idee de centrala termica, pe curent
Alydor |
- Igo8 - C520
Geox16v |
Membru autentic Group: Members Posts: 613 Joined: 29 March 07 ![]() |
Un Godin nu ar merge??
EX-DACIA
LOGAN PRESTIGE
2006 1,6 16v Creierul a invins intotdeauna muschii!
![]() fan Dacia Group: Members Posts: 21.630 Joined: 12 November 05 From: Bucuresti ![]() |
Centrala pe carburant lichid? Soba cu motorina?
- negru pe alb
OAP |
![]() Membru autentic Group: Members Posts: 808 Joined: 7 November 06 From: Bucuresti ![]() |
Alydor |
ma intereseaza doar ca temperatura sa nu scada in incaperile respective sub 10 grade.
Suma respectelor, Alydor |
- Igo8 - C520
dacia_slk |
![]() If I'm not back in five minutes... wait longer! Group: Members Posts: 544 Joined: 13 November 09 From: Milky Way ![]() |
Hehe... vrei sa-ti incalzesti garajul la iarna?
Deci, boilerul electric incalzeste apa (daca are 40-50L banuiesc ca are o putere undeva in jurul a 2500-3500W), pompa plimba apa din boiler in calorifere si inapoi in boiler... Adica un fel de centrala pe gaze, numai ca merge pe curent electric. Ideea mi se pare geniala, daca se dovedeste rentabila. Ramane sa vezi daca suma care o platesti la curent e mai mica decat ai plati cu alte solutii de incalzit. PS: Ar fi bine sa ai izolate bine camerele alea... |
SLK
55 AMG That's why I told you "touch nothing"... But you're a bunch of cowboys...
"Consilio et animis." |
OAP |
de ce?...ai o combina frigorifica acolo ?
29 Sep 2010, 16:10: QUOTE(dacia_slk @ 29 Sep 2010, 16:07) Adica un fel de centrala pe gaze, numai ca merge pe curent electric. Ideea mi se pare geniala, ![]() This post has been edited by OAP: 29 Sep 2010, 15:10 |
yoncv |
![]() Membru ochelarist Group: Members Posts: 442 Joined: 28 September 06 From: Craiova ![]() |
Exista si centrale pe curent, nu e nevoie sa improvizezi tu una.
VW
Jetta
2017
- dj-17-???
OAP |
QUOTE(dacia_slk @ 29 Sep 2010, 16:07) (daca are 40-50L banuiesc ca are o putere undeva in jurul a 2500-3500W), 1500 - 1800 W la 50-80 litrii |
Alydor |
ideea pe combustibil sare pentru ca e o cladire la dracu--n praznic si mi-e tarsala sa ma car cu bidoanele de motorina saptamanal. E vorba de o casa de vacanta, foarte putin spre deloc utilizata pe timp de iarna. Incaperile sunt izolate termic.
@yoncv -daca citeai cu atentie primul post vedeai ca stiu ca exista asemenea centrrale. Difera doar costurile. Am gasit boliere de 4Kw Suma respectelor, Alydor This post has been edited by Alydor: 29 Sep 2010, 15:15 |
- Igo8 - C520
bolidu |
![]() Pai daca n-am ?! Group: Members Posts: 2.068 Joined: 1 July 06 From: Medgidalas ![]() |
Dar de ce nu iti iei 2 calorifere electrice, e vre-o 100 lei unul, si ii pui termostatul la jumatate daca nu vrei mai mult de 15 grade in camera si ai scapat de tot calabalacul. Si apa aia a ta o plimbi prin ce? Ai uitat sa treci pe lista si calorifere.
