Probleme biciclete, defectiuni, recomandari piese, tips & tricks
bogdanelkva |
15 Aug 2012, 09:57
#301
/\____/\____/\____/\ Group: Members Posts: 1.147 Joined: 4 November 09 From: reghin |
ford
focus facelift tot cu benzina
C a t a l i n |
15 Aug 2012, 10:29
#302
Adica e cromata...
yhattori |
16 Aug 2012, 10:10
#303
* Group: Members Posts: 492 Joined: 18 August 09 |
sau nichelata...
Serpico |
16 Aug 2012, 11:40
#304
Membru autentic Group: Members Posts: 511 Joined: 10 April 03 From: Timisoara |
sau data cu Lunar...
Laureate Plus 1.4MPI 2007
CGB |
14 Sep 2012, 08:54
#305
CGB Group: Members Posts: 2.445 Joined: 4 May 05 From: behind |
ulei siliconic (nu d-ala de dat pe bordu masinii. e ceva mai gros) e ok ptr uns lantul. am intr-un spray p-acasa si eram curios.
are nijte desene pe tub in care arata c-ar fi bun ptr piulite, diferite angrenaje (inclusiv o poza c-o bicla)....etc. |
Clio RS Line
2022 _______________
b76bgaarh |
3 May 2013, 12:01
#306
Membru autentic Group: Members Posts: 9.966 Joined: 5 October 06 From: Bucuresti |
cum aflu ce dimensiune are camera fara sa o scot?
Megane sedan
Markos |
3 May 2013, 12:02
#307
fost programator Group: Members Posts: 8.016 Joined: 27 October 05 From: Scursurești Vale |
Inchiriezi niste ochelari cu infrarosii.
Megan
vis-a-vis |
3 May 2013, 12:08
#308
DaciaClubber Group: Members Posts: 7.890 Joined: 20 June 05 From: Bucuresti |
Camerele au tolerante mari la dimensiuni. Cel mai naspa e cand vrei sa bagi o camera mare pe cauciuc mic (de cursiera). Eu am reusit si asa dar s-a cutat.
Invers e doar problema de pana, ca se subtiaza peretii camerei, dar vor umfla cauciucul fara probleme. |
Logan MCV
Markos |
3 May 2013, 12:13
#309
Rocket science, nene...
Sa luam de exemplu o bicla cu roti de 26. Gasesti doua dimensiuni mari si late de camere: 26x1.75 si 26x1.95. Te prinzi sigur de care-ti trebuie. |
Megan
b76bgaarh |
3 May 2013, 12:24
#310
visule trebuie sa iau din carfur. e vreo corespondenta intre dimensiunea anvelopei si a camerei?
nu vazusem ce a scris grecu. This post has been edited by b76bgaarh: 3 May 2013, 12:25 |
Megane sedan
vis-a-vis |
3 May 2013, 12:26
#311
Da. Vezi ce dimensiune are cauciucul si iei camera in functie de asta. Citeste ce scrie pe el.
Logan MCV
Markos |
3 May 2013, 12:27
#312
Daca e MTB cu roti de 26, cumperi de 1.95
Sau zi-ne ce bicla e. |
Megan
b76bgaarh |
3 May 2013, 12:30
#313
un dhs impulse flames.
merci. |
Megane sedan
vis-a-vis |
3 May 2013, 12:35
#314
2.1"
Logan MCV
b76bgaarh |
3 May 2013, 12:58
#315
merci.
Megane sedan
AlexNIT |
7 May 2013, 20:00
#316
16v Inside Group: Members Posts: 318 Joined: 8 April 12 From: Dej/Cluj-Napoca |
o intrebare! : ce problema ar putea fi faptul ca atunci cand dau mai tare la pedale (de ex. in urcare) , cateodata pedalierul ...nu stiu cum sa zic ...aluneca ..e o senzatie nasoala ... de la ce ar veni problema?
Megane 1.2
1999 1.6 16v Grandtour
- RXE
C a t a l i n |
8 May 2013, 03:46
#317
Clichet caseta pinioane.
Bulldog |
8 May 2013, 06:47
#318
"Nembru" Group: Members Posts: 566 Joined: 6 February 08 From: Cluj-Napoca |
Sau uzura exagerata lant, sau pinioane (cel mic se manifesta mai devreme), sau uzura foi angrenaj pedalier (se manifesta pe cea mijlocie de obicei, fiind mai folosita), sau cum a zis Catalin, uzura caseta. Asta daca ai caseta, daca ai pinioane pe filet, trebuie schimbate cu totul.
Poti sa incepi cu masurarea lantului. |
Bicicleta,
RATUC,
Taxi Imi scot mașina in ploaie să se tuneze cand tună
corbex |
8 May 2013, 14:10
#319
In cazul lantului s-ar auzi zgomotul specific. Ar fi detectat singur cauza.
2005, cheala
AlexNIT |
8 May 2013, 15:00
#320
clichetii au fost schimbati saptamana trecuta... la un atelier particular ....oare sa imi fi pus niste clicheti de la o bicicleta dezmembrata?
Megane 1.2
- RXE
melcu |
8 May 2013, 16:31
#321
Halatu'...cat e halatu' ? Group: Members Posts: 1.140 Joined: 12 July 06 From: Bucuresti / Pottstown, PA,USA |
Vad ca esti din Cluj. Da o fuga la baietii de la Maros, undeva vis-a-vis (aproximativ) de aeroportul din Cluj.
Posibil sa-ti fi montat gresit clichetii, sau ai uzura excesiva in corpul casetei si degeaba ai clicheti noi. |
Laguna 2
2002 Privilege 3.0 V6 CVA
- B-33-RTN Toyota Yaris Sol 1.33 VVT-i - B-202-CSM
Totoya Prius V-Five - HRL-1459 Formatez drivere de cooler... |
AlexNIT |
8 May 2013, 20:50
#322
Am fost si mi-au gasit problema ..la foaia de la pedalier ..cea din mijloc , are un dintisor uzat si acolo scapa ...noroc ca nu a fost o problema mai mare
Megane 1.2
- RXE
C a t a l i n |
9 May 2013, 05:25
#323
Da, da, cu siguranta aia era problema!
Nici daca lipsesc un sfert din dintii unei foi nu iti va aluneca lantul. Mai taie din ei, da-i dreaq. |
b76bgaarh |
10 May 2013, 12:58
#324
intrebare - 26 x2,1, cu valva de 40 sau de 48?
Megane sedan
vis-a-vis |
10 May 2013, 13:03
#325
Logan MCV
Victoras2001 |
10 May 2013, 13:13
#326
Membru autentic Group: Members Posts: 2.840 Joined: 15 February 08 |
A, deci la aia de le ziceam io "catei" in copilarie si i-am schimbat de cateva ori la semicursa, acum le zice "clichet" frate. Pe vremea aia ziceam ca desfac chiuveta ca sa ajung la ei. Acum ce desfaci?
ZAZ
Zaporojeț
vis-a-vis |
10 May 2013, 13:14
#327
Punga
Logan MCV
Markos |
10 May 2013, 13:17
#328
Megan
Victoras2001 |
10 May 2013, 13:19
#329
ZAZ
Zaporojeț
b76bgaarh |
10 May 2013, 21:56
#330
intr-un final am cumparat camera, schwalbe, valva auto de 40 (prea scurta) cu 26 lei bucata.
am facut pana. cat de usor se poate face pana la mtburile astea, ce mai chin era la semicursiera in ani 90, cauciucul intra doar cu mana. |
Megane sedan
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 5th June 2024 - 10:38 |
