swap tacho from DSN Clima/Rapsodie to Europa, ?
DarioGTI |
![]() Membru incepator Group: Members Posts: 31 Joined: 14 February 10 From: Croatia/Germany ![]() |
SuperNova 2002 Europa /
Logan 2005 Laureate +
SupeRNova 2003 E7J Europa LPG -> 219 800 km (!) Logan MCV 2007 K4M Laureate LPG-> 55 000 km (sold) |
pulbur |
![]() Membru autentic Group: Members Posts: 270 Joined: 23 June 09 From: SM ![]() |
You don't have to install new senzors,you just take the RPM and temperature signal from the black box with fuses near the battery.
You have to be carefull,because there are 2 types of DSN boards,with 3 sockes and 4 sockes. If you buy a board that has 4 sockets,and your board has 3,than you will have to do a 'gauge transplant'(this is the simple way) Here is a link that might help,if you use google translate maybe it will make sense. #26 Post might help ! http://www.daciaclub.ro/Ceas-APA-pentru-SN...pa-t171171.html Also,you could adapt Renault Clio or Dacia Logan gauges. http://www.daciaclub.ro/-t36952.html This post has been edited by pulbur: 3 May 2010, 10:56 |
Dacia/Fiat
DSN
DarioGTI |
do you maybe know, wich model year has 3 sockes, wich year has 4 sockes?
i thinked about to install the Logan board into DSN, but i like more the board from DSN, because i will make a LED light, white-red, or red-blue combination.... |
pulbur |
Your board has above the tacho meter 2 circles and in the left side is the 'Crash' indicator and on the right side is the 'left & ringht signal' indicator,than you have a 3 socket board.
When the signaling,is displayed separately that you have a 4 socket board. This post has been edited by pulbur: 4 May 2010, 07:40 |
Dacia/Fiat
DSN
DarioGTI |
over the tacho, on the left side i have an icon with 2 green indicators(when I turn left, or when I turn right), on the right side is the red triangle(crash).
that means I have a 3socket ? |
pulbur |
Well,then i suppose you have a 3 socket board
![]() PS: You will have to take 2 wires from the black box with fuses near the battery ,to the board and connect it to the gauges. |
Dacia/Fiat
DSN
DarioGTI |
I founded a tacho from the SN Rapsodie model that has separeted blinkers (in the left circle is for the left blinker, in the right circle is for the right blinker), but my tacho in SN Europa (2002) has the left and right blinker iz ONE circle wich is on the left side, and the crash light is in the right circle.
What I have to do to install the "separated blinker table" into my SN that has "in one circle left and right blinkers tacho" ? I watched the tutorial on the link above, but I'm not shure if it is possible in the way I have to do... Thank you!! |
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 9th May 2025 - 05:20 |