Solenza Confort
Opel Astra Coupe
- CT-XX-CMF Daca te lasi de fumat, de baut si de femei, nu traiesti mai mult, doar ti se pare ca timpul trece prea incet.
dacia_slk |
QUOTE(OAP @ 29 Sep 2010, 15:11) Atunci e jale... n-o sa incalzeasca la iarna (la -10 ...-20 grC) astia aproape 2kW cele 2 camere de 55mc... cre'ca aproape deloc. Adica un fel de frectie la picior de lemn. O singura camera (4x4x2,5=24mc) n-am reusit s-o mentin la 15-20 grC printr-un noiembrie (cand afara erau cam -5grC) acu' vreo 2-3 ani cu un radiator de 2kW! Ii trebuie putere mai mare de incalzire si izolatie ca lumea la camere, mai ales la cum se anunta iarna asta... |
SLK
OAP |
QUOTE(Alydor @ 29 Sep 2010, 16:14) E vorba de o casa de vacanta, foarte putin spre deloc utilizata pe timp de iarna. In cazul asta cel mai rentabil e sa evacuezi apa din instalatie si sa o lasi asa...la ce o incalzesti daca nu o folosesti??? |
Alydor |
caloriferele sunt si instalatia termica este deja facuta. In speranta ca odata candva se va ajunge sa bage gaz in zona. Cu un calorifer din ala de 9 elementi am tinut anul trecut in camera copiilor temperatura de 23 de grade (fara alte surse de incalzire) Nu imi surade ideea sa las doua calorifere in priza (desi instalatia e facuta cu cablu de cupru 1.5 mm)
- Igo8 - C520
ianacosti |
![]() Membru autentic Group: Members Posts: 307 Joined: 6 August 07 From: Brasov-Campulung AG ![]() |
Ori ca pui centrala electrica, ori ca pui boiler cu pompa, ori resou, radiator etc.
camera se incalzeste la fel. Cati kw de energie elctrica consumi tot atata ii transformi in caldura cu diferenta ca la radiator incalzesti uleiul si dupa aceea aerul din camera, iar la boiler incalzesti apa si dupa aceea aerul din camera si mai consuma si pompa 100 W. Curentul electric se transforma in caldura cu randament 100%. Eu as pune calorifer electric. |
SOLENZA
- BV 78 EDM SEAT TOLEDO NH 1.2 TSI 105 CP 2014
EX. DACIA SOLENZA 2005 |
Ake |
![]() Morderator Group: Moderatori Posts: 1.040 Joined: 6 July 04 From: Bucuresti ![]() |
Ca sa rezumam. Tu vrei sa faci o bricolezi o centrala electrica, astfel incat in loc sa te coste 30 de milioane, sa te coste 6.
Cateva observatii. - Nu o sa te coste 6 ci mai mult. termostate, tevi, fire...etc - Nu gasesti o pompa ca lumea cu care sa faci recircularea. - Randamentul la o centrala termica "de firma" e cam 1:1. daca umbli cu cioace si inovatii, exista riscul sa ajungi la 1,5:1. La 55 mc, in functie de locatie, izolare si altele trebuie sa pleci de la minim 2500W putere termica. Adica aproape 4kw putere electrica in sistemul bricolat. Fa si tu un calcul si vezi daca merita. Cred ca cel mai simplu si cel mai ieftin e cum zicea cineva mai sus, cu radiatoare electrice. Pe care eventual le aranjezi putin din patent. Adica umbli pe la termostat sa poti porni pe la 10 grade si sa te opresti la 15. Riscul de incendiu, ars cabluri, sigurante si altele e acelasi ca la boiler+pompa. - cablurile de 1,5 desi suporta mai mult, se folosesc pentru circuite de 10A. insuficient oricum pentru toata instalatia. This post has been edited by Ake: 29 Sep 2010, 15:51 |
(si) Dacia
Alydor |
pompa consuma 40W. De ce nu golesc instalatia? Pai daca ma apuca piticu sa ma duc acolo cand sunt -20 de grade afara ce dracu fac pana se incalzeste in casa?
- Igo8 - C520
Ake |
Ce instalatie sa golesti?! ca acu ai pomenit prima data.
Cumva ai apa in calorifere acu ?!? Nu stiai ca trebuie umpluta cu palinca? |
(si) Dacia
bion |
Orice gospodar pune in instalatie antigel si palinca o bea
SLZ Scala
Alydor |
vezi postul 14
Suma respectelor, Alydor This post has been edited by Alydor: 29 Sep 2010, 16:02 |
- Igo8 - C520
bion |
Unde zici de antijel ![]() |
SLZ Scala
Vreo metoda de control la distanta pentru instalatia electrica, ca sa dai drumu la incalzire inainte sa ajungi acolo?
