decat pe 8, dar inca fac destule greseli pe cursa. |
Renault Symbol
1.5 dCi 62 kW
- ~ 155000 km
DrK |
![]() Lapins Creed Assassin Group: Members Posts: 2.132 Joined: 5 January 07 From: From: From: ![]() |
Eu procedez in felul urmator:
In calificari mix 3, in cursa mix 1 / 2 in functie de circuit. Williams-ul pare a fi cea mai buna alegere desi ai un top speed de 320 fata de altii care au 340 ![]() Ma tot uitam pe clasamentele pilotilor si in acest joc Vettel (spre bucuria mea) merge ca o cizma si nu se claseaza niciodata mai sus de locul 4 ![]() |
Sedan
Negru
2015 Bunul simt nu creste in pom.
Veni Vidi Discepto Exsecror Cesso |
Solon |
Weekendul asta e festival! Ma bag in el!
Sper sa fie mai bun comparativ cu 2010, ca la ala cariera e dezastru! Imi da de ales intre pocnitorile alea 3 de echipe! Din 5 curse am 3 victorii si un loc 3, dar deja sunt epuizat psihic, ca umblu cu caietul dupa mine si notez fiecare modificare! E prea greu deja! |
3 japoneze
2 nemtoaice
si cam atat
AR-18-MOS |
Cume jocul acesta? Cere multe resurse? E cu licenta, are demo?
BMW
730Ld
'07 High Executive
Solon |
Intreaba-l pe drk! El le stie!
Are si licenta evident! ![]() |
3 japoneze
2 nemtoaice
si cam atat
S4b1n |
Solon, la ce dificultate ai jucat? La medium, insa cu assisturi doar ABS si traction control (fara dynamic racing line care franeaza la curbe) am reusit si eu sa iau si pole position si locul 1 pe Kuala Lumpur la cariera, cu Williams.
Insa parca n-are farmec, asa ca ma chinuiesc pe hard (cu aceleasi assisturi ABS si traction control). Plus ca doar la Hard poti schimba maparea motorui, sa ai uzura motorului, sa ramai fara gaz, sa uzezi pneurile, care btw mi se pare foarte realist cum se uzeaza si nu mai intri calumea in viraje ![]() This post has been edited by S4b1n: 29 Sep 2011, 17:27 |
Renault Symbol
1.5 dCi 62 kW
- ~ 155000 km
sorin000 |
#53
![]() Just a member Group: Members Posts: 517 Joined: 16 April 08 From: Marte ![]() |
A aparut 2011 ? Daca a jucat cineva,cum e comparativ cu 2010 ?
2010 mi s-a parut bunicel,am jucat vreo 2,3 sezoane...La medium n-ai niciun stres,castigi cursa dupa cursa...La hard e putin mai greu,dar nu cine stie ce... |
Megane IV facelift 2021
ZEN TCe Audi A4 2016 TFSI S-tronic
Ex. Megane Sedan II 2008 Lux privillege dCi "Dacă mașina mea era ruptă ca tine , nu trecea de RAR..." |
Solon |
#54
@sabin: Eu nu inteleg cum cariera cu williams? Poate la 2011!
La 2010 incepi cu mizeriile de Virgin, HRT si Lotus! Habar nu am ce nivel e, stiu ca am activat doar traction control, fara ABS si dinamic line! Nasol e ca ma avertizeaza antivirusul ca executabilul de la 2011 e harmful si sunt in standby! Poate o ia calculatorul in bot! |
3 japoneze
2 nemtoaice
si cam atat
sorin000 |
#55
N-ar mai avea farmec daca ai incepe cu Ferrari,McLaren...
![]() Eu am inceput cu HRT ,am iesit campion si m-am dus la Renault dupa. |
DrK |
#56
Hmmm
![]() ![]() Sa ma duc? Sa nu ma duc? ![]() ![]() Attached thumbnail(s) Clip_2.jpg ( Size: 243.77k ) Number of downloads: 120 |
Sedan
Negru
S4b1n |
#57
Solon: vorbeam de 2011, ca am inceput cu Williams.
PS: mi s-a tirat deja de joc, pentru ca mi-a bulit 2 savegame-uri. A dat crash, si cand sa intru la loc pauza. Daca mutam savegameul in alta parte mergea, dar o luam de la zero. Sucks. Poate vine unu original curand ![]() |
Renault Symbol
1.5 dCi 62 kW
- ~ 155000 km
ArtVandelay |
#58
![]() Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova ![]() |
are cerinte mari jocul asta? ca m-ati facut curios...
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
Solon |
#59
Gata l-am prins pe 2010!
Cu Virginul in campionat scot cu 9 secunde peste timpul obtinut cu RBR in race-ul obisnuit! Asta e bulangeala! |
3 japoneze
2 nemtoaice
si cam atat
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 13th July 2025 - 01:57 |