This post has been edited by einstein1984: 29 Sep 2010, 16:08 |
- negru pe alb
Alydor |
da cu comnada prin internet, o sa imi pun in hot-spot cu IP fix si un calculator cu un remote manager, care va controla prin usb pornirea automata a centralei. Merge???
@ bion - mesajul era pentru Ake Suma respectelor, Alydor This post has been edited by Alydor: 29 Sep 2010, 16:15 |
- Igo8 - C520
ArtVandelay |
![]() Anytown, USA.. Group: Members Posts: 2.662 Joined: 5 January 08 From: Craiova ![]() |
pune 2 convectoare electrice si aia e
dar de ce trebuie sa fie neaparat 10-15 grade in camerele alea daca nu sta nimeni? nu poti sa pornesti caldura atunci cand stai acolo ? This post has been edited by ArtVandelay: 29 Sep 2010, 16:14 |
focus
2001 He wondered why the boomerang kept getting bigger. Then, it hit him.
I got 99 cookiez cause a bitch ate one. |
bion |
Au fost altii destepti mai de mult. Par egzamplu http://www.handy-fernbedienung.de/de/index.htm?manual.htm
SLZ Scala
Alydor |
crezi ca e tot una sa urci de la 10-15 grade sau de la 3-4 grade la 22 de grade?
- Igo8 - C520
Ake |
Io m-am bulversat total. Deci:
QUOTE Cu un calorifer din ala de 9 elementi am tinut anul trecut in camera copiilor temperatura de 23 de grade Asta se intampla in casa cu pricina? Si cu ce ai incazit daca n-ai inca centrala termica? QUOTE caloriferele sunt si instalatia termica este deja facuta . de calorifere am inteles, dar prin instalatie am inteles numai tevile, nu si centrala termica cu lichidul de rigoare. asta pricepusem ca n-o ai.bioane, nu mai stii de gluma? io zicem palinca da ma gandeam ca ca in apa de pe retea se baga ceva substanta speciala pe baza de alcool . Cica antigelu de masina bagat blana in calorifere face buba. |
(si) Dacia
bion |
Antijelu`i tot alcool dar necomestibil.Cica daca centrala sta mult timp nepornita s-ar putea produce ceva depuneri pe paletele pompei.
Io stiu de gluma da`i pacat sa bagi rachia buna in calorifere si nu in matz. ![]() |
SLZ Scala
cosmin_2300 |
Alydor, o d-asta nu te coafeaza? (e primul link de pe goagal).
Un boiler nu este facut sa incalzeaza apa care circula incontinuu .... ceea ce vrei tu sa faci e o improvizatie care (zic eu) ca n-o sa mearga. De asemenea, el este facuta sa incalzeaza acea 50-60l (sau cat are) in 2 ore, deci ceea ce vrei tu sa faci e egal cu 0, pentru ca nu o sa faca fata! Daca tot vrei sa faci ceva electric si (relativ) ieftin, de ce nu incerci sa folosesti un AC? Consumul de curent este mult mai mic (eu am LG de 12.000 BTU si consuma ~1100 w pe incalzit) si cred ca este mult mai eficient decat ce vrei tu sa improvizezi ![]() ![]() QUOTE(ianacosti @ 29 Sep 2010, 16:40) Nu exista asa ceva, sunt doar gaselnite de marketing ![]() ![]() De ex si la centralele termice "prin condensatie" afiseaza un randament >100%. Dpdv al fizicii asa ceva nu exista, dar daca te uiti pe factura de gaze o sa ai un minim caloric (parca asa-i zice) si in functie de ala se calculeaza randamentul afisat de ei ![]() This post has been edited by cosmin_2300: 29 Sep 2010, 17:54 |
Astra J - 2016 -
Markos |
Megan
Lo-Fi Version Harta site Parteneri Jocuri online Curs Valutar HRH Haine din lana merinos | Time is now: 20th July 2025 - 22:43 |
